| Author | Topic: Effect of Gear Ratio On Selection of Outboard Motor |
| mikejoyce77 |
[The author is] looking for some advice on gear ratio for outboard motors. [I] notice that every manufacturer has a different gear ratio. [W]hat exactly does this mean? [I]s [the gear ratio of an outboard motor] important to consider when buying an outboard? [I]s a higher gear ratio better then a lower gear ratio setup? |
| contender |
Not sure how outboards work but I assume its the same as a rear end ratio in an auto, Say the gear is a 5:13 this means the engine will turn high rpms very quickly and makes the car jump out of the starting block, but does not have good top end performance (Also for pulling if the engine has plenty of torque) Say the gear is a 2:73 this is a high speed gear the engine does not turn a lot of revolutions better performance at high speeds, but has no power out of the hole and no torque for pulling anything. If you want top speed go for the smaller numbers, if you are looking for water skiing you may want a mid range gear, and if you plan to work for tow USA you would want a large gear...good luck |
The gear ratio is usually expressed as the ratio of crankcase revolutions to propeller shaft revolutions. I don't think the gear ratio is really a significant factor in choosing an outboard motor. The analogy to automobile rear axle ratios is not a good comparison. Outboard motors can be fitted with propellers of varying diameter and pitch in order to accomplish adjustment of the power and speed range desired to match with the load. |
| glen e |
A lot of big bore [Suzuki] owners would disgree with you Jim. Many chose [Suzuki] as gearing was part of their buying decision. [Suzuki] runs large gear ratios on most their over-150-HP stuff so they can get better hole shot turning a bigger wheel. I'm sure Tom Clark can elabaorate. |
| Peter |
Gear ratio is an important factor in selecting an outboard IF, and ONLY IF, you are trying to make a decision between an ordinary outboard and a HIGH THRUST version of the same outboard. For example, Yamaha makes two versions of its 60 HP 4-stroke, one has a gear ratio of 1.85:1 (1.85 flywheel revolutions : 1 propeller revolution) and the other, a HIGH THRUST version, has a gear ratio of 2.33:1. Going from 1.85:1 to 2.33:1 is like shifting into a "granny gear". The gearcase on the HIGH THRUST version is larger than the gearcase on the regular version. The larger gearcase enables the use of a larger diameter propeller (13 inches versus 11 inches) which provides more blade surface area and the ability to produce more thrust at low engine speeds. However, because a larger diameter propeller is more resistant to twisting in the water due to its larger blades, it is harder for the powerhead to turn the propeller. Thus, to help the powerhead overcome that resistance, the gear ratio is increased to provide greater mechanical advantage. The downside of the larger gearcase is that it produces more drag at speed. If your end application is a pontoon boat, then a HIGH THRUST version of a motor, if offered, with its higher gear ratio is the better choice. If your end application is a classic 15 Whaler, for example, then the version of the same motor with the smaller gearcase and lower gear ratio is the better choice. The larger gearcase, higher gear ratio HIGH THRUST version will also work pretty well with the classic 15 Whaler but the smaller gearcase, lower gear ratio, regular version might not work so well with the pontoon boat. |
| Peter |
I meant to also add that the HIGH THRUST version is less likely to cavitate and thus better able to maintain "traction" during close quarter manuevers because the propeller is turning slower for a given powerhead RPM. |
| bigjohn1 |
Mike, there is not really an easy one-size-fits-all answer to your question. I feel that lower gearing in a four stroke can be a big plus, and this seems to be supported by Suzuki making engines with lower gearing than many competitors. Through trial and error in propping a mid-range 4-stroke, I have found lower gearing allows you to take advantage of many more prop choices. |
| Tom W Clark |
Mike, John gives the most accurate answer: It depends. It is not as simple as a higher or lower gear ratio being better or worse. The gear ratio works in conjunction with the propeller to convert powerhead energy to forward propulsion. Different manufactures take different courses with the gear ratios they choose for their motors. Even within a given manufacture's line of motors, the gear ratios are not all the same. Gear ratio is usually expressed by the number of revolutions of the power head for one revolution of the propeller. Thus a motor with the common 2:1 gear ration will have its crankshaft spin twice for one full revolution of the prop. As a general rule, lower gear ratios (higher numeric value) are used with larger propellers. But this "rule" breaks down fairly quickly once starts to examine all the offerings from different manufactures. I have found that usually a manufacturer will use higher and higher gear ratios as the horsepower increases. Thus we may see that a manufacturer installs a 2:1 gear ratio lower unit on their 150 HP models, a 1.86:1 gear ratio lower unit on their 200 HP models and a 1.75:1 gear ratio on their 250 HP models. The motors used in my example are all V-6 outboards using the same physical size of lower unit and thus the same range of propeller diameters. The propellers uses 150 HP motors are typically the same as used on the much higher HP models, motors as powerful as 275 HP. In order for those higher horsepower motors to deliver that power to the water with the sam range of props, the propeller simply has to spin faster, thus the higher gear ratio (lower numeric value.) It is certainly NOT the case (as Peter asserts) that gear ratio is not important unless you are looking at a high thrust application. Lower unit gear ratios are not just for high thrust motors as evidenced by Suzuki's use of geared down lower units tuning larger diameter propellers. Suzuki outboards are not just for pontoon boats, yet they have gear ratios as low as 2.5:1 or even lower. It is not even true that that motor models designed expressly as "High Thrust" are only to be used on Pontoon boats or other high weight, low speed craft. Sometimes the lower gearing and larger propellers are better for small light weight craft that are quite fast. The 15 foot Whalers made by Boston Whaler are perfect examples of this phenomena. Whaler equips some of their models with the Mercury "BigFoot" 60 HP outboards instead of the smaller gearcase versions precisely because the boat performs better, plan and simple. This, in spite of the fact the BigFoot models were originally designed with the pontoon boat market in mind, not light weight skiffs. The same will hold true of the Yamaha High Thrust models if one were contemplating buying one for a small Whaler. I think the point Jim was trying to make was that if you are looking at a motor for your boat, you do not get a choice of optional gear ratios for a particular motor and thus you should concern yourself with the motor and not the gear ratio. But even this is not always true as evidenced by the Mercury BigFoot/Yamaha High Thrust example given above. Certainly if one were considering repowering a boat one might look at the Suzuki outboard line precisely because they are using a novel approach of lower gear ratios and larger propellers and are dong so with great success. So much success in fact, that I suspect as the years go by more and more manufacturers will be adopting lower gear ratios for higher horsepower outboard motors. Of course every lower unit an its gear ratio only works at all because it is spinning a propeller and here are LOTS of different propellers out there. Propeller design and selection is a VERY broad topic an one best visited in another discussion. |
| Peter |
Tom -- I think you need to go back and reread my comments. I never said that HIGH THRUST models are ONLY to be used on Pontoon boats and the like. Given that a new Whaler 150 Sport weighs in at a portly 900 lbs dry with no motor (compare that to the classic 15s 550 lbs) it's not a pontoon boat by any means but its not lightweight skiff. With a wider beam it's also got more hull to push through the water than the classic 15 does. The evidence on CW seems fairly clear that the Yamaha F60 (small gearcase) performs better on a lightweight 15 Classic than the Yamaha F60 HIGH THRUST. I will say again that gearcase ratio is basically irrelevant when choosing among different outboard motor brands of equal HP. The gearcase ratios are chosen by the manufacturers to optimize the peformance of their powerheads throughout the operating range (idle to WOT). If you are selecting a brand of motor based on gearcase ratios, there is a potential to make a big mistake. Selection of a motor brand should be based on the adequacy of after-sale support, not gearcase ratios. I've never, ever heard anybody say, "Damn, I wish I had bought the Suzuki because it has a 2.5:1 gear ratio and I could have run 16 inch diameter propellers." But what I often hear is "Damn, I have to drive 2 or 3 hours to the nearest Suzuki dealer to get my motor serviced. I should have bought the other brand whose good service is just 2 miles down the road". |
| itl |
I think the idea behind low gear ratio is torque. Say we have a powerhead which can prodeuce X amount of torque and we have two gearcases, other one is 2:1 and other one is 1.5:1 ratio. Now, with same powerhead the 2:1 gearcase the propsaft give 2X torque and with 1.5:1 gearcase it produces 1.5X torque. So 1.5:1 gearcase produce 25% less propsaft torque than 2:1 gear. However, we must remember that low gear ratio usually means high propeller pitch and high pitch require high torque to be able to spin and vice versa. Not so simple. |
Re propeller and gear ratios--it is a cart and horse relationship. Now which came first? Hmm--a mixed metaphor. Forgive me, it is late in the evening. What I am trying to say is that the reason for engine gear ratios to have relatively minor differences as horsepower varies is to better suit the engines to series of propellers. Each manufacturer makes a line of propellers in various pitch increments. My feeling is--sorry I don't have much science to back this up--that by making a few gear ratio changes among the various engines the engines can be matched up this standard line of propellers. The alternative situation would be one where all engines used the same gear ratio--let's say 1:1--and then there would have to be a wider range of propellers available. The reason a 19-inch propeller can be used on a 18-foot boat with a 150-HP motor and also on a 22-foot boat with a 225-HP motor is probably related to the fact that those motors have different gear ratios--or at least I hope they do! |
