ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance E-TEC: Use of OMC Leftover Parts From the 1980's
Author | Topic: E-TEC: Use of OMC Leftover Parts From the 1980's |
posted 09-19-2007 12:57 AM ET (US)
Recently it was suggested that the Evinrude E-TEC motor was suffering from a lack of proper research and development, and that Bombardier motors had "old leftover OMC components, transom mounts, blocks and gear cases...from the 80's." I like to think that on CONTINUOUSWAVE we present information that you can rely on, so I cannot let this pass without making a few comments, as my understanding of the E-TEC leads me to believe that this characterization is completely wrong. Let's look at the engine block. Here is some factual material about the engine blocks used in E-TEC motors: "The new V4 and V6 models from 115 to 200 HP all share a 60 degree V angle and the same bore and stroke as previous Evinrude 60° V angle engines, but that’s where the similarity ends. The E-Tec models have a newly designed lost foam cast cylinder block with larger air intakes and reed valves, more cooling system area and a larger, more free-flowing exhaust system." Source: http://www.brp.com/NR/rdonlyres/FB41084E-1331-446F-BE09-BD3E83EB358B/0/ Guide_ETEC115.pdf Let's look at the fuel injectors: The E-TEC engine has always used a different fuel injector than was used on the OMC-era Ficht engine. The design of the fuel-injector is one of the principal differences in the E-TEC and FICHT engines. The E-TEC fuel injector uses much less electrical power. This helps to reduce the electrical power needed to operate the engine and permits all E-TEC motors to be able to start and operate without a battery. The FICHT injector was a solenoid type injector, and the E-TEC injector is a voice-coil type injector. The voice-coil design of the E-TEC injector also allows for management of the injector motion by modulation of the exciting voltage. This has been exploited to enhance acceleration and deceleration of motion resulting in higher injection pressures. It also reduces the clicking sound of operation that is normally associated with fuel injectors. In addition, for 2008 the E-TEC fuel injector has been redesigned and improved. The injector has a new nozzle design which decreases variation in fuel flow over the life span of the injector. The new injector is also smaller, different in shape, and has a different mount arrangement to the cylinder heads. This also implies that the cylinder head castings have been changed for 2008, as well. Source: various BRP documents and dealer reports. Let's look at gear cases: in order to accommodate the increasingly more powerful torque output being produced by the E-TEC, Bombardier redesigned the gear cases being used. Bombardier E-TEC motors use a new MAGNUM gear case. It is not an OMC part from the 1980's. The strength of the gears used in this gear case is amazing. I have personally seen an E-TEC gear case involved in a massive propeller strike. The four-blade stainless steel propeller was twisted and bent, but the internal gears of the MAGNUM gear case survived intact and appeared in perfect condition. Source: first hand observation and dealer reports. Also please read and view the photographs I took in http://continuouswave.com/ubb/Forum4/HTML/003959.html regarding this new design of the BRP gear case. Let's look at some internal components of the E-TEC: "Evinrude E-TEC incorporates pistons made from a new alloy, which was developed by NASA. This alloy has proven to be 2 to 3 times stronger at operating temperature than the aluminum alloys pistons are traditionally made with. The pistons used in the 40 through 60 and the 75/90 are what's known as "full-skirt" pistons. The internal design of the block (the intake, exhaust and transfer ports) doesn't require machining "port windows" into the piston. This combined with the new alloy, increase the piston strength and durability." Source: http://www.evinrude.com/en-US/About.Us/FAQ/E-TEC.htm#Q5 The full-skirt pistons are a significant improvement. Many four-stroke motor devotees like to point to the ported piston designs of two-stroke motors as an area of weakness and inferior design. This is not a problem on the E-TEC 40, 60, 75, and 90. Let's look at the engine mount: the E-TEC uses a new design trim and tilt system called FasTrak. This system replaces the system used in the 1990's on OMC motors, which replaced the system used in the 1980's on OMC motors. As far as research and development, Bombardier has done a good job of building on OMC industry leading technology. Among OMC innovations were: --the first loop-charged induction outboard in 1968 Bombardier has continued the tradition, including the first NMEA-2000 certified engine controller, and I sure other improvements which I am not even aware of. In summary, please ignore the charge that Bombardier is building motors with old components designed in 1980's by OMC. It is not accurate. I am sure there must be a few parts in some motors that perhaps do go back that far, but my impression is that for the most part the E-TEC engine represents a new design which consists of a substantial number of new and improved components. |
GSH |
posted 09-19-2007 11:16 AM ET (US)
Thank you, JimH, it was both interesting to read your post and very nice that you corrected the negative stuff others have suggested about the work at BRP! -Seb |
