| Author | Topic: 1992 21 WALKAROUND with Honda BF250 |
| acseatsri |
I'm purchasing a 1992 Boston Whaler 21' Walkaround with a new Honda BF250. What size propeller? |
Based on some first-hand observations reported by Steve in an article at http://continuouswave.com/ubb/Forum6/HTML/001066.html when his 21 WALKAROUND was in its prime, the top speed of a 21 WALKAROUND boat when lightly loaded with a 200-HP engine was 42-MPH. Plugging this data into my Crouch's Calculator gives us a solution for weight and hull factor, which can then be used to predict the speed for 250-HP. But first we add 100-lbs for the heavier engine. The prediction is for 46.3-MPH. http://continuouswave.com/cgi-bin/crouchcalc.pl Finding the gear ratio and maximum rated engine speed of the BF250 from its specifications to be 2.00:1 and 6,300-RPM, then using that data in my Propeller Calculator to reach a speed of 46.3, and allowing about 8-percent for SLIP, suggests the pitch should be around 16.9-inch. http://continuouswave.com/cgi-bin/propcalc.pl On that basis, I would begin testing with a 17-pitch three-blade propeller that was a large blade area propeller, something like a Mercury MIRAGEplus 17-pitch. |
| bcoastal |
I think [a c.1992 Boston Whaler 21 WALKAROUND with a HONDA BF250] should be able to get better than 46 [MPH]. I have an Outrage with the Honda 250 and get 47 [MPH] on a four-blade propeller. I can look up exact size for you, [if you are] still looking [for a propeller]. |
| acseatsri |
My current OUTRAGE 22 with 225 E-TEC and T-top does 46 to 47 [MPH] lightly loaded and trimmed out, spinning a Rebel 15.5 x 17 propeller. The 21WA weighs 800-lbs more than the Outrage, and the beam is 12-inches wider than the Outrage. For now, both boats are sleeping comfortably in my backyard and will be until April 15th or so. When I do get the 21WA in the water, I'll post results here. I ended up with a 15.25 x 19P Michigan Wheel propeller, probably to be swapped for a ECO Enertia. |
| Peter |
The 21 Walkaround is built on the Accutrack hull which is a more efficient hull shape than the classic Outrage 22 hull shape. Despite the weight and beam increase, performance should be comparable to the Outrage 22. I'm not a big fan of Michigan Wheel propellers. They are fine to carry around as a spare prop but I think you can do much better. The Enertia is probably a very good choice. I think your ultimate pitch is in the 17 to 19 inch range and the Enertia comes in 1 inch increments so it should be easy to fine tune. |
The 21 WALKAROUND hull is more of a variable deadrise deep-V hull. I don't recall if Boston Whaler used the term Accu-Trak with that hull, but it seems to me to be quite different from later hulls that were given the designation of Accu-Trak. Accu-Trak hulls always seemed to be rather rounded, and those c.1992 21 WALKAROUND hulls are quite angular and have deeper V-hulls. I suspect a hull of that type may be harder to drive onto plane and keep on plane than the relatively modest V-hull of a classic 22-foot Boston Whaler hull. |
| Peter |
The post classic hulls use more lifting strakes than the classic hulls, the strakes run the entire length of the hull, they have no sponsons dragging through the water and at least at the stern, the keel does not come to a point as it does in the classic hulls. Thus, all of these differences make the post-classic hull plane easier than the classic hulls. This is why they achieve the same top speed despite increased weight for an equivalent length hull. See continuouswave.com/whaler/cetacea/cetaceaPage75.html for an image the stern hull shape of a 21 Walkaround. |
I'll be switched! That 21 WALKAROUND does have a rather rounded hull shape at the stern. Thanks for the pointer to those images. |
| gqwhaler |
I can tell you first hand this statement is true. "I suspect a hull of that type may be harder to drive onto plane and keep on plane than the relatively modest V-hull of a classic 22-foot Boston Whaler hull." I have logged thousands of miles on a 21 walkaround and my only complaint is this boat is stern heavy and takes alot of power to put and keep on plane. outboard #1 2000 Mercury 200HP EFI 2 stroke. Mercury Mirage plus 17P was ok max RPM just under 6000 and 43-44.5MPH. however in choppy seas prop would ventilate at cruising speed of 19-23MPH. maybe I should have dropped the motor down one hole? second prop was a Mercury REV4 17P this prop is awsome on this boat. no loss of speed, able to plane at slower speed and would never vent or cavitate. the stern lift this prop gives is a perfect setup in my opinion. outboard #2 Yamaha 200HP 4stroke 4cyl. prop Yamaha Reliance 17P with SDS. max speed is 42.5-43MPH at 5600RPM. this setup is good but just doesnt have the stern lift the REV4 had.of course you do have to take into consideration the Yamaha is around 80lbs heavier. I wish I could run the REV4 on the Yamaha but when I tested it it just clunked into gear so loud and at idle rattled badly, then the 4cyl just didnt have the snap the 2 stroke did and it seemed a bit sluggish. but once you got the RPM'S up it had the same top end speed. I hope my experience with this hull and props helps cheers Captain Billy |
| acseatsri |
Thank you for all the information! A question for Captain Billy- Do you have trim tabs, and if so, did they make a big difference as far as the stern feeling heavy? As far as the REV4 goes, it's only 14 5/8" diameter, but the Honda will swing a 16" prop. Are there any other larger diameter props with stern-lifting properties? |
| gqwhaler |
acseatsri, yes I do have trim tabs, and I feel they are a must have. with your Honda's weight I would think you would want the biggest tabs you can fit. I understand you could swing a larger diameter prop but that is only one of many factors in choosing the best one for your application. I have a REV4 in 17P that i am looking to sell but i think you will need a 19P for your 250HP. cheers Captain Billy |
