| Author | Topic: Verado 175-HP: First Impression |
I finally had a chance to drive a Boston Whaler boat with a Verado 175-HP. The Verado 175 is a four-cylinder version of the original six-cylinder Verado. The 175-HP Verado was on the transom of a new Boston Whaler 200 Dauntless. The 175-HP Verado started and went to a smooth idle on the first turn of the key. The weather was warm, and the motor had been previously run, so the conditions were not much of a test. The sound level of the motor was quiet, however I do not believe that the four-cylinder Verado motor runs as quietly at idle as its bigger brother the six-cylinder Verado. The big Verado motors are just fantastically quiet at idle, and this four-cylinder was not quite at that level. The confidence stream of water from the cooling system is arranged to exit the cowling on the forward side of the motor so that it was easily observed and heard. Like all Verado motors, the 175-HP has Mercury digital throttle and shift (DTS). These electrically operated controls are very smooth and operate with low friction. The controls have a signal lamp which illuminates when they are in neutral to help identify that position. When you pull the throttle back from higher settings there is a mechanical detent position at idle speed but still in forward gear. Pulling back some more clicks the throttle into neutral gear and illuminates the signal lamp. The throttle actuator comes on quite fast, and even though I have driven several Verado motors, I again found that I gave the throttle too much advance initially. I am sure this tendency would go away after a few hours of experience using the DTS controls. The 175 Verado motor on this boat was not rigged with the electro-hydraulic power steering option. As a result, steering the boat required quite a bit of effort at the helm. The hydraulic steering ram actuator on the Veradito looked the same as the one used for power steering models, but without the boost pump the steering effort was noticeably higher. The high effort on the steering was in stark contrast to the very low effort needed on the throttle. The wheel is two-hands-on and give it a turn, while the throttle is two-fingers and just gently move it. The 175-HP Verado was rigged with SmartCraft gauges using matching multi-function gauges with analogue pointers and an LCD readout at the bottom. Adjusting the engine trim automatically flips the LCD readout to show trim position. This is a nice feature and shows the intelligence and user-friendliness that can be built into a modern electronic control system. Other than my usual problems with vision from not wearing bi-focals, the LCD readouts were reasonably easy to see. Once we cleared the NO-WAKE zone at the marina, I gave the throttle a gentle push forward and the boat came nicely up on plane and accelerated to about 30-MPH. When you push the throttle hard forward, the engine spools up rapidly and gives a nice low-pitched growl as the supercharger boost kicks in. I then tweaked the trim to bring the bow up, and we cruised along quite nicely, the engine noise reduced noticeably without the supercharger boost. Poking at the right-arrow button on the SmartCraft tachometer gauge, I paged through several read outs until I found the miles-per-gallon computation. The boat did not have any added electronics, so I believe the speed input was from a PITOT tube on the motor. The fuel flow is self-computed by the motor. So both boat speed and fuel flow are indirectly measured. The fuel economy was nearly 5-MPG, and I pulled back a bit on the throttle to see where it might peak. About the best I could get was 4.9-MPG, but that is quite respectable. After a minute or two, I pushed the throttle ahead and ran the boat up to about 40-MPH. The Verado was turning about 5,500-RPM at this point, leaving a few hundred RPM (or more) to go. I did not want to firewall the throttle, as this was a new motor, but there was some throttle left to go. In any case, 40-MPH was flying. The engine noise was still relatively quiet. At this point we were getting into some shallow water, and lacking a depth sounder, our Mercury dealer guide suggested we turn around and head back. I turned the wheel over to another test driver and sat back to enjoy the boat ride. You might not find too many new Boston Whaler boats with the 175-HP option. This boat was made before Mercury introduced the 200-HP Verado, and Boston Whaler has moved to using the 200-HP as the optional motor in preference to the 175-HP. |
| Jordi |
Jim, Your observations are right on the money. I would add the sound differences between the 4 and 6 are not as apparent to most astute listeners. The Verado feedback on this site is very sparse in comparison to other outboards. |
| Dick |
Jim Why do you insist on using the word "Veradito" when the motor is a Verado. As [extremely accurate] as you are about spelling and grammer [sic], I am surprised that you would be using a slang name for the motor. I am certain that I couldn't get away with using JohnRude for Johnson and Evinrude motors. |
