1994 OUTRAGE 21 Deck Plates and Hatches
Outrage 21 Jmac
Postby Outrage 21 Jmac » Fri May 29, 2020 3:36 pm
I want to replace the deck plates and hatch on my 1994 Outrage 21
Give me a suggestion where to find replacements deck plates and replacement hatches.
Thanks—John Mac
Re: Deck Plates and Hatches
Postby Phil T » Fri May 29, 2020 8:17 pm
Take some measurements of the outer ring diameter and the actual cutout of the deck cover.
https://beckson.com/prydp.html
Drill out the rivets, seal the edge with sealant and install the new deck plate.
Re: 1994 OUTRAGE 21 Deck Plates and Hatches
Postby jimh » Fri May 29, 2020 8:20 pm
Within the last three years, I ordered replacement circular deck pry-out access plates directly from Beckson in the original Desert Tan color.
I also found OEM replacement hatches.
These were for a 1990 boat.
See
Beckson deck access plates
viewtopic.php?f=6&t=2406
And
Pompanette Hatches
http://continuouswave.com/ubb/Forum3/HTML/017057.html
roundle1979
Postby roundle1979 » Wed Jun 03, 2020 8:42 am
I have had good luck purchasing parts for my 2004 Boston Whaler Nantucket 190 from Nauset Marine:
https://www.nausetmarine.com/deck-plates/
JSK55
Postby JSK55 » Wed Jun 03, 2020 11:10 pm
Pretty sure the 1994 deck plates aren’t Beckson as they are not pry-out design. The 1994 has a toggle handle design in the deck plates. Definitely not Desert Tan but white hull with Pantone gray deck and interior in 1994 so the deck plates were white in color.
JSK55
Postby JSK55 » Thu Jun 04, 2020 12:17 pm
I looked back at my notes and found Viking Marine as the supplier of deck plates on the mid 90's Whalers. Not sure if they are still available or not.
Postby jimh » Thu Jun 04, 2020 7:32 pm
Postby Phil T » Thu Jun 04, 2020 7:43 pm
Note all the items in Jim's link are either sold out or discontinued.
