| Author | Topic: TURBO Offshore II Series Three-blade |
Here is some data from a propeller test I made a few years ago. I was doing some house cleaning, and I came across the raw data sheets from this test. I do not believe I have published this data before. There has been some recent discussion about TURBO-brand propellers, and here is a test of one of them. Thanks go to Tom Clark for providing the propeller for testing. Propeller: TURBO Offshore II Series Three-blade 15-inch diameter x 18-inch pitch Date: October 3, 2010 Location: Mullet Lake, Michigan, a large, fresh water, inland lake in northern lower peninsula Boat: Boston Whaler REVENGE 22 W-T Whaler Drive Engine: Evinrude 225-HP E-TEC, 2010 model year; gear ratio 1.86:1. (26:14) Test conditions: Test Data The data is raw data, not averaged or made in runs with or against wind and current. RPM MPH MPG LOAD Legend RPM = revolutions per minute per the digital NMEA-2000 tachometer Description of the propeller style from the manufacturer: "Exclusively designed for outboard powered offshore boats." Superlative load carrying ability and transom and bow lift for large, heavy offshore boats using outboard power. Provides outstanding speed and fuel efficiencies at cruise RPM, while reducing ventilation and slip normally caused by rough water and/or following seas. Excellent for 200 - 300hp V6 offshore-type applications in single or multiple engine configurations. Offshore II propellers also work well in sterndrive applications. Offshore II = 3-blade design. Analysis of Test Data The top speed of 41.7-MPH is in the lower end of the expected range for the boat when lightly loaded and in cooler weather. The fuel economy was not as good as had been obtained with other propellers in the mid-range cruising speeds. Fuel economy might have been affected by wind and waves, but in this data is generally lower than what is usually seen. |
A comparison of the TURBO Offshore II Series three-blade propeller can be made with three other propellers tested by referencing an earlier article at REVENGE 22 W-T WD with 225-HP, Three Propellers |