| fourdfish |
Gee Dick, How many people really care what term Jim uses for that engine. He started using that term because they distinguish them as the 2nd generation smaller versions of the large block Verado! They are after all significantly different than the first models. I don't think it is some kind of cut or slap at the engine. |
Dick is correct--I have confused myself. I use "Veradito" to refer to the little four-cylinder motors minus the supercharger, which Mercury calls "FourStroke" motors. I invented "Veradito" to help link those fine little motors to their Verado forefathers, not to insult them. The 175-HP motors, the four-cylinder ones, are real Verado motors, not the little Veradito motors like the 75, 90, and 115-HP. [I corrected my usage above.] By the way, I coined the term VERADITO, so you'd think I could remember what it means! I think Veradito is a much better name for those 75, 90, and 115-HP motors than "FourStroke," but then again, "FourStroke" is probably the worst model name in the history of outboard motors so it does not take much to improve on that. |
By the way, to make matters even more confusing, I see that Mercury has just redone the cowling styling on their lower horsepower four-stroke motors, giving them an appearance similar to the Veradito. These motors are now being called "miniature Verado" motors. I think that is really a stretch as those motors do not have much, if any, heritage from the Verado, save for the new look of their cowlings. So just to review, we have
The VERADITO, the same motor as the four-cylinder Verado minus the supercharger and who knows what else. (Does it have DTS? Maybe Dick will tell us.) The Miniature Verado, a totally unrelated motor but one whose cowling has just been restyled to look like a Veradito. |
Dick--Have you driven any Boston Whaler boats which are powered by the Verado 175 or other four-cylinder Verado motors? Let us know how they ran for you if you have had a chance to drive one. That is why I posted this rather long article about the 175-Verado, to tell people how they run. I agree, there is not much feedback about the Verado motor on this discussion, and as a result whenever I have had an opportunity to even get close to a Mercury Verado motor--even if it has not been on a Boston Whaler boat--I have written at length and in detail about it. You cannot find anyone who has written more about the Verado on CONTINUOUSWAVE than I have. I have been telling people about this motor going back two years before it even was announced and available. I even flew to Florida and attended the Miami boat show just so I could show people some of the first pictures and details about the Verado. I think that makes me by far the biggest booster of the Verado around here. I really wish someone would "step up" ( and here I just love to use that term and all the connotations associated with it) and buy a Verado for installation on a classic Boston Whaler boat. These motors have been out for over three years and as far as I know there is absolutely no one who has bought one and installed it on the transom of a classic Boston Whaler. Does that make this discussion moot? MOOT--another one of my new favorite terms being thrown around the website these day. Let me try it on you, Dick: If you don't own a Verado that makes your comments moot. Or at least that is what some would say. Well, not me, you don't have to own them to talk about them. You can just test drive them, or even just read the specifications if you like. |
| Dick |
Jim I do not own and have never run a Verado but that does not make my comments moot, as you said. I thought your report on the motor was well done and informative. I do take exception to you coining your own names for the various versions of the Verado motors. If Mercury calls them a Verado that's what they are and that's the name that should be used. Guess I am a bit biased here as I bought my first Mercury in 1953 and have owned no other brand since. I have over 20 years as parts manager at Mercury facilities plus now that I am retired I still work part time at one, we also do JohnRude parts. I just want Mercury to get the respect that they are due by using the name they brand a motor with. |
| bigjohn1 |
A minor point of input which relates not specifically to the Verado but to all of the new generation dfi 2-strokes and 4-strokes regardless of brand. They all start very easily with a quick turn of the key. I have fishing partners with Opti's, E-tec's, and Merc/Yamaha/Suzuki 4-strokes. All of them start instantly; while I don't have a friend with a Honda, the local Coast Guard SAFE boats are Honda-equipped and they start instantly by my personal observation. Why do I bring this up in a Verado thread? I see quite a bit of reference made on the internet to the fact that a new "Brand xx" outboard starts easily with a turn of the key - they all do now. Hard starting is something that plagued classic 2-strokes of the past. |