Peter |
posted 09-19-2007 11:20 AM ET (US)
Just to keep the facts straight, the FastTrak midsection that is used on the E-TEC has been in use, unchanged as best that I can tell, since sometime around 1990/1991. This midsection is a proven design that works well. As they say, "if ain't broke, don't fix it." I read the comment from CW's No. 1 Mercury fan and sometimes salesman regarding the use of "old leftover ...transom mounts" to be in reference to the difference between the ordinary or standard transom bracket design which is used by ALL of the outboard manufacturers and the pedestal mount used ONLY on the Verado I6. The comment suggests that there continues to be denial of the fact that the basic pedestal mount design is not new, but rather, something taken from a U.S. patent issued to Volvo back in the 1970s. See continuouswave.com/whaler/reference/verado/veradoMount.html . The comment trys to infer that the pedestal mount design is superior, or conversely that the traditional bracket design is somehow inferior. Interestingly, however, despite this attempt to infer superiority in the pedestal design, the pedestal mount design was not adopted for all new product offerings coming from Mercury. Thus, it seems the lack of universal adoption of the pedestal design on all new products by the only company using the pedestal design tends to cause the inference to backfire on the author. Rather, the reluctance to adopt this alternative design suggests that it was not selected as being inherently better or superior but rather to solve a particular problem with an unusual and complicated outboard motor configuration. |
posted 09-19-2007 01:41 PM ET (US)
Re the trim tilt system on the E-TEC and its origin in a 1980's OMC motor: the current Bombardier motors use a system which is different than the one used on my 1992 Evinrude. I also notice that my trim and tilt system is different than ones I see on motors from the 1980's. That is how I came to the conclusion I did regarding the trim and tilt systems. The current motors have a single hydraulic ram to operate the trim and tilt, while my motor has three rams. I concur that if one looks at most current outboard motors (of all brands) they are using a transom mount which is very similar to the mount used by Bombardier, and the only exception to this is on the larger Verado motors from Mercury. In any case, the tilt and trim system is not the same as was being used in the 1980's. The transom mount is likely to be similar, but on the other hand, the transoms of most boats have not changed much since the 1980's so there is not a strong incentive to replace a component that has a long track record of good service. |
Tohsgib |
posted 09-19-2007 01:52 PM ET (US)
Used to be Merc had it's transom mounts and OMC had their own. This kept owner loyalty when repowering. When Suzuki came ashore in 1977 they used OMC's bracket type so they woud get OMC buyers to maybe use their brand. Yamaha did the same in 1984 when they came here. Merc eventually changed to OMC style and so did Honda when they made larger engines. I believe all the V6 Mercs have been using the OMC style since 1977 but my 1983 70 was still old school. This way you can repower with whatever brand you chose without drilling new holes. I think Merc again went with another type for the verado, not only to keep brand loyalty but also to support the weight. It will be interesting to see if Yamaha uses the Verado style holes or their own for the new 350's which I believe have 6 bolts not 4. |
seahorse |
posted 09-19-2007 02:38 PM ET (US)
PETER:
The trim units used on the 115hp and up E-TEC Evinrudes are the same style Showa built units that OMC introduced in 1991 as the Fast-Trac trim-tilts. Still used today, 17 years later, the same style and make is now used by some Yamaha and Honda outboards. The trim units from the late '70's (about 1978) up through 1990 and on some later economy motors had 3 mounting bolts on each stern bracket and a large diameter pin on the engine's swivel bracket. This was an original OMC design. The Fast-Trac Japanese built Showa trim units are fastened by an upper swivel bracket pin and a lower pin through both transom brackets, no bolts. In-line E-TEC motors from 40 to 90 hp use a single piston unit that contains a special biodegradable hydraulic oil in it. |
onlyawhaler |
posted 09-19-2007 02:39 PM ET (US)
Thanks Jimh Great report and very interesting. I have had several OMC Johnsons from the 80s and they were reliable, dependable engines. It wasn't until the late 90s that they lost themselves in the fuel injection process It is interesting in your report to see that the industry basically adopted the mounting pattern by OMC to avoid additional drill holes in a transom. During the 70s and 80s it seemed to me that OMC Johnson/Evinrude was a real leader in carburated outboards. Onlyawhaler |
posted 09-19-2007 04:04 PM ET (US)
For more on the Showa hydraulic trim and tilt systems for outboard motors, apparently an industry standard and used on Bombardier, Yamaha, and Honda motors, see |
crabby |
posted 09-19-2007 10:39 PM ET (US)
My 90 hp etec circa 2004 uses two trim cylinders and a single tilt cylinder, much like my old 1986 70 hp Evinrude. |
seahorse |
posted 09-20-2007 03:10 AM ET (US)
crabby posted 09-19-2007 10:39 PM ET (US)
TexasWhaler |