| Peter |
"The reason a 19-inch propeller can be used on a 18-foot boat with a 150-HP motor and also on a 22-foot boat with a 225-HP motor is probably related to the fact that those motors have different gear ratios--or at least I hope they do!" -- JimH All depends on the motor manufacturer. Johnson/Evinrude have been using 1.85:1 gear ratios on their 150 through 250 HP motors forever, for example. Yamaha uses a 2:1 ratio on its 150 through 250 HP 4-strokes. On the other hand, Honda and Suzuki and Mercury use different ratios on their 150 HP 4-stroke models versus their 225 4-strokes. |
| Tom W Clark |
Jim, Yes, I think you are right and that is the point I was trying to make in my sixth paragraph above. A great deal of time and money is spent developing propeller designs and producing them. While all propeller lines come in different pitches, the range is not infinite so if a higher horsepower motor is to turn the same propeller as a lower horsepower motor and go faster, then it must spin it a greater number of times per distance travelled. |
| Tom W Clark |
"If you are selecting a brand of motor based on gearcase ratios, there is a potential to make a big mistake. Selection of a motor brand should be based on the adequacy of after-sale support, not gearcase ratios." Come on, I don't think anybody selects an outboard based on the gear ratio alone, but it is not something you just ignore either. While I agree that it is good to receive support after the sale, that is not the sole factor in deciding what motor to buy either. No single parameter is. You don't buy a motor because it is the fastest in one test, or because it is painted black or because it uses a certain kind of oil, but all of these things together certainly should be weighed in the decision making process. |
| Peter |
I've bought alot of outboards over the year and have never, ever considered gear ratio as factor in outboard motor selection. I take whatever the manufacturer offers. The very high ratio is a Suzuki sales pitch attempt to differentiate its product. I have many friends who have bought a fair number of outboard motors over the years and I can vouch that none of them have ever chosen an outboard based on gear ratio. The proposition that a high gear ratio universally permits the use of a larger diameter propeller is unfounded. Take for example, an 18 Outrage with equipped with a conventional 2-stroke Johnson 150 with a 1.85:1 gear ratio versus one equipped with a Suzuki DF 150 and a 2.50:1 gear ratio. Assume that 18 Outrage can go 45 MPH with a 150 and 6 percent slip. Propeller calculator suggests using a 17 inch pitch for the Johnson and a 21 inch pitch for the Suzuki. The propeller calculator results are consistent with my own experience with my current 18 Outrage/Johnson 150 for it is rightly equipped with a Mercury Mirage Plus 17. Now, according to the propeller offerings by Suzuki, the largest diameter propeller they have for the DF 150 is a 15 1/2 inch. That diameter is no larger than the diameter of the Mirage propeller that I use now with a motor having a 1.85:1 ratio and the Suzuki can't use Suzuki's 15 1/2 x 17 inch pitch propeller for the 18 Outrage application because the pitch is too low. For the 21 inch Suzuki propeller, the diameter shrinks down to 15 inches. So much for so called low ratio large diameter advantage.
| Peter |
Sorry that should be "high ratio, large diameter advantage". |
| Tohsgib |
Being I have owned a few Suzukis I will pitch in. The higher gears allow to spin a larger prop which has already been discussed. The main benefit I see with this is it allows for a better cruise, which is where we usually run. The other thing is when you have say a 1.86 ratio going from a 17-19" pitch makes a HUGE difference and sometimes you eally want an 18" which would have to be custom made. The difference between a 20 and a 22" on a 2.59 ratio is a lot less drastic. The 2" does not really move you 400 rpm like on conventional gear ratios and allows you to "dial" in your engine more accurately. I was kinda turned off by the excessive gear ratios Suzuki uses at first but ow I understan it better and it definately works. |
| Wild Turkey |
I know Suzuki has been promoting the higher ratio gearboxes for their outboard motors. Doesn't a higer gear ratio mean lower efficiency for the gear box? I think the higher ratio would rob power from the overall outboard system. The power lost doesn't seem to be discussed in relation to higher gear ratios. |
| Tom W Clark |
"The very high ratio is a Suzuki sales pitch attempt to differentiate its product." Come on Peter, now I know you're teasing us. You don't seriously think gear ratio is irrelevant? Sales pitch? As if the engineers at Suzuki told the marketing department: "...oh you guys pick a pretty number and we'll build the gear case with that gear ratio." hahahahahahahahaha! I think a motor's gear ratio is a little more than merely cosmetic. It is, in fact, more significant than the color of paint used. It is simple physics. Lower gearing allows larger propellers to be used. While you may be able to run a MIRAGEplus on a Johnson 150, you certainly cannot run a 16-1/2" diameter Suzuki prop on that same motor. If you try, you are going to have a badly mangled gearcase, prop or both. Wild Turkey, No, lower gearing does not mean lower efficiency. Lower gearing simply means slower rotational speed with greater torque. |
| elaelap |
When I repowered my first Whaler, a smirkless Katama 16, the dealer talked me into a Yamaha 50 High Thrust, and I couldn't have been any happier. That rig had no top end to speak of (barely 30 mph/6000 rpm/WOT)--for reasons described above--but it jumped up onto plane almost instantly, maintained plane at low speeds in lumpy seas, trolled at very low speeds, and made that little Whaler very responsive when the wind and seas kicked up a little. The boat felt powerful, at moderate speeds anyway, even though many here felt it was 'underpowered.' It was a perfect combination for my uses (fishing, mostly alone or with one other person) in the ocean north of San Francisco. I put something like 360 hours on that motor in a year and a half, and CW member Steve/17 Bodega, who has owned the boat since I sold it, has put at least twice that many hours on it since then...no problems for either of us. If/when I buy another 16/17 I'll probably repower with something similar, maybe a 60 next time...and I'll certainly consider the Big Foot/High Thrust gearing for any small Whaler if top end isn't important (which it isn't for my current uses). Tony |
| Peter |
Tom -- I think you're teasing us with Suzuki's gearcase ratio marketing speak. What do you mean "Lower gearing allows larger propellers to be used?" By the way, I never meant that the engineers told the marketing folks to pick a gear ratio. Rather, the marketeers seem to have put a nice spin on the high (or low, depending on how your are looking at it) ratio used by the engineers. |
| glen e |
been on many 250/300 zuke boats - they spin bigger wheels - Tom is correct...and as the new Yam 350 and the zuke 300 get bigger wheels made for them, gearing/displacement becomes a great equalizer to supercharging 4 strokes.... |
| L H G |
Mercury says within a given propeller line/design, prop efficiency INCREASES as pitch INCREASES. This is why you want a lower gear ratio (higher numerically) for a given HP range. You can run a more efficient prop, get more economy and better speed. The gear ratio on your outboard IS important. Suzuki knows what they are doing, and their sales show it. I have been blasted for this before by the Evinrude people, but I will say it again. In the 75 and 90 HP range, the Evinrudes have the LEAST desireable gear ratio of 2.0. All other brands have better, lower (higher numerically) ratios, mostly around 2.33. Evinrude's 2.0 gear ratio forces E-tec 90 owners to run very low pitch props, 13, 15 or 17's, and is too high for a 75 or 90 HP 3 cylinder engine. Mercury last used a 2.0 gear ratio on the 1988 in-line 6, a high torque engine, but lowered it to 2.33 when the new 3 cylinder 90's came out, so they could turn more efficient, higher pitch props like the Laser II's. This shows in the engine's top perfromance among 90's, and is also showing in the new Verado block 90 EFI's, a hot performer according to Boston Whaler. OMC also used the high 2.0 ratio for it's V-4's, propably a good decision, but this engine also is more powerful than the 3 cylinder E-tec 90. In short, BRP should spend some R&D and give the E-tec 75 and 90's a better ratio gear case, rather than using the old leftover case from the 80's. Currently Mercury correctly uses the 2.0 gearcase on the 135 Optimax, and earlier 2.0 liter 135/150's, V6 engines a LOT more powerful than the E-tec 75 or 90. The high performance 4 cylinder Verados, 135-200HP even have a brand new 2.08 ratio gearbox. This has got to tell you something. The small E-tecs, no more powerfrul than the Optimax 75 and 90 with 2.33 ratios, are badly handicapped by this high gear ratio, and forced to run low pitch, non-performance oriented props because of it. The inefficient props show up in decreased economy and less top end. It is also a good reason not to underpower a boat. You are forced to run lower efficiency, low pitch props. |
If higher pitch is better, then why don't outboard have gear ratios of 4:1 and turn 36-inch pitch propellers? Could we have a cite to where Mercury says that higher pitch is more efficient? My understanding is that efficiency comes from the choice of the angle of attack of the blades. The angle of attack come from two factors: the speed of advance and the actual angle of the blades. Therefore, a propeller of any particular pitch can be made efficient if it is designed for a certain speed range. You can see this in the performance of propellers like the MIRAGEplus. They run more efficiently at speeds of 30-MPH than they do at 40-MPH. That's because they were designed that way. The angle of attach was optimized for that speed range. Performance results of some boats may be misleading because when really high speeds are reached, the hull of the boat is hardly in the water. This changes the "hull factor" and most of the drag resistance comes from the outboard gear case, not from the hull. So at really high speeds, a boat may seem to be running more efficiently, but I don't think it comes from the propeller pitch. It comes because there isn't any hull left in the water. |
| Tom W Clark |