Re starting, my old carburetor V6 starts and runs at the turn of a key most of the time. The only time it does not is when it has been sitting for a couple of weeks and the carburetors are not all completely primed and full. So, yes, I agree, starting at the turn of a key is not exactly the defining moment of the modern outboard motor. If Mercury had come up with any sort of decent model name for their fine little Veradito motors, there would be no need to invent one. If Bombardier had named their E-TEC motor the "TwoStroke" I am certain that I would have been motivated to be similarly inventive of a new name. You cannot seriously think that calling a motor a "FourStroke" is an example of a good model name, can you? |
| hauptjm |
I find it interesting that with the connection that Whaler has to Mercury, and the fair number of Mercury owners on this site, we still don't have anyone with a Verado mounted on a classic Whaler! What's the limiting factor? My personal impression of the Verado was very positive. I have never owned a Mercury outboard, but found the 250hp Verado (unfortunately, not on a Whaler) to be an incredible motor. I think the DTS, greatly enhanced that experience. So, if we were to create the perfect Classic Whaler/Verado combination, what would it be? I think based on everything I've read about weight, the larger classics would be the likely candidate. Let's say, a 1980's Outrage in the 25 or 27 foot range with either twin 200 Verados or maybe a single 275. Is it because so few of the larger Whalers are owned that there are fewer opportunities to repower? |
| Peter |
The limiting factors to a Verado repower remain the same, primarily: 1) excessive weight on the transom, and 2) highest repower cost. Also, I think not everybody is willing to accept the much, much higher degree of complexity in the Verado.
| gss036 |
The Coast Guard here in our area seem to be trending to the Verado. I have personally see 2 Safeboats repowered w/Verados and one Customs 36/38 ( I think still a new model SafeBoat w/3 250hp Verados strapped on the back. Now that would have to a floating fuel tank they way these guys run here in the islands. |
| L H G |
Jim: In all fairness, I think you also need to come up with some clever little names for the Honda, Suzuki, Tohatsu and Yamaha EFI 4-strokes, and not just pick on Mercury. After all, they all use that boring name called "4-stroke". For smaller 4-strokes, 115Hp and below, how about: Honditos It's interesting to see how similar Spanish and Japanese can be. Needless to say, the rumor on the street & web is that you're not making any friends at corporate Mercury with that Veradito handle, hence their absense of any Verado or Optimax based participation whatsoever. Although it's popular with the anti-Merc crowd around here, a lot of people, like Dick, don't think it's very funny, that there is nothing wrong with using the term "EFI 4-stroke" (like all of the Japanese manufacturers use), and that Veradito (I hear this is soon to be the name of Taco Bell's next offering?) is derogatory to the world class engineering that went into the entire Verado platform, 75-300HP. I believe that continued and frequent use of "Veradito" is damaging to the overall reputation of CW in the very Mercury and Boston Whaler community that this site claims to serve, especially since two of Whaler's most popular models, the 170 and 190 Montauk, come with them. But that's your decision not mine. |
| mfrymier |
After reading this thread, I immediately ran out and bought/consumed a burrito with guacamole and salsa ; ) |
| hauptjm |
I'm not sure I would agree that the Veradito name is uncomplimentary. Since, I don't know what Verado means in whatever language it comes from, if any, it does sound latin in nature. Therefore, the dito (baby) for the smaller models actually sounds like an interesting variation. I tend to agree that Mercury has done a wonderful job to distinguish themselves from the crowd with regard to their offering, so a unique name should be appropriate. Now, to more important matters: Larry, when are we going to see two new beautiful Verados on the equally gorgeous Whale Lure? I really think they would look and operate wonderfully with that rig. Have you given any thought to adding one (or more) to any of the Whale Lure fleet? If so, please don't let past ramblings here or elsewhere, keep you from submitting photos. I, for one, would like to see it! |
| george nagy |
I read the "veradito" namesake as being quite affectionate towards the engine line. Many spanish speaking people use the disminutives "ito" and "ita" to refer to things or persons that they are quite fond of. Well on another more related thought I was wondering what your impression was of the 200 dauntless with the 175? |
