MISCHIEF 15: Battery Hold Down
Churchalla
Postby Churchalla » Thu Jul 23, 2026 12:35 pm
Q1: how can the battery on a 1989 MISCHIEF 15 be accessed in order to thread hold down straps?
Q2: is there a special method to re-thread the battery strap that holds down the battery?
BACKSTORY
My family owns a 1989 MISCHIEF 15. The boat battery is located in the stern compartment. It is positioned aft of the fuel tank and it is rather far back. The access holes in the stern seat are not sufficiently large to get a hand far enough into the compartment to properly re-strap the battery.
ASIDE
To find others who own a MISCHIEF and get advice from them is hard.
[Moderator;s note: This post has been separated from a older thread which was discussing several topics related to restoration projects on a different MISCHIEF 15 which was revived after several years. Please do not revive old threads and change their topic. A duplicate of this post was also posted and revived another older thread on a different topic. Please do not post multiple copies of the same post in different threads. Posting the same questions in multiple places only tends to dilute the information content of the thread. By collecting all your posts about how to re-install battery hold down straps on a 1989 MISCHIEF 15 into this thread, this thread will become the thread most focused on the topic of re-installing battery hold down straps on a MISCHIEF 15 and thus will be very likely be located in the future if anyone searches for information on how to re-install battery hold down straps on a MISCHIEF 15.]
Re: MISCHIEF 15: Battery Hold Down
Postby jimh » Fri Jul 24, 2026 1:05 pm
Churchalla wrote:Q1: how can the battery on a 1989 MISCHIEF 15 be accessed in order to thread hold down straps?
If the only possible way to reach the battery is via the method you are trying to use, and the battery is aft of the fuel tank, then the only reasonable conclusion is the battery must have been put in place before the fuel tank. With that foundation, you would need to move the fuel tank out of the way to get to the battery.
