Topic: Mercury 115-HP Four-stroke: Grinding Noise
tigercub |
posted 11-30-2004 05:44 PM ET (US)
I bought a new Mercury 115-HP four-stroke in 2001. The motor was perfect when new, it was very quiet and ran great. After about only 20 hours running time I noticed a whirring and grinding noise from the engine, but only at idle. The dealer replaced the gear case under warranty and the noise went away for another 20 hours or so, then returned. The last thing the dealer did was to grease some bearing in the drive shaft. This was the latest fix from Mercury and it did not solve the problem either.I wrote to Mercury Canada and was told that this grinding noise was "normal", however they were aware of some similar complaints and the engineers were working on the problem. The motor has only 84 total hours on it! You can hear the whirring and grinding noise from 30 feet away and guests on my boat frequently comment, "Is it supposed to sound like that?" Needless to say, I'm very disappointed with Mercury and won't stop fighting till I get some satisfaction. Does anyone else have this symptom on their 115-HP Mercury four-stroke? I wish I'd have bought a Honda.
WaterSportWhaler
posted 04-04-2005 01:42 PM ET (US)
tigerclub,My new 2004 Mercury 90 hp four-stroke - mounted on a Montauk 170 - does the same thing you describe, which is incredibly aggravating. I have had it to two dealers because I wanted a second opinion, but the solution has not been found. The first dealer thought it was something to do with the exhaust. The second dealer - not a Boston Whaler shop - said he thought it must be a "Whaler" issue because he'd never heard that noise before on any Mercury 90s or 115s. Funny enough, I also have a 2004 115 hp four stroke - essentially the same engine - and it doesn't make the sound. Thoughts or recommendations from any of you Whaler experts? Thanks. |
fourdfish
posted 04-04-2005 10:29 PM ET (US)
Tigercub--You should lay this one on your dealer and get him to pressure Mercury. You should also keep the pressure on the company. It won't go away on it's own and it sounds like the company knows it. Wonder why LHG has not lent his input on this one? |
posted 04-05-2005 09:45 AM ET (US)
Is the gearcase on a 2001 Mercury 115-HP four-stroke made by Mercury or Yamaha? |
LHG
posted 04-05-2005 05:32 PM ET (US)
Jim - I believe all lower units in the "Yamaha powerheaded" 75-115's are Mercury's own.I would contact Mercury customer service on this one, and keep after them, as it sounds like a factory defect that they should take care of. |
high sierra
posted 04-06-2005 12:02 AM ET (US)
My 2003 115 EFI started the grinding sound today. Only does it in nuetral. What's going on? |
whaler1234
posted 04-07-2005 07:32 PM ET (US)
I have noticed the same noise on my '04 90 fourstroke. Mine happens only in neutral. In gear, the whirring sound disappears. Tigercub, any updates to share? |
fishinchips
posted 04-07-2005 10:13 PM ET (US)
If you put her in gear and take her out of gear the noise will disappear. |
WaterSportWhaler
posted 04-08-2005 11:58 AM ET (US)
Whaler1234,My 2004 90 does the same as you describe - and yes, the noise goes away completely when you put it in gear. So glad to know I'm not in this alone! |
AQUANUT
posted 04-09-2005 11:37 AM ET (US)
whiningyour 115hp merc 4 stroke has a drive belt that turns two cam gears off the crank shaft. have your ever heard a noisey fan belt..or the drive belt on a supercharger at the drag strip? How about the drive belt on a harley? could be one possibility also, grinding only in nuetral, an improperly adjusted shift cable at the shift platform can cause this. ideally, when running the motor on a flush attachment..the prop will not be spinning. not always the case tho. it is a fine adjustment to get the shift platform properly adjusted @ the nuetral safety saftey switch[ not its actual name] so the right amount of pre-load is set. mercury's instructions have your dealer check it next service regards terry |
elaelap
posted 04-09-2005 05:11 PM ET (US)
I haven't noticed that problem (or any others) with my 2004 Yamaha 115 4/s EFI. It's got 310 hours since I bought it eleven months ago, with about half the hours at slow trolling speeds (700 rpm) and drifting with the motor on and in neutral. I thought these motors shared the same power head...if so, maybe look for the problem in the bottom end/drive shaft/water pump and cooling system.Tony |
whaler1234
posted 04-10-2005 04:09 AM ET (US)