Oh brother, what a mess. Do you guys really want to have a theoretical discussion about propeller design here in a thread about gear ratios? I think we would all be well served by saving that discussion for another thread. "The very high ratio is a Suzuki sales pitch attempt to differentiate its product." Peter, those are your words, not mine and they are simply false. Glen makes a good point about Yamaha's new 350 HP and 300 HP V-8s. They will use new propeller castings that are larger than any current V-6 propeller offerings. Bigger power, bigger propellers. We will see more of this in the future. Larry you ol' FUD-miester you. I won't even bother deconstructing your mish-mash of misinforamtion but I will echo what Jim has already pointed out: If higher pith props were simply better, everybody would be using lower gears and higher pitched props. All the different factors that affect an outboard's performance can be (and are) varied for one manufacturer to another and from on model to another. Often the differences are subtle. A little more displacement here, lower gearing there, and sometimes the differences are more profound. Supercharged four stroke in this camp, simple DFI in that camp. But no matter what choices are made by the engineers, today's modern outboards are all wonderful power plants for our boats. What is best for you will depend on your needs and resources. If it were all as simple as "this way is the best", or "that strategy is proven to be more efficient", we would all be running the same outboard, with the same gearing and the same propeller. |
| L H G |
It really annoys me that you self appointed prop experts really don't know what you're talking about. I suggest you read up a little on prop efficiency, if you can even understand the concept and mathematics, before implying I am some sort of buffoon. |
| Tom W Clark |
Larry, you don't need our help, you do a fine job of that yourself. Now instead of simply pointing to some web resource elsewhere, why don't you explain to us in simple terms why propeller higher pitch means greater efficiency. And while you at it, please define "efficiency" as it is used in this thread. Feel free to use all the math you like. |
| Perry |
I have noticed several larger boats powered by single Suzuki outboards. One in particular is a classic 25 Outrage with a DF300. I'm sure this boat as well as other similarly powered boats benifit from an outboard with lower gearing becuse it enables them to run a larger diameter prop. A 16" diameter prop will definately help get a large heavy boat up on plane and stay on plane. |
Mercury says (at the cited link above): ..."all the characteristics of a propeller--diameter, pitch, number of blades, rake, even slip--may affect efficiency..." "...efficiency peaks at approximately 80% (3-degree to 4-degree angle of attack) and begins to decline as the angle of attack increases beyond the optimum..." and then concludes with: "If all other variables remain unchanged, propeller efficiency increases as the pitch/diameter ratio increases." These three statements support the points made by Tom, Me, and Larry, respectively. But I don't think they lead directly to some of the conclusions presented. For example, I really doubt that after being in the business of manufacturing outboard motors for over 70 years that Evinrude would have not figured out something as simple as changing their gear ratio would instantly make their motors perform better. |
Perry--Good point about the diameter of the propeller tending to increase in these motors where there is a high (numeric) gear ratio. In almost all of these cases the motors with the high (numeric) gear ratio are set up to use larger diameter propellers. The larger diameter propeller allows for more blade area. More blade area is generally needed to transmit more power from the engine to the propeller thrust. |
| Peter |
Tom -- You still haven't answered my simple question. What do you (and Suzuki) mean by "Lower gearing allows larger propellers to be used?" |
| itl |
"Lower gearing allows larger propellers to be used?" As far as I know: Lower gearing = more propsaft torque. Large prop need more torque than smaller prop. Simple as that. |
| Tom W Clark |
Ilkka explains it well. |
| Peter |
OK. But what is considered a "large prop"? |
| Peter |
None of the resident propeller experts wants to step in with an answer to the simple question? OK let me see if I can help move this along. Is a propeller with a diameter of 15 1/2 inches and a 22 inch pitch (15 1/2 x 22) a large or small propeller? What about 15 1/4 x 18, large or small? What about 14 3/4 x 23, large or small? |
Peter--I am surprised at this question. Whenever there is a comparative adjective used in this discussion, the reference point is whatever OMC does. The direction arrow points toward whatever Mercury does. And the comparative is always in the positive. For example: if OMC uses a 2:1 gear ratio and Mecury uses a 2.33:1 gear ratio, then the Mercury is "higher" and "better." If OMC uses a 14.5-inch propeller and Mercury uses a 15-inch propeller, then the Mercury is "larger" and "better." If you just apply this general rule you will be able to make all of the proper distinctions. |
| glen e |
big zukes run 16 inch diameter props...that's classed as big....and the Yam 350/400 will get bigger than that soon... |
| Tom W Clark |
Peter, What is your question? |
| Peter |
My question is actually quite simple. I'll repeat it again: what is a larger prop? The reason I ask this is that Suzuki's marketeers (and Tom you've apparently gone along with this) have set forth the proposition that their 2.50:1 gear ratio of their DF 150 is an advantage versus Honda BF 150's 2.14:1 or the Verado 150's 2.08:1 or Yamaha F150's 2.00:1 (for whatever reasons they don't touch the Evinrude E-TEC's 1.85:1 ratio or the Mercury Optimax's 1.87:1 ratio.) In touting their high ratio, they say "lower gear ratio to swing a larger prop for improved acceleration." I simply want to understand what is considered to be a larger prop in the context of the DF 150 and its competition. We'll leave the bigger V6 Suzukis and the 800 lb Yamaha gorilla for a later discussion. |
| itl |
This is my opinion of the prop size (diameter) in the context of the 150hp four stroke engines: Large = more than 15" Suzuki DF150 can spin as large as 16" diameter prop. I think that this size of propeller is a huge in this context. |
| Lil Whaler Lover |
This is quite a thread. Some valuable information and some relatively bogus stuff. First off, NO lower unit or propeller produces torque (or horsepower). The engine produces 100% of the torque (HP). The gear ratio combined with the propeller converts the torque (or HP) to THRUST in order to move the boat. To either clear up (or further muddy the waters), I will refer to the relative effectiveness of the thrust as TRACTION. As has been said, a larger diameter prop will (generally) have more blade area and should provide better traction. The larger blade area shuld have less slippage and move a heavier load better. One down side of the larger diameter prop is more hydrodynamic drag which should result in limiting top speed. This backs up LHG's observations in this thread and others that Mercury outboards tend to have a closer gear ratio and provide a higher top speed for the same HP. All of this is further compounded by the torque curve and horsepower curve of the motor itself. To back this up I will give a real life experience. In the fall of 1983, I purchased a (please forgive me) Baylinner 1900 OB with a 125 HP Force and 19 " pitch aluminum prop.. With the factory set up it ran 42 mph, took about 5 seconds to plane at 20 mph with just me in the boat. After adding an elevated ski pylon we tried pulling slalom skiers. I could just barely get an experienced slalom skier up in deep water on one ski. When I hit the throttle the engine would peak at 2800 rpm and struggle to get to 3500 rpm. At 3500 rpm it hit its torque curve and ran strongly. I picked up a 15" SS progressive pitch prop from Soderburg (sp?) in Duluth Minnesota. With this prop I hit 3600 rpm on the hole shot. I could get a pair of 200 pound slalom skiers up in deep water with no drag and the time to 20 mph was about 1.8 seconds. Interestingly top speed went up 7 mph! A basically crappy motor now ran well by getting it into its torque/power curve with a prop that cost well over $00 in 1984. A Boston Whaler comparison of gear ratios and lower unit sizes is my current 1988 15' Center Console. I git it used with its original 1988 70 HP Mercury, and a 22" Laser 2 prop. This ran well, 43 mph GPS, but with the large lower unit 2.33 gear ratio and about 13.5" diameter was almost impossible to steer at speed. I had to alter the power trim to change directions. This very light hull was totally overpowered by the torque, the large lower unit (relative to the boat) and a propeller that gave tremendous traction. Also the weight of this motor, over 300 pounds with SS prop was too much. The 15' CC now has a Yamaha F-60 with a 1.85 gear ratio, a 11' x 15" pitch Solas SS prop. It runs 42 MPH, and can be steered with one finger at any speed. Getting a much smaller lower unit in the water vastly improved the performance of this hull. Back to the question at hand, gear ratio does not matter without a proper set-up and correct prop to get the best possible traction matching the torque/power curve for the motor. If this is done with a larger propeller blade area, it should result in a slightly better ability to move a heavy load. However it is far more propeller dependent than gear ratio dependent. Dave |
| RTM |
Maybe Ron Hill can straighten this mess out. Rich |
| Tom W Clark |
Dave, I don't think anybody thinks the propeller itself if producing the power; we know what the powerhead does. When we talk about torque we are referring to the torque at the propeller shaft because that is where it is relevant to the propeller chosen. Where the power is produced is neither here nor there to this discussion. One important factor in the case of your 15 footer that you failed to mention is the smaller gearcase itself will offer less drag and thus contributes to greater top speed of the boat. |
| Tom W Clark |
