  Power Loss Problem cont.
Author Topic:   Power Loss Problem cont.
Salty Tricks posted 04-19-2005 09:54 AM ET (US)   Profile for Salty Tricks   Send Email to Salty Tricks
1985 Johnson 90 HP.....Runs fine for several minutes than loses power... I have changed the water separator, the quick disconnect, and determined it wasn't a venting problem by removing the fuel cap from the Pate tank during running. The motor throttles to full power when not in gear. When in gear she will not get full power. It will surge with power when I engage the pushbutton choke. Before condemning the VRO anything else I should try?
rmart posted 04-19-2005 10:22 AM ET (US)     Profile for rmart  Send Email to rmart
I had a similar problem a couple of years ago with my 1987 Yamaha 115hp. You may read this link to see what others recommended to me.
www.continuouswave.com/ubb/Forum3/HTML/004389.html
In the end the problem was solved and to this day, I am not sure which fix corrected the problem. However, I have not had another problem with the engine now that I run a De-Carb can at least once a summer and have tightened all fuel fittings and lines to remove any air.
Chuck Tribolet posted 04-19-2005 10:24 AM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
FTR, the original thread was:
http://continuouswave.com/ubb/Forum3/HTML/008232.html
Salty Tricks posted 04-19-2005 02:29 PM ET (US)     Profile for Salty Tricks  Send Email to Salty Tricks
Me Again Yeah Chuck I am running out of options. A local mechanic says it's unlikely it's the fuel pump as pumping the primer bulb would have resulted in increased RPM....it did not. He thinks it might be water in the carbs. Assumimg he is right... can the fuel bowls in the carbs be drained off? Will WaterZorb or Dry Gas along with changing/or emptying the separator/filter eventually clear this?
WHALER27CC posted 04-19-2005 02:59 PM ET (US)     Profile for WHALER27CC  Send Email to WHALER27CC
Start with the least expensive first....
Primer bulb
Spark Plugs
Fuel pump
Power pack
Stator
Putting the engine under load when the problem happens would seem to indicate to me that its starving for fuel, so thats where I would start. Oddly enough the wrong spark plugs can mimic the same problem.I wouldnt think the VRO would be the problem given the description.
What kind of maintenance have you done recently to the engine????Have you replaced any of the above in the last 3 yrs or so???
Peter
NewportMe posted 04-19-2005 03:37 PM ET (US)     Profile for NewportMe  Send Email to NewportMe
I had a bad power pack and had no fire on two cylinders. In neutral or on muffs you could not tell. Under a load it wouldn't turn 1500 RPM
Vince posted 04-19-2005 09:39 PM ET (US)     Profile for Vince  Send Email to Vince
Salty, It's a stretch but try draining down the carbs first. You'll see small drain screws on each carb. open them, let them drain, and pump fuel from a source that you know is clean. Tighten everything up and see how she runs. If the problem persists, it's most likely a power pack issue. Try this and post the results. There is so much good input from everyone I'm sure you can solve it. I had the same engine on a service call last year with similar symptoms. Checked EVERYTHING! Before I tied the customers anchor to my legs and threw myself overboard, I went back to the shop, grabbed a helper,went back to the boat. Sea trial went as follows, had helper drive the boat,got underway,and when we put the coals to it,the fluctuations started, I then began to check everything when I inadvertantly hit the engine harness. It ran like a swiss watch. Started grabbing different areas of the harness on the port side near the solenoid and found it was a wiring issue. Replaced the harness and have not heard anything since. Let me know how it works out.
where2 posted 04-19-2005 11:47 PM ET (US)     Profile for where2  Send Email to where2
The ability to throttle to 5k RPM out of gear takes so little of the carburetor fuel delivery that it is NOT a good indication of carb function. (unlike an automobile which has an accelerator pump)
Thus, the fact that you note that the engine springs to life in gear if the choke is pushed, notes to me that ONE or more of your high speed jets in your 2 double barrel carburetors is plugged. With one or more of the high speed jets plugged, the choke acts to add additional fuel modifying your lean mixture on the cylinders which were not being supplied adequate fuel, and and making your cylinders with OK high speed jets run rich. The result will be the momentary burst of power you have noted. (been there, done that on my 70Hp 1985 Johnson)
The reason you get a momentary burst of power by pressing the choke is because the choke is actually a "primer solenoid" on the 1985 electric start models. (yes, I have the service manual in front of me). It squirts a tiny burst of fuel straight into the engine, follow the hoses and look for yourself.
