| Author | Topic: 1997 Outrage 20, E-TEC 175-HP |
| Commander Coo1 |
I am finally re-powering my [1997 Boston Whaler OUTRAGE 20] with an E-TEC 175-HP. The motor comes with a Rebel propeller, so I want to know what pitch I should get. My previous motor was a [1997 Mercury 200-HP with carburetors]. With that engine [I] had a [Mercury] stainless 19-pitch propeller. [The boat's] performance with a heavy load, five people, freedive gear, 1/2-FULL fuel tank was 38-nautical miles per hour at 5,800-RPM. With a light load of two people and 1/4-FULL fuel tank, [the boat speed was] 42-nautical-miles-per-hour at 5,900 to 6,000-RPM. I am not sure if I should get the same pitch because it was almost under-pitched before. People keep telling me that this E-TEC 175-HP will be more powerful than the older 200 Mercury. Thanks for the input! |
Select a propeller pitch which permits the E-TEC 175-HP engine to reach its maximum horsepower output, which occurs between 5,500 and 5,600-RPM. See http://continuouswave.com/whaler/reference/ETEC_EngineRPM.html The boat speed information from your old motor will helpful in selecting the pitch of the REBEL propeller you plan to use with the E-TEC. We can pick a starting pitch based on the notion of the boat speed. If you went 42-nautical-miles-per-hour with the 200-HP motor, we can expect a boat speed with a 175-HP motor of (175/200)^0.5 x 42 = 39-nautical miles hour Let me convert this to statute miles per hour, as this is a more familiar unit for most people to work with for small boats not involved in long ocean voyages. 39-nautical-miles/1-hour x 1.1515= 44.9-MPH The gear ratio of the E-TEC 175 should be 1.85:1. Now we use the propeller calculator at http://continuouswave.com/cgi-bin/propcalc.pl to find the pitch. We enter the data as follows RPM = 5,600 The calculator predicts a pitch of 17.4. Try the REBEL 17 for starters. |
| Commander Coo1 |
Thanks a lot Jim. Did you notice any difference in power between your old motor and the ETEC? You had a carbureted motor before right? I am sure the ETEC will move my boat because I live near a guy who loves his 175 ETEC on his 25' wellcraft walkaround.I have wondered if the 175 ETEC will be satisfying for my outrage 20 or if I will be disappointed coming from the 200 mercury. I did get beat up pretty bad when I tried to use the speed of the 200, but I have added trim tabs so hopefully that will help. |
My new motor is the same horsepower rating as the 15-year-old motor it replaced. I did observe an increase in boat speed with the new motor. |
| Sal A |
I just replaced a 24 year old Johnson 200 with an E-TEC 150 on my Revenge 20 WT. My boat gets on plane quicker and is faster. I can not explain it, except to say maybe the Johnson was not propped right? |
| phatwhaler |
Commader, keep us posted with some numbes after your repower. I have the same boat as you and I'm interested to see what a 175 E-tec can do. I also agree with the 17P theory, especially if you're gonna have a bunch of weight in the boat. |
| Tohsgib |
25hp is 12.5% which I doubt you will notice much either way. |
| Commander Coo1 |
I will keep you guys updated, it should still be 3-4weeks until its up and running. Hopefully i can try out a few props, the mechanic i know says he has a few BRP props laying around. I would really like to see exactly what the new engine can do with the old prop.it might be worth it to but an evinrude engine/mercury prop hub |
| Tom W Clark |
Jim's calculations are quite accurate and his observations are spot on. If you want a Rebel, you want the 17" pitch for your boat/motor. You should also try the 17" pitch Viper as well. Regardless of whether the E-TEC 175 is as powerful as the old Mercury 200 and even regardless of whether it is as fast at WOT, it most certainly will feel much more powerful than the old motor, especially during acceleration, whether from a standing start or from one cruise speed to a higher cruise speed. Having just spent some days with an E-TEC 40 on the Kennebec River in Maine, I am more and more enamored with performance of the E-TEC outboard. Even on a miserable old 17' Logic, that diminutive two cylinder E-TEC 40 packs a real punch if you want it. The instant starting and quiet smoke free operation are very nice as well. |
| Commander Coo1 |
Tom, that's good to hear. I think that the cruise is really so much more important than the WOT anyway. WOT only really gets you bragging rights and an empty tank anyway. |
| Commander Coo1 |
By the way, which mounting hole would you suggest for the Outrage 20, 175 ETEC, and 17" Rebel prop? Thanks, I should have the motor in about 3 weeks. |
| phatwhaler |
I have my Mercury 200 on the 3rd hole up, which has decreased the porpoising significantly. FYI |
| Commander Coo1 |
