ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Small Boat Electrical Perko Dual Battery Switch
Author | Topic: Perko Dual Battery Switch |
pcrussell50 |
posted 04-11-2011 04:32 PM ET (US)
My Alert or Montauk was set up by the previous owner for dual batteries. [The battery switch] has [positions marked] OFF-1-BOTH-2. "Both" would parallel [the two batteries]. Right now, the OFF position kills all engine functions, such as tilt-trim, and cranking for start, but the rest of the electronics still work in the OFF position, so the whole boat is not electrically dead, even with the selector in OFF. This is the way the previous owner set it up. He is a very experienced and careful mariner, as well as a CWW member. I'm thinking I'd rather change it so that the OFF position kills power to everything, but I don't want to do something not recommended or smart. Further, I don't even know if the switch will allow such a thing anyway. Here are the electrical customers that will still work even with the switch in OFF: Thanks for any tips/advice, or if this can even be done. -Peter |
posted 04-11-2011 08:15 PM ET (US)
There must be a direct connect to one of the two batteries which is supplying power to those loads. If you want to move those loads to be controlled by your OFF-1-BOTH-2 battery switch, disconnect the feed that powers them from one of the batteries and move it to the COM terminal of the battery switch. |
andygere |
posted 04-11-2011 08:31 PM ET (US)
The direct connect may be on the batteries, or it may be on the hot lug on the battery switch. You may find a cable wired to the hot side that powers a terminal block that all those items are wired too. I like your idea, off should mean off. If the boat were kept on a mooring, keeping power to the bilge pump may have been required. |
posted 04-11-2011 09:21 PM ET (US)
Yes, I agree with Andy: OFF should mean everything is off. On my boat that is how I have it wired, except for one sump pump which is fed directly from a battery. In that way, I can have everything electrical shut off except the one sump pump. That pump is controlled by its own switch and can be left in an automatic operating mode so it will evacuate water from the deepest compartment in the boat. In that way I can leave the boat for a few days without worrying about it being flooded with rain water. |
contender |
posted 04-12-2011 10:22 AM ET (US)
Yes and Yes, Off is off and everything should be off period. |
Jefecinco |
posted 04-12-2011 07:31 PM ET (US)
Many non-trailerable boats are wired so that when the battery switch is in the OFF position the bilge pump continues to be connected to a battery for obvious reasons. The reasoning may be applicable for smaller boats kept in the water. Butch |
posted 04-13-2011 12:10 PM ET (US)
In general, one can say that distribution of DC electrical power on a boat normally does not involve any devices which are self-aware, and the behavior of the devices will conform to the fundamental laws of Physics, according as they are wired together. If you experience an unanticipated behavior from electrical devices, the root cause is most likely from the manner of their interconnection and not from some new phenomenon previously unobserved. As for the question of what is the proper way or the best way to interconnect devices in the distribution of DC electrical power on a small boat, there is some room in this realm for a variation of opinion, and we have seen that demonstrated here. |
pcrussell50 |
posted 04-13-2011 03:31 PM ET (US)
Andy, Yes, there is a terminal block that the non-engine-function customers are wired to. I'll look into wiring it so that OFF is off this weekend. And yes, it is trailered only, so I don't need auto-bilge-pumping capability. Thanks to all. -Peter |
pcrussell50 |
posted 04-30-2011 02:05 AM ET (US)
OK, I finally did it. I wired it like this: http://continuouswave.com/whaler/reference/dualBattery.html Now, OFF is officially, off. -Peter |