The fix is to remove the carburetors and rebuild them with "rebuild kits" available from your local OMC dealer. The kits will set you back roughly $20 per carburetor which is a bargain in comparison to some Yamaha kits I've encountered. I used to advocate simply opening up the carbs and cleaning them, but after discussing that with my mechanic he noted that the kits are cheap $20 each, and that some of the gaskets (especially on the fuel pickup tube) are only designed to be compressed once, and may leak air if re-used. Thus, I now advocate new gasket kits on the advice of a trusted mechanic, especially since OMC kits are inexpensive!
You're welcome to "try" running a water absorbing product through the fuel system, but I WOULD NOT, because it is NOT likely to cure the real problem with the carburetor. It may be more likely to cause something like this: http://www.tfn.net/~wendtm/damaged_piston.jpg Ironically, that piston is out of a 115Hp OMC engine block... My mechanic noted that most of the pistons he sees like mine in the photo were a result of the high speed jet getting clogged, and the owner continuing to run the engine hoping that it would magically "clear up", rather than taking the engine to him to have the carburetors rebuilt. As he noted: After the engine trashes a piston like this, I have to rebuild the block, and I still have to rebuild the carburetors. Otherwise, the new piston will look just like this before the engine gets out of break in... The owners think they are saving a buck by not bringing the engine in to have the carbs rebuilt, and they end up spending $2000 to rebuild the block, in addition to rebuilding the carbs...
Salty Tricks posted 04-20-2005 08:11 PM ET (US)     Profile for Salty Tricks  Send Email to Salty Tricks
Well I thought I came across the problem when one of the spark wires came out of the boot...but I replaced the wires and still same problem. I will have to wait til the weekend to go through the entire fuel line and see what I got. I believe I am resigned to the fact that the carbs may be clogged. Question...Are rebuilding carbs a big deal. I have done automotive carbs in the day but cringed when I had to do idle and mixture adjustments etc. Is this best left to a pro?
Nonetheless I do want to thank you folks again for all your input...it gives me alot to check on, but at leat I have a plan. thanks
Salty Tricks posted 04-20-2005 08:42 PM ET (US)     Profile for Salty Tricks  Send Email to Salty Tricks
Sorry....one other thing
Some have suggested to look for other things other than fuel problem.. Wouldn't the fact that the power is briefly restored when I press the choke/primer solenoid negate the problem being anything else but fuel system?
Chuck Tribolet posted 04-21-2005 11:49 AM ET (US)     Profile for Chuck Tribolet  Send Email to Chuck Tribolet
Yep, the fact that it picks up when you hit the prime button
indicates that the problem is fuel.
Bthom posted 04-21-2005 11:56 AM ET (US)     Profile for Bthom  Send Email to Bthom
Salty,
If initiating the choke switch rectifies the problem then it is a cinch your motor is too lean when this happens. The fact that it only happens after a period of time indicates a fuel delivery problem but squeezing the primer bulb does not help so it isn't the pump at fault. It sounds like you have a partial blockage of your fuel system,downstream of your pump. I would inspect the float valves and seats in the carbs, and ensure they are capable of passing a good volume of fuel.
Good Luck,
Brian
where2 posted 04-22-2005 01:20 PM ET (US)     Profile for where2  Send Email to where2
I continue to stand behind my previous statment that the carbs need rebuilding, kits are roughly $20 each, and it's not incredibly difficult.
Would you like me to shoot photos while I do the carbs on my 70Hp Johnson. I've had the kits at the house for months now, but the little nagging 15' Rage has been pestering me to be completed, so I have been putting off the carbs on the 15' Sport.
Honestly, outboard carburetors are not drastically different from their 4-stroke automotive cousins. They are technically less complex since they do not have accelerator pumps. If you had success in the past with automotive carbs, then a 2-stroke will not be that difficult. I'll see if I can email you some helpful information on the subject.