posted 09-20-2007 11:03 AM ET (US)
Jim, I apologize for deviating from the original subject of the thread, but I wanted to try to catch Seahorse's attention. Seahorse, would you be able help with a topic that has some puzzled, including myself? Is there a difference between the 2007/2008, blue E-TECs and the white "Saltwater Edition" E-TECs, as far as stainless/non-stainless components? I know back in 06, you had mentioned: Is this still the case? |
fourdfish |
posted 09-20-2007 04:38 PM ET (US)
Thank you Jim for setting the record straight. I think Peter is correct in saying, "If it isn't broke, don't fix it." Sometimes newer technology does not mean better technology. The midsection of the E-TEC motor is one of the best of outboards on the market today. I have not seen anything on the< competing manufacturer's engines that is better. Many aspects of today's autos have not changed for many years, as nothing superior has been found to replace them. |
Tohsgib |
posted 09-21-2007 10:17 AM ET (US)
The wheel is still round and held on with lugnuts. |
posted 09-21-2007 08:36 PM ET (US)
I think there is further irony in this discussion. As a matter of fact, when Bombardier took over the bankrupt remains of the Outboard Marine Corporation (OMC) they began a total re-engineering of all the components in the OMC outboard motors. It is often said that every part used in OMC motors had to earn its way into Bombardier motors, and many poor quality parts or out of tolerance parts were discarded. In 2001 the OMC manufacturing operation was spread over many locations both in the United States and in Asia, and the engineering, design, fabrication, machining, and assembly of motors was split between multiple sites. When Bombardier took over they closed most of these facilities and built an entirely new plant in Sturtevant, Wisconsin. The majority of manufacturing and part finishing operations were moved to the new plant, and 95-percent of assembly operations were moved there, too. The location was chosen to be close to the engineering and design center in Waukegan, Illinois. This allowed for much better control and feedback between engineering and production. Although Bombardier continued to manufacture the Johnson and Evinrude motors, the new Bombardier motors were of significantly better quality. The establishment of a new plant and relocation of almost all manufacturing operation to a new facility also allowed Bombardier to carefully select and hire the best of the former OMC employees and to build a new team spirit for the re-born Evinrude and Johnson product lines. Bankrupt OMC was a manufacturer in serious trouble, and Bombardier pulled off a very impressive resurrection to gave the famous Evinrude and Johnson brands new life. Even competitor Mercury's CEO, George Buckley, recognized the task ahead for Bombardier when he made his famous remark about how the Bombardier people had better have "their Jesus shoes" on. Bombardier changed the character of the Johnson and Evinrude brands, and bought back strict engineering and quality control to their design and manufacturing. |
L H G |
posted 09-23-2007 12:17 AM ET (US)
Jim - Your characterization of Evinrude could be correct, not Johnson. French Canadian Bombardier Recreational Products has effectively destroyed this famous American brand, not giving it a dime of R & D so badly needed to turn it into a 4-stroke brand, like the initial direction white painted Suzuki's indicated. All they did was run the obsolete OMC 2-strokes off the books, and buy a few "white" Suzuki's, many of which ended up "dumped" at bargain basement prices by the Dealerships. All Johnson did was effectively help Suzuki gain a foothold in the emerging 4-stroke market, now ironically, black Suzuki's are taking sales away from Evinrude and the others with their bottom line pricing and high quality product. Some partnership! Now Johnson is effectively dead, with no relevant product to sell except a kicker or two. If Johnson had received the 100 million of R & D that Merc put into the Verado platform, Johnson could be something today. "Big" Bombardier had the resources to do this, but abdicated. Now there is nothing but a memory of the Johnson name, while Evinrude struggles to keep up with continual new product innovation and introductions from Mercury Optimax and Yamaha HPDI. I still say BRP's track record with the remains of OMC is how to get the most out of spending the least they could get away with. A bottom line type of philosophy. All of the other 5 manufacturers are spending tens of millions delivering new product to the outboard market, building new plants, etc. BRP has yet to show us they are doing that. All their resources seem to go into their bread and butter core product, the SeaDoo and SkiDoo lines. BRP's stewardship of Evinrude/Johnson would make a great case study for the MBA progams. |
GSH |
posted 09-23-2007 07:44 AM ET (US)