| george nagy |
| george nagy |
Opps hit the button too soon! Do you think 150 would be ample? The $3,300 upcharge seems steep considering the 50 hp jump. I'm basing that on the assumption of the 150 and the 200 being based on the same block. I like the looks of the dauntless line with thier lower freeboard and the added options list they are quite versatile. One thing I can't tell without a personal inspection is if the porte-head is sized for an average size adult? |
Larry--All those other motors have model names. For example, a Honda has a BF90, Suzuki has a DF90, Yamaha has an F90, but only Mercury has a "FourStroke 90" . It is a terrible model name, the worst I can imagine. The term "four-stroke" is a common term to describe the power cycle of the motor. To try to turn it into a model name by omitting a space is just foolish. Even Boston Whaler had to invent a new name for them, L4NA. Boston Whaler could not tolerate "FourStroke" either, it appears. But the Veradito motors (75, 90, 115-HP) are not the topic here, it is the four-cylinder Verado, a fine motor, it seems, and in spite of the reputation of the Verado for being a heavyweight, the 200-HP Verado four-cylinder is the lightest 200-HP four-stroke motor. However, one thing that worries me about these motors is the high ratio of horsepower to displacement. When I was young and learning about motors, it was more or less a benchmark of performance if you could get one horsepower for each cubic inch of displacement. When you got to that level, you had a high-performance motor. If you had a 283-cubic-inch Chevy V8, when you got 283-HP from it you had high performance. It was time to go out on Woodward Avenue and do a little street drag racing. These Verado motors shatter that notion. The 200-HP Verado motor is based on a 1.7-liter engine. In cubic inches that is only 105.7-cubic inches. When you get 200-HP from a motor with this little displacement, you are really cranking on it. To go back to my Chevy 283-cubic inch V8 analogy, if we got the same horsepower from the small block Chevy as Mercury does from the Verado, we would have to crank out 535-HP. If you have a 283-cubic-inch small block Chevy that can deliver 535-HP you have one fire-breathing, full-blown, race motor. Well, silly me, I guess you do have a full-blown motor, because that is what a supercharger is. To put this into better perspective, consider the 350-cubic-inch V8 in my GMC truck. In its current form it produces about 210-HP and hauls my boat around quite nicely. If it were hot-rodded to the same extent as the Verado, it would develop 662-HP. So let me ask you a simple question: If GM had a 350-cubic-inch V8 in a truck or a car that produced 662-HP, would you consider this to be a nice conservative engine, something that can go 150,000 miles with ease, something that can last for decades? Let me have your answer on that, please. The level of performance and power that Mercury is asking these small displacement motors to delivery is really quite amazing. For every cubic inch of displacement the Verado 200-HP motor is producing 1.89-HP. That is really a high-performance state of tune, in my opinion. When you compare the 200-HP Verado four-cylinder against all the other 200-HP four-stroke motors, its displacement is very small. Most of the other motors are about 200-cubic-inch displacement or roughly twice as large. In terms of how the rest of the world views CONTINUOUSWAVE and its opinions of the Verado, I can tell you this: I never spent a long weekend in the Bahamas hanging out and partying with the Verado marketing and engineering staff, I don't have the telephone number of anyone at Mercury Marine on my cell phone speed dial, and all my observations and comments are based entirely on my own first-hand observations and experiences. Does that make me unqualified to have an opinion? I will stick with the same opinion that I had back in 2004 when I first saw them; see my article for details: http://continuouswave.com/ubb/Forum1/HTML/006715.html I think there is some weird new dimension to talking about the Verado; if you do not gush and rave about it, somehow this is now considered being a Verado-hater. I am not a Verado-hater, at least I do not consider myself to be one. On the other hand, I am not a Verdo Fan Club website publisher. My mission is not to endlessly extol the virtues of the Verado. I am interested in outboard motors and I enjoy writing about them. What I do here is to write about my own experiences with them, including the Verado, When I write about my own personal, first-hand experiences with the Verado motor I am giving you exactly that: my own first-hand experiences. I am not reading from a press release. I did not check my senses at the door. I have not accepted any special favors or treatment from Mercury and I do not think I owe them anything in return. I think I make all this clear. I just write what I experience and what I think about the motors. When you shove the throttle forward on these four-cylinder Verado motors they really do emit a growl. That is the sound of very high horsepower being developed from very small displacement. That is not me being a Verado-hater and it wasn't me that designed the motor to only have 105.7-cubic inches of displacement, |
