Q1: where can information be found that shows all the layers of various Boston Whaler boats?
Q2: where can exposed foam be visible [specifically in a 1999 OUTRAGE 18]?
BACKSTORY
Now that I have [a recently purchased 1999 OUTRAGE 18] in my possession, I am trying to figure out how it was built. I can stick my head down in the bilge from the rear seat opening and see the [fuel] tank and and a little ways up the boat. I am trying to figure out where the hull is Unibond and where there is deck over the top.
1999 OUTRAGE 18 Unibond Hull Construction
Re: 1999 OUTRAGE 18 Unibond Hull Construction
I am unaware of any source of information that individually documents exactly how every Boston Whaler boat was constructed. The principal feature of all Boston Whaler boats is the construction of the hull using the Unibond Hull method. The details of the Unibond Hull method were revealed in the initial patent obtained by Boston Whaler in the 1960's. For more information on the Unibond Hull method read:JoeNorm wrote:Q1: where can information be found that shows all the layers of various Boston Whaler boats?
Original Patent
of the Boston Whaler Hull Construction
https://continuouswave.com/whaler/refer ... atent.html
Original Design and Conception
of the 13-foot Whaler Hull
https://continuouswave.com/whaler/refer ... esign.html
BOSTON WHALER FACTORY TOUR
Where Legends Are Made
https://continuouswave.com/whaler/refer ... ctory.html
From the earliest days of production of Boston Whaler boats, the use of additional pre-molded top "caps" that were added to a basic Unibond hull structure was employed. The top caps were built in the usual method of employing female molds and in-mold lamination and build-up of the structure.
Early examples of this method of adding top caps to Unibond hulls are the c.1970 OUTRAGE 21, the MENEMSHA 16, and the REVENGE series.
Typically the only location on a Boston Whaler boat where exposed foam can be seen will be in the fuel tank cavity. The foam was typically used to encapsulate the welded aluminum fuel tank in order to securely hold it in place.JoeNorm wrote:Q2: where can exposed foam be visible [specifically in a 1999 OUTRAGE 18]?
In the c.1990's Boston Whaler began to mold the cockpit deck top cap layer without any opening over the fuel tank. This change left the fuel tank inaccessible. If some failure or problem demanded access to the fuel tank, the method suggested was to cut an opening in the cockpit deck, usually at what was already a false joint-line created in the molded deck. When the fuel tank was repaired or replaced, the temporary deck cut-out section would be rebounded to the rest of the deck.
The thinking behind this change in construction was to reduce the ability of water on the deck to get into the fuel tank cavity area due to poor sealing of what was a removable center section in the deck that would provide full access to the fuel tank area.
So when peering into the bilge area, the portion that the tank is sitting on is the inner skin of the unibond and should be a continuous, impervious layer through the entire length of the boat?
This 1999 Outrage appears to have a large removable deck section over there fuel tank. The console would have to be removed in order to lift it.
