  Transom Delamination
Author Topic:   Transom Delamination
wwbach posted 01-11-2005 03:06 PM ET (US)   Profile for wwbach   Send Email to wwbach
I'm considering a classic 18 OR and the broker mentioned that there is a small crack or delamination of 6-8" on the top of the transom where the liner attaches to the hull.
Is there an easy way to tell if there is water in the transom?
Is this sort of thing common?
Can it be repaired effectively and permanently?
What should a repair of this nature cost?
Should I skip this boat and look for the next one? Otherwise, it looks to be in reasonable condition for the vintage and price.
Thanks. -- Bud
DaveS posted 01-11-2005 03:30 PM ET (US)     Profile for DaveS  Send Email to DaveS
Bud,
I believe it is called a green line separation, not that all uncommon in whalers. If you do a search on it you should find more than enough information to make an informed decision...here's a couple...
http://continuouswave.com/ubb/Forum3/HTML/006825.html
http://continuouswave.com/ubb/Forum3/HTML/004292.html
Good luck...
DaveS
Buckda posted 01-11-2005 03:45 PM ET (US)     Profile for Buckda  Send Email to Buckda
DaveS - The Outrage 18' does not have a "green line". The 17', 15' and 13' hulls have this line, but at least the 18' Outrage does not.
That being the case, is this a bigger cause for concern on an Outrage hull, given that there was never a strip of missing gelcoat as is present on the smaller hulls?
DaveS posted 01-11-2005 06:05 PM ET (US)     Profile for DaveS  Send Email to DaveS
Thanks for the correction...I was assuming they were all constructed that way...learn something new everyday! :)
JohnNorthEast posted 01-11-2005 06:50 PM ET (US)     Profile for JohnNorthEast  Send Email to JohnNorthEast
I would treat any transom delaminating or crack as serious and in need of repair as water will lead to rot. I purchased a 22 whaler last winter which was in excellent conditioning except a “minor transom crack” similar to as your describe.
While I did have several estimate and was told I could run the boat without repair or that the repair could be cosmetic and repaired for less than 600.00, I also was told that eventually I would have to rebuild the transom as the wood will rot.
I ended up having transom rebuilt by a professional fiberglass guy. Yep there was water damage, although not as serious as it could have been. No regrets, stronger than new and looks as if no one ever touched it. I’d consider treating it as a necessary transom repair and use the opportunity to knockoff a few thousand and then have a transom rebuilt for about the same.
DaveS posted 01-11-2005 07:44 PM ET (US)     Profile for DaveS  Send Email to DaveS
JohnNorthEast,
Prior to purchasing my Newtauk I had the opportunity to pick up a 1984 18' outrage...I seriously thought about it but finally decided against it...one of the main reasons was those cracks on the transom...even though the dealer assured me they were "cosmetic"...I've often wondered if I made the correct decision...reading about your whaler confirmed a bit more the one I made was the right one for me...I've sinced talked with the indivudual who did pick up that boat and he really didn't say too much about the transom...did a ton of work to it and sold it...Good points...
DaveS
wwbach posted 01-11-2005 08:36 PM ET (US)     Profile for wwbach  Send Email to wwbach
Since I can't easily look at it myself (1100 miles away), I think I'm going to make an offer contingent on a marine surveyor having a look at it to determine if there has been water intrusion. I figure it is cheap insurance. If it is cosmetic, I'm sure it can be repaired fairly easily and may provide further negotiation room-- I just don't want to deal with a rotted transom!
-- Bud
wwbach posted 01-11-2005 08:46 PM ET (US)     Profile for wwbach  Send Email to wwbach
BuckDa, I wonder if the OR is the same style of construction as the "green line", just that it is covered with gel coat.
Also, anyone care to comment on what may have caused this? Something with the engine? Wrong trailer? Just a bad way to put the hull and deck together?
Tom W Clark posted 01-12-2005 11:28 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
The green line is there on the larger Whaler hulls, just covered with gel coat. The construction of the hulls is the same.
As pointed out, transom separation at the green line is not uncommon. I would suspect swollen plywood as the result of water in the transom. It could be minor or it could be major.
It would be best to get the advice of a professional who actually sees the boat in question.
The professional repair of a minor transom seam separation might cost $500 or so and would involve the removal of the motor(s).
wwbach posted 01-12-2005 12:55 PM ET (US)     Profile for wwbach  Send Email to wwbach
Tom or anyone listening, What exactly is the 'green line'? I'm guessing it is where the upper deck is bonded to the hull at the transom. If this is the case, is the plywood in the transom fully encapsulated in fibreglass before the upper deck is attached? If this were the case, it would seem unlike that the split/crack/delamination would cause water intrusion into the transom. It would seem to me that it is just the deck separating from the hull and it would be straight forward to bond it back together and repair the gel coat. Now if the separation has been caused by water in the transom swelling and causing the damage, it is a whole different ball game!
I agree, I need to have a professional look at it. If I get the pictures the broker promised, I'll post them for grins.
-- Bud
wwbach posted 01-17-2005 04:37 PM ET (US)     Profile for wwbach  Send Email to wwbach
I finally received some pictures of the delamination at the transom:
[IMG]http://img.photobucket.com/albums/v359/wwbach/MVC-004S.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v359/wwbach/MVC-002S.jpg[/IMG]
Obviously I would want to have the transom checked for water/rot and have this repaired correctly, but would this be a reason not to buy this boat assuming the price is reasonable?
Any other comments or suggestions about how to repair it or might cause this?
Thanks. -- Bud
wwbach posted 01-17-2005 04:40 PM ET (US)     Profile for wwbach  Send Email to wwbach
Buckda posted 01-17-2005 04:53 PM ET (US)     Profile for Buckda  Send Email to Buckda
Bud -
Good news is that it appears that the owner recognized it as a potential problem and appears to have taken steps to prevent water ingress.
I was somewhat suprised by these photos, as I'd never seen or heard of this problem on any but the smaller (17' and smaller) classics.
1. It would affect the price I was willing to pay, because there are boats out there that don't have this problem.
2. It would not be a complete deterrent to purchase, but the expectation on my part would now be that I had some restoration work to do before the boat was ready to be used again.
Just my thoughts.
Good luck - I hope to be there in Lake Michigan when you take whatever boat you buy on it's maiden (to you) voyage.
Dave
JohnNorthEast posted 01-17-2005 06:16 PM ET (US)     Profile for JohnNorthEast  Send Email to JohnNorthEast
Well, it doesn’t look serious and it has been somewhat controlled, but who knows exactly when the “fix’ occurred. I would add that it is impossible to say from this picture(s) if water has set in and, if there is rot. A water meter will probably show evidence of water in the transom. I would look to how well this motor is attached- and in a related way, was the motor reattached and over tightened etc. Look for compressed wood by the bolts for example. Also, perhaps ( and I mean perhaps ) this sort of damage could have occurred from backing into to something maybe once or twice? Obviously, If you can negotiate a price reduction and simply get the area fixed then it will be a better boat with “no worries”.
wwbach posted 01-31-2005 08:57 PM ET (US)     Profile for wwbach  Send Email to wwbach
As of now, this boat is on hold for me. I have a contract pending on another 18 Outrage.
17 bodega posted 01-31-2005 11:17 PM ET (US)     Profile for 17 bodega  Send Email to 17 bodega
I have a little of that problem but I stuffed some poly resin in there. Gunther told me ..." oh yeah... they all do that... stop worrying and go fishing..."