Peter, I'm glad to see you are trying to make a point. I have always found your reasoning (for the most part) sound and logical. If you are trying to support a position, I invite you to articulate it instead of playing twenty questions. You have now asked three questions. I'll start with the easy one first: "...what is considered a 'large prop'?" This is considered a large prop: Then there is the different question: "... what is a larger prop?" Well, larger is relative. Larger can be looked at different ways and not just by diameter. Weight, blade area, pitch are all factors that are relevant to a propeller's size. Let me offer some examples: A BRP 14-3/4" x 19 SST is a larger prop that a 14-3/4" x 17" SST. The greater pitch will require more torque to spin it to the same RPM. A 14-5/8" x 19" Mercury Revolution 4 is a larger prop than a 15-1/4" x19" Mercury MIRAGEplus even though the diameter of the Rev 4 is smaller. Heavier weight, larger blade area, more aggressive grip all requiring more torque to spin it to the same RPM as the MIRAGEplus. A 14" x 18" Stiletto Advantage I for Suzuki is a larger prop than a 13-1/4" x 19" Advantage I for OMC/BRP. Even though the propeller design (blade geometry) is the same, the propeller with the lesser pitch is still the larger propeller because of it larger diameter and increased blade area. It is not a coincidence that this larger propeller is made for the Sukuzi outboard. A Suzuki 16" x 17" stainless steel three blade is a larger propeller than a 15-1/4" x 17" MIRAGEplus. The latter you may fit to your Johnson 150; the former will NOT fit your Johnson 150...because it is too large. Then you ask: What do mean by "[i]Lower gearing allows larger propellers to be used?" Well, that is obvious and has been answered twice. Lower gearing means higher torque. Simple physics. With higher torque a larger propeller may be used. Now to the heart of what I suspect is your argument. [Feel free to jump in here and articulate your own thoughts. It would probably be better than playing a game of of laying clues for the rest of us to try to piece together.] Gear ratio is irrelevant to the ultimate performance of an outboard motor. The gear ratio is merely cosmetic and has nothing to do with the size of propeller used. In the case of Suzuki, their choice of relatively low gear ratios for their motors is merely marketing hype. I am in disagreement with that argument. It is illogical and defies simple physics. The gear ratio is relevant, lower gearing allows larger propellers to be used. As to whether this lower gearing is an advantage or not, that can be debated. You will note that I never said that it was an advantage just that it is very relevant and should be considered,ot dismissed. Certainly the evidence clearly suggests that Suzuki's unique gearing is an advantage in many cases. Outboard manufacturers will always tout their technology as being superior and use examples to prove their point. This is nothing new. The truth is often found somewhere in between and will vary from one situation to another. Shall I argue that Evinrude's E-Tec DFI technology is of no advantage? It is merely a marketing ploy to make consumers think their product is better? Did the marketing guys at Mercury say to the engineers: "Hey! Pocket protector, slap a Supercharger on that puppy, consumers will dig the sound of Supercharger!" I think more of Suzuki and the choices they have made for their motors. If you want to argue about the performance of the Suzuki outboards and the merits of the gear ratios chosen for them, that is a good topic for another thread. If you want to demonstrate that gear ratio is irrelelvent please support your argument with some data. |
| cooper1958nc |
Why to big boats run reduction gears? Not to ensure they can run props of a given *pitch* but to ensure they can turn props of sufficient *diameter*. Propeller diameter influences the volume of the water column discharged. Pitch influences the speed of discharge. Newton's Third Law states that the reaction force is equal and opposite to the primary force. The primary force results from momentum change of the water column. Momentum is speed times mass. Higher mass means equal momentum change with less speed change. Kinetic energy, unlike momentum, is equal to the square of the speed times the mass. That means it requires more energy to accelerate a small volume of water to higher speed than a big volume of water to lower speed. For the same energy expended, you can get more momentum change by going to a large volume of water accelerated less. High diameter does exactly that. Why not have 50" diameter props on outboards? Realistic limits on lower unit size. Big direct drive boats commonly run as large a diameter prop as will fit within the space. (When it is necessary to trade off other things to run a really big diameter prop, you have a tug boat.) |
| glen e |
Wow! you guys are fun to read...as a simple college grad with a Lib arts degree and been in sales all my life, you guys lose me with all this engineering/physics stuff...I'm sure you are right....but..all I know is what I feel and experience...my neighbor has DF 250's spinning a 16 inch 4 blade and my boat was spinning a smaller rev 4 w/ V 250's - both got great hole shot...TO ME, the supercharger got me there and he got there with bigger props and displacment....to each his own.... |
Regarding propeller design and selection, there is a great book on this topic by Dave Gerr, PROPELLER HANDBOOK. It is quite readable and provides a strong mathematical basis for most of the conclusions and assertions it presents, without going too far into the arcane or the complex. It is possible to read this handbook and locate particular sentences, which, if taken out of context, could be used to support claims that a certain characteristic of a propeller is preferred or optimized over others. However, I don't believe that propeller selection is that simple, for if it were it would not be necessary for Mercury to make over 700 different propellers in a dozen or more styles. The existence of thousands of competing propeller designs might be seen as prima facie evidence that there is no single design which is optimum. Engines have different gear ratios because, among other things, they have different sizes of gear cases. The gear case and the arrangement of the propeller aperture limit the diameter of the propeller which can be used. From what I can tell, an engine manufacturer chooses a gear reduction ratio which he feels will give the best range of performance for the propellers which will fit on the gear case and operate in the aperture, and which the motor will also have enough power to turn. The innovation of the Suzuki motors has been to enlarge the propeller aperture to permit propellers of larger diameter to be used. Generally the largest propellers were limited to about 15-3/4-inch diameter by the aperture of most other motors. Suzuki has apparently enlarged the aperture on their higher power engines and can use propellers of larger diameter, including ones 16-inches or more in diameter. It seems well correlated that the gear ratio of a Suzuki gear case will have to have a greater reduction (higher number ratio) in order to spin these larger propellers, for a larger diameter propeller is always harder to turn. This break from tradition came as engine power began to grow above 250-HP, a relatively recent development. I believe this prompted the change to greater gear reduction, not some magic potion of greater propeller efficiency in general. |
| Sam Cullis |
The answer that is eluding all or most of the responders here is that just as there is a practical limit on pitch, there is also a practical limit on prop blade tip speed. The larger the diameter, the lower the rpm at which the tip speed will be too high and cause problems (mostly, true water boiling cavitation -not "ventilation") The smaller a prop is, the smaller the thrust stream behind it will be. This is acceptable if the boat is small and light and if the boat speed is so high that lower unit drag is an important factor. Smaller diameter props can be run at higher rpm because the blade tip speed will be less in inches per second, mph or whatever units you want to use. (Each trip around the circle is fewer inches than a larger prop.) Bigger boats need bigger props to produce the necessary volume of thrust, but these props must be run at comparatively slower rpm to avoid running the tip speed into the cavitation range.
| Peter |
Sam, you beat me to it. I was going to say that unless you are operating a boat at the extremes, heavy and slow like a barge where "high thrust" is desired or light and very fast like the 80+ MPH go fast boats, the gear ratio is not a significant consideration. There are numerous considerations including blade tip speed to take into account. Angle of attack is another, for example. All quite complicated of course. In any case, I realize this is the Suzuki marketeers speaking but Suzuki's comparative advertising for the DF 150 attempts to convince the reader that its higher reduction ratio is better because that higher reduction ratio allows it to run a "larger propeller for better acceleration" -- whatever they mean by that. Some thought "larger" simply meant diameter while others think its more than that. What I found interesting in the published information is that despite having this higher reduction ratio, Suzuki's test reports never run a propeller with more than a 14 3/4 inch diameter (like a 14 3/4 x 21 for example). Basically, the propellers they run in the test report are within in a family that includes a 15 1/2 x 17, what I run on the Johnson 150 with its 1.86:1 ratio. Perhaps that is just how things worked out for the tests. But what is of further interest is that Honda has test reports for its BF 150 (a lower reduction ratio of 2.14:1) running a 15 1/4 x 22. That propeller is no smaller, in my opinion, than the line of propellers Suzuki offers for the DF 150. Of course we all know that Mercury's Optimax and Verado 150s, Yamaha's F150, and the Evinrude 150 can also run propellers within the same "large" size families (15+ inch diameter propellers). So I have difficulty with the almost automatic conclusion some have reached here that the higher reduction ratio automatically means a larger propeller relative to same HP motors with lesser reduction ratios. In my opinion, a larger propeller can be used only if the powerhead has the crankshaft torque to support it. Based on the Suzuki propeller offerings for the DF 150, it does not appear to me that the Suzuki DF 150 has the crankshaft torque to support the use of a "larger propeller", that is, a propeller which is larger than what the competition can use and does use. By the way Jim, Mercury makes a 16 inch diameter Mercury Mirage Plus propeller (a 16 x 13) and, at least according to the Mercury propeller calculator, that propeller can be used on the Verados and the Optimaxes if you are using those to push a heavy barge around. So apparently there is enough clearance under the anti-vent plate for a 16 inch propeller but perhaps not enough to ideally use a 16 inch diameter in a much higher pitch. |
| myjule |
"hookum" repowered last year with a suzuki DF150 on his 18 outrage and he is able to use a 3 blade 16x21 prop? sorry I dont have the link to attach. I have an 18 outrage with a 150 evinrude and there is no way I would be able to get remotly close to that size prop. I am swinging a 15 1/2x17 mirage and top out at 5400. My performance is ok but I cant even hold a candle to hookum. CRUISE is most important to me and His cruise blows me away in fact he is 9 mph faster than me and his #'s blow away the suzuki test data with there 14 diameter prop as well and I believe it has alot to do with diameter. I just put deposit on a suzuki DF150 and the main reason was NOT prop size but it was one of the key factors that put that motor over the edge. |
