  VERADO On-The-Water Tests
Author Topic:   VERADO On-The-Water Tests
jimh posted 03-01-2006 08:49 PM ET (US)   Profile for jimh   Send Email to jimh
I finally--almost two years after first seeing one and riding in a boat powered by one--got a chance to go out for an extended ride in a boat powered with a VERADO. This ride was a much better introduction to the VERADO than my previous test rides. In those situations the rides were too short, there were too many people aboard, and the pilot really never let me take the wheel and grab the throttles for an extended period.
This morning, thanks to glenE, I got a long ride in a very nicely set up center console (not a Boston Whaler but a fine WELLCRAFT) with a pair of 250-HP VERADO motors. It was a very pleasant two hours and many thanks to Glen for taking me (and LHG) out for a spin in the deep blue water of the Atlantic Ocean.
I'll have more to say about this test ride in the next few days, but for now let me just give a quick re-cap:
--the Verado has an extremely smooth power band. The engine seems glad to run at any RPM you set it for, and it delivers very smooth throttle response;
--the DTS controls are fabulous. They really are a great addition to a boat. This is not just a VERADO-only feature with Mercury, but it is standard with the Verado engine. Mercury has done a great job with DTS. Particularly with TWIN engines, the DTS is a revolution. The throttles have a totally cool auto-synch feature. If the throttle handles are within a few degrees of each other, the DTS system will automatically try to synchronize the engine speeds. If the throttle hands are more than about 5-degrees apart in their mechanical positiion, then the DTS software figures you are intentionally trying to run them at different speeds, and it does not automatically synchronize them. Having spent a couple of years running twin engine boats and using a lot of that time to tweak the throttles to match, this is a FANTASTIC feauture. The engines keep themselves in synchronization most of the time without you having to bother with gazing at the tachomoters and figuring out which engine is running slow or fast.
--the NOISE, VIBRATION, and HARSHNESS (NVH) or lack of it is amazing. Every time we cut the engines back to idle, their noise was so low we thought they had died! Glen commented that it took some getting used to, as the engine noise was so low you could not use it as feedback when manuevering around the dock. You had to be careful not to come into the dock too hot because the engine noise was just about non-existant.
More impressions from the test ride are coming. Stay tuned.
--jimh
tombro posted 03-02-2006 07:51 AM ET (US)     Profile for tombro  Send Email to tombro
Glad to hear the good words. I love my Verado 225, and can't wait to get out on the water this spring with it. I have corresponded with Glen, and his Verado owners guide pointed out a fact you mentioned: the engine is likely revving a bit higher than you think while docking, maybe 1000 rpm---which you can't guage by your hearing.
The DTS _is_ fabulous, plus the power assisted steering is a breeze. I have owned twin Merc 175 horse Black Max's in the 1980's....and would love a pair of similar sized Verados on a larger hull in the future, that auto-synch.
jimh posted 03-02-2006 10:46 AM ET (US)     Profile for jimh  Send Email to jimh
The extended test ride also gave me a chance to track down and see the electric-hydraulic boost pump that provides the power steering for handling the 500-HP on the transom. The pump unit is connected to the hydraulic steering from the helm pump. This is the low-pressure side of the hydraulic system. The helm pump supplies hydraulic pressure to the system, and the boost pump increases it, just like power steering in your vehicle.
Some builders initially placed the boost pump in the console area, but it makes more sense to have it in the stern. That is where Wellcraft has located it. The pump is about the size of a large battery. Hydraulic lines, control wiring, and heavy electrical cables connect to the pump. It is housed in a black enclosure which looks something like a tall battery box. On glen's boat, the pump has been fitted with a field service modification to suppress a high-pitched whine which was noticeable in some early pumps. Even leaning into the stern compartment and carefully listening, I could not really hear any noise artifacts from the pump. At the helm and in the cockpit, it was inaudible.
The advantage of the power steering is two-fold: the steering effort at the wheel is reduced, and the speed of the steering is increased. Only four turns lock-to-lock are needed. When manuevering around the dock, the faster steering is very handy. A third benefit is the steering acts as a economy auto pilot. The boat will hold a courseline when you leave the wheel unattended for a moment, a tendency which is always appreciated in any vessel.
The combination of the DTS and power steering make piloting the vessel more like driving a car. You don't need to have constant attention to the throttles, as the DTS acts like a cruise-control system, and the helm also requires little attention to maintain a straight course as there is no propeller torque to fight.
PMUCCIOLO posted 03-02-2006 11:25 AM ET (US)     Profile for PMUCCIOLO
jimh,
It sounds as if your experience was similar to mine: http://continuouswave.com/ubb/Forum4/HTML/003161.html
It would be interesting compare your experience on the Verado powered boat with boats powered by four stroke engines from Yamaha, Suzuki, and Bombardier. Competition has clearly benefitted the consumer in this segment of the outboard market.