I know I shouldn't and still... First of all, I'm very sorry about what has happened to the Johnson brand. I've only ever had two brand new outboards, and the first of those was a 25 hp Johnson, and even if it wasn't the best outboard ever (oh, the sound of it...), I still was very proud of it and kindof miss it. I actually just talked to a Johnson dealer about the future of the brand, he didn't tell me much, he did tell me what I heard before, that a contract between Suzuki and BRP came to an end in 2006, and as such hasn't been renewed. Now if I was a manager at Suzuki making deals with OMC or BRP regarding re-branded four-strokes, I would include an articel in the contract forbidding the customer (OMC/BRP) to bring non-Suzuki four storkes to the market during the time when the contract is valid and for some time after that, perhaps two to four years. If I'm right, BRP doesn't have the right to bring new four storke outboards to the market before, say, next year. But does BRP want to support two different technologies for outboards? Honda and Suzuki do not. Tohatsu does, but who knows what kind of a deal they have with Brunswick. Yamaha does, but really, from my point of view, the haven't done THAT much for the HPDI line-up in the last few years. Anyone is free to disagree. What in my opinion speaks for BRP ”re-entering” the four stroke market is the fact that BRP includes Rotax. (I don't know if this has been in the new in the US, but when HD wanted a new motor for their new Buell sportsbike, they teamed up with Rotax.) BRP of course already have four storke marine engines in their jetskies and what-do-you-call-them-boats, even supercharged ones, no less. One would think that would be of some help if wanting to put new four storke outboards on the market. However, and this could also make a nice case study for an MBA program, if BRP will re-enter the Johnson brand to the outboard market, it's clear they cannot step on the toes of their current main brand Evinrude (ref. all the talk about Optimax vs. Verado). So what will they do, what should they do? I'm just hoping they will not make Johnson a marketing brand for even cheaper four strokes from the far east. Better let the brand RIP... And an also-ran to Honda/Suzuki/Yamaha four strokes would just be soooo boring, would it not? -Seb |
posted 09-23-2007 09:24 AM ET (US)
The Outboard Marine Corporation (OMC) had two brands, Johnson and Evinrude, which for decades were just about identical (mechanically) except for the color of the paint that was used on the motors. But even back in the 1950's there was a slight tilt in favor of Evinrude as the premium brand. When I was just a pup and we had an old 5-HP Johnson motor with a green paint job, I could tell that it was not as fancy as the Evinrude motors that had special model names like "Fast Twin" and had fancier paint schemes and more decorative engine cowlings. The positioning of the Evinrude as the premium brand and Johnson as the secondary brand evolved over decades of marketing by OMC, and it was not something that Bombardier just arbitrarily imposed upon the bankrupt company they revived. Marketing with two brands was a very traditional (and successful) technique in America in the decades following the 1950's. General Motors was the master of it. They had a succession of brands, all of which were often just about identical mechanically, and differed only by paint colors, styling, and marketing. You could buy cars in a succession of brands, from Chevrolet, to Pontiac, to Buick, to Oldsmobile, to Cadillac, and you really got just about the same product, but dressed slightly differently. At one point it got so ridiculous that Cadillac had a small sedan, the Cimarron, that was clearly just a Chevy with better tail lights and hubcabs. And everyone knew it. (See the hyperlinked article for confirmation.) Even Mercury got into the multiple branding, introducing a Mariner line of motors to coexist with their Mercury brand. As far as a study for an MBA paper, I am fairly certain that the whole concept of multiple brands was driven by the desire to get as many retail outlets for the product as possible. OMC could have a Johnson dealer on one side of the lake and an Evinrude dealer on the other. This multiple brand marketing of very similar products now has begun to fade, and you can see it in automobile marketing. General Motors has already eliminated the Oldsmobile brand, and, if their presence at the latest auto show is any indication, Pontiac and Buick brands are receiving much diminished attention. The brands that remain, like Chevrolet and Cadillac, now have very distinctively different products. In this respect, for Bombardier to stop selling the same outboard motor under two brand names, Johnson and Evinrude, is not a big surprise. And for Bombardier to choose Evinrude as the primary brand is no surprise, either. As I said, even as an 8-year-old in the 1950's I could tell that Evinrude motors were cooler than Johnson motors. As far as providing a Japanese manufacturer with an entry point into the North American outboard market, I am certain that every word written about Bombardier and Suzuki can be also ascribed to Mercury and Yamaha. Mercury has had a much longer relationship with Yamaha and has been selling their motors under the Mercury brand name for decades. It is only this year, 2007, that Mercury finally stopped buying its four-stroke motors from Yamaha. As for "dumping" motors, I believe that some of those 4,000 units of Yamaha 225-HP four-stroke motors, which Mercury bought to fill a huge gap in their product line when the Verado motor was not ready for production, are still around and being sold at significantly reduced prices. As for what value remains in the Johnson brand name and how Bombardier intends to take advantage of it, I cannot say. I do not think it is a serious loss for them. Some owners of Oldsmobile automobiles were quite surprised to discover that they had a Chevrolet engine under their hood instead of an "Oldsmobile Rocket V8," but in the main OMC outboard buyers had never been led to believe there was any special magic in their Johnson-branded motor. They already knew it was just an Evinrude with a different paint job. In modern marketing, it makes more sense to differentiate your brand on something other than just the name and the paint color. Bombardier has distinguished Evinrude with E-TEC, and I am afraid they won't be trying to sell a parallel brand of Johnson's with J-TEC. For obvious reasons, a J-TEC outboard would not be a good choice for an outboard motor brand name. |