| towboater |
You guys have my vote for "best performance thread" of 07. thx Still poised to repower my CPD 18 with high gear ratio twins for rescue towing (seeking "traction"). Interesting results within the topic here. Read all of Buckda's stuff. Suzuki DF 70, 2.42:1, 710 lbs Twin 60-HP Big Foot EFI Yamaha two-stroke |
If a gear ratio of 2.33:1 was optimum, why isn't it used on all engines? Mercury makes a lot of other engines with different gear ratios. Why is 2.33:1 only used for one engine and not all? |
If a (typical 90-HP four-stroke) motor is rated for 6,000 to 6,400-RPM for maximum horsepower and it has a gear ratio of 2.33:1, the propeller shaft is going to turn 2,575 to 2,745-RPM If a (typical 90-HP two-stroke two-stroke) motor is rated for 5,000 to 5,500-RPM for maximum horsepower and it has a gear ratio of 2:1, the propeller shaft is going to turn 2,500 to 2,750-RPM In other words, the propeller shaft is going to be turning the same speed on either engine. The propeller cannot tell which engine is turning it. The propeller will turn at the same speed on both engines. The propeller will not be able to read the marketing literature and know that it is supposed to operate more efficiently on the engine with the 2.33:1 gear ratio. It is going to operate just the same for both engines. People who think that 2.33 gears are magic are going to have to jump in here and offer some explanation of how the propeller is supposed to figure out when it is to be more efficient so that their claims can be substantiated. |
| towboater |
I dont know if 2.33 gears are optimum, the efficiency of gear ratios depends on the power band of the engine. I need to find out more about the Yamaha 2 strokes and how the gears and powerband marry up. I find the gear ratio difference between the 70 & 90 interesting. Example of power band effect on gear ratios; Pitch = power |
| Peter |
I have had the Yamaha 70 2-stroke with the 2.33:1 gears on a 15 Super Sport. I think the 2.33:1 gears were a compromise on that motor to allow Yamaha to use the same propellers from the 60/70 3-cylinder through their V4s. Also, the Yamaha 90 only turns 5500 RPM max versus 6000 RPM on the 70. In setting up a 18 CPD tow boat with twins, I think the Yamaha 70s are probably ideal. Great power to weight ratio. The 2.33:1 gears would allow the motors to turn 13 inch diameter propellers and so you'll get to spread the thrust out over two relatively large propellers. |
| Lil Whaler Lover |
Peter you just hit the target dead center when you said the gears were a compromise that allowed Yamaha to use the same propellers for both the 70 and 90. Simple economics for the manufacturer to spread development costs over more products. Most, if not all manufacturers have done the exact same thing. The same logic led Mercury to develop the interchangeable hub allowing a propeller to be adapted to any brand of engine. |
| mikejoyce77 |
Wow, I would of never thought this topic would have so may hits. I found all of your thoughts very helpfull. So thank you. |
| towboater |
Thx for the comments on the Yamaha 70. I only expect 20% towing/work loads. How bad does this engine load up after a hour or two of trolling?
The man who built my Tug once told me a tow winch/bit should be placed 2/5ths the distance of the hull. Too far ahead and you are CONSTANTLY steering, too far aft and you are stern bound. If the tow bit is too high, you can get into irons and roll. I fear if I set the engines further back I will need to raise the towbit or use a crash bar. mk
Regarding the PITCH/DIAMETER ratio of a propeller, which has previously been cited in Mercury literature has having a direct correlation to propeller efficiency, that is, the higher the PITCH/DIAMETER ratio the higher the efficiency, I would like to note these comments from Dave Gerr in his PROPELLER HANDBOOK (pages 25-26): "Very roughly, a pitch ratio of 0.8 can be expected to produce efficiencies of around 0.65, while pitch ratios of around 1.4 can result in efficiencies as high as 0.74. At pitch ratios higher than 1.5 efficiency generally starts to fall off."
Mercury MIRAGEplus Propellers PITCH DIAMETER PITCH RATIO If we are to believe Mercury, then we all ought to change to a 27-inch pitch propeller and look for a gear ratio of 3:1 to turn it. On the other hand, if we believe Dave Gerr, it looks like the most commonly used propellers are all in the range of pitch ratio that he mentions. The 21-inch pitch propeller lands at the suggested optimum. Perhaps this means we all need to run 21-inch pitch propellers for best efficiency. Maybe engine manufacturers ought to offer gear ratio options so we can tweak the engine to fit this preferred propeller. |
| glen e |
I'm WAY over my head here discussing efficiency and props and in the strict sense Jim, you may be right ...but like all other things in boating, I don't think it's that simple. It's not just about effciency....I can take 3 diff 19 inch props and they they all get diff #'s...and they do diff things...for me the enertia gives the best smoothness, the tempest best hole shot, and the mirage the best overall performnace...but the mirage blows out for me where it's impossible to get a tempest to blow out at any speed or sea state. And a rev 4 is stil the best docking prop - the grip of that blade for me is amazing.... so it's all about choice I guess.... and what your preferences are.... |
The difference in efficiencies that Gerr cites are from 0.65 to 0.74, or a variation of about 9 percent. In this particular propeller line it looks like the 19 to 21-inch propellers are closest to the optimum pitch ratio. Now there is no guarantee that in every propeller line the propellers with the optimum pitch ratio are always going to be the same ones. Maybe someone will do a bit of research and see if there are other propeller lines with different sets of pitch ratios. |
| Peter |
The pitch/diameter ratio-efficiency correlation is applicable within a line of propellers, such as the Mirage Plus line or the Revolution 4 line, etc. Of course, different style propellers with a different number of blades, different blade shape, different amount of rake, cupping, progressive versus non-progressive pitch.....will behave differently relative to each other. But within a line of propellers, the propellers that are closest to the 1.4 ratio would be the most efficient according to the correlation and theory. Of course, as with absolutely everything in boating, there are trade offs to make. Back to ratios, as we have been discussing, a higher reduction gear ratio may be chosen to allow for a larger propeller diameter to be used. The higher reduction ratio also leads to the use of a greater propeller pitch if the expected performance is to be maintained and the motor is not permitted to over spin. One drawback (or advantage) I see and have experienced running larger diameter/higher pitch propeller (a much larger propeller in every dimension) on the same boat is the tendency for increased stern walking caused by the fact that the thrust coming from the propeller is asymetric, a sort of paddle wheel effect. My first hand experience with this came when I repowered my 15 SuperSport. I repowered from a Johnson 48 SPL which was turning an 11 3/4 x 17 propeller to a Yamaha 70 which was turning a 13 x 19 propeller. The stern walking of the 15 SuperSport was much more pronounced with the Yamaha than it was with the Johnson. Backing into a slip or trying to dock can be difficult if you are on the wrong side of the walk. Now this walking which is a disadvantage can become an advantage if you have twin outboards in which one is counter rotating. I use it often to my advantage when docking or backing into the 27 Whaler into the slip. |
Propeller design is complicated by at least two important factors: the boat is moving forward, and the boat pulls some water along with it. If a propeller were designed to operate in a stationary setting, for example as in a fan, the optimization of the blade design will be different than if the propeller is moving forward as it operates. This is the case on a boat. As the boat speed changes, the speed at which the water moves into the propeller blades is changing. Because of this the design of the propeller cannot be optimized for all boat speeds. The speed at which the water flows into the blades changes the angle of attack of the blades. Further complicating this is the concept of wake. In terms of propeller design the term wake refers to the water that the hull of the boat is dragging along with it as it moves forward. If a boat is going 25-MPH, a simplistic analysis would think that the water is flowing into the propeller at 25-MPH, but this is not always the case. As the hull moves forward, it drags some water long with it. This slows the relative speed at which water flows into the propeller. The degree to which this occurs depends on the hull design. So a particular propeller cannot be optimized for all hulls. I imagine that as boat speed increases and more of the hull lifts out of the water, that the influence of wake decreases. However, at most moderate speeds, say 20 to 30-MPH, on a Boston Whaler boat there will still be a significant amount of hull in the water. Therefore, it is likely that the influence of wake will affect the propeller performance. |
| cooper1958nc |
Well, not exactly. The forward motion of the boat, seen as water flow into the prop, does affect the angle of attack, but so does the RPM of the prop. So, if RPM stays in rough proportion to speed, angle of attack is not changed as much as one would think. As to a planing boat "dragging" water along with it, the test of this would be whether a speedometer pitot (mounted a few inches below the bottom) shows true water speed or is affected materially by this dragged water. GPS measurements seem to show that good speedometers show true water speed within a few percent. This would seem to refute the hypothesis that much water is being dragged. Of course the prop may run in somewhat disturbed water, especially if the boat has a deep keel. This does affect prop performance, but probably not by the mechanism described. |
Regarding selecting an outboard motor and how the gear ratio affects that decision, it comes down to this: you buy a boat, then a motor. Then you look for a good propeller to use with the combination. You don't buy a propeller first, then look for a motor that can use it to best advantage. My recommendation: buy the motor you like, and don't worry about its gear ratio. Whatever the gear ratio, you will be able to find a propeller that works well with your boat and motor. There are thousands of propellers to pick from. |