I agree that boat shows sometimes provide great opportunities for test rides, but the individual experience is often lacking. There is no substitute for a sea trial with a willing owner on his personal boat, especially one who is experienced like Glen.
Paul
jimh posted 03-02-2006 11:25 AM ET (US)     Profile for jimh  Send Email to jimh
The test boat was a BIG boat, a 32-foot center console, and the big Verado motors looked in prefect proportion on its transom. The hull is a modern deep-V design. The transition from displacement mode to hydroplane was very smooth. There was no bow rise at all, and the Verado motors were very content to supply power at any throttle setting. There is no "dead band" in the engine response as you often find on a two-stroke motor where 1,500 to 2,500-RPM seems to be a forbidden zone. The four-stroke motor produced power and response at any setting.
I was wearing a hat with a lanyard, so when Glen hit the throttles after we left the Hillsboro Inlet we didn't have to turn around and go back for it. The acceleration of the big boat onto plane and up to 35-MPH was very impressive.
When the boat was delivered the engine mounting height was set as low as possible, but subsequent testing has raised the engines three holes. There was also a slight toe-out rigging (i.e., the wakes are slightly convergent). A change to REVOLUTION4 propellers from MIRAGEplus was also made. En toto, the boat performance was improved by an impressive 9-MPH as a result. The builder has now adopted Glen's set-up as the standard configuration. The boat will hit over 50-MPH with a light load, allowing the engines to wind to 6,000-RPM. We did not hit that speed, but we did see an impressive 48 to 49-MPH.
I believe the hull weight is about 8,200-lbs, so the 1,4000 pounds of Verado are not a problem. Glen feels quite certain the Verado is the right motor for this boat, but he pointed out it may not be the right motor for all boats, particularly for boats under 23-feet or so. The boat is about 14 months old, and Glen already has 300 hours or so underway. Oh the joys of waterfront living in Florida!
The Verado, the DTS, and the power steering are all components that depend on electrical power for operating. As a result, Glen has four top-of-the-line AGM marine batteries on board. The engines need a strong battery for starting and running, so there is a separate digital voltmeter and battery monitoring system installed to precisely track the battery condition.
Glen's motors have the newer cowling design which reduces problems with water ingress. The cooling system aspirators are also mounted on the forward side of the engine. Often the sound of the water exhaust hitting the ocean is the only aural indication that the motors are running. Glen's motors also had a very nice flush port attachment on the forward portion of the mid-cowling. That location makes flushing the motors easier. There is also a well-engineered hose connection that is simple to thread onto a hose end fitting. You can do it from the cockpit.
We did not tear into the beautifully rigged console, but Glen said there were more electronic black boxes associated with the engine and its SmartCraft instrumentation system hidden behind the dashboard. The boat was equipped with twin tachometer displays and a central speedometer display. All of these can also display other data via scroll buttons. Six or seven separate analogue-style gauges also kept track of engine temperature, engine water pressure, fuel tank level, and fuel flow rate. (I'll have more to say about the vessel electronics in another article for SMALL BOAT ELETRICAL. The executive summary: first-class and about the most well-integrated system on a small boat that I have ever seen.)
I jumped aboard Glen's Verado and SmartCraft machine after several days of running a "classic" outboard, LHG's Mercury 150-HP V6 c.1980 equipped with mechanical cable steering. Larry's motor is in fine tune and runs as well as any two-stroke of that age and configuration ever did, however, the gap between running that motor and running a Verado is much wider than you might think. The four-stroke motor's smooth response, the DTS shift and throttle, and the effortless power steering combine to create a new level of boating. There is no comparison. I know this is trite, but it is a whole new world of boating with a modern engine like a Verado.
While out and about on the waters of the Ft. Lauderdale area, we did see a number of boats with Verado engines. Most of them were new boats, and longer than 30-feet in length. Most of the Verado sightings were twin or triple installations. We did see one or two single Verado boats, and one Verado re-power installation (on a 25-foot MAKO center console which was for sale). The local Mercury dealer, Sundance Marine, delivered Glen's boat. They are the Number-One Verado dealer in the country, I believe. New boat deliveries with Verado motors keep their three factory-certified Verado mechanics so busy that even they don't have much re-power business for these modern motors.
PMUCCIOLO posted 03-02-2006 11:38 AM ET (US)     Profile for PMUCCIOLO
LHG,
It sounds as if this might be a great opportunity for you to upgrade to a new Verado. The Outrage 18 is in South Florida and Sundance Marine is right there! Open up the wallet, and let the new Verado fly!
Paul
Backlash posted 03-02-2006 01:29 PM ET (US)     Profile for Backlash  Send Email to Backlash
Great first hand report Jim! Here is a link showing a photo of the very nicely rigged console on Glen's Wellcraft. Scroll down to middle of page.
http://tinyurl.com/etllr
Peter posted 03-02-2006 02:19 PM ET (US)     Profile for Peter  Send Email to Peter
"A third benefit is the steering acts as a economy auto pilot. The boat will hold a courseline when you leave the wheel unattended for a moment, a tendency which is always appreciated in any vessel."
