| Author | Topic: OMC Outboard: Life Expectancy Without VRO |
| beaufort |
Are my 1988 Evinrude V-4 motor's days numbered now that I'm mixing and not relying on the VRO? I'd love to hear how long yours ran after you unhooked and capped off your system. Chip's Ahoy |
| where2 |
My 1985 70Hp OMC has been running without a drop of VRO mixed fuel since I bought it in 1996, and who knows how long before that. It was capped off when I bought it from the original owner. I had it out on Saturday, and it ran like a champ! On the other hand, my 1995 Rage is still running with its VRO hooked up. It's nice to be able to dump fuel in the tank and not have to measure-and-mix. |
| john anderson |
where2 --do you use the recommended OMC injector oil in your RAGE? Have you tried other oils? |
| DillonBW |
1990 Johnson 60-HP, been non-VRO since purchased. Only problems seem to be that I need my water pump and Thermostat replaced. Si |
| c_mccann |
I had a Johnson 140 with VRO. I smoked three powerheads due to VRO failure, whatever that is--air bubbles, bad unit? On powerhead number three, I was ready to kill someone. All powerheads had under 100 hours on them and I baby all my equipment. The mechanic suggested I should now disconnect and run premix. Huh? How about suggesting that $10,000.00 ago--you %@#*! Instead, I disconnected the whole Johnson and connected a Honda. VRO: Very Rarely Oils. All sarcasm aside, I heard that if they work, they are great, mine was a bad apple. |
| Sheila |
We use, and like, the [fuel-oil mixing pump] on our Suzuki 200 and the little Suzuki 4 troller (they came with the Revenge. Winkie's 1984 Johnson V4 90 had been disconnected before she moved to our house. Hinano Girl's 1973 Johnson 65 is pre-VRO. (Yes, the newest Menemsha finally has a name.) |
| Sealover |
I have a 1986 70-HP that runs [with fuel and oil pre-mixed]. Yesterday I took it out and it ran well, but loaded-up when at low speeds, other than that, it ran super well. |
| efduffer |
I disconnected the VRO on my 1985 150-HP motors recently and now pre-mix. Everything seems to be running fine, as well as before, if not better. If made for extra space on deck, I don't have to prime oil tank bulbs or monitor consumption, worry about cracked or leaking tanks, lines, or pump. Biggest difference is peace of mind. |
| beaufort |
I love you guys. Chip's Ahoy |
| Teak Oil |
My 1985 engine's VRO was disconnected when I bought the boat. I didn't buy it from the original owner but I think it has been disconnected for at least 15 years. Motor still has great compression and power |
| prj |
1990 Johnson 70-HP on a 15' Striper. VRO disconnected in 2002 or so, a couple years into my ownership. I was under the impression, due to several anecdotal bits from various sources, that my overheat alarm was caused by the VRO and an oiling issue. I eliminated it as a variable (then changed my impeller which was the most likely cause), problem solved. Frankly, regardless of the unit's efficacy, the space savings in such a small boat made it well worth the effort. And for those that describe difficulties in managing simple mathematics to obtain accurate oil/gas ratios, maybe boat ownership isn't for you. |
| Tom2697 |
I disconnected mine the week I bought my boat. I ran about 650 hours before killing the motor from corrosion in the water jacket. The head leaked saltwater into the cylinder. The motor probably already had over 1000 hours on it. I'd rather my motor dying due to my fault for not adding oil than to have a $140 part do it for me... |
| Link |
I have a 115-HP 1990 Evinrude and the VRO has been disconnected since new. The motor I owned previously was lost when it VRO failed. I use only Evinrude two-stroke oil. The motor still runs like new. |
| minitauk85 |
I have a 70-HP Johnson with the VRO disconnected, I don't know how long it's been that way but the motor runs like a top! It's an 1988 and I suspect it's been disconnected for quite some time! |
| Binkie |
Does anyone know what brands of motor are more prone to VRO failure? I just bought a 1987 Suzuki 150 Super Six, for my bass boat, and I think I`ll disconnect it. Those things make me nervous. |
| seahorse |
For those who have said that they experienced "VRO failure", read in the REFERENCE section about the myth of the VRO. http://continuouswave.com/whaler/reference/VRO.html Depending on what type of failure inside the motor occured, you might have a different opinion of the person who diagnosed "a bad VRO". |
| Hal Watkins |
1988 60 HP Evenrude w VRO still operating! Engine starts hot and cold at the bump of the switch. Is a miser on oil consumption because we cruise at fast idle mostly. will move my 15' SS at 34 MPH/GPS. I was a nervous nellie at first with VRO but an enlightened mechanic talked me off the ledge. Good luck to us all. Hal of Waseca |