The wait is killing me, but hopefully I will have the motor next Sunday. I have already run most of the cables: throttle, shift, harness, and new trim tab wires. As I am sure many people here also spend hours researching all things boating when their boat is broken down or weather is no good, I have been looking at the possibility of adding a manual jackplate. Does anybody have any experience with the late 1990's Outrage 20 with a jackplate and five to six-inch setback? Would the performance gains be worth the trouble? Would it be bad to put a 433-lb engine six-inches further back on a hull that is so sensitive to transom weight? I have seen people running the V-20 outrage with the anti-ventilaiton plate about four-inche above the keel with a five to six-inch setback. Could I expect similar results on the Outrage 20? |
| phatwhaler |
Not sure about a jack plate, however if you mount that motor 2 or 3 holes up then your going to have to trim the black plastic transom "cap". Otherwise the motor will not lay completely flat against the hull. By the way I saw a 20 Outrage with a 200ho E-tec the other day and the static trim with the big V6 looked pretty normal. |
| Commander Coo1 |
Well I have the new 2012 etec 175. I'm still in the process of rigging the motor. The dealer accidentally sent me a 19" Viper prop instead of the 17" Rebel. He said to try the viper and if I don't like it he will send a different prop which i think is a pretty sweet deal. So here are some preliminary photos, if i can get them to work. http://i6.photobucket.com/albums/y243/JCush/P8310506.jpg http://i6.photobucket.com/albums/y243/JCush/P8310512.jpg http://i6.photobucket.com/albums/y243/JCush/P9060514.jpg http://i6.photobucket.com/albums/y243/JCush/P9060515.jpg I will let you guys know how the rest goes and I will post performance stats if anyone is interested. |
| Commander Coo1 |
OK, so i finally got the boat out for some testing today. Viper 19 RPM MPH MPG Slip% I am planning on trying a Viper 16 tomorrow, hopefully that will get my RPMs up. I'm hoping for 5500ish But i am really enjoying the motor's starting ease, quietness, and fuel economy. I have analog gauges with the NMEA 2000 data displayed on my lowrance gps. looking at the AV plate at 4000RPMs there is quite a bit of water on top of it. I am also able to trim way out and still hold on. |
| Tohsgib |
If 3 holes up then you are only 1 hole from engine being all the way down correct? If so go up another 2. |
| Commander Coo1 |
I am here: o o o<- o I can go one hole higher, but I am already 1-2 in above the keel |
| Tohsgib |
You are 3 holes down and I doubt you will gain much by going up another 3/4" but you never know. |
| Tom W Clark |
Actually, the motor is now "two holes up" using the third set of holes. I recommend the motor be raised to the last set of holes or "three holes up" o |
| phatwhaler |
My 150 Merc EFI swung a 17p Merc Vengeance to 5400 RPMs on the same boat with a T-top. My current 200 carbed Merc swings a 19P Mercury Vengeance 5600 rpms. I would go with a 17P. The white motor looks good on there. |
| Commander Coo1 |
Thanks guys, I am definitely going to raise the motor some more. to "3 holes up." so that naming converntion just refers to how many unused holes are above or below the used mounting hole? Do you expect I will pick up any more RPMs? Data Summary: Viper 19
Ride in normal 1-2'chop: RPM MPH MPG So far, I do not really care for the viper 16, it has good acceleration, but I feel like I am constantly adjusting the throttle much more than the other props while cruising. and the gas mileage is quite a bit worse. I did not get a chance to try out the older OMC prop. |
| Commander Coo1 |
Thant last line should read "I did not get to try out the older OMC prop at WOT." |
| phatwhaler |
I think that bottom paint must be killing your speed. My 150 Merc EFI plain old 2 stroke would give me 41 mph and fuel burn at cruise was 3nmpg measured with a gps and my Navman fuel computer. Are you trimming the motor out when you take these readings? |
| L H G |
So, in answer to your original questions, if I am reading the data correctly, the new, hot, high technology, direct fuel injected 175 E-tec is nowhere near as fast as the old fashioned, throwback, cabureted Mercury 200. (Jim's terms, not mine!) Since both the E-tec and Merc use the same gear ratio, for the Evinrude to equal the Merc's performance, both would turn a 19" prop to 5900 RPM, as the Merc does. But it appears the Evinrude is 1000 RPM weaker. That's a lot, but it's what I would expect considering the HP ratings of both! Guess your friend gave you bad advice on the relative horsepower of each. Never understimate the power of a Merc 2.5 liter V-6, Optimax or conventional. |
| Peter |
Why would anyone think a 175 HP propshaft rated motor be more powerful than a 200 HP propshaft rated motor? Am I missing something? I recommend trying a Rebel propeller. The Viper propeller can produce some decent top speed but I have found that it does not perform well in the mid-range based on my experience with it. |