I don't understand how the power steering provides any benefit here. I've had several boats with hydraulic steering (not power assisted), both single and twin powered, and all have held a courseline when the wheel is left unattended for a moment. The only advantage that I see in the power steering is the reduction of the number of turns from lock to lock while maintaining the typical easy effort found in a hydraulic steering system. Of all the creature comfort features of the Verado "propulsion system" provides, the power steering is the least integrated feature (see the I4 Verado for example). Part of the reason power steering is used on the I6 Verado is so that the hydraulic ram on the motor can be made of a compact size to accomodate the non-standard mounting bracket.
glen e posted 03-02-2006 07:06 PM ET (US)     Profile for glen e  Send Email to glen e
Jim -
It was a pleasure taking you and LHG out yesterday - you better go a bit easy on the nice comments - it'll just bring the anti-verado hoards out in droves....
glen e posted 03-02-2006 07:28 PM ET (US)     Profile for glen e  Send Email to glen e
Jim -
I might add an addition/correction to your report and that is about the batteries. I really did not add the batts due to the verados but to make sure I have excess capacity. The verados do take a lot of power with the pump and ecm's but would do nicely with two AGM's of proper capacity. But it's the other stuff I have that drain. I have a 600 watt amp driving 6 coaxials, along with a dash that incorporates over 21 different components that draw current. The extra two batteries are for drift condition where the stereo is loud, bait wells are running and most of the dash components. The verados will run fine on two AGM's but they must be 1000 CCA's.
If I had my druthers, I would like to see Merc adapt the magneto system of the etec...(there... now will you guys not jump this thread?
fourdfish posted 03-02-2006 07:52 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
You wonder who glen e is refering to? When I was down in Fl in Jan a friend of mine took 2 of us out grouper fishing on the gulf. He has a brand new Proline 35' Express with twin 250hp Verados hung on the back. The boat has all the options. What a beauty! We put on over 70mi & we were out 35mi at one point. We spent the day. I was able to drive the boat for a while and check out everything. I commented on it in my previous posts as I was duely impressed. I have to agree with most(not all) of what Jim has posted. Since I also own a 200hp ETEC I was actually able to compare them in person. I really enjoyed the trip and hope to take more of them. I see no reason to get in some kind of bashing war with my comparison as it would be counter productive. Later, We stopped by the dealer and I found out even more. I will only say that I am still very happy with my ETEC as my friend is with his boat. What was nice, the Proline dealer offered his boats with Mercs, ETECs and Yamahas!
OH! and by the way, I caught 2 nice grouper!
sundancekid posted 03-02-2006 08:20 PM ET (US)     Profile for sundancekid  Send Email to sundancekid
Glad to finally seeing some support for Verados, I've been saying it forever now, they will be taking over! We got Glen's boat dialed in and we have been working closely with Wellcraft in dialing in their Verado installations. properly mounted, these motors will run with all the 2-strokes! We are in the process of riging 20" shafts on a 352T Wellcraft with triples right now and expect speeds in the mid 60s! The overall experience when running a boat with Verados is an absolute pleasure, especially in rough weather. The package greatly reduces fatigue. BTW, I had Glen's boat running 54!
Peter posted 03-02-2006 08:44 PM ET (US)     Profile for Peter  Send Email to Peter
Glen -- Tell us how the power steering helps hold the course line, I'm dying to know. Next thing we'll be hearing is that the Verado makes its own fuel. Sound familiar. ;)
glen e posted 03-02-2006 08:55 PM ET (US)     Profile for glen e  Send Email to glen e
peter - it's obvious tha you just want to strart a fight here - go find another thread...
Peter posted 03-02-2006 10:18 PM ET (US)     Profile for Peter  Send Email to Peter
Glen -- I'm not looking to start a fight here, just want to point out something that made little sense to me with respect to power steering. But just so the Verado's feelings aren't hurt, I will say that the DTS auto-sync is a nice-to-have feature, although I'm not sure its exclusive to the Verado.
jimh posted 03-03-2006 11:28 AM ET (US)     Profile for jimh  Send Email to jimh
(I am going to comment more about the electronic's on Glen's boat in a separate article. I didn't know the audio amplifier had 600-watts behind it! It sounded darn good. And of course, we could hear the music without the drone of any engine noise.)
To overlook the flawless performance of the engine itself--which I guess these days we almost want to take for granted in new motors--what impressed me the most about the long Verado test drive was:
--NVH
--DTS
--SmartCraft
These are not unique to the supercharged four-stroke outboard motor, but I have to say the Verado has these features in spades.