| ConB |
Having driven the same boat jimh drove I would say the 175 was plenty of power on the Dauntless 200. I would think the 200 hp would be really fast and the 150 might be fine for light loads but lacking with four or more adults, fuel, and gear. I would say inside the console looked the same size as the Dauntless 22 did. But I did not have a desire to go into it. It is a well thought out boat for all purpose use. Reverse shear still hurts my eyes though. Con |
| glen e |
Jim - I have not posted in a while but I think we need to clear the air…
As far as what I get from merc, I paid my way to all the rendezvous and I still run the 2005 250 Verados that you drove on my boat and still pay for all my maintenance. Thanks for letting me post here. Regards, |
Glen--I do agree that your Verado Club events are somewhat different in that they are organized and promoted by the customers and apparently attract enough interest that the manufacturer wants to attend. This is the opposite model from the typical Whaler owner's event, which is organized by the manufacturer and attracts the customers. You have my admiration for that. As far as socializing with the manufacturers, I do this with Boston Whaler employees from time to time at Boston Whaler sponsored owner events. Yes, a lot of information gets exchanged at these gatherings, going both ways. The customers learn things from the manufacturer and the manufacturer learns from the customers. But in terms of maintaining an independent perspective or point of view, getting too cozy with a manufacturer puts a reviewer's credibility in a bit of jeopardy. It is only human nature that after you have a few beers and a few burgers on the grill with nice folks that it tends to make it harder to say anything critical about their product in public. I consider myself to be a Verado-booster, and I judge that based on what I have written. But somehow a few people--the dyed-in-the-wool Mercury fans--seem to think I am a Verado-hater. If I say anything at all which is the least bit critical of the Verado or another Mercury product, then--Voila--I am instantly a Mercury basher. That is nonsense. I just write very simply and plainly about my personal first-hand experiences with outboard motors of many brands. By the way, you can read about my experience on Glen's boat in the archives: |
| erik selis |
Modern engines, used in European and Japanese cars for decades, are often high performance engines with reasonably small displacement yet very high power output. These engines have proven themselves to be reliable over long periods of use. They have also proven themselves to be fuel efficient. Efficiency is all about making things lighter, faster and using less fuel for the same output. The quality of engineering and R&D is very important. New materials, synthetic oils, CADCAM and simulation have helped engineers in making engines more efficient and fine-tuned from the start. I think these light(er) weight Verados are moving along with what the European and Japanese car industry have been doing for years now. Nothing wrong with a big V8 but there's nothing wrong with a well built modern 4-cylinder either. IMO. BTW, I think the name Veradito sounds good and in no way sounds degrading. Erik |
| OutrageMan |
Jim, Was this a dealer demo you were on, or a private boat? Brian |
| Peter |
It is my understanding with respect to at least certain countries in Europe, motor displacement was, at one time or another and may still be, taxed thus causing domestic manufacturers to use or continue to use small displacement motors and then adding forced induction to improve performance as a way to work around the tax. My guess is that this tax was probably originally put in place as a trade barrier to keep American manufacturers that were tooled up to make large cars with large displacement motors from importing their cars into these countries' markets for the most part. So I'm not so sure that the trend to smaller displacement motors with forced induction is caused by natural engineering forces gravitating to such formats or marketplace behavior modifications caused by the actions of one or more local governments. In the U.S., there has been no tax on displacement so automobile motors have come in many different displacements and configurations. If anything, in the U.S. there has been a gravitational pull toward ever larger displacement, naturally aspirated motors. ****** Now at the risk of being threatened with bodily harm by members of the Verado fan club for discussing the Verado ;) ....