the drive belt on a supercharger at the drag strip sound is exactly how it is. At idle speed in gear, the sound completely goes away. Thanks for the suggestion. |
WaterSportWhaler
posted 04-11-2005 01:20 PM ET (US)
OK, I just returned from the dealer and think I received an explanation about the grinding/whining sound that makes sense...According to the service manager, the noise is coming from the drive shaft running from the power head to the prop. When there is no load on the shaft and gears, i.e., when the motor is idling, the shaft is rattling around in the lower unit. Putting the motor in gear "binds" the shaft against the gears and noise goes away. The service manager says all outboards make this sound. As this 2004 four stroke 90-hp is approximately my 10th outboard motor (but first four stroke), I asked why I haven't heard this sound before. The explanation was that the noise eminating from two stroke power heads masks the drive shaft whining/rattling. With four strokes, the power heads are so quiet that you can hear this - and other such sounds much more clearly. Apparently, Evinrude has a factory "fix" for this problem by running some kind of plastic sleeve down the shaft, which reduces the amount of travel that the shaft has inside its housing. There is no such "fix" from Mercury. For me, this is really unacceptable. As tigercub explained above, this isn't some kind of slightly annoying sound - it is really loud when in the boat and can be heard from quite a distance. I plan on writing letters to Boston Whaler and Mercury to see what can be done. The worse part is that I waited for years to buy a 170 Montauk with a four stroke because the promises of the quieter motor - since I use it as a lake boat. Now I just want to sell it and buy an I/O. |
fairdeal2u
posted 04-11-2005 01:26 PM ET (US)
I have the 115 efi yamaha....Yamaha uses the lower end from the v6 motors . Merc uses the yamaha powerhead but use their own lower ends. No noise. 225 hours on the motor. |
Jerry Townsend
posted 04-11-2005 01:46 PM ET (US)
WatersportWhaler - Your dealer's "... a shaft rattling around ..." explanation doesn't cut it - and doesn't make sense to me. Also, his "...all outboards make this sound ..." is straight bull. I have a 115 Johnson/Evinrude and it is quiet.As Larry (LHG) suggested - camp on Mercury service until the problem is eliminated. ---- Jerry/Idaho |
WaterSportWhaler
posted 04-11-2005 02:26 PM ET (US)
Thanks for your comments, gents. I must agree with both of you. My last 90 hp evinrude (1995 model mounted on a 17 Montauk) - although a two stroke - was pretty darned quiet and I didn't hear any lower unit grinding/whining at idle. This four stroke is actually a lot louder at idle than the evinrude. Of course there's no comparison once you put the Merc into gear.As mentioned, I also have a 2004 Mercury 115 hp four stroke mounted on a Dauntless 16 and there is no such noise at idle or any other time. The dealer explanation is that the motor is mounted much lower in the water on the Dauntless as compared with the 170 Montauk, so you can't hear the lower unit as well. Yeah, right.... BTW, the dealer drained the lower unit oil in the 90 hp to see of there were any metal flakes in the fluid that would indicate metal on metal friction inside the unit, and there was no such evidence. They saved the gear oil in a jar and showed it to me when I picked up the boat. Of course I had that fluid changed at the 10 hour checkup and think any related issue would have been spotted at that time. The idling noise started with the first key turn and the motor now has a whopping 15 hours on it. Yes sir, I'm going to write some letters... |
AQUANUT
posted 04-11-2005 06:18 PM ET (US)
first off...the drive shaft doesn't just rattle arround when the gearcase is in nuetral.the driveshaft is connected to the crankshaft in the engine block dirrectly via "splines" as long as the engine is running the driveshaft is turning the same speed. [rpm] if you look physically at a drive shaft of a 4 stroke as compared to the drivshaft of a two stroke..a. you will notice there is more metal in the two stroke verses the four stroke. also the number of slplined teeth is different. as long as the driveshaft is spinning[engine running] the water pump inpeller is being turned also to cool the engine block. my point is..this is nothing like automotive. its a marine outboard.engine running driveshaft is always turning thus under a minimal load.