NVH--I think we can use this acronym for Noise, Vibration and Harshness with some familiarity these days as it will soon be about as common as RPM--is a new standard of measurement in outboard motors. In fact, Mercury Marine president MacKay said that NVH represented the future of boating improvement. This is especially true for outboard motors. We have historically been using two-stroke outboard motors that have had lousy NVH characteristics. In the minds of most people, the next outboard motor they buy will have to have better NVH characteristics than their current motor. I would not replace my current classic two-stroke with a new motor unless the new motor has significantly improved NVH characteristics. Yes, I want other improvements, too, but my next motor will have to run quietly and smoothly. That is near the top of the list of important features. The Verado delivers this probably better than any other outboard available at the moment. It is quiet, there is no vibration, and there are not qwerks or harshness to the response.
DTS is more important in twin engine installations where the auto-synchronizing feature is just absolutely great. The detail with the throttle handle position initiating auto-synch is very compelling. I had not heard this mentioned before, and it is important. As people who drive twin engines know, you can spend too much time tweaking with the throttles and gazing at the tachometers while trying to keep the engines in synchronization.
However, I could give it up in a single engine installations. It also makes the engine tied to a battery. When I say that, I recognize that the engine is also tied to other things, too. It won't run without fuel. It won't run without a propeller. It won't run without cooling water. We live with these demands. For an engine on a big boat, we will have to live with the demand for a good battery. Actually, I cannot start my classic two-stroke without a fully charged cranking battery, so needing a strong battery to run the DTS is not that much of a stretch.
I think electronic throttle control will become more common. It is already common in many vehicle applications. And the irony of a modern engine is that in most cases the mechanical controls just operate an electrical control under the cowling, as well as a mechancial throttle plate. At some point, engine technology will get rid of the throttle plate or butterfly, and everything will be electronic.
In the Verado, the electrical controls still operate mechanical controls under the cowling. If you had a real failure with the DTS, it would be possible to yank the cowling and run the engine using the mechanical levers. It would be awkward, no doubt, but possible.
SmartCraft is a plus for the Verado. Mercury has had SmartCraft in production for several years, and they are already on the second generation of display devices. Their new Vessel View--I am still seeking a photograph of this new device shown in Miami--adds color ot the display and gives reportedly better viewing in sunlight. And probably better graphics. SmartCraft is not a deal maker or a deal breaker, but it is a nice feature. It is mandatory on the Verado engines, from what I can tell.
After this test ride, I do think that the Verado lives up to its billing as a "propulsion system." The supercharged four-stroke motor is integrated with DTS, power steering, and SmartCraft, and together they deliver an impressive new level of engine performance, control, and quiet.
To get all of these features will require an overhaul of most existing classic Boston Whaler boats. You will need new controls, new instruments, new steering, and possibly upgraded battery and electrical systems. Your boat will also have to tolerate the weight, not only the engine weight but other required components like the steering boost pump. (The size of the steering pump should be about the same size as a large two-stroke oil reservoir.) And of course, you will have to tolerate the cost, too.
Off the top of my head, I do not recall anyone having re-powered a classic Whaler with a Verado, other than a couple of larger 27-foot hulls. It would be interesting to hear from anyone who has put a Verado on the transom of a smaller Whaler, something under 27-feet. If I have overlooked a previous report about such an installation, feel free to remind me.
As I mentioned above, by a large majority all the sightings we noted of Verado engines were in twin installations on new boats of 27-feet or longer. It appears that without question the Verado has become a very popular motor for that segment of the new boat market. And even more amazing in our unscientific study the 275-HP motor was by far the most popular. As 30-foot offshore boats with twin or triple engines are already well above $150,000 MSRP, it is not surprising that the added expense of going with a Verado has been easily overcome by its excellent performance.
PMUCCIOLO posted 03-03-2006 12:07 PM ET (US)     Profile for PMUCCIOLO
jimh,
Wait a minute...LHG actually listened to a stereo on a moving boat and you're using acronyms? The sun must be particularly hot in South Florida this time of year! That's a sign that new Verados are in Larry's future, but he'll have to purchase them in bulk if his fleet continues to expand!
All kidding aside, it sounds as if Glen has gone to incredible lengths to put together and perfect a great package. He is a wealth of knowlege whose posts are very informative. I have studied the photographs of his boat and learned a lot. Wellcraft, Mercury, and the myriad other vendors whose products he's installed could learn a lot from him as well.
Paul
mkjmarine posted 03-03-2006 12:56 PM ET (US)     Profile for mkjmarine  Send Email to mkjmarine
Great expert info.
Factory outboards on 32 ft boats making 45ish!
yikes.
How do you guys view the big picture,
are I/O's doomed?
regards,
Michael K
prm1177 posted 03-03-2006 02:00 PM ET (US)     Profile for prm1177  Send Email to prm1177
At the local show last month, a worker at the Whaler exhibit indicated he was repowering his Conquest 23 with twin Verado 150s. I'll try to see if I can get any documentation on what was involved, and maybe get a ride on it when it's finished and can post my comparison between it and my twin Opti CQ.
handn posted 03-03-2006 04:32 PM ET (US)     Profile for handn  Send Email to handn
One of the forum participants suggested other 4-stroke owners write about their experiences as compared to this and other Verado reports.
