| Author | Topic: VHF Marine Band Multi-Band Radios |
There are several hand-held radios that provide a Marine Band VHF Marine radio and transceivers or receivers for other bands. The usual combinations are to add to the VHF Marine Band a Family Radio Service (FRS) transceiver, an FM-Broadcast Band receiver, an AM-Broadcast Band Receiver, and an Aviation or Aircraft Band receiver. A brief summary of the frequencies, modes, power levels, and channelization for those five bands follows> VHF Marine Band Family Radio Band FM-Broadcast Band AM-Broadcast Bandp Aircraft Band |
The typical multi-band radio with VHF Marine Band features will usually have a transmit capability on the Marine Band and FRS Band. The broadcast bands and aircraft bands will be receive only. I am interesting in compiling a list of hand-held (or fixed mount) radios that are VHF Marine Band and multi-band radios. I can start the list with these: West Marine VHF 250 (no longer made) Standard Horizon HX470 (no longer made) (This radio also had Multi-Use Radio Service MURS capability.) Standard Horizon HX471S (not sure if still in production) Are there any hand-held radios in current production that combine a VHF Marine Band radio with a Family Radio Service radio? |
| Chuck Tribolet |
One important note is that if the radio can transmit in the FRS band, it cannot have a removable antenna, which means you cannot use your boat's antenna to get better range in the marine VHF band. My hand-held is a Standard Horizon HX470S. It's a decent
The MURS band is better suited to combining with a VHF Marine Band radio because MURS is allocated on channels just below the Marine Band, from 151 to 154-MHz. Also MURS is a 2-watt power limit. That means MURS might be able to transmit on an antenna tuned for the VHF Marine Band, assuming the antenna was not a really sharply tuned, narrow band antenna, without having the VSWR be too high. The 2-Watt power is 6-dB more power than FRS radios. On the other hand, a UHF handheld radio probably has a more efficient antenna than a VHF handheld. MURS is mentioned as being used by some government agencies. I don't know if they are on the same channels as the public. Also, the feds may be using encrypted transmissions on MURS channels. See |
It appears that MURS radios can be used with an external antenna to increase range, at least that is the inference I get from this advertisement: http://shop.murs-radio.com/MURS-Base-M538-BS.htm and confirmed by the FCC description: http://www.fcc.gov/encyclopedia/multi-use-radio-service-murs-0 |