There does seem to be a large body of anecdotal evidence that VRO systems have failed, as demonstrated by the comments above. However, many are still working and working well. My guess is that represents the more common experience. On my current engine, a 1992 Evinrude 225-HP, the VRO system is intact and working. I upgraded the engine to have the SystemCheck gauge system. The engine has several alarms and sensors which monitor the operation of the VRO. They check for: --oil level in the reservoir Pre-mixing of fuel and oil would be inconvenient for me. Because the boat is kept of a trailer, most of the fuel I buy is on the highway. The tank holds 77-gallons. I typically buy over 50 gallons when adding fuel. The fuel fill is on the side of the cabin, and, when the boat is on the trailer, it is over my head. It is very awkward to reach the fuel fill when either standing on the pavement or standing in the cockpit. (it is very handy dockside, however.) It would take two people and a ladder to properly pre-mix the gasoline and oil using the recommended technique. (The recommended technique is to use a very wide mouth funnel and to pour the oil and gasoline into the funnel simultaneously, mixing them as they enter the tank.) When filling a large tank like this you have to guess about the exact amount of fuel to be added. The amount of oil to be mixed then has to be computed based on this guess. It is far more convenient to just top off both the fuel tank and the oil tank. These are in good proportion, too. The oil tank holds 1.8-gallons. This generally means I can pour in a gallon of oil at a time when fueling. If I have a full tank of gasoline, say 70-gallons, I will need 70/50 = 1.4 gallons of oil. Thus if the oil tank is close to full, I know I have enough oil in the reservoir to run the boat until the fuel tank is empty. Re-fueling becomes a simple process of just topping off both tanks. For boats with smaller tank capacities and with the fuel fill in a more convenient location, pre-mixing may be less of a chore. When pre-mixing, the volume of gasoline added is often constrained in increments that are proportional to the amount of oil in a handy container size. That is typically a quart. So gasoline is added in proportionate amounts, which would be twelve gallons (at roughly 50:1 mixing). What generally happens is the tank is not filled to capacity, or some extra oil gets thrown in to empty a quart can. The math can get a little more challenging if you happen to buy fuel overseas. This includes Canada, where I do much of my boating. The pump often dispenses fuel in liters. Or sometimes in Imperial Gallons (which have 5-quarts to a gallon). It is my experience that if pre-mixing in a small tank the ratio of oil to fuel will tend to increase over time due to errors in adding oil. The tendency is to err on the side of too much oil. We used to have this situation on a small auxiliary motor on a sailboat. About three months into the season the fuel in the tank had so much oil in it that the engine could barely run! Another problem with pre-mixing is the tendency to buy the oil in smaller containers so they are more convenient to use. Buying oil in quart or pint packaging is more expensive. I buy oil only in gallon containers. (By the way, I buy it from my dealer's bulk oil tank and re-use the containers.) For me, avoiding the need to pre-mix oil and gasoline is a big advantage. I plan to keep the VRO working on my Evinrude. |
| homey |
My 1989 Johnson 150's run great and still have their VRO's...I wouldnt even consider disconnecting them. Proper maintenance is required. Have fun premixing... |
| Binkie |
OK, so what is proper maintenance, and should you carry oil with you incase the alarm goes off? |
| newt |
My 1990 150 Johnson always has and always will have the VRO system connected. I'm with JimH on this one - pre-mixing is a pain in the arse. Binkie, I do carry two quarts of oil with me in case I forget to fill up at home and end up running low. |
| Joe Kriz |
I guess I am too Stupid to own a boat with a two stroke engine. As jimh mentioned, it is very difficult to get the correct amount of oil mixed with the fuel for many reasons. Yes, if you put in 6.25 gallons of fuel in at a time then you can add the correct amount, but how many times when you FILL up the tank does the amount of fuel equal, 6.25, 12.5, 18.75, etc. gallons. 