I have a 305 Conquest powered by two YamaMerc 225 efi 4-strokes. The boat has conventional analog guages made by Mercury and conventional cable shifting. The binacle was made by Mercury, everything else by Yamaha. It has 17p counter rotating props.
Speed, I get 34 knots with minimal, fuel, water and gear but I do have a generator and air. Verados seem to be faster based upon this report and the experiences of Verado powered 305 owners.
I have conventional Sea Star hydraulic steering. It won't hold a course on its own but it does accept a wide range of autopilots. An autopilot is a necessity on a big boat. Its not a big effort to steer the boat manually. Close quarter manuervering is done mostly with the clutches and doesn't involve spinning the wheel from lock to lock. Advantage neither; Verados will have the advantage when there is a wide choice of auto pilots made for them.
My YamaMercs are quiet. I could hear the stereo at running speeds if I wasn't hearing impaired. Mercury designed the cowling and sound deadening and YamaMercs are rumored to be quieter than Yamahas.
Throttle and clutches are by cable. Both work better than my previous Whaler which was Optimax powered. Shifting is noisy, probably because the engines are so quiet. I don't find it burdensome to match the rpms on each engine and once adjusted, the engines hold the settings. Verados have the advantage.
I am coming up on 550 hours after two years of use. The engines have been economical and completely trouble free and that is the reason that I chose them over the Verados. At the time I purchased the boat Verados were completely new to the market.
Were I to make an engine buying decision today, I would still choose Yamahas but I would not be afraid of Verados as they have compiled an acceptable reliability record.
I like having two electrical systems so that an electrical problem won't shut both engines down. I also like the simplicity and reliability of Yamahas and to me the extra features of Verados are not worth the extra price.
elaelap posted 03-03-2006 07:42 PM ET (US)     Profile for elaelap  Send Email to elaelap
I read your several posts on this thread very carefully, jimh, but I'm still not clear...these newfangled Verado outboards--d'ya like 'em?
Tony
fourdfish posted 03-03-2006 07:48 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
What everyone is waiting to hear! Do you think you are going to buy and repower with one? or like PMUCCIOLO says
Do you think Larry will finally put up and buy one for one of his many boats!
Captan_Dick posted 03-04-2006 05:02 AM ET (US)     Profile for Captan_Dick  Send Email to Captan_Dick
[The author of this article is an agent provocateur who has joined the discussion only for the purpose of creating discord. He has registered with multiple names and adopted opposing positions under different names. He has since been banned from the website.--jimh]
Great report here and a good read for all those interested in the Verado. I haven't been on this forum long but try and check through it from time to time. I have quickly come to recognize input from Jim as being thorough and easy to follow for the novice and experienced boater alike. I also enjoy reading the unbiased input from glenn e on many topics on this and other forums.
Unfortunately, it seems like this and most other forums have a few "hecklers" who seem to derive joy in stirring the pot on some topics (Fourdfish and Peter). Gentlemen, lets stay on topic and just enjoy informative reports without all the extra "fluff". I have come to regard this discussion board as a cut above the rest out there, mainly due to respect I see most people show each other. If you want to argue, go to "the hull truth". ok, I'm off the soap box now.
fourdfish posted 03-04-2006 08:13 AM ET (US)     Profile for fourdfish  Send Email to fourdfish
Lighten up Capt Dick! It is called respectfull difference of opinion! I agree this forum is far more civil and personnel bashing is held to a minimum as I have been posting here for a
long time. Jim does a great job here!
Peter posted 03-04-2006 09:21 AM ET (US)     Profile for Peter  Send Email to Peter
Captan_Dick -- A mutual Verado product admiration society probably can be found at the Verado Club clubhouse. This forum is not the Verado Club clubhouse as I'm sure you know. Here, we express our views and experiences (positive, negative, good, bad, indifferent) on all kinds of products relating to Whalers as well as Whalers themselves. We've been doing that here for all of the years that I've been a participant (over 6 now for me) and no product is immune from the discussion. It helps us learn and hopefully make better decisions as consumers.
Captan, I might remind you that my original input on this thread was a simple challenge to Jim's suggestion that the power steering had something to do with the boat's ability to maintain course (track straight) while the wheel was momentarily unattended. (I think by now Jim is used to my occasional challenges). The post immediately following that was glenE's. Rather than simply saying something like "yes you are correct or I agree" or "no, I don't agree you are not correct and the reason why is that the powersteering system is not simply a power steering pump but rather a prime mover with advanced extra terrestrial course holding fully integrated, gyroscopic gadgetry borrowed under license from the NASA space shuttle program....", which would have been constructive, informative and additive to the dialog, Glen simply chimes in "you better go a bit easy on the nice comments - it'll just bring the anti-verado hoards out in droves....".