I don't think the VIPER 19 or the VIPER 16 are the optimum propeller for extracting the last few MPH of boat speed, if that is the goal. What we typically see in data about boat speed is that the last few hundred RPM of engine speed translate into the most effective gain in boat speed. This is because the propeller slip will usually be at a minimum, and a few hundred RPM of increased engine speed will add two or three MPH of boat speed. In the case of the VIPER 19 your engine speed is a bit low, only 4,900-RPM. In the case of the VIPER 16, your engine speed is on target, in the optimum range of 5,500-RPM to 5,600-RPM which I recommended to you in the first reply in this thread, but the propeller pitch is a bit low. With a 16-pitch propeller the boat speed will be limited by the pitch. Your reporting of SLIP is in error. Your SLIP values are not expressed as percentages. For example, your SLIP is not 0.09-percent but actually 9-percent. Your figures are off by a factor of one-hundred. Finding the perfect propeller can take some time. I experimented with over a dozen propellers on my boat before settling on one particular propeller as the best choice. Boat speed is a function of horsepower. When replacing a 200-HP engine with a 175-HP engine there is no reasonable basis to expect that the boat speed will anything but lower with an engine of less horsepower. Modern engines, in particular, tend to produce precisely the horsepower at which they are rated, due to the strict testing and limitation of exhaust emission requirements. |
| L H G |
I agree with Peter and JimH. Maybe you guys missed what the poster wrote in his opening statement: "People keep telling me that this E-TEC 175-HP will be more powerful than the older 200 Mercury." He also later wrote: "I have wondered if the 175 ETEC will be satisfying for my outrage 20 or if I will be disappointed coming from the 200 mercury."
| Tom W Clark |
Who would expect a 175 HP outboard to be more powerful than a 200 HP outboard? There is no need to debate Commander Coo1's satisfaction, we can just let him tell us about it. |
| prj |
quote: From the original post, "People". |
| Tom W Clark |
"People" also tell Larry all sorts of silly things. |
| Tohsgib |
The clowns are CHASING me! |
| Commander Coo1 |
Hello everyone, all of this prop testing has given me a new respect for the raw power that the 2.5 merc can produce! as far as being disappointed with the etec, I am not. The cruise speed remains at exactly the same speed and at about the same RPM as with the old merc. Noise, fumes, low speed fuel consumption and operational ease have improved greatly with the new motor. acceleration between the two engines up to cruising speed is pretty similar. It only lacks in top end, when cruising then hammering the throttle there isnt that huge instantaneous burst of speed like the merc had. but it is possibly that thrill that lead the merc to an early death! phatwhaler, yes these readings are trimmed out. jimh, i also noticed my error in reporting my slip, i did not mean to add the % sign, but i could not edit my post, so i just left it alone. also, your prop testing reference articles have been very helpful and informative. LHG, your observation about the ETEC being 1000 RPM weaker is not entirely evident, using the old vengeance prop on the merc most times i was near 20% slip at WOT whereas these Viper props have been closer to 9-12% if the vengeance had the grip that the viper has, i probably would not have been seeing those rpm numbers on the merc. on the other hand, if the merc had a better prop, the performance gap between the two engines would be even more significant. I am still trying to find a Rebel prop to try, I may also just get a hub kit and try a Mirage plus because I read that they are somewhat close in design and performance. I am going to raise the engine to the last set of holes this week hopefully. I think i will probably need the 15 Rebel and that is what I will order unless i find something better. my favorite prop so far has been the old OMC that I believe to be a SST, it is identicle to the old one in jimh's prop article that has the distinct ring on the hub to help diffuse exhaust gases. |
| Peter |
I currently use a 19 inch pitch SST propeller on the 150 Johnson on my Outrage 18 and it provides very similar speed versus RPM results as a the 17 inch pitch Mirage Plus propeller I used before. I have found that the ride comfort in a chop is better with the SST than with the Mirage Plus. With the Mirage Plus, the propeller transition between grip and no or low grip is more apparent. Once the Mirage Plus lost grip in a chop, it would seem to have a difficult time recovering. The SST does not seem to have this difficulty. |
| Tohsgib |
You are an anomoly Peter...we have said this dozens of times before :) |
| Commander Coo1 |