For example, I have a small car with a supercharged 4-cylinder 150 HP motor with about the same displacement as the Verado 150. Over the course of depleting a tank full of fuel, I average about 28 MPG with an average speed of about 30 MPH. That means that the average rate of fuel consumption over the course of depleting the fuel tank is about 1.1 GPH for the mixed driving that this car gets. At cruise on a flat highway at 60 MPH, the instant fuel economy for this car is about 32 MPG which is a consumption rate of about 1.9 GPH. Accelerating up a hill with a significant grade starting at 60 MPH, the instant MPG drops to about 10 MPG so the instant fuel consumption rate climbs to about 6 GPH for just about the hardest work I can put this little car through in normal driving. This acceleration up a hill event never lasts more than 1 minute in duration. Now, using Whaler's performance report data, compare that to a Verado 150 on a 200 Dauntless. An average consumption of 1.1 GPH would have the Dauntless moving about 6.5 MPH. At an instant fuel consumption rate of 1.9 GPH, the Dauntless will be moving about 8 MPH. At that speed, its not on plane. At the 6 GPH consumption rate, the Verado 150 is moving the Dauntless at about 25 to 26 MPH, just about minimum plane speed from what I can tell. So, anytime on plane, the Verado is running in conditions that at a minimum would be equivalent to accelerating my little car up decent grade hill at 60 MPH. It's not unusual for the Verado, or any other outboard, to be required to work like this for perhaps an hour or more at a time. Based on the data for the Dauntless 200, the ICOMIA duty cycle would have the average hourly consumption of the Verado 150 at approximately 4.5 GPH which, as mentioned above, is about 4 times what is actually experienced in a car with a similar engine running a typical mixed driving cycle. While I am not implying or suggesting that the car engine and the Verado are built the same, but even if they were built the same, the Verado 150 does have an advantage in that it has an inherently better cooling system to take care of the heat generated by an average duty cycle that is 4 times that experienced by the typical automobile engine. Although I think automobile engine analogies for boating are not very good, I think the best auto analogy one can make between outboard use and automobile use is to make reference to the large SUV many of us use in the U.S. to tow our Whalers. An automobile motor operated while towing something uphill is probably the closest thing to an outboard motor moving a boat through the water. Now none of the large SUV manufacturers, even the European makers of SUVs, that expect that some part of their vehicles' use could be for towing something employ a small displacement, forced induction, gasoline motor. Perhaps the experts will jump in to answer the question of "why not use small displacement, forced induction for such applications"? **** One last comment: I don't see the coined term VERADITO as being negative in any way. Rather VERADITO quickly and efficiently distinguishes the group of FourStroke branded Mercury 4-stroke outboards in the 75 to 115 HP that are built using VERADO based components from all of the other FourStroke branded Mercury 4-stroke outboards which do not use such components. It also distinguishes the latest generation of FourStroke branded (a.k.a. Veradito) 75 to 115 4-strokes made and sold by Mercury from the prior generation of 4-stroke outboards that had Yamaha powerheads surrounded by Mercury "clothing" often referred to as YamaMercs or Mercahas. Veradito is no more or no less damaging to anybody's reputation than these other previously used coined terms to convey information about the product origin quickly and efficiently. |
My test drive of a Verado 175-HP motor was on a boat owned by a Boston Whaler dealer and took place at a dealer sponsored owner's event, just like the ones held by many Boston Whaler dealers and open to all owners to attend. On the Great Lakes it has been my experience that all the Verado-powered boats I have seen underway are owned by dealers, and that was true until just a few weeks ago when I ran into a privately owned boat powered by a Verado, well actually powered by three Verado motors, that was underway on the Great Lakes. I am certain that if I hung out around Government Cut in Miami, Florida I would probably see more, but I hang out in northern Lake Huron and I don't see many boats up there with Verado motors. So when I get a chance to get some time at the helm of a Verado motor, and in this case my first chance with these newer four-cylinder motors, I take it. Regarding the habits of automakers in Japan and their engine displacement size, this is an interesting opportunity for a comparison because it just so happens that all of the Japanese manufacturers that made outboard motors also make automobile engines. Honda, Suzuki, and Yamaha all make four-stroke engines for automobiles and for outboard motors. The comparison is most apt in the case of Honda, where they actually use the same engine in a car and in an outboard. The Honda 200-HP outboard uses a 3.5-liter displacement engine, or 212-cubic inches. This is more than twice as large as the 200-HP Verado. I am not certain what inference to draw from this, but if we are to be guided by the experience of small four-stroke engine automakers, it seems that