| L H G |
If you buy a 90 HP engine with a 2.0 gear ratio, requiring a 15" prop that produces a low efficiency factor of 65% (as if engine was mounted on a Whaler 170 Montauk), that means you have 58.5 HP coming off the prop to push the boat. If you buy a 90 with a 2.33 gear ratio, running a 20" Laser II prop (like WT's 90 Merc EFI 4-stroke), that produces a higher efficiency factor of 75%, that means you have 67.5 HP Now you know why running a new 170 Montauk with a Merc 90 EFI on it against same boat with an E-tec 90 on it, would not be pretty for the Evinrude. 38-40 MPH vs 46 MPH maybe? So yes, buy the engine you like, they are all excellent, but don't come in here with that 2.0 gear ratio looking for prop help to make it go faster! |
Since the four-stroke turns about 6,400-RPM through 2.33:1 gears, the propeller shaft turns 6400/2.33 = 2746-RPM The E-TEC turns 5,500-RPM through 2.0:1 gears, and the propeller shaft turns 5500/2 = 2750-RPM The propeller shaft turns the same speed in either case, the boats use the same propeller, and they both go the same speed. The propeller cannot tell who is turning the shaft. You are forgetting that they both make 90-HP at their rated maximum RPM. But that turns out to be the same propeller shaft speed. You have to explain how the propeller is supposed to know it is more efficient when the Mercury is turning the propeller shaft. What I have shown above is precisely why they have different gear ratios--it is so they get the propeller shaft to the same speed, and that is because that is the speed which all the propellers are designed for! |
I forgot one thing: because the E-TEC is lighter, it goes a little faster. Speed is always in inverse proportion to weight. |
| Peter |
"So yes, buy the engine you like, they are all excellent, but don't come in here with that 2.0 gear ratio looking for prop help to make it go faster!" So following the above logic, should we say to the Mercury Verado 250 owner, "don't come in here with that 1.86:1 ratio looking for prop help to make [your Conquest 305] go faster"? The poor Verado 250 needs a 15 inch pitch propeller to push the massive Conquest 305 around. Looks like Mercury made a big mistake when they put 1.86:1 gears on the 200 to 275 I6 Verado and an even bigger mistake when they put 1.75:1 gears on the 300 Verado. So we must conclude from the above that they would have been much smarter to put 2.33:1 gears on these motors. I guess their engineers don't know nothin'. LOL. |
| bigjohn1 |
To ensure we are making accurate comparisons, some of the data above needs to be corrected. The Mercury 90efi has a WOT rpm of 6,000 vice 6,400. The 90 E-tec has a WOT rpm of 5,500 but is available with either 2:1 or 2.25:1 gears. |
There is also no real data to support the efficiencies cited. The numbers are a slight exaggeration of some data suggested by Gerr based on a pitch/diameter ratio. My feeling is that Gerr's data is probably in reference to rather large propellers used on ships, and not necessarily applicable to outboard motor propellers which tend to have other design aspects, such as rake, progressive pitch, edge cup, and so on, which are probably not considered in the theoretical analysis which suggested certain pitch ratios are slightly better. What really is happening in these motors with higher gear reduction is that they are using a large gear case and are suited for use with the V6 line of propellers, even though they are generally not in the 150-HP or higher range. In order to turn those larger propellers the 90-HP engines need more gear reduction. If one gear reduction were magically better, you'd see all engines using it. |
| Peter |
Exactly. As I mentioned before, unless you are running on the extremes, pushing a barge or running an 80 MPH boat, the gear ratio is a non-factor in the selection process. When you get to the 80+ MPH application, then gear ratio starts to matter as evidenced by Mercury's offering of a few different ratios like 1.62:1 and 1.75:1 but also offering different hydrodynamic profiles with those. Again, I guess Mercury Racing doesn't know what it's doing with such low ratios. So Mercury Racing motor owners, "don't come in here with that 1.62:1 ratio looking for prop help to make your go-fast boat go faster". Those motors should be running 2.33:1 ratios. LOL |
| L H G |
Jim - I have no idea what you are talking about regarding the two engines would the same prop because of your prop shaft speed calculation. I know one thing, THERE IS NO WAY A 90 E-TEC CAN TURN A MERC 20" LASER II ON A 170 MONTAUK. That engine can only turn a 15-17" prop on a much lighter classic 17 Montauk, if I read correctly here from the various installations. I doubt if it could turn a 20" Laser II up to more than 4500 rpm, vs BW who says the Merc 4-stroke can turn 6000RPM. Big John: to get the more desireable 2.25 gears, you have to buy a 25" 90 E-tec. 25" 90's are as rare as sharks teeth, so it's a non-issue. If you get rid of that 4-stroke Mercaha 115 (2.07 gears) on your 170, and install a 90 Evinrude, you will be shocked with the decline in top end and power. You will need a 13" or 15" prop. Peter, I agree, running a 15" prop on any engine, including a 250 powered Verado single on a very heavy boat, is a bad buy, and HP out the prop is lost (although I would bet a 15" Rev-4 is probably a more efficient prop than most others). This points out an interesting situation on singles vs twins, and why the twins are often, surprisingly to some, faster and more efficient than an UNDERPOWERED big single. Same old rule applies - DON'T UNDERPOWER, get close to 90% of RATING for a boat, so YOU CAN RUN A MORE EFFICIENT PROP and USE MORE OF YOUR RATED HP. Remember some recent articles that have shown triple Verados use no more fuel on same rigs than twins. The trips use higher pitch, more efficient props. |
The suggestion that Larry keeps making is that somehow if I had a higher gear ratio I would get better results because I could run more pitch. The basis for this is that some pitch/diameter ratios may be slightly more efficient. But this same argument would apply to his boat. He could get more efficient with more pitch, too. Into this proposition Larry has introduced unrelated factors--twin engines, much higher reserve power, different engine mounting configurations, and other variables, including different types of engine fuel induction. It is not at all reasonable or scientific to throw so many variables into the comparison, then come out with the answer that the cause is the pitch/diameter ratio of the propeller--that it alone makes all the difference. My own comparisons of propellers are a bit unscientific on one important basis: the OMC SST propellers I have used are old, well-worn, and possibly re-worked propellers, while the Mercury propellers I have test have all been new or in new-never-used condition. In order to test Larry's theory we need everything to be the same--same boat, same motor, same time, same weather, same load, same temperatures--except the gear ratio and the propeller pitch/diameter ratio. We would test by using several gear ratios and several different propellers, but the propellers would have to be very similar in their design, blade shape, blade area, etc., so that the only significant difference was the pitch/diameter ratio. We perhaps could use a set of all new propellers in a certain brand's family of propellers. Getting the propellers is easy, but getting a motor where we can change the gear ratio at will is just about impossible. I don't think we are going to see any direct testing of this theory. If we could make some reasonable tests, then we could see if the rather vague and sketchy information presented about propeller efficiency being improved with higher pitch/diameter ratio is actually obtained in practice. ASIDE: I am going to need a better pointer to the Mercury literature where they list the relative efficiencies of all their propellers. I am not seeing it in the link mentioned above. |
| L H G |
Jim - I do not think the Evinrude 3.0 liter 225 has the wrong gear ratio, and did not say that. It has the same 1.87 ratio that Merc and Yamaha use for their 2.5 liter blocks of similar power, and is correct, I would think. Using your boat as a comparison, my point is that a lower power big single (as opposed to the 300 HP engines now available) force the use of a low pitch, lower efficiency prop, even further decreasing performance. Obviously, prop efficiency is just ONE of several factors regarding the fuel economy of our respective boats, but it has to be one of them. That was my only point. I do think, however, the 3 cylinder Evinrude 90 E-tec has the wrong ratio for maximum performance the engine COULD achieve, and needs a new gear ratio, closer to what ALL of the other manufacturers are using. Evinrude is the odd man out with that high gear ratio, my only point. After all, much more powerful engines, such as my in-line 6 115's, the 2.0 liter block Merc V6 150's and the current 135 Optimax, all use a 2.0 ratio, and can turn higher pitch, more efficient props because to the increased power. As for this whole issue of propeller efficiency (how much propshaft rated HP is lost thru the propeller itself), I would think Mercury Marine knows what they are talking about, and has the testing laboratory and dyno equipment to do the correct calculations. I take their research and design work as probably the best information available for the outboard propeller design world, and when they say that a 23" Laser II (the prop dimensions they use as an example) runs about 80% efficient, and a 13" Mirage Plus runs 65% efficient, I believe them. I am just the student and messenger here, and like all the rest of us here, know nothing about designing and engineering propellers. None of us have the ability nor equipment to test propeller efficiency, as important as it is (it is the final calculation on the actual HP pusing the boat. Mercury can isolate and accurately determine the efficiency calculations, we can't by just running our boats around on the water using GPS and RPM only. Do I think either Crouch or Gerr know as much about propeller design, engineering, application and manufacturing, as it applies to 2 and 4-stroke outboard engines, as Mercury Marine? NO WAY. I urge all people reading this, interested in the mechanics of propellers, to thoroughly read, study and assimilate the propeller information published on mercurymarine.com., and then to study how this information is used in developing the various propeller lines, and their recommended application, that Mercury produces, including pitch and diameter ratios, number of blades, and design factors. It is valuable information to know when purchasing new power for your boat, and what to expect in terms of performance. They even sell a very handy calculator for 5 bucks. |