50:1 Ratio I used to mix my fuel/oil back in the 70's when I had my 13' Sport with an Evinrude 35hp on it. Ended up always adding a little more oil just to be on the safe side. Also had to carry one of those professional style measuring containers with the ounces marked on the side. Messy... Now what do you do with this container. I owned a 1985 Evinrude 70hp for 15 years... Never had to do anything but replace a ratchet clamp on the oil hose througout the years. That's about all the maintenance I can think of unless the bulb or hose starts to go bad from being out in the weather. Not everyone's boating needs are the same. We all have to look at the big picture. Some people take extended trips and either need to carry extra oil onboard or find a dock station that sells pre-mix. Pre-mix isn't cheap. Another thing about pre-mix, is you are always running rich at idle. No if's, and's, or but's about it. The VRO system uses less oil at lower RPM's. More along the lines of 75:1 to 80:1. Running rich has a tendency to foul spark plugs. I now own a 1985 Evinrude 150 hp and I fill up the oil tank before I take it out. No matter what, I always carry 2 quarts of extra oil in the boat. For extended vacations, I will take either a 1 gallon or 2 1/2 gallon container of OMC oil with me and keep it at the Cabin, Motel, etc... I buy my oil in bulk like jimh does. I have 2 of the factory 2 1/2 gallon containers that my dealer fills up from his 50 gallon drum. Every little bit of savings helps. So, I save a little money on the cost of oil by buying it in bulk. I save a little money on the amount of oil used because the VRO meters the oil according to RPM's. I also save a little money on plugs because they do not get fouled as frequently by running too rich from pre-mix. Again, every little bit of savings helps. I can buy more fuel with the savings. The 4 strokes do have the advantage of not having to carry oil onboard and the space necessary for the oil tank. I personally would never consider disconnecting my VRO system. |
| prj |
While I'm fairly confident Joe is being facetious with his first statement, I've got a little secret that I'll share to alleviate the complex mathematics involved in CALCULATING the gas/oil ratios required for premixing:
2.5 ounces oil per 1 gallon gasoline Write it back'erds and tape it to your forehead And NO, I do not recommend disconnecting VRO's and |
| Joe Kriz |
prj, Don't forget to help us to convert this to liters. Please... I also have a problem when calculating the oil when I buy 37.73 gallons of gasoline. I think I will buy a slide rule or electronic calcualtor and carry it when I go boating. :-) I was always good in math but I think I have a mental block when it comes to adding the right amount oil... Just can't stand it I guess... I just want to go boating. I guess the guy who designed the VRO system couldn't stand figuring out the amount of oil to add to his tank either... :-) I'm not picking on you prj, it just seemed funny that someone would say something like that. That would be like me saying to someone, (no one particular) Joe |
| where2 |
Joe, I guess I need to go into the slide rule marketing business... Never needs batteries, will work in poor lighting situations where Solar Calculators won't... The main reason it doesn't phase me to pre-mix on my 15' Sport is because I have two 6 gallon tanks. (easy portability, easy pre-mix measurements). As for VRO maintenance, http://continuouswave.com/whaler/reference/VRO.html Space for the tank was not an issue on the Rage, so after reconstructing the VRO pump, I filled the tank with oil, and have been happy ever since I burned the last pre-mix out of the fuel tank at the end of break-in. |
| beaufort |
I hate you guys. Chip's Ahoy |
| Sheila |
Two questions: Is "VRO" an OMC-specific term, and therefore inappropriate for my Suzukis? What might be involved in reconnecting the VRO on the 1984 Johnson 90 V4? |
| Cicada |
I don't know if VRO is OMC specific. Basic components of the system are a tank, line with primer and pump that connects to some sort of port on the motor. Seems easy enough for people to disable them, should be pretty easy to reconnect. Chances are that everything you need may still be there. I just went through a rebuild of my 1989 150. The VRO had nothing to do with it. That motor had alot of hours on it with the original VRO. I think that some of the mechanics may want you to disconnect the VRO as a form of insurance for themselves. Disconnect the VRO, go to premixed, and it's hard to blame them for a problem. If I were a mechanic I'd probably want the same thing. Paul |