displacement is used more generously in their outboards than in the four-cylinder Verado. We can also look at Suzuki for guidance. Their 200-HP outboard is even larger displacement, 3.7-liters or 220.5 cubic inch. And in the case of Yamaha, their automobile engines are somewhat more obscure, but their four-stroke outboard motors are very popular. The displacement of the Yamaha F200 is 3.35-liter or 204.6 cubic-inches. Another interesting commonality among the Japanese four-stroke motors--and just about all small automobile engines these days--is the use of variable valve timing or cam phasing to enhance performance. In this regard the Verado is a complete departure in that it does not use any sort of variable valve timing or cam phasing. To my way of thinking a variable valve timing arrangement is added complexity and complication, but on the other hand its use is so widespread that is seems to have become the norm. Now I am not a Luddite, and I don't think that the path to the future for the automobile industry is to go back to the 389-cubic-inch V8 with two-barrel carburetor that powered our family's 1962 Pontiac CATALINA. In the old world of manufacturing it was probably more cost effective to produce a big block which was not assembled with the precision of a Swiss chronometer, and back then there was a much lower expectation about longevity than there is today. But in the modern approach to manufacturing in which less displacement is asked to produce more power, it seems to me, in a sort of natural and intuitive way, that the tolerances, precision, and quality needed in the product will have to be higher. And coupled with this is an even greater expectation of durability from the customer. When you add all that up, and then ask the engine to make the power with half the displacement of the other four-stroke outboards, how does this affect the durability? |
| OutrageMan |
Jim, Your point about durability is well taken. One would be smart to ask about it. That said, I have a bit of an inside track on what the testing was like prior to release of the Verado, and what is currently going on. Suffice it to say, that never in Mercury's history was a product that made it to production more thoroughly tested. From what I know I don't think Tim Allen or the Mythbusters could have been more torturous. Further, it is my understanding that internally, Mercury believes that they have produced their most reliable engine to date. Of course that comes with the caveat that not everything shows up until a product has been in the end users hands for a while. Brian |
| andygere |
Hondito--sounds like something tasty from my local taqueria! I must admit, F90, BF 90 and DF90 are every bit as lame as FourStroke 90, so perhaps Larry is on to something with the new nicknames. Gone are the days of the Starflight, Javelin, Black Max, Faststrike, Ocean Runner, and Sportwin. I'll admit, even E-TEC is soft as names go. Sounds more like some type of computer appliance than a high performance engine. On topic: Nice review Jim. It sounds like a strong motor, and I too am impressed with the hp to displacement ratio. For what it's worth, the 283 in my 1963 Impala Super Sport put out 195 hp from the factory, before I started hot rodding it. |
To follow up on the European side of Erik's suggestion that automobile engines are trending toward smaller displacement and higher horsepower, I happen this evening to have had my head under the hood of an AUDI Quattro which was powered by a 2.0-liter, four-cylinder, four-stroke motor that develops 200-HP. The Audi engine is not quite as high-output as the Mercury Verado, but it comes about as close as I can find in a production automobile. If there is another production automobile engine which cranks more power from its displacement, please let me know. Like the Verado, the Audi also uses a forced induction system, a turbo-charger, to boost horsepower. However, it is also akin to the Evinrude E-TEC in that it uses direct-injection, and I think it is one of the first gasoline four-stroke engines to use this advanced technique. The Audi engine does have the advantage of a six-speed transmission to couple its power to the wheels. |
| L H G |
Wouldn't it also be akin to the Mercury Optimax or Yamaha HPDI in using that direct injection technology. Does it use Orbital/Optimax technology by any chance or the Ficht/E-tec system? |
| Perry |
Jim the 2008 Mazda speed3 has a 2.3 liter turbocharged 4 cylinder motor built by Ford that produces 263 horsepower. That is lots of power per cubic inch of displacement. |
| OutrageMan |
As long as we are making these comparisons, my 06 BMW K1200GT makes 158 hp on an inline 4. Thats a lot of hp for 1200 ccs. My 07 R1200GSA is the traditional boxer twin. It does just south of 100 hp but puts out gobs of torque. Brian |
| erik selis |
OK Jim, Here are just a few that I can remember and a couple of new engines showing just how much output HP can be achieved in small displacement engines on standard production cars. There are probably many more. The older models: - Honda Civic 1.6L VTI : 160 HP - Nissan 200SX Turbo: 1.8L and 170 HP - Renault Clio Sport 2.0L : 172 HP - Toyota Corolla T-Sport 1.8L : 189 HP Now the newer models: - Seat Leon Cupra FSI 2.0L : 237 hp - Vauxhall Astra VXR 2.0L : 240 HP - Lotus Elise 1.8L : 190 HP (Toyota sourced and Yamaha built btw) Now the beast; - VW Golf 2.0L GTI : 270 hp ..yikes!
