Topic: OMC 70hp 2-stroke difference in model years
R I Whaler |
posted 09-24-2009 08:06 AM ET (US)
I'm looking for a used OMC 70hp 2-stoke to repower my newly aquired '87 Montauk. What is the difference, both good and bad, between the different generations of this motor? (Pre '86), ('86 to '92), ('92 to '00).Thanks, Mike
Peter
posted 09-24-2009 08:22 AM ET (US)
The primary difference between pre 1986 and post 1986 is the displacement. It went from about 49 cubic inches to 56 cubic inches. I think that is also the time frame when the redline went from 5500 to 6000 RPM. |
Tohsgib
posted 09-24-2009 12:02 PM ET (US)
If engine block is black it is the newer generation and the one I prefer. Tilt & trim and electronics are much better(depending on year). Have the carbs rebuilt and jetted according to a service bulletin(not sure which one) and that engine really comes alive(75-80hp). |
tedious
posted 09-24-2009 05:23 PM ET (US)
Mike, I am not completely sure I have this right, so take it with a grain of salt, but I think the 49CI motors were rated at the powerhead and the 56CI switched to being rated at the prop. OMC wanted to keep the motor a 70, so increased the size and bumped the redline to 6K. The result is that the 56CI has more get up and go.Tim |
Tom W Clark
posted 09-24-2009 05:57 PM ET (US)
To quote the very knowledgeable Dave Wheeler:"OMC built 2 different blocks for the three cylinder 70 hp engines. The following information is directly from Johnson brochures from 1968 through 2001. The first generation engines were 49.7 cubic inches. These motors were introduced in 1968 as 55 hp engines. The first 70 hp engines were introduced in 1974. These engines had a rpm max of 5500 rpm and came with a 12-29 gear ratio (2.42). A typical prop for this engine was a 13 1/4 inch diameter. This engine was built with very few changes through model year 1985. This block was also used for a 75 hp engine with a rpm max of 5800 rpm. It was introduced in 1975. From 1975 to 1984 it was available in a long shaft with the same gear ratio as the 70 hp engine. It was also built as a 15 inch shaft from 1975 through 1988 with a smaller gear housing and a 15-28 (1.87) gear ratio lower unit. This model was built to comply with the 50 cubic inch racing class. The brochure talked about Sprint Drive", a low drag lower unit. This lower unit would swing a 11 3/4 inch diameter prop (for low drag). This engine was built for racing and high performance applications. In 1986 model year OMC introduced a new 70 hp engine with 56.1 cubic inches, and a rpm max of 6000 rpm. It still kept the same lower unit with the 12-29 ratio. This engine remained in production through the 2001 model year." Ref: http://continuouswave.com/ubb/Forum4/HTML/005160.html |
R I Whaler
posted 09-24-2009 09:28 PM ET (US)
Thanks for all the replies. So, if a '88 70hp and a '98 70hp have the same block, are there any other features, changes to things like the electronics, power-pack, etc that would make one different for better or worse? |
tedious
posted 09-25-2009 08:37 AM ET (US)
Mike, you might want to read this reference document, if you have not done so: http://continuouswave.com/whaler/reference/VRO.htmlOne minor difference is the maintenance valve which was introduced in 1991; that makes it easier to fog or decarb the motor. Not a big deal though as it's easily added to older motors - I did so to my '89. Tim |
brisboats
posted 09-25-2009 11:01 AM ET (US)
Later models had the better VRO, fast trac trim and systems check. The best of the best would be a 1999-2001 model in my opinion. Hard to find though. Brian |
Tohsgib
posted 09-25-2009 12:02 PM ET (US)
Sorry Bris but the worst of the worst would be 99-01. That is when OMC built a lot of junk and hence went under. Then again if one is still running, it probably was not built on monday or friday.The trim unit and electronics are a plus on newer engines, especially the SLOW feature. |
Peter
posted 09-25-2009 01:05 PM ET (US)
As early as 1992, the 70 had the larger displacement, S.L.O.W. overheat protection, and the Fas Trak transom bracket. |
Tohsgib
posted 09-25-2009 01:22 PM ET (US)
Thanks...was not sure when because my 1990 did not but 1993 did. |
dgoodhue
posted 09-25-2009 08:08 PM ET (US)
OMC went under because the V6 that blew up at part throttle after a couple hundred hours. The warrenty claims and reputation did them in. |
brisboats
posted 09-26-2009 06:28 PM ET (US)
We can speculate why OMC went under but it certainly cannot be attributed to the venerable three cylinder 70 hp motor. Even the ones built in the "bad" years of OMC have proven to be the reliable performers of the ones that preceded them. I had a 2000 70 hp and own a 2000 9.9hp I bought new, not so much as a hiccup out of either. Brian |
Wasatch Whaler
posted 09-28-2009 10:31 AM ET (US)
I don't know the timeframe of some of the changes, but the engine mounting/swivel brackets were changed (IIRC about 1979). My understanding is that power trim/tilt was considerably different between the two and is not interchangeableThe lower units were a bit different over the years. The earlier ones had a straight skeg and it was changed to a swept design. I think it was in 1989 the driveshaft was changed to a finer spline. So pre 1989 and 1989 and later lower units are not interchangable |
Hilinercc
posted 09-28-2009 03:32 PM ET (US)
There is another aspect of the 70 OMC that you guys left out - The lost-foam casting intorduced in 1991. This model year they re-designed the cylinder head for the 2cyl. 50 and 3 cyl. 70. Tom C., if you have a 91 catalog, OMC illustrates this. The "old style" head had more fasteners and a different configuration of how the (3) seperate head pieces and gaskets went together. The newer head, Post 1991, had a (2) piece head that was less prone to compression/water jacket leakage and used fewer fasteners. Either one is fine. |