bigjohn1 |
posted 09-23-2007 06:34 PM ET (US)
Interesting discussion on the historical context of OMC re: Johnson and Evinrude. I have always wondered why BRP does not sell the Johnson overseas (like Merc does with Mariner). Of course I guess you could just as easily wonder why Mercury does this instead of simply marketing Mercury both at home and abroad. |
posted 09-23-2007 07:15 PM ET (US)
Re multiple brands: automaker Ford recently announced it was planning on reducing by 40-percent the number of "platforms" (brands and models) it was marketing in the next few years. In the context of this sort of brand reduction, I don't see the move by Bombardier to shift outboard manufacturing toward the Evinrude brand as being something unusual. Ford Group Vice President Derrick Kuzak, as quoted in the DETROIT FREE PRESS on August 24, 2007: "Over the next five years we'll reduce our number of platforms by 40-percent. We're focused on 10 core platforms, and within five years, 70-percent of our volume will be on those 10 core platforms." |
GSH |
posted 09-24-2007 03:01 AM ET (US)
John, if I may: Regarding selling Johnson outboards overseas: what do you mean? As BRP sells Johnson outboards at least in the EU, do you think Evinrude should be the North American brand and the rest of us would get Johnson? If so, I really don’t understand why? (After all, we now even get Korean cars branded as Chevy… ) Also, here in the EU we have both Mercury and Mariner outboards, I guess the idea originally was to get more sales, just as Jim said regarding Evinrude and Johnson dealerships. By the way, check out the look of the Mariner Verado outboards, for example on www.marineroutboards.co.uk. Some may like the full black of Mercury, but given the choice I would go with the Black/Silver/Red Mariner for sure! Jim, I know you are right, but I’m still feeling some nostalgia. Evinrude and Johnson, they were a team, a dynamic duo, like Batman and Robin, even when it was only a matter of colors and brand name. I guess I’ll have to settle for just Batman… -Seb |
bigjohn1 |
posted 09-24-2007 08:57 AM ET (US)
GSH: Thanks for the lesson, I did not know Johnson was alive and kicking still in the EU. I own a Mariner myself so I understand your like for the graphics. As I reside in the U.S. Territiry of Guam, we too get both Black Mercury's and Grey Mariner's for some strange reason. We do have a few Verado-equipped boats here but those have black Mercury cowels. Here is a funny aside: I recently talked with a local island fisherman who said he hates Mercury and would never own one. "Why", I asked, he went on to say, "Mariner is a much better engine and more reliable". I just smiled and nodded. |
Peter |
posted 09-24-2007 09:39 AM ET (US)
In the past, I think some Mariner outboards might have been a Yamaha in Mariner wrapping paper. |
Tohsgib |
posted 09-24-2007 11:53 AM ET (US)
If you search you will find a more detailed post I did on Merc/Mariner but mariner was all Yamaha up to 60hp when they came ashore in 1977. From 70-115 they were Mercs. More mercs moved out yamahas evey year until about 1986 or so when there were no more yamaha and Tohatsu was now taking over the smaller Mercs/mariners. Yamaha did this to get into the USA which they finally did in 1984. Mariner was already a brand name overseas as mainly a commercial grade engine and that is how they marketed it here in 1977. I have just about every Mariner brochure from 1977-1990 or so. I also owned 2 Yamahas badged as mariners a 5hp and a 30. |
andygere |
posted 09-24-2007 04:38 PM ET (US)
quote: Yamaha is down to one model in it's HDPI line, the 200 2.6L HPDI. New product innovation? Yamaha is killing the HPDI faster than it's killing the conventional 2-stroke line. When I was motor shopping a few years ago, none of the dealers had one in stock, nor would they order one for me. Sounds like product innovation to me. Note that warranty on the HPDI is only 2 years, vs. 3 on Yamaha's comparable 4-stroke motors. I suppose we should mourn the loss of the Johnson name right along with Mariner, which also went by the wayside here in the U.S. |
L H G |
posted 09-24-2007 05:44 PM ET (US)