I believe that the term VRO is associated strongly with Johnson and Evinrude. This is the acronym used by them to describe their oil injection system. I believe it was originally derived from the term Variable Ratio Oiling or possibly Variable Rate Oiling. The proper name for the current system is VRO²® On Yamaha engines the variable rate oiling is called PRECISION BLEND. Mercury outboards have this feature, but I could not find any specific mention of it by a special name. In the specifications they just refer to it as "single point variable ratio oil injection" or sometimes as "electronic single point variable ratio oil injection." I don't know how Honda, Suzuki, Nissan, Tohatsu, or others refer to this feature. My impression is that these variable ratio oiling systems on outboards other than OMC-brands are seldom if ever disconnected. I cannot recall hearing a even a single report of someone disconnecting it from a Yamaha or Mercury. The use of crankcase vacuum pulses to operate the OMC VRO pump is often mentioned as a problem, and some other systems apparently use different techniques for driving the oil injection. On a Mercury--at least on some models--it is apparently driven electronically, or so I would assume from the nomenclature. But almost all outboard motors use crankcase vacuum pulses to operate the fuel lift pump, so it would seem reasonable to infer that this is a reliable source of power for a pump. I've never heard of anyone saying they disconnected their crankcase vacuum fuel lift pump. They all seem to work fine. |
| hauptjm |
jimh, I could be wrong, but I believe the reason of the association with VRO and oil injection in general is because OMC was the first to offer it. Like BandAid, brand names become synonymous with the general product. Again, because OMC entered the market first (at least on a large scale), they apparently had some initial problems with their system. Personally, I have never come across a problem with mine or anyone else's. Often, mechanics misdiagnose a problem and look to blame a new technology because it's easier than figuring out the real reason (or they're incapable of determining the real problem). They perpetuate this in discussions with customers and the myth begins. Are they (VROs) capable of failing, absolutely. Do they fail with the regularity some would like you to believe, absolutely not! |
| Binkie |
I have a question. I have no experience with VRO, or oil injection. Every outboard I`ve ever owned predates VRO. I just bought a `87 Suzuki 150, Super Six with VRO. When the owner demo`d the motor for me on a stand with earmuffs, he had the motor hooked to a 6 gal tank with premix in it. It ran fine and smoked more than I would consider normal, but he said that was because of the premix and the VRO, which sounded plausable. The oil tank on this motor is mounted under the cowling, and was 1/2 full. Before I mount this motor, I would like to test the oiling system to make sure it works. Anyone have any ideas? |
| Buckda |
Returning your engine to a VRO system after it's been converted to pre-mix is simple. It's a matter of finding the original parts (external oil tank, etc) and then replacing the fuel pump. Because the mixture actually occurs at the fuel pump, this is the device that either has the capacity to mix the oil with the gas or not, depending on which way you've gone. I asked this question when I had the VRO on my 70 HP Evinrude disconnected two years ago. I agree with JimH - generally, for larger boats/outboards, pre-mixing your fuel/oil is a royal pain for all the reasons mentioned above. On the smaller boats, it is much easier to mix (portable tanks) and frees up valuable space aboard for storage, deck space, etc. I would NOT want to pre-mix the fuel for my 18' Outrage, although I know a fellow forum member does with his. Important to note, however, is that that forum member doesn't use this boat very often anymore in favor of a vessel with "oil injection". Might this convenience factor have some contributing effect on this phenomenon? Who kows...it would for me. Dave |
| where2 |
Binkie, The only way to really know that any oiling system is working is to have the engine mounted on a boat and run the boat on pre-mix until you see the level in the oil reservoir drop a measureable amount. Since the amount of oil used will be variable with the amount of fuel used and the RPM that the engine was run at, there will be no set "ratio" for which the oil consumed can be compared to the fuel consumed, other than a ballpark figure. JimH: I don't think Honda called their VRO anything, I thought they were always 4-stroke and required no mixing. OMC recommends running pre-mix until you are certain that the oil reservoir has noticeably dropped in level. They have a test proceedure where you can check using a piece of clear hose and a measured amount of oil, but all that tells you is that the oil mixing portion of the pump is drawing in oil. |
| Binkie |
where2, Thanks for the info, that sounds like a logical way to do it. |
| Liteamorn |
Oil? |
| LHG |