Now getting back on topic, I'm very much in agreement on Jim's later comments with respect to the DTS system. I see the auto-sync feature as really the most valuable part of it and its only valuble, obviously, for twin outboard installations. The auto-sync feature should help out in the fuel economy department as I can see a difference in fuel economy on my Navman 3100 when my twin outboards are not in-sync versus when they are in-sync. While we heap all of this praise on the auto-sync feature, let's keep in mind that the auto-sync feature isn't a new concept. Glendenning has had an auto-sync for diesels for years. The Teleflex electronic control system (out in the world before the DTS system was) that can be used for outboars, I/Os and in-boards also has an optional auto-sync feature although I think it requires the push of a button to engage it rather than just entering the sync mode when the levers are less than 5 degrees apart. The DTS system does appear to have an advantage over the Teleflex system in that the electro-mechanical actuators are under the cowl instead of resident on the boat. I suspect that this is what is meant when we hear the word "integrated" used.
With respect to failures, I do have some concerns with respect to electronic/electric controls (DTS or Teleflex or even OMC's late 1960s push button Selectric Shift) on a boat used in salt water in that they do not seem to provide any progressive feedback concerning the state of the cable system and the linkages under the cowl. Mechanical controls usually provide lots of feedback as to the overall state of the cable system and linkages, and much advance notice that the system is degrading or needs some attention long before an ultimate failure. With a digital or electric cable, there may not be any advance advance notice prior to an ultimate failure caused by corrosion, for example.
fourdfish posted 03-04-2006 11:04 AM ET (US)     Profile for fourdfish  Send Email to fourdfish
I guess Captan Dick didn't read my first positive comments about my experience with the Verados on my friends boat.
As I agreed with most of Jims post! Either that or he is just after me!
jimh posted 03-04-2006 11:10 AM ET (US)     Profile for jimh  Send Email to jimh
I can't really say with certainty if the power boost of the Verado steering makes it more effective at holding a courseline than an unboosted hydraulic system. Perhaps the seakeeping characteristics of the hull--in this case a deep-V Wellcraft--come into play, as well.
The use of electrically operated mechanical throttle and shift controls, and their integration into a throttle and shift system such as has been done with the Mercury DTS, so far as been very reliable, as least to judge by the complete lack of any reports of failure of these systems. I think DTS is a plus, a very big plus for twin or triple engine installations.
As for auto-pilots, it is ironic that this comes up. One of the purposes of the cruise was for Glen to do some testing of an autopilot device for the Verado engines. I have not made a thorough study of auto-pilot equipment, but apparently it is becoming popular for use with outboard-powered boats, particularly as the size of these boats increases and moves into territory once exclusisely the realm of inboards. I will go into more detail about this aspect of vessel electronics in the other forum (SMALL BOAT ELECTRICAL).
jimh posted 03-04-2006 11:16 AM ET (US)     Profile for jimh  Send Email to jimh
I do appreciate the comments regarding the level of discourse in the forum. I like to think of continuouswave as a thinking man's forum for boating topics. And, yes, it is best to keep rancor about brands to a minimum.
I have tried to relate my first-hand experience with the Verado, and I'll be glad to do the same with other engines and configurations, after I get a chance to go out in boats with those engines.
By the way, I am still in Florida, and posting via a flakey Wi-Fi connection, so that's why the topics are a bit short and sometimes disjointed. The signal comes and goes!
glen e posted 03-04-2006 11:44 AM ET (US)     Profile for glen e  Send Email to glen e
"A mutual Verado product admiration society probably can be found at the Verado Club clubhouse"
Peter - I like how you use the word "probably" in the above phrase - you "probably" have not even been over there!!!...this is type of crap that a few of us are talking about - why slam another site that does nothing but discuss the probelms and solutions of the verado? If you look down the message board, there are far more problems posted there than solutions. I would think you and your kind would love to point out all the problems listed there. And find me one flowery post where we are all kissing each others backside and acting smug and elite about owning verados. You can't.... it's not there....
Peter posted 03-04-2006 11:47 AM ET (US)     Profile for Peter  Send Email to Peter
I suspect the observation on tracking was significantly related to the hull shape, particularly because its a long hull, and having twin outboards. My twin powered 27 Whaler WD tracks far better than any of my single powered shorter Whalers.
I don't think the DTS system has been out in the real world long enough and in large enough numbers to be able to fully grasp its long term reliability yet. While the DTS system preceeded the Verado, I don't think many Optimaxes were deployed with the DTS system. Just like anything else newly introduced and deployed, time will tell regarding long term reliability in the variety of real world situations encountered.
fourdfish posted 03-04-2006 12:45 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
"you and your kind" ???
Captan_Dick posted 03-04-2006 03:24 PM ET (US)     Profile for Captan_Dick  Send Email to Captan_Dick
You see fourdfish, this is exactly what I am talking about. Leave it alone man, its like you're on a gradeschool playground always trying to get the last word in. Let it go and let's act adultlike please.