With all due respect, look at the current Yamaha website. I'm sticking with my comment. You will see HPDI's in 150, 175, 200 (2 block sizes), 225, 250 and 300. There is also a brand new "Series 2" 2nd generation V-Max, in 200, 225, 250 and 300 HP. It is interesting to see that Yamaha believes the "Offshore" market (25" and 30" engines) to be moving to all 4-stroke, and not attempting to compete with the Mercury Optimax and the 250/300XS offerings from Mercury racing. Where is badly needed E-tec "Generation 2", and true 250 and 300 HP models? Evinrude needs better fuel economy, acceleration and top end to compete with the Merc and Yam DFI ongoing Research and Development. Then there is Yamaha's considerable R & D on the new 350 V8, which, incidentally is now standand with Yamaha's own "Command Link" DTS. Another area of technology where Evinrude is seriously behind Merc, Yamaha and Suzuki. There may be, however, a vendor out there offering this technology they can buy it from, similar to what they do with the power trim units. |
andygere |
posted 09-24-2007 06:21 PM ET (US)
Larry, I was certain you'd come back with that. Note that none of the VMax motors are available in anything but 20" shafts, rendering them useless for just about anything but a bass boat. If Yamaha was really investing R&D dollars in this technology, surely they would be making it available across the product line. Just a year or so ago, you could get the HPDI in everything from 150 h.p., including 25 and 30 inch shaft lengths. What happened? Also note that the "Series 2 VMax" is pretty much the same as the previous generation, with minor tweaks to the fuel map and oil injection schedule. By the way, have you repowered Whale Lure with Verados or XS Optis? :) |
GSH |
posted 09-25-2007 02:30 AM ET (US)
John, One would have to say that at least for that one fisherman product branding really worked! L H G, a few thoughts that comes to me when reading your reply: The Yamaha F350 V8 sure must have been a big project, but in a way I think they were smart and managed to get some outside money for that one: the development of the Volvo 4.4 liter V8 used in the XC90 SUV. Base on tech specs the two engines does not seem all that different, for example: F350 vs. Volvo 4.4: Displacement: 325.3 ci (5 330 cc) vs. 296.4 (4 414 cc) I didn’t check, but I’m 99% sure both are 60 degree V8:s. The Volvo engine was, as you know, the first to come out. Some car magazines were very surprised that Volvo got the green light from Ford to buy the new V8 design form Yamaha, as Ford should not be that short on knowledge on who to design a modern V8 them slews. I think the key to the background is that Volvo got the design from Yamaha for a ‘special price’, as Yamaha saw how they could use some of the work for their outboard division. Synergies… The US bass boat market is huge, isn't it? It sure seems to me that’s what keeping HPDI alive. And as a result, we also get some V-Max HPDI:s over here, which is nice! -Seb PS |
fourdfish |
posted 09-25-2007 01:09 PM ET (US)
Larry-First you said that BRP should be spending a ton of money and do away with the older designed parts that are still some of the best designed midsections in the industry and now you are carelessly saying that the ETEC has to be redesigned for better "fuel economy, acceleration and top end" when you know that the ETEC already has better fuel economy, acceleration and top end according to your own often quoted B&B magazine tests! I guess YOUR MBA degree has left you with with something lacking! BRP is not the one laying off employees and they are doing well financially! Everyone knows that the large HP go fast engines are a small percentage of the market. Most here could care less about these engines. It was obvious that you failed to say anything about the Merc-Yamaha and Mariner connection when you knocked BRP for thier Suzuki/Johnson engines. Why would they be any different? As Andy, myself and others here have asked over and over! Just when are you going to stop talking about the engines you don't own and buy one! You have flapping about them for a long time now! |
L H G |
posted 09-25-2007 02:28 PM ET (US)
Fourdy needs to re-read his copies of Bass and Walley Boat DFI tests. This is old news. E-tecs came in last to Optimax and HPDI across the board. Fuel economy & acceleration was dismal compared to Merc and Yam. Mercury even used these tests for the basis of their "'RUDE AWAKENING" campaign. The difference between Mercury buying 75-115 4-stroke POWERHEADS from Yamaha, and Johnson having Suzuki paint them some white Suzuki 4-strokes, is that the Mercury purchase was a stop gap 2-way deal, where Merc developed and sold the 30-60HP 4-stroke powerheads to Yamaha (40-60 still being sold to Yamaha), while Yamaha developed the 75-115 powerheads to be sold to Merc. During this time MERCURY WAS BRINGING THEIR OWN 75-115's into development. Bombardier did no such thing, with no R & D spent for successor 4-strokes of their own once the 1-way Suzuki deal ended. A dead end, and let down and death blow for Johnson, whereas Mercury is alive and well in the 4-stroke business on a long term basis, and actually having jumped into the lead in 4-stroke engine technology. I understand a 350HP Verado L6 is just around the corner, a full 200# lighter than the Yamaha 350, and faster accelerating. Nor does Yamaha have any 275 or 300 HP 4-stroke offerings. I have also wondered if Mercury has any plans for a 3.4 liter Verado platform V-8. If so, that could be good for an easy 400 HP. None of this should mean that the Evinrudes aren't fine engines and give good service to those who own and like them. The few that I have actually seen out on the water all seem to performing just fine, and their owners rave about them. But there are some limitations, as all products have. No product is perfect for everyone. All the choices, pro and cons of each, are what keeps things lively around the internet! |