| towboater |
been following religiously...trying to come up with a conclusion to Mikes question for my own purposes. I understand how OEM can combine different power heads (HP) and gear ratios to come up with the same HP at the prop. Thx. This is all fine and dandy sitting in a dyno test tank. Everything changes when you mount that engine(s) on a specific hull for a specific purpose. How do you manipulate the gear ratio's to achieve a performance target if the OEM setup is inefficient? Most of the prop performance threads Ive read either involve first hand experiance or trial and error after the fact (discovering a OEM setup is inefficient). Santa is hoping twins on a CPD 18 will result in hole power to come on plane quickly and hold traction at just over planing speed going with or against a routine 1-2 ft westerly wind swell (a little bit higher and wider river wave than what I would call chop or easterly swells). Alum hull would loosen teeth, WOT would constantly belly flop. It seems to me, adding pitch would better serve this purpose with 2.33:1 gears & two wheels in the water turning moderate RPMs for long periods than a single with 2.00:1 gears. happy holidays mk |
| bigjohn1 |
Here is something to throw into the mix. My 170 Montauk is powered by the 2.07:1 geared 115 EFI Mercury four-stroke. I had thought of changing to the 2.33:1 gear commonly used in the Merc 90 four-stroke to take advantage of more propeller choices. Conventional wisdom seems to dicate that a gear change is not a cost-effective modification. This has been discussed here on CW as well as other boating sites. Recently, a bushing in my water pump shaft failed allowing seawater into my lower unit. I caught it early, the dealer made the repair, and no harm was done to the lower unit. I may not be describing the repair accurately enough but my lower unit gears and all had to be disassembled and reassembled in order to complete the repair. The bill for this repair was $310 parts and labor. I asked my mechanic how much it would cost in labor to replace the forward gear if I mail ordered one and provided it to him. His reply was it would have cost NOTHING in additional labor. MY POINT? In my case, I could have changed my forward gear to a lower ratio for a little under $700. We all have to judge for ourselves if we feel this would be cost effective or not. I propose there is no one-size fits all answer on this. Because fishing season is here, I decided to simply bolt on a cheap 15P aluminum four-blade prop. The cost was $125 for the Solas Amita prop. |
| cooper1958nc |
There is no magic in the realization that, all things equal, it is more efficient to swing a large pitch prop slower than a low pitch prop fast. Why? Because hydrodynamic parasitic drag on the prop blades increases as the square of the RPM: D = 1/2 rho V^2 K A Where D is the parasitic drag on a blade Because total drag on a prop blade is the sum of parasitic and form drag, and only form drag produces lift, obviously reducing parasitic drag is helpful. A longer explanation of this is possible, but it seems kinda obvious. |
| bigjohn1 |
Larry, Thanks for the clarification on which gear ratios come on various E-tec models. Wouldn't it be nice if, when purchasing an outboard, we could choose between different gear ratios depending on how we would be using the engine. Sort of like choosing an axle final drive ratio on a potential new purchase of a pickup truck. |
Larry--If I accept your representations, then all the engineers at Bombardier need to do to permit their E-TEC 90-HP motors to gain 8-MPH in top speed when used on a 17-foot boat is to change the gear ratio from 2.0 to 2.33. Am I right in interpreting what you said? I think that is the data you laid out earlier in the discussion.
quote: To go from 38-MPH to 46-MPH is a very significant increase in speed, and normally such a increase in speed, a ratio of 46/38 or 1.21, would require an increase in horsepower of the square of that ratio, or a 46.5-percent increase in horsepower. In other words, instead of a 90-HP motor you would normally need a 132-HP motor. But, instead, if we accept the representation that has been made here regarding the influence of gear ratio, we find that we can achieve the same improvement without any change in horsepower, we just have to change the gear ratio and use a propeller whose pitch/diameter ratio is more favorable. If true, then this is remarkable. |
| cooper1958nc |
It would be hard to imagine that propeller changes and gearcase changes could matter more than a few percent in power, and the square or cube root of a few percent in speed. |
| Peter |
If you were to accept that the 2.33 ratio is the right one, which is what the resident gear ratio expert is saying, his engineering buddies over at Mercury didn't get the memo. The gear ratios for their motors are all over the lot. 25F - 1.92 The most interesting aspect of the above data is that Larry's engineers have a greater tendency to use gearcase ratios closer to a 2.0:1 reduction and below not 2.33:1. I'll bet the weighted average is under 2:1. |
| L H G |
"Larry--If I accept your representations, then all the engineers at Bombardier need to do to permit their E-TEC 90-HP motors to gain 8-MPH in top speed when used on a 17-foot boat is to change the gear ratio from 2.0 to 2.33. Am I right in interpreting what you said? No, that is the wrong interpretation of what I said, Jim. As for likely performance of a 90 Evinrude E-tec on a 170 Montauk, I think it is correct that I am saying the engine would likely perform better on the most applications for which it is installed, if it had a 2.33 or similar gear ratio, since it could use more efficient props, and a wider selection would be available in the market. Top end and fuel economy should be better. So, yes, Evinrude should give up the old gear ratio from the 80's, like Merc and Yam did, and treat the engine to a newer one. I didn't really want to get in to my reasoning for what appears to be a big perfromance gap between the Merc engine that BW is now installing on the 170 vs the 90 E-tec. But if you insist, here it is, to the displeasure of Evinrude Etec fans. I guess it does keep things dicy here, and the personal attachs on me continuing from the BRP group, which brings in readers. There have been many installations of the popular E-tec 90 on the equally popular Classic Montauk, a boat which weighs 950 Lb. These contributors, from Ratherwhaling on down, report between 43-40 as the engine's top end. So, putting this same engine on a new 170 Montauk, a boat which weighs 50% more, or 1400 lbs, besides requiring a lower pitch, less efficient prop (less HP delivered to the water), would be lucky to achieve more than 40 MPH, maybe less. Obviously, until someone dumps their Merc and gets one of the E-tec 90's, we won't know, but that's my logic anyway, and I think it's pretty good. Regarding the Merc 90 EFI 4-stroke, Verado based, Boston Whaler's testing is showing 46 MPH and a higher efficiency 20" Laser II prop. I guess we have to believe them. So, how else to explain a 6-8 MPH difference between two 90 HP engines? Taking away prop efficiency, not a major contributor of the difference, I guess it gets down to TRUE HP the engines deliver. I've been attached by the E-tec lobby here for saying it appears the 90 E-tec puts out about 82 HP, (similar to the Yam 90 2-stroke), and that this Merc 90 seems to be pretty close to 100 HP (which they sell it as in Europe, incidentally), but it looks like that is the situation. Sorry to be the bearer of bad news, and I think these two engines represent the extremes of 90 HP engines, with all others falling somewhere in the middle. |
| Peter |
quote: Some say that things don't always seem as they are when you are in love www.youtube.com/watch?v=sZ4eiEdeJLs so you might want to take a break from the sweetheart and take another look at Whaler's performance report for the 170 Montauk www.whaler.com/rec/pdfs/performance/6.pdf . ;) After you've done that, get yourself a free education over at the CW learning center regarding Crouch's formula http://continuouswave.com/cgi-bin/crouchcalc.pl where there, with just a tiny bit of experimental effort, you may discover why a 90 HP motor can push a 1400 lb boat to the same speed as a 90 HP motor can push a different 950 lb boat. |
| L H G |
Re-checking out the BW performance graph on the 170 in your link, I see a 60 HP engine giving 31 MPH and the 90 as 46 MPH. Peter, as usual, you're being rude to me, and maybe it's you who should take off the rose colored glasses. I'm just the messenger and indicating what I have observed. But anyway, in the spirit of the season, have a Merry Christmas and Happy New Year. And you can argue with me about your point some time next year. In the meantime, I'm going out tomorrow to see how my new, high efficiency 23" Tempest Plus props run on Whale Lure. |
| cooper1958nc |
It just occurred to me that the "vent holes" described in some propellers are precisely the result of having a single gear ratio. To be efficient at cruise the ratio is too high (numerically low) to permit the engine to develop sufficient power to plane the boat, without artificially raising RPM through ventilation. Ventilation is an inelegant, wasteful solution. Better would be to have a two speed gearcase. Surely such a thing would be fairly easy to accomplish given the resources of Bombardier, Brunswick, Yamaha or the rest. |