Well, I raised motor to the highest position, it increased my WOT RPM by 30! so instead of 5300 WOT I am now able to achieve 5330 RPM which is too little of a difference to tell if it is really from the height adjustment or if it is just a slight change in conditions. No GPS data yesterday so I dont know what it did to fuel mileage or speed. the boat seemed to get on plane a bit faster (not what i would expect) and handling was a bit more stable. overall a good change. I only lost grip once while driving in 1-2ft following chop while trimmed out at 4200 and turning. trimming back in fixed the problem. I have ordered a Rebel 15 that should be here in a few weeks. new height AV pic: |
| Commander Coo1 |
Well after buying a mercury hub adapter i was able to try my old vengeance 19 and a mirage plus 17 Mirage Plus 17, 50 gallons of gas, freediving/spearfishing gear, 3 adults, and coolers (meduim-heavy load) RPM MPH MPG Slip % 3800 29 3.6 7% 5200 41 NA 4% WOT performance was great in every way except for low WOT rpms Vengeance 19, 55 gallons of gas, 4 adults, cooler, freedive/spearfish gear (medium-heavy load) I am still waiting for the Rebel 15, it is in the shop but over here in the bahamas you have to actually be there at the dock when the shipping vessel arrives to claim your goods, which conveniently always comes to my island when i am to busy to leave work! but i still think it might be very good, i read that it is similar to the mirage plus which i liked very much other than the low RPMs I have also managed to get the SST 17 up to 5500 rpms and 44.1 mph with 8% slip with a slightly lighter load and better trimming |
| Commander Coo1 |
I know you guys have been on pins and needles! After 8 months my dealer finally sent my prop! I had a pretty heavy load, but found some smooth water and got a pretty good idea of my WOT performance.
Still a bit low... im not sure where to go from here. i am in the process of removing my bottom paint that is old and peeling so i hope to gain some from that. but i doubt i will get the 300 rpms i need. i like the feel of the rebel i wish i could get my rpms up. the motor is mounted in the highest position. i did not like how the viper handled on my boat, but maybe a 15 of the older style SST might work out well for me. or possibly an enertia from mercury in 15" Let me know if anyone has any ideas. |
| jmorgan40 |
Commander I just dialed in my 200 HO eTec on my 1987 Outrage 20 yesterday I was also running a 19 pitch on my old carbed Yamaha. Best prop for me was the rebel 17" pitch. I am turning 5600 rpm with the 17". I tried the 15" Rebel and the 18" Rebel and Viper. |
| jmorgan40 |
Commander, I also did not like the Viper pro at all. It had way too much torque and forced the boat to pull severely to starboard as soon as I got the RPS up. Very weird. |
| Commander Coo1 |
Yeah, i didnt care for the viper, it is good on my friends 19 mako that is quite a bit lighter. but didnt have the thrust to push my whaler too well. now i am at the point where i have pretty much 3 options: get a different prop and lose all the characteristics that i really like about the rebel/mirage get the mirage modified and have an unknown outcome and a prop i couldnt sell. stick with the rebel and enjoy the superb handling and not worry about the slightly low rpms (and hope to gain some when i finish sanding the bottom. |
| acseatsri |
With 4 adults, 50 gallons of gas, and a full 100 qt cooler on board, I'd say this qualifies as a heavy load and therefore the low RPM's aren't that bad UNLESS you run close to WOT with this kind of load all the time. |
| RMCCAIN |
Commander Coo 1, I have also went through your same trials on a 1992 Boston Whaler Outrage 19 II with a 150 E-TEC, having tried all of Evinrude Props, Vipers, Cyclones, Rebels, and SSTs, also Michigan Wheels, Powertech Props, Solis Props all to no good results, and have ended up with good and the best results with an Enertia, 15x 15 1/4, by Mercury, this prop gives the best I can get rpm's of 5350 at 39 mph. My boat also has bottom paint, T-Top, 3 batteries, 75 gallons of fuel, and the motor is also mounted as high as it can go. So it is not the most efficient on the water. My lake elevation is also at 3600 ft, so that takes a little away from the power of the motor. |
| Commander Coo1 |
I usually run between 3200 and 4200 rpm at 22 to 32 mph. it is still within the recommended operation range, just not the "optimal range" of 5500-5600 with a normal load. still fuel economy is pretty good with this setup, with a full load i was still touching 3.7 but usually around 3.5-3.6 and with a lighter load i was touching 3.9 with a usual economy of 3.7mpg. also, the rebel seems to stay hooked up like crazy, i did a full throttle trimmed up hard turn without breaking loose! also with the rebel my AV plate is above the water at 4000rpms which is an improvement. RMCCAIN, i have been looking closely at the enertia, but they dont come up used too often like the mirage i got for $150 on ebay. how do you like it compared to the rebel? do you still have low speed control for docking? does it tend to lift the bow or stern? thanks for the input! also does anybody know what kind of gains can be expected when removing old peeling bottom paint? |