posted 09-25-2007 09:02 PM ET (US)
The "rude awakening" ground has been plowed up time and time again but it remains fallow; it bears no crop. |
JayR |
posted 09-26-2007 03:15 PM ET (US)
'nuff said! ;-) |
fourdfish |
posted 09-28-2007 06:45 PM ET (US)
Larry-You mentioned it first and are still rehashing the same posts word for word over and over again! It still does not answer the question why someone is pushing engines that he himself does not own and therefore has no real long time experience with them! Oh HUM! |
TexasWhaler |
posted 09-29-2007 04:32 PM ET (US)
LHG stated: "Fourdy needs to re-read his copies of Bass and Walley Boat DFI tests. This is old news. E-tecs came in last to Optimax and HPDI across the board." Simply not true. The Bass and Walleye Mag, 200 DFI shootout, declared the E-TEC 200 HO as the winner in top end speed. I couldn't resist one other thing...;-) I guess the same comparison could be made to the DFI technology currently being used. Yamaha and Evinrude developed, and produce their own DFI systems. This is an area that Merc must have been overwhelmed by, as they have had to rely on Orbital Systems of Autralia, to provide them with the DFI system they use. |
posted 09-29-2007 06:34 PM ET (US)
Regarding the trend for very high horsepower outboards, 250-HP and more, to be equipped with an electrically operated shift mechanism, it is quite ironic that this development is used as a means of criticism of Bombardier, the new owner of the OMC brands of Evinrude and Johnson. While I am not an outboard motor historian, I am fairly certain that OMC, Bombardier's predecessor, designed and produced outboard motors and stern drive units with electrically operated shift controls many years ago. |
DeeVee |
posted 09-30-2007 11:19 AM ET (US)
Jim, You are correct. I owned a 1971 Evinrude 100 for 15 years oowering my 1965 Sakonnet. It had the old Morse MT-1 to actuate the switch that shifted the gears. The system was designed so that if there was a power failure to the shift solenoid at the lower unit, the engine was in forward gear. It was a really nice smooth system. Virtually effortless shifts. Doug |
Peter |
posted 09-30-2007 12:25 PM ET (US)
The push button electric shifting, called "Selectric", was offered in the mid 1960s. It still had a mechanical throttle cable. You could get this feature in the Lark 40. |
andygere |
posted 09-30-2007 04:19 PM ET (US)
When I was a kid, we had a mahogany runabout with a 1968 Evinrude Lark 40 outboard with Selectric Shift. It worked well. I learned to operate powerboats on that little vessel. |
fourdfish |
posted 09-30-2007 05:41 PM ET (US)
I am just curious here but didn't Mercury go ahead and buy both the Orbital Systems Company and the company which produces their DTS systems in their engines |
posted 09-30-2007 07:32 PM ET (US)
Thanks for the confirmation. Outboard Marine Corporation (OMC) was producing electrically operated gear shift for outboard over 35 years ago. It sounds to me like Mercury and Yamaha are just catching up. |
L H G |
posted 10-02-2007 09:40 PM ET (US)
I think Peter may be on to something here. Desperate to compete with the excellent and hugely popular Merc DTS system, with no hope of catching up to Suzuki and Yamaha also, Evinrude could introduce (via an infomercial with French guys in G-strings, of course) the brand new "E-LARK", complete with the 1960's electric shifting push button "SELECTRIC" system and old fashioned mechanic throttle cable they are still using in 2008. Now that should be a hot seller, and would go along quite well with all of the other 70's and 80's components still being incorporated into the 2008 engines. It is a shame, however, to see that OMC let this brilliant invention lie dormant and unused for the last 40 years, with no new infusion of R & D money. You've got to wonder what management was thinking. Push button shifting is a brilliant idea and would set the new E-LARKS out ahead of the crowd of boring 4-strokes, Opti's and Vmax's. This could be the R & D break needed to succeed and bring sales out of 6th (last) place in the industry. |
posted 10-02-2007 11:39 PM ET (US)
I think the push button selectors are too dated. They remind me of a Chrysler LeBaron from the late 1950's. And with respect to Bombardier, wouldn't that have to be L'Alouette Quarante (Lark Forty) for a model name? But all joking aside, the shifting, even in a Verado with DTS, is still mechanical. There is an electric actuator connected to create the mechanical movement that accomplishes the shift. The new invention in the DTS is the digital control link. The electrical actuator is controlled by a digital system. But there is nothing special about that, either. What is special about DTS is the ability to install supervision or intelligence into the digital realm of the controls. This enables the rather nice shadow-control feature where two levers can control three engines. It also puts in safe guards about what speed ranges can be tolerated for shifting in and out of gear. And it can implement automatic synchronization. That part of DTS earns a tip of the hat, not the simple fact that it is electrical or digital. The fact that the Verado shifts smoothly really has nothing to do with DTS, either. That smoothness is another mechanical improvement. Mercury redesigned their gear cases to take that CLUNK out of them. You don't remove CLUNK with electronics; you fix it with better gears and clutches. The Bombardier E-TEC shifts as smoothly as a DTS Verado. It just does not do it electrically nor does it have a digital control system which can be taught how to run triple or quadruple engines in synch and keep an eye on them when shifting. |