Might I add, it seems this is not the only forum where you have a reputation for heckling people. I took the liberty of searching your name on the hull truth and what came up was quite a long list of arguments and Mercury bashing. We can all do without such stuff please.
fourdfish posted 03-04-2006 04:36 PM ET (US)     Profile for fourdfish  Send Email to fourdfish
Cap-It would seem that you have come over here to do the heckling. You take a lot of libertys. I have been posting on this forum for a lot longer than you have. It is a shame that you have to add these attacks here also!
elaelap posted 03-04-2006 05:49 PM ET (US)     Profile for elaelap  Send Email to elaelap
CapDick,
Both fourfish and Peter have strongly disagreed with me on various subjects over the years here, but I've learned from both of them--especially Peter, whose posts are just about always filled with fact and logic to support his positions. These guys are anything but trolls, as you'll find out if you stick around and participate for a while. Peter is one of the 'Ten Wise Men' at this forum, IMO (most of us know who the others are, and I'd list them but I know I'd leave somebody out who has been a generous teacher since I joined).
Anyway, the comments of fourfish and Peter on this thread haven't been disruptive to me or most of the rest of us, so why not leave them alone and get back on topic. I want to learn more about those Verados; jimh's posts here have been the most exhaustive personal and trustworthy comments I've read since they were introduced; and if some intelligent probing is done by some of the members, it just leads to more helpful information being elicited.
Tight lines, Cap and others...
Tony
glen e posted 03-04-2006 06:30 PM ET (US)     Profile for glen e  Send Email to glen e
A thoughtful post Tony -
But here’s my problem – I have been posting here for just a short time but on THT for a few years,. I try to do a lot of this like Jim and always add pics and graphs to support my experience, I think the best thing about forums is to bring add’l knowledge of some real experience to the table, I come here to learn and share.
That’s what I don’t see these other guys like fourdfish and peter doing across all the boards. They never add or write a review of something they have, they just pick apart the semantics of the way someone writes or better yet, if they don’t like product, they search for a keyword like verado or Garmin and tear apart a thread for stupid stuff. That’s what I don’t like. Bring your experiences to the party or don’t post.. For example, you would never see me tear down a Furuno Radar just cause I have a Garmin, because I don’t know the Furuno product. I really get the feeling these guys just want to debate and they really have a hard on for some products…..
And I ask again, if Peter is one of the top elders of this board – what is with the comment of “"A mutual Verado product admiration society probably can be found at the Verado Club clubhouse." Does not the word “probably” show he is just inciting an argument? I expect better from “elders”…
This will be my last post on this thread….
Captan_Dick posted 03-04-2006 08:31 PM ET (US)     Profile for Captan_Dick  Send Email to Captan_Dick
Tony - sorry for my causing any "flap" on this and I have no issue with you. Like Glenn, I am a member over on the Hull Truth and have thoroughly enjoyed Glenn's totally un-biased input on a daily basis over there on a very wide variety of topics. He is a Verado guy for sure but will never talk down another product line. Matter of fact, I have seen on multiple occasions where he actually recommends a competing manufacturer's product (E-tec) when someone solicits advice. That will always be a "class act" in my book. I contrast this with the two members I mentioned above who seem to jump in at every opportunity to talk down certain prodcuts (Verado and Optimax) to promote the brand they probably own. This is counter to mature and un-biased discussion on the merits of any product. It is not my aim to de-rail here so I will bow out now on the thread. Peace from San Diego to all....
elaelap posted 03-04-2006 08:36 PM ET (US)     Profile for elaelap  Send Email to elaelap
glen e,
First of all, thanks for giving Jim the ride which gave rise to this very interesting thread.
Peter and fourfish can speak for themselves much better than I, but perhaps you're too personally involved in this particular topic to sense how innocuous and actually helpful their comments have been. Hell, we've had some real nasty battles around here on occasion, and while this is the only online forum I participate in regularly, I understand that THT and many others seem to attract much more unpleasantness than CW, at least at the current time. I credit a combination of Jim's hard work and the cooperation of 99% of the members (including myself!) for the civility which has mostly reigned over the past year or so (and I'm keeping my fingers crossed for the future, especially with the upcoming mid-term election cycle).
This discussion really should continue over in the Meta forum, and we should get back to talking about the Verado sea trial. I'll close by disagreeing with your statement that Peter and fourfish never write positive posts or raise constructive topics...to the contrary and with respect, if you go back over the posts and topics for the past several years, you'll see how mistaken you are.
Tony
glen e posted 03-04-2006 09:21 PM ET (US)     Profile for glen e  Send Email to glen e
sorry tony - I said I would not post again but you've drawn me out by protecting individuals that I think have an pointed agenda...why is it thay always rise to the mercury threads? (do a search)
and again I ask how Peter's comment about the Verado club is not just a cheap shot for an elder....
I am an "elder" at THT and that's not how we elder's act... right jim?