Larry--Thanks for the additional information. I now understand that your prediction of speed results is based on your belief that the Mercury 90-HP motor will be producing almost 100-HP and that an Evinrude 90-HP motor will only be producing 82-HP, and not entirely on the distinct advantage that Mercury has given itself by choosing the "right" gear ratio for their motor. And again, these results for speed which you are presenting are not based on any actual testing, but on your extrapolation of results seen in other tests or inferences you have drawn from the results in other tests. If we accept these conditions are part of the performance prediction you are making, we can determine how much of the speed difference is due to horsepower. Let's see if we can do the math: 100/82 = 1.21 so the speed difference should be proportional to 1.21 ^0.5 = 1.10 If the actual Boston Whaler 170 with the 90-HP FourStroke is 46-MPH, then we would expect the 90-HP E-TEC to go 46/1.10 = 41.8-MPH So now we can isolate the influence of the gear ratio. The predicted speed for the E-TEC is only 38-MPH. Thus the influence of the gear ratio must be the cause for this gap. So if I have this correct, the E-TEC is only going to hit 38-MPH, but if we changed the gear ratio to 2.33:1 it will go 41.8-MPH. Again, that is fairly significant improvement, a gain of 3.8-MPH or ten percent. Going back to Gerr's data, he says that the range for propeller efficiency variation is about 9-percent from PITCH/DIAMETER ratios of 0.8 to 1.4. If we are willing to assume that all of the possible difference in propeller efficiency occurs in the hypothetical comparison put forth here, then it might be reasonable to see a difference of 3.8-MPH in the boat speed due to the effect of the propeller PITCH/DIAMETER ratio. Let's look more closely at this. Larry proposes that he'll use a 20-inch pitch propeller on the Mercury motor. If this propeller is to be optimum, then its diameter will have to be about 14.25-inches. OK--that works out fine. Larry also proposes that a 15-inch propeller be used on the E-TEC. If we want to make the E-TEC be the least efficient, then we need that propeller to have a diameter of about 15 / 0.8 = 18.75-inch. Oh, darn, we have a problem. If the E-TEC is to turn a 15-inch pitch propeller and it is only to have a PITCH/DIAMTER ratio of 0.8 (so it meets the criterion for lousy efficiency necessary to make all this work out) then the propeller will have to have a diameter of 18.75 inches. That is too big for the propeller aperture. It looks as though the theory does not fit the speculation very well. |
| Tohsgib |
Where are you getting 46mph, the graph shows 42.8. Now that in itself is pretty good since the 90 2 smoke only ran just a tad over 40. |
| Perry |
Nick, scroll down to the bottom comparison graph on the pdf and you will see around 46 MPH at 6200 RPM. It is odd that the performance numbers show 42.8 MPH at 5900 RPM but the comparison graph between the 60 bigfoot and 90 HP 4 stroke show 46 MPH at 6200 RPM. BTW, max RPM for the 90 fourstroke is 6000 RPM. |
| L H G |
"Larry proposes that he'll use a 20-inch pitch propeller on the Mercury motor. If this propeller is to be optimum, then its diameter will have to be about 14.25-inches." Jim: I'm not proposing anything. Boston Whaler USES the Mercury 20" Laser II on the 170 Montauk/90 EFI combination! But I am sorry to learn that Mercury Marine's prop engineers goofed when they designed this prop 15 years ago, failing to make it "optimum" according to this Gerr fellow. The prop has a 13-1/4" diameter. I run small tube Mercury Laser II's on my 18 Outrage, and inspite of the smaller diameter than Gerr's "optimum", they run quite well, and give great fuel economy. When Gerr has a plant that turns out 550 props a day, and are used all over the world, I'll believe him instead of Merc. But until then, I'm going with Merc's engineering and performance testing. And if the E-tec 90 had more power, and a 2.33 gear case, it, too, could run a higher efficiency Merc 20" Laser II on a 170 Montauk up to 6200 RPM, and would not need an 18" diameter prop. But in it's current configuration, it can't. You guys wear me out! I surrender. |
A propeller with 20-inch pitch and 13.25-inch diameter has a PITCH/DIAMETER ratio of 1.51, which we now learn is optimum because, well, because I guess it was made by Mercury. But that argument is a dangerous one to make. Here is why: if this particular propeller is working at the optimum efficiency possible because it was made by Mercury, that same argument can be made about all the other Mercury propellers made by Mercury. So when I extend Larry's argument a little further, I just use a Mercury propeller on the E-TEC, and now it has the optimum propeller. You can see where this going. The claim that the propeller must be the best possible design just because it was made by Mercury can be made for any of their propellers. And now we are back to an assertion that proves whatever we want it to prove whenever we want to use it: Mercury is always right or always better. This is not a very elegant solution to the problem. I would--and I am serious--just like someone to explain to me how to deduce what the optimum gear ratio is for a particular motor without having to rely on the principle which has been used here--which as we have seen resolves down to "Mercury is always right." Now I am not trying to argue that "Mercury is always right" is wrong. It could very well be that Mercury is always right. But I need this explained to me in some sort of scientific way, using some sort of principle which can be easily stated, and then applied to other situations to test and evaluate them. |
| cooper1958nc |
In general larger, slower turning propellers have an advantage in efficiency, as described in above posts. This advantage is somewhat offset by the need for a larger submerged gearcase which increases parasitic drag. I expect trial and error finds the best balance. |
Coop'--Thanks for the statement of the general nature of the problem, but I am afraid it does not help me. Here is my situation, if I may restate it: I am trying to understand why 2.33:1 is the "right" gear ratio for a 90-HP, and at the same time 2.00:1 is the "wrong" gear ratio. So far the only basis for this that I can see relies on a simple principle: "Mercury is always right." I am willing to accept that the principle "Mercury is always right" is a simple way to explain why 2.33:1 is the "right" gear ratio for a 90-HP, but I would like to know the underlying basis. What confuses me is that Mercury uses 2.33:1 gear ratios on engines with a very wide range of horsepower. They have 40-HP engines with this gear ratio as well as 90-HP engines. In other words, there is a range of horsepower with a variation of 90/40 or 2.25 to 1 for which a gear ratio of 2.33:1 is used. This seems to me to indicate that there is an awfully wide range of motors for which 2.33:1 must be the "right" gear ratio. When I look the relationship between gear ratio and horsepower, and using Mercury motors as the basis because, as we know, "Mercury is always right", I discover that gear ratio tends to be inversely proportional to rated horsepower. As the horsepower increases, the gear ratio decreases. But this relationship breaks down in the 40-HP through 90-HP range, because a constant 2.33:1 gear ratio is used. So now I need an explanation of why it is possible for 2.33:1 to be the "right" gear ratio for so many engines of such different horsepower. Look at it this way: a 40-HP motor is different from a 90-HP motor by a factor of 125 percent change, and somehow they can use the same gear ratio and it is "right." But at this same time, another 90-HP motor can have the "wrong" gear ratio when it uses 2.00:1 gears. Now 2.33 and 2.0 only differ by about 16 percent which is quite small. If there really is something scientific about an engine's horsepower which dictates that only one particular gear ratio is going to be "right" for it, how can this relationship be so broad in one instance that it can be used over a horsepower differences of as much as 125-percent, yet, at the very same time, this factor is so precise that a small change in gearing of a difference of 16 percent throws it off? To anyone with a rational mind used to scientific principles, this proposition seems to be completely inconsistent. |
| Tohsgib |
Stop the nonsense and just e-mail Mercury, BRP and Suzuki and ask them. |
| Perry |
Mercury isn't the only producer of 90 HP outboards with a 2.33 gear ratio. Yamaha and Honda 4 strokes also have 2.33 gears and Suzuki has a 2.59:1 reduction ratio. |
Maybe Suzuki is onto something--2.59:1 sounds even more "right." |
I also notice that Mercury uses different gear ratios for the same horsepower level depending on the type of motor; all the two-strokes use lower gear ratios than the four-strokes. Gosh, if that is the case in the Mercury line, doesn't it make sense that the two-stroke E-TEC will use a lower gear ratio than the four-stroke FourStroke? It seems like that is exactly what Mercury does, and we know... |
| towboater |
Mourning Bhutta today. From what Ive been learning on this thread and reading OEM promos recently, Jims last post seems to be the one that sums up the effects of gear ratio on outboards. "all the two-strokes use lower gear ratios than the four-strokes." There are a few discrepencies but overall, this makes sense to me. Gear ratio's are relative to the power band. For all of the different setups everyone mentions, I am not aware of any outboard engine that is strictly limited to one prop dia/pitch. I think everyone understands how one prop will deliver more speed wot, and another will deliver more power...as Tom says, "depending on many things". Mike doesnt ask about props, nor am I. So lets remove the props & speed for a second and look at "the effects of gear ratio on the selection..." Higher the ratio numbers, the higher the gears. I am not aware of any 2 stroke motor that has a low end power band. Ship engines are 2 strokes. The 4 stroke has a much wider power band and thus, more gear ratio options that vary substantially between brands/HP Ive researched. My conclusion is that:
Happy New Year. Michael K Johnson
| bigjohn1 |
I have read twice in this thread where folks are stating that "higer numbers" mean "higher ratios". This is NOT true. Take the 2.33:1/2.07:1 comparison. The 2.33 is a HIGHER numerical value yet it is a LOWER gear. The 2.07 is a LOWER numerical value yet it is HIGHER gear. This was correctly pointed out by Tom Clark in his orignal post and somewhere along the line, someone revered it. Higher numbers mean lower gears. |
| Peter |
Higher numbers gear ratio numbers under the current convention simply means a GREATER or HIGHER reduction between the crankshaft speed and the propshaft speed. A propshaft turned by a gearcase with a 2.33:1 ratio will turn slower than a propshaft turned by a gearcase with a 2.07:1 at the same crankshaft RPM. Years ago, gearcase ratios used to be expressed as a whole number ratio of propshaft revolutions to crankshaft resolutions, i.e., 14:26 (=1.86:1), 12:28 (=2.33:1), etc, simply based on the number of teeth in the pinion gear and the forward gear. At some point in the last 20 years, the industry changed the way these ratios are expressed to crankshaft revolutions per single propshaft revolution, probably because its easier to understand and compare than the reversed whole number ratios or number of teeth in the gears. |
One hundred follow-up comments is often a good benchmark for a discussion which has run its course. I am going to close out this thread, however, I have pursued this topic in a REFERENCE article. I invite everyone to read it, and, if still interested, continue in a second thread I have created for further comments. 90-HP Comparison |
| towboater |
yep, I blew it there...I noticed the conflict earlier, I know the relationship was wrong but went with it instead of correcting. This has been a great thread. Ive learned a lot. mk |