VRO is an OMC trademark, I believe. With it's reputation, fair or not, no other brand would go near that designation. When OMC collapsed, there many were newspaper and boat mag articles, besides web based stuff, about why. Besides Ficht, VRO was often mentioned. An OMC engineer, I'm sure disgruntled, said that the system was a poor design from day one, as evidenced by the need for continuous upgrades, improvements and warning system upgrades. He said rather than spend the money to redesign it, they just put more alarms on it so people would know when it was failing. Mercury and Yamaha have never had do to a thing to their designs, both bulletproof. He said that OMC made continuously bad corporate decisions not to COMPLETELY re-design the system, rather than bandaging it. Another article I remember reading was that in the late 80's models, where most of the serious engine failures occured, supposedly as a result of VRO, OMC replaced over 4000 powerheads under warranty. And look what we see here continuously. Endless OMC engines with oil injection disconnected, for fear of failure. You just don't see that with Yamaha or Mercury, unless an OMC friend of mechanic recommended they do it!! From what I can tell by ovservation, Yamaha has the cleanest performing oil injection design. Except for the 225 and 250's, very little start up smoke. |
| where2 |
There's a reason the VRO was disconnected on my 15' Sport. SPACE That's the same reason that the previous owner hiked the rear thwart 2", and managed to stuff two 6 gallon fuel tanks and the battery ALL under the seat. Premix require no additional space in the boat, because the fuel tanks are always there... If there had been a Yahama on the transom with a built in oil reservoir, space would not have been an issue. It is true that early VRO systems like the one on my 1985 70Hp Johnson had no electronic warning systems other than low oil in the reservoir tank. However, the 1995 VRO system I last dismantled has a brain and can sense when the pulses on the oil side of the fuel pump are not in line with the RPM's of the engine. As for smoke at startup, that's a sign I want to see! All those parts that were just sitting stone cold are now moving, and knowing they are properly lubricated is something that is important. This isn't a 4-stroke automobile we're driving here, where smoke at startup is a nasty bad thing that means your valve guide seals are shot. In puttering with my 1995 VRO fuel pump, I have noticed that several minutes after you shut the engine off, as the fuel pump relaxes, it will click once as it injects one last dose of oil. When you start up the engine the next time, that last dose of oil is what appears as smoke. |
I'd love to see a copy or a citation of that magazine article with the OMC engineer bashing the VRO. Anyone have it? |
| TampaTom |
Merc oil injection is gear driven off the crank. The weak link is that a driven gear is usually plastic. Generally it will live as long as the motor but it will occasionally fail. Especially when run over 6,000 rpm, one reason that racers disconect it. I think the Yamaha design is similar, except the driven gear is metal. |
| wjriling |
Hello All, All the comments, info, etc. posted here about VRO's are very informative, however, it still doesn't do alot to ease my mind about VRO. Yesterdays maiden voyage of the season found the alarm going off for the 1st time for me. We had just left the dock and were moving at about 7 knots, not even planing, when the alarm went off with a continuous beep. I put the boat in neutral and it stayed on for about five minutes then went silent as suddenly as it came on. My passenger was freaked out by the alarm and didn't feel comfortable continuing even though the alarm was no longer blaring so we turned back (and proceeded to kill the prop on a submerged rock, I swear if I didn't have poor luck lately I wouldn't have any luck at all). When I returned to the dock I checked the oil tank, line, etc. as best as I could but there didn't appear to be any leaks, etc. From what I gather here the long continuous tone is over heat. How does a water cooled engine over heat? On a car it's easy to diagnose but on an engine what are the signs? The previous owner told me to pre-mix 100:1 even with the VRO working, just in case. It sounds good but I'm afraid the engine is getting too much oil as it's very oily on the transom. Regards, |
| Sheila |
Wendy, Hang in there, it'll work out! How was the telltale stream from your motor? A common cause of overheating is a piece of plastic (like from a floating bag) blocking the water intakes on the motor. Also, any number of things can block that telltale hose and prevent water from coming out. Do a search here to learn more. I think I read that a piece of weed-whacker line is handy for clearing the hose, but I may be mistaken. |
| efduffer |
I too was told to mix 100:1, just for protection. I was having wildly different oil usage between engines, random alarms, and quickly fouled plugs. I figured if I was premixing anyway and had all these other nagging doubts, why not disconnect, premix anyway