BOB KEMMLER JR posted 03-04-2006 11:00 PM ET (US)     Profile for BOB KEMMLER JR
Lets get this back on track,Mercs kick azz!
Peter posted 03-04-2006 11:25 PM ET (US)     Profile for Peter  Send Email to Peter
Having now thoroughly visited Glen's website, I certainly do owe Glen an appology for suggesting that his Verado Club is probably a mutual Verado product admiration society, something that has clearly angered him. It's clear he's put much hard work into that site to capture all kinds of information and share his experiences. Anyone who is an owner or one contemplating the possibility of being an owner of "the most advanced, kick-ass motor out on the market today" should visit his site become a club member.
glen e posted 03-05-2006 08:27 AM ET (US)     Profile for glen e  Send Email to glen e
apoligy accepted...I have deleted posts that are just ra-ra pieces like "buy a verado!" ....If it does not pose a qaution or offr a solution, it does not get on the board....
jimh posted 03-05-2006 12:17 PM ET (US)     Profile for jimh  Send Email to jimh
I'll apply a similar hand at editing when I return. The signal is too flakey to do it now.
Glen--I left my blue fleece in your stern locker. We'll have to go out for another ride so I can get it back. :-)
jimh posted 03-05-2006 12:33 PM ET (US)     Profile for jimh  Send Email to jimh
Glen's boat had a very nice characteristic: when you set the engine speed to a particular setting, the engines tended to stay at that speed. I don't know if this comes from the engine, the DTS, or just the ample power available.
On many boats with classic two-stroke motors, the engine speed responds to the throttle like it is connected with a long rubber band. You give the engine some throttle, and the boat slowly winds up to speed, with the engines winding up along with it. The boat gets going too fast, so you have to throttle back. Then the engine loses power and the boat starts to fall off plane. You give it more gas and the engine winds up again. Sometimes, with careful adjustment, you can find a sweet spot where the engine will run at enough speed to maintain plane, but not so fast that the boat will tend to keep accelerating once on plane.
Throttle response like that tends to require a lot of attention from the helmsman. Even on boats with plenty of power, I have seen this sort of response from the engines. Finding the right setting is a bit of an experiment.
On Glen's boat I did not notice this tendency. You set the throttles, the boat quickly responded, and the engines settled down at the new speed. It may be due to the ample horsepower, 500 ponies on the transom, or it may be due to the four-stroke design.
I think the engine torque curve probably affects this behavior, too.
Glen is running the big four-blade REVOLLUTION4 propellers. They seemed glued to the water. I never noticed any sign of the blades losing grip.
It would have been interesting to hop off the Verado-powered boat and onto a similar one with, say, twin Yamaha 250-HP four-strokes without supercharging. That would make for a nice back-to-back comparison.
About two years ago I spent a similar amount of time out in a 240 OUTRAGE with twin 150-HP OptiMax engines. Based on these two trips, I would pick the Verado motors if given a choice. That preference is based primarily on their low noise and smooth handling.
There are other considerations that I have not touched on, for example, fuel consumption and maintenance, but based strickly on the on-the-water experience, I would go with the Verado if the boat can handle the size and weight.
glen e posted 03-05-2006 12:55 PM ET (US)     Profile for glen e  Send Email to glen e
Jim wrote -
"You set the throttles, the boat quickly responded, and the engines settled down at the new speed. It may be due to the ample horsepower, 500 ponies on the transom, or it may be due to the four-stroke design."
I have noticed the same thing and I think it is the combination of all the things you mentioned. I bought the verados after having a 35 donzi with twin 225 opti's that did exhibit what you talked about -the constant moving of the throttles to maintain the same speed. On the verado, I think it is the props and the motors with DTS that perform the "steadyness". With my opti's I always felt I holding them back and many times they would creep ahead and out of sync on a long cruise. With the current setup, the boat will hold 4000 rpm's/33 mph/18 gph total, no matter what the seas are like (under 5 feet, of course).
LHG posted 03-06-2006 01:16 PM ET (US)     Profile for LHG
Glen - it was a real pleasure meeting you and enjoying several hours on your very fine Verado powered Wellcraft Center console. You and the people at Sundance did a fabulous job setting her up, and I appreciate the time you spent with us. After experiencing the super quiet, instant throttle response and acceleration of the 500 Verado horses, going back to my my 2-stroke was a real setback in time!
It's nice to have you participating on Continuouswave, and I am sorry that these "RUDE" trolls attempted, as they always do, to sidetrack Jim's thread on our experience with the usual sarcasm, personal inuendos, and general Verado/4-stroke bashing. As you know, this is not the only site they patrol. Generally, CW is a quality site with a huge majority of great boating people.
One of the most memorable moments was seeing and hearing the Alan Jackson/Jimmy Buffett video, set on an offshore Sportfisherman, played through the large Garmin Sonar/GPS screen. Very cool! It's a great rig you have.