| Tom W Clark |
Removing bad peeling bottom paint can have a HUGE effect on boat speed. Do not rush your bottom paint project; get it as fair as you can. It will be worth it. |
| Commander Coo1 |
I am waiting for a new sanding pad for my orbital sander... i started to use it and it broke abot 5 minutes into use... the joys of trying to accomplish anything in the bahamas! from what i have read, i see that there is usually a 1-2mph difference between new bottom paint and gel coat. with my slip numbers approaching 0%, that could easily make 200-300 rpm WOT difference i am looking for. My friends and wife think i am nuts doing all the work for a few mph and RPMs... oh well, there are a lot of nutty people out there (and on this site!) |
| RMCCAIN |
Commander Coo 1, Sorry for not getting back sooner. The Enertia is just overall better than the Rebel, even though the Rebel did very well and performed great in all areas, slow speed holding the boat on plane at around 21-22 mph depending on conditions, cruise speed was good and economy was good, it came on plane very quick with minimal bow rise and will hold in most trim conditions, yet would not get as high of rpm as I would have liked for this motor, around 5100 rpms at 39 mph full load. The Enertia now will improve on all of the above, planes almost instantly even if the trim is at more than 19 %, so I do not have to run the trim down just to come on plane, the prop feels stronger! The Enertia will also stay on plane at the same low speed 21-22 mph. Cruise speed will get between 3.6 and 4.0 mpg at about 29-30 mph. Also the Enertia will hold the boat with out porpoising at a much greater trim angle, enough to give a rooster tail, even though this doesn't help economy at all. As far as slow speed as in docking and tight spots, the Enertia is not a problem. I hope this helps. |
| Commander Coo1 |
Thank you for the update, i really hope to try an enertia soon. it really does sound like a great prop, and it would be my first choice if i was going to buy a new prop. what was your cruise economy with the rebel 15? i know you said you can trim way out without porpoising, but how is the stern lift? can it hold the bow down effectively in a chop? |
| Swellmonster |
225 efi, trimtabs, 17 rev 4 rocks. I could go to a 19, but who runs wide open? I love the tork and handeling. |
| Commander Coo1 |
Some may have already seen some of this info in another thread, but just to add some closure to this on incase someone finds this thread and wants to use it for a reference. (I find so many interesting threads that the OP never finishes once their issue is solved.) Mercury Enertia 15p mounted all the way up with no bottom paint. Vessel weight was about 3900lbs The first thing I noticed on the water with the Enertia was the holeshot was hugely improved over any prop I had tried. I found myself pulling back on the throttle much sooner to settle into cruise speed. RPM stayed constant while running through the chop much like the Mirage/Rebel. Midrange acceleration was also the best that I had experienced on this boat. Low speed control and docking was also just slightly below the Mirage/Rebel. I plan to keep the Enertia with the Mirage Plus as a backup. In another thread, Phatwhaler asked: "Could you shed some light on the difference in performance of the 200 Merc and the 175 E-tec. To answer his question with my most up to date experience, I would say that the E-TEC out performs my carbureted 2.5L mercury 200 in every way other than WOT speed. Now 43mph and was 48 with the Merc (but i dont remember the conditions the 48mph was under, i would guess it was with the wind and current, and with a very light boat.) Acceleration is better and cruise performance is a similar speed but more stable and I don't need as many throttle adjustments with the new E-TEC. The E-TEC uses about half the fuel over a diving or fishing trip, doesnt smoke me out when the motor is up wind of me, and is extremely quiet. The E-TEC also doesn't stall while idling for a long period. The E-TEC weighs about 30lbs more than the 2.5L mercury (398lbs) and this doesnt make any noticeable difference in the boat's static trim or seakeeping abilities. I am completely happy and wouldn't ever go back to the merc unless I was racing and needed the extra speed. As a side note, if I had put as much time into engine height and propeller selection I believe I could have seen 50mph with the mercury. -James |
| phatwhaler |
Thanks for the info. My old Merc runs pretty well, however I would love a new motor. Fourstrokes are great but I'm used to good holeshot and ability to plane out 7-800 lbs of people easily. |