L H G |
posted 10-03-2007 01:25 AM ET (US)
No it doesn't, Jim. Put a Rev 4 prop on an e-tec and it clunks like hell. Put it on an L6 Verado, smooth as silk. Big block Optimax's also shift smoothly with Rev-4's. |
XStech |
posted 10-03-2007 08:26 AM ET (US)
fourdfish posted 09-30-2007 05:41 PM ET (US) -------------------------------------------------------------------------------- I am just curious here but didn't Mercury go ahead and buy both the Orbital Systems Company and the company which produces their DTS systems in their engines ---- No, Merc never bought Orbital. No, DTS was developed inhouse with MOTOTRON, a group within Mercury. |
fourdfish |
posted 10-03-2007 10:21 AM ET (US)
Larry-How can you possibly say how a Rev 4 prop acts on an ETEC. This is your opinion without any experience or some dock talk again! |
L H G |
posted 10-08-2007 01:38 PM ET (US)
Fourdy - If you try a Mercury Revolution-4 prop on your engine, you'll see what I mean. At idle and salmon trolling speeds, it will shake, rattle and roll, and really get some good harmonics going on that Crestliner. |
andygere |
posted 10-08-2007 05:03 PM ET (US)
Gee, maybe the problem is with the design of the Rev 4 prop. For all the hype about this prop, I wasn't impressed with it. |
fourdfish |
posted 10-08-2007 07:48 PM ET (US)
Larry, That is just another example of you saying something that you cannot backup! No evidence again. Andy is correct, you might be actually trying to say that the prop just doesn't stack up! BTW, Your company owns Crestliner or didn't you know that either! I'm sure our family's Whaler is older than yours! |
posted 10-08-2007 08:29 PM ET (US)
I have tried a Mercury REVOLUTION4 propeller. It does make one helluva clunk when shifted, which I believe is mainly due to the FLO-TORQ II hub and the extraordinary weight of the REVOLUTION4 propeller. A REVOLUTION4 has a very large mass. Whenever the gear case is shifted into gear from neutral and the propeller is not rotating, you get a very big CLUNK from my OMC gear case. On the other hand, other propellers I have used have literally NO CLUNK when shifted, which I believe is due to their lighter weight and better mounting using a rubber cushioned hub. One of the sources of the additional weight of the REVOLUTION4 is the hub snout or extension. As compared to any of the other dozen or so propellers I have tried, the REVOLUTION4 has a very long extension of the hub aft beyond the blades. This portion of the propeller is not really subject to any stress--at least as far as I can see--but on the REVOLUTION4 this part of the hub is made from the same thick stainless steel that anchors the base of the blades. It has to add two or three pounds to the weight of the propeller. I think you could manufacture a propeller with blade shape and size similar to the REVOLUTION4 and cut the weight down quite a bit. Mercury seems to have recognized that some of their propellers need some help and have made improvements to the FLO-TORQ mounting system which helps to reduce the CLUNK. The FLO-TORQ IV hub is an improvement, but it is expensive (about three times the cost) and is only made for Mercury propeller shafts. Ironically, I just spent three days underway with a Mercury propeller and a FLO-TORQ II hub on my OMC gear case. The propeller was a three-blade MIRAGEplus, which weighs quite a bit less than the four-blade REVOLUTION4, But even with the lighter weight, the Mercury MIRAGEplus makes quite a clunk when shifting. In contrast, there is no clunk when using an OMC SST propeller of similar size and weight. I attribute the difference to the rubber cushioned hub, which makes for smoother shifts than the FLO-TORQ II. The shape of the blades ought to be independent of the weight and hub configuration, and therefore you ought to be able to get the same propeller performance without the CLUNK if more refinement in the propeller design was undertaken. |
fourdfish |
posted 10-09-2007 09:21 AM ET (US)
It seems to me from previous posts that the Mercury owners also complained of the clunk from these props. If so it would not matter on which engine you used them. |
Peter |
posted 10-09-2007 10:09 AM ET (US)
I also think that part of the reasons that the Mirage and Rev 4 propellers have a reputation for "clunkiness" is due to the stainless steel alloy material used and the thickness of the blades. If you rap your fingernails against a blade of a Rev 4 or Mirage propeller, the propellers resonate almost with an almost bell-like ring. Do the same on a Viper or SST propeller and you'll get a very different sound. I will come to the defense of the Rev 4 propeller, at least for use with twin outboards. It definitely carries a heavy boat like the 27 Whaler WD well with little blow out in rough seas. It's very different than the Mirage Plus which I have now found on two different Whalers, the 27 WD and now the 18 Outrage to be exact, to be just an absolutely lousy rough water propeller. |