lower unit rattle...nature of the beast for now...until a better mouse trap is built. trgards . terry |
LHG
posted 04-11-2005 10:01 PM ET (US)
Since Whaler is selling both the 90 and 115 4-strokes on various models, has anyone contacted Customer Service for their input on this situation? It seems like an unacceptable problem to me. |
fourdfish
posted 04-12-2005 12:09 AM ET (US)
Watersportwhaler-- I think most will agree that just being a Dealer does not make you a reliable resource. I've had dealers tell me some real falsehoods right to my face! However, some mechanics/dealers are heads above the rest. If the company won't help, consult other mechanics and I would also write to Boat US asking for help! |
AQUANUT
posted 04-12-2005 02:42 PM ET (US)
LHGthey...the 4 stroke and the two stroke Optimaaamax have the same appearence..but are not one in the same...gear ratios [gears]..and driveshafts and and a few minor details are different. I personally have seen just how much these driveshafts flex under load. I have seen them break also. sheared right in two. I feel the 4 stroke version flexes more than the two versions. possibly due to more torque being applied. Due to the flexing the four stroke shafts have been machined in certain areas to prevent rubbing on the exhaust housing. You already aware of the ratcheting sound and its source lower gearcase. lol Regards, Terry |
whaler1234
posted 04-12-2005 03:45 PM ET (US)
-- Update --I contacted Mercury today re the noise and the rep told me the noise is listed as normal in their database. I described tigercub's sitation and his letter stating, "they were aware of some simillar complaints and the engineers were working on the problem", but the rep told me Mercury Canada may have a separate issue at hand. My goal in calling was to see if there is a corporate wide known fix or problem to begin with, since there seems to be different theories on the noise. Since tigercub's post was back in Nov of 2004, I would assume Mercury would have a service bulletin out by now if there were one. I contacted Boston Whaler for their opinion and they said it may be the belt as aquanut had mentioned earlier. In summary, tigercub, high sierra, WaterSportWhaler, and myself have had the same problem (and lack of resolution) just from this post. Since I only have 2.5 hours on my motor, I will wait for the 20 hour and see what the dealer states. |
davej14
posted 04-12-2005 10:33 PM ET (US)
I like my two-stroke more and more. Especially the exhaust smell in the morning! At least I got what I paid for. Obviously Mercury has a problem. Why would you intentionally design a motor that sells, at least in part on its quiet operation, to be noisy at idle? Sounds like CYA to me. |
jk_mcknight
posted 08-02-2005 11:18 AM ET (US)
Tigerclub,Did you finally get an answer (solution) to your grinding sound problem because I have the same engine with the same problem? Thanks John |
high sierra
posted 08-02-2005 10:49 PM ET (US)
It is not the upper unit . It is the gear shifting mechanism it self. While on a flushing unit , I could hear the noise in my 115. By moving the shift lever in or out , I could stop and or duplicate the noise. The motors are not totally coming out of gear. Doesn't seem to bother it. The prop is not turning. The gears seem to be just touching each other in the lower unit while in nuetral . high sierra |
tigercub
posted 11-26-2005 08:03 AM ET (US)
Well it's nice to see someone else suffers as well...To update my situation: The dealer last removed the bottom end and made up a shim to be placed in the lower unit's bearing race? This was an attempt to stop side to side movement of the gears. He reasoned that the bearing surfaces had worn and this was allowing latteral movement which lead to the grinding/whirring noise at idle. It didn't work! In fact I think it made it worse. So the dealer has the boat again for storage this winter and is again in contact with the Mercury Rep. Our boating season is so short here that I still only have 80 hrs use on this engine in 4 years! Thank you all for your suggestions and recomendations but please remember that this noise was definately NOT there when the engine was new and only appeared after 2o hrs use. I'll give the dealer another week to hear from Mercury then update.