WHALER27CC posted 04-22-2005 05:32 PM ET (US)     Profile for WHALER27CC  Send Email to WHALER27CC
I will say this.....I oddly enough would check your spark plugs!!The dealer I used to use put the wrong plugs in my old twins one time and it did EXACTLY the same thing.I would pump the bulb at higher speeds to keep the rpms up. He put the motors on muffs and tested them for everything it seemed, and when he double-checked the plugs they put in during the spring tune-up......It turned out his mecjanic Cletis put in the wrong plugs!!! Never thought it possible ,that e mechanic would miss by that much, or that wrong plugs could do that, but sure enough they did. Needless to say thats why I dont use Gomer, Cletis and their dealership anymore.
Peter
myakka posted 04-22-2005 05:52 PM ET (US)     Profile for myakka  Send Email to myakka
With my 1989 Johnson 50 with VRO, a crack in the oil tank let in enough water to make the engine loose power intermittently and occasionaly stall.
Mike
CHRISWEIGHT posted 04-22-2005 05:58 PM ET (US)     Profile for CHRISWEIGHT  Send Email to CHRISWEIGHT
peter
I was avoiding posting but we had exactly this problem on our two stroke engine two weeks ago, it would start fine and then lose power. we stripped the carbs checked the fuel changed tanks and as a last resort changed the plugs.
engine went like stink 36 miles one afternoon without a missed beat,if it does'nt work you have spent $10 but at least you will know.
regards chris
where2 posted 04-23-2005 06:25 PM ET (US)     Profile for where2  Send Email to where2
Sent email with helpful hints on disassembling the carbs, good luck!
Salty Tricks posted 04-23-2005 08:58 PM ET (US)     Profile for Salty Tricks  Send Email to Salty Tricks
I am most grateful for all your input. I am resigned to believe it is the carbs as Where2 and others have suggested. The spark plug issue is interesting in that I was confused as to the correct plug. West Marine and the Champion site says a Champion 931. I actually purchased the Stainless equivalent. However my Clymer says its a QL77JC4. I believe this is a Champion new number 828-1 plug. What's the right plug? Nonetheless I reiterate...would wrong plugs be temporarily corrected by engaging the primer solenoid.
Rain today(Saturday in NJ) stopped me from do anything to the boat.
where2 posted 04-23-2005 09:22 PM ET (US)     Profile for where2  Send Email to where2
From Page 3-6 of the "1985 OMC 2hp-V6 Recreational Models Service Manual"
5 thru 90Hp, 120Hp and 140Hp: running sustained low speed should use QL77JC4 or L77JC4. Same engines running sustained high speed use: QL78V or L78V.
115Hp and V6 running sustained low speed: QUL77V or UL77V. Sustained high speed: QUL77V or UL77V (not a typo, those were the same numbers for either application on the 115Hp and V6)
WHALER27CC posted 04-23-2005 11:42 PM ET (US)     Profile for WHALER27CC  Send Email to WHALER27CC
Where2 ....Once again a wealth of knowledge!!
Salty............In answer to your question, Yes. The plugs would cause this problem if they are wrong. I do believe that you may have the wrong plugs in after all, based on the numbers you posted.Change them, you'll have very little to lose, and much to gain.
Peter
Salty Tricks posted 04-24-2005 10:15 AM ET (US)     Profile for Salty Tricks  Send Email to Salty Tricks
Switched plugs this morning and still same problem. I will pull the boat this afternoon and rebuild the carbs this week after I pick up the kits. It will be good experience for me since I also have a 200 HP Evinrude on my other boat with similar carbs. You guys have been great. I will report back with the results. Special thanks to Where2 for the carb re-build info.
Mike
Salty Tricks posted 06-06-2005 09:44 AM ET (US)     Profile for Salty Tricks  Send Email to Salty Tricks
This is a long time coming however I wanted to say thanks to those of you who helped me out with this. I finally got around to rebuilding the carbs and the Montauk now goes like a bat out of heck. Thanks again for all your input.