Peter, you are absolutely correct when you say that we get taxed for displacement. That's one of the reasons the European (and Japanese because they first targeted the European market before the North American) engines are small displacement - high output. I think that fuel prices are an even bigger reason for building small, highly efficient engines. BTW, wasn't the chief design engineer for the Verado engine the chief design engineer at Porsche? Maybe that would have something to do with these lighter Verados having high output, small displacement. Also, I totally agree with what you and Jim say concerning large displacement engines and their use in marine outboards. Maybe this time Mercury is just ahead of Honda, Yamaha and Suzuki with their concept. Time will tell if they are durable and I believe they will be because of the experience we have here with the smaller displacement-high output engines used in the automotive industry. In any case it makes for fine, friendly debate. Erik |
| OutrageMan |
Erik, You are correct about the designer being a prior Porsche engineer. However, he has recently left Mercury and is back home in Germany. Brian |
L H G --Orbital's combustion system is being used on some self-powered Rickshaws in third-world Asian countries, but I do not believe that German luxury and performance automaker AUDI has adopted it. |
| fourdfish |
After doing an internet search, I have not found any significant manufactures using the Orbital Technology except Mercury with the Optis. I did not read into the nickname any real bashing. Larry and Glen have a paranoid problem everytime they percieve someone bashing Mercury. I did not see that in this thread. |
| L H G |
I should get a life? Well that's a joke. I'll take my Classic Boston Whaler life any day over a beer can aluminum CRESTLINER life! With friends like Fourfish, Continuouswave hardly needs enemies. |
| Plotman |
I would love to learn what these new 4 cyl Verados actually produce on a dyno, what the torque curves look like, and how that compares to their 6 cyl cousins, as well as the competition. I would love to see a classic 25 with a pair of 175s on it. There was a 27 I was noodling recently, and I was wondering how it would perform with a pair of the small-block 200s on the transom. Alas, someone in Indiana and not I won the powerball, so I must wait... |
| lurkynot |
Since this is a Boston Whaler site and you were operating a Whaler how did the new 200 Dauntless handle the water? What were the conditions? What lake? Did it seem more balanced as far as center of gravity as opposed to older model Dauntless. They have had a reputation of riding "bow high". |
| glen e |
gotta respond to fourdfish as it's been along time..don't really care what you say about merc...they can handle themselves...my only response here is that my site,like this one, just tries to let people post...I can tell you that the Gen II V's are a direct result of this site, others and mine telling Merc that MPG had to be better.....8 years ago when the V was approved, the big priority was hole shot...and now it's MPG so they were tasked 3 years ago to get both..they have done that with the new 300 and 200...and it's not over by a long shot.....the new Yam at 800 lbs? not too far off to get a V at 350 as the same weight as all the V's at 600 lbs and yam will be hanging out there.......... I will not joust here with Peter, et al...thanks Jim |
| Jordi |
Glen, In the world of "information" we live in today, albeit your site and CW has offered a great service to many who read and contribute. I hope Mercury does a lot more that gauge public opinion of their products than reading opinions on these forums. "I can tell you that the Gen II V's are a direct result of this site". There is a lot of misinformation that get's posted on these sites and at times the "discussion" last forever to see who is right or wrong. You run a good site, at times your post are very definitive almost "authoritative". You’re very knowledgeable about Verado's and provide a good service, BUT you are NOT the official voice of Mercury. Public forums serve the public best when the right balance of opinions, real life experience, knowledgeable consumers and civility co-exist. Jordi |