posted 11-26-2005 10:19 AM ET (US)
Thanks for the update on the problem with the grinding gear noise on your Mercury 115-HP four-stroke outboard with Yamaha powerhead and Mercury lower unit.It is a bit ironic, but in the 2006 Mercury outboard motor catalogue the page which deals with this engine has highlighted only two special features for it. One of them is: --Smooth shifts, trouble-free service |
posted 11-26-2005 10:42 AM ET (US)
Perhaps this special FLO-TORQ III hub will help with these noises. It specifically mentions your engine and the word "rattle" in its description: http://www.mercurypartsexpress.com/ |
elaelap
posted 11-26-2005 11:51 AM ET (US)
Just to rattle some Mercury cages, I noticed that I posted on this thread back in early April of this year about the satisfaction I've had with my 2004 Yamaha 115 four stroke EFI. Back then it had 310 hours; now, eight months later, it's got 700 hours without a single problem (and certainly no mysterious whirring/grinding noise which the factory is trying to claim to be 'normal').I can't take any personal credit for repowering my first and second Whalers with Yamaha four strokes, since my local dealership (which also sells and services other brands) almost twisted my arm off to go Yamaha, but after a total of well over one thousand hours on the two motors in three years--without a single problem--I'm sold. By the way, the dealership owner is an offshore fishing addict and only runs Yamaha motors on his own boat, for whatever that's worth. Tony |
posted 11-26-2005 01:06 PM ET (US)
Tweaked the URI above to Mercury Parts to work around the expiration of my session.Tony--I think there are a lot of repeat buyers of Yamaha motors. |
sosmerc
posted 11-27-2005 06:38 PM ET (US)
This may or may not solve the noise problem mentioned here. But I would sugguest you spray a lubricant such as Fluid Film, or LPS or WD40 up around the top of the driveshaft area. You can see the driveshaft where it goes up into the powerhead...if you point your spray nozzle up while the engine is running the lubricant may get up where the driveshaft sometimes rubs the exhaust adapter plate. This definitely solved a squeeky 60hp 4 stroke I worked on this summer. However, if this does not make any difference, I would then try playing with the shift adjustment. Disconnect the shift cable so that you can manually move the engine's shift arm. Do this with the boat in the water tied to the dock. See if you can find a "clean" neutral...there should be no grinding noise in neutral. There does need to be a slight preload towards reverse (when in neutral)...but too much preload will cause the clutch to tick or grind as it starts to make contact with the reverse gear. Throttle and shift cables do stretch with age and use and this may explain why some engines worked fine in the beginning...and then developed a problem later. It is also important that the engine idle speed be correct and I would not recommend shifting until the engine has properly warmed up and reached it's proper idle speed...this puts much less strain on the gearcase and associated shift components...including your control box and cables. Yamaha does seem to have a superior standard side mount box design, and they use superior cables. It will be nice when Merc gets DTS on alot more of their models...even the lower horsepower models that are so popular like the 90-135hp range. This will really enhance the driveability of our boats. |
fourdfish
posted 11-27-2005 08:55 PM ET (US)
Jim-- I don't think the FLO-TORQ hub will be a final solution from Mercury. You would think they would not count on only one type of prop to solve the problem. Of course they say the noise is normal so we don't know if they are working on it at all. I have read a bunch of comments about it on other forums. sosmerc-- How could a spray of fluid film or WD 40 be a permanent solution to this problem? |
high sierra
posted 11-27-2005 10:31 PM ET (US)
sosmerc, I'm going to try for that clean nuetral you speak off. My Merc 115 does it occassionally and quits when I jiggle the control lever a bit. High sierra |
sosmerc
posted 11-28-2005 12:10 AM ET (US)
fourdfish...all I can say is that it DID solve the problem that I encountered on a 4 stroke 60hp. It may require repeated applications down the road. But the noise we encountered was more of a "squeel" as opposed to a grinding sound. A mal-adjusted shift linkage is more likely to produce a "grinding" type of sound. To complicate matters, what I might call a "squeel"...others might call a "grind". We haven't even talked about belt noise yet...and that is certainly common on 4 stroke automotive...so why not marine 4 strokes?!! |
tigercub
posted 02-27-2006 12:29 PM ET (US)
well just checking in here. I'm still waiting on mercury's answer. They take their sweet time hoping i'll sell the boat/motor, have it stolen or die of old age.Dealer says i will hear from them in a weeks time..... Waiting
The Judge
posted 02-27-2006 02:01 PM ET (US)
Never heard of the idle rattle on "all" engine BS before. My 70 Suzuki and my friends 3 other Zuki's have all over 200 hours and they are soooooo quiet in neutral that all you hear is the telltale hitting the water. Get her fixed, it aint right. |
high sierra
posted 02-27-2006 02:25 PM ET (US)
Adjusted the shift cable on my 115 Merc 4 stroke and the grinding sound went away! It was the cause of the sound from the lower unit. Thanks sosmerc |
hhagan
posted 02-27-2006 09:48 PM ET (US)
I have just read this thread for the first time. I have a 2004 190 Nantucket with the 115 4-stroke that has made the sound mentioned at idle from the first day I started it up in the summer of 2004. The engine has 100 or so hours on it now and still makes exactly the same sound. Sound instantly gone when in gear. No other issues or problems with the engine at all. Runs very nicely and economically. I brought this up on two occasions with the dealer and have been told it is normal for this engine. I really don't buy this since I have NEVER heard any other outboard, 2 or 4 stroke, make a similar noise. Since performance and reliability of engine have been fine otherwise, I have let it go, but my 3 year warranty will expire next year and I would hate to have this turn into something expensive if there is a fix. It really is an annoying sound. More like a whirr from a bad bearing than anything else. Anything new from Mercury? |
bigjohn1
posted 02-28-2006 06:48 AM ET (US)
hhagan: nothing new from Merc and there likely isn't going to be anything in the future, its the nature of the beast on some of these mid-sized YamaMerc's. Buy a shop manual and do the shift linkage adjustment as high sierra states and I think you'll say goodbye to that noise. I read about the problem on this forum so I adjusted mine to factory specs per the manual right after I bought the boat. That noise has NEVER come up on mine and the shifting into and out of gear is easier as well. |
hhagan
posted 02-28-2006 10:14 AM ET (US)
I did the shift adjustment last year per the shop manual which I purchased after I bought the boat. Didn't make a bit of difference with the sound from the lower unit, though. Maybe I'll take another look at it and if it makes a difference, I will post it.
elaelap
posted 02-28-2006 01:09 PM ET (US)
bigjohn1 mentions that these are Mercury/Yamaha motors...not exactly true. This from Larry/LHG on this thread last April: "I believe all lower units in the "Yamaha powerheaded" 75-115's are Mercury's own."The Yamaha F115 weighs fifteen or so pounds more than the 'same' Mercury motor...I suspect that extra weight might well be found in its sturdier, apparently better designed lower unit. I've never heard of this particular problem occurring in a Yamaha F115--I've certainly never experienced in mine after more than 700 hours of use--and I'd sure raise hell with the dealer and the manufacturer if either tried to tell me it was 'normal.' Tony |
David Livingstone
posted 02-28-2006 02:15 PM ET (US)
Could this be a built in safety feature to keep from burning out the starter on an already running motor?I've lost count of the number of times that I've tried to start a running Honda or Yamaha. A little noise might be a good thing. David |
bigjohn1
posted 02-28-2006 08:00 PM ET (US)
Tony - yes they are Mercury/Yamaha motors...the powerhead is Yamaha and the lower unit is Merc. I'm not trying to pin this problem on Yamaha as I feel it is a Merc problem (and I'll bet you and I will agree on that). As you basically state, I have never heard of this problem on any purely Yamaha outboard. This whole situation on the mid-sized Merc's totally stinks with the hard shifting and grinding noise. Be that as it may, I doubt Merc is going to do much engineering-wise since these engines will be out of production soon in favor of the new miniature Verado design. Many anecdotal reports I have read state Merc recommends to check shift linkage adjustment and install a stainless prop as ways to get rid of these problems. That may well be true as I have smooth shifting and zero grinding noise from my 2004 115efi motor...but I adjusted the shift linkage myself when the engine was new and perhaps I had a bit of luck also. |
elaelap
posted 03-01-2006 12:22 PM ET (US)
You know, bigjohn1, several years ago I was just this close to buying a new Montauk 170...I was going back and forth in my mind about the joys of having a brand new boat for the first time in my life compared with my enthusiasm for classic Dougherty Whalers, especially the somewhat comparable 'eighties Outrage 18. I've posted before about sea trialing the MT 170 in the Alameda estuary (S.F. Bay)--the pleasure I found in the boat's quick response to its 90 hp Mercury carburetted four stroke motor, its sweet handling characteristics while tooling around jumping tug boat wakes and trying to get a feel for the boat in protected waters, its surprisingly large interior space, etc. I also posted about my disappointment in the grinding, clunking noises from that motor's lower end when shifting from neutral into forward and reverse, and a strange spinning, whining sound it made when one swiftly backed off while going pretty fast (4000 rpm approx). The dealer who was in the boat with me--Craig from the Outboard Motor Shop, our main NorCal authorized BW dealership--gave me the same song and dance about the wierd noises that I've read in this thread: "Don't worry; it's normal." I didn't make an issue about it at the time, and Craig didn't seem very pleased to have to make such an embarrassing statement, but it was one of several factors in my decision to buy an OUTRAGE 18 rather than a 170.Tony |
fishinchips
posted 03-04-2006 09:05 PM ET (US)
I enjoy my 170. And the whiring/grinding noise only happens on occasion during startup. I just notice I shift it into forward and then back to nuetral it goes away.Seems to me its an adjustment on the throttle. Ken (170 montauk / 22 hydrasports wa) |
tigercub
posted 03-13-2006 03:51 PM ET (US)
Guys,I'm still waiting on the Mercury rep to call me. I guess he must be afraid to call when all he will tell me is the noise is normal and there is nothing Mercury will do. I mentioned to my dealer the cable adjustment fix and he just poo-poo'ed it, as he believes the noise is coming from the runnout in the lower unit's bearing. He did however admit thay there are ALOT of these complaints reguarding said noise on these units. tigercub |
posted 03-14-2006 09:00 AM ET (US)
According to the author of this other discussion, Mercury is replacing a three-year old 90-HP four-stroke motor with an entirely new motor as a remedy for the poor shifting. See: http://continuouswave.com/ubb/Forum1/HTML/011780.html |
Darryl185
posted 07-20-2007 12:33 PM ET (US)
[The noise being reported and discussed] sounds similiar to the noise I've had, but [my Mercury 115-HP four-stroke outboard motor] does it only at 2,000 to 3,000-RPM. |
browni1983
posted 10-21-2007 01:17 AM ET (US)
I have a 2005 Mercury 90-HP two-stroke [that has the] same noise. Should I call Mercury to get my name on the books? I thought that [the noise] was my propeller thrust washer but I see it's a larger problem. My engine has only 28 hours. It came on my Triton. |
posted 10-21-2007 10:56 AM ET (US)
My impression of this problem with grinding noise from the gear case of the Mercury 115-HP four-stroke motor is that it is not a normal or acceptable condition. I recommend you contact your Mercury dealer and seek a remedy for this grinding noise under the warranty provisions of your motor. |
fishhand
posted 08-23-2008 03:46 PM ET (US)
I have a 1993 mercury 2-stroke, bought new on an 18 foot CC Sea Ray in 1993. I use it a lot.. very well used many-many hours. It works just fine with zero unusual noise. The rig is used exclusivly in salt water, run wide open all the time, still uses the original oil injector system and it makes zero unusual noises. I'm looking at a whaler (always wanted one)... but y'all are scaring me off the 4-stroke |
posted 08-23-2008 04:10 PM ET (US)
This discussion is many years old, and the motor which is being described is no longer made. It has been replaced by a new FOURSTROKE model. These new motors have no model year designators, and their model names are the same as the old motors, so it is hard to identify them. However, the cowling shape is very distinctive. It has a rounded top, and the cowling is quite tall. Sometimes there are minor variations in the decals and from those experts can tell more about the motor "generation."We call these new motors the Veradito motors because they use some of the same components as the VERADO motor. The displacement is the same and the engine block dimensions are the same. It is likely there are some shared components. The Veradito FOURSTROKE motors are also sometimes unofficially called the L4NA motors, as in in-line four cylinder naturally aspirated. In any case, the new Mercury motors sold with Boston Whaler boats are excellent motors. These Veradito motors in 115-HP not the same motors as the 2001 Model Year 115-HP FOUSTROKE, even though they have the same model names. Don't let this discussion about a noise in the old motor persuade you from getting a new Mercury Veradito. Everyone I know who has a Veradito is quite pleased with it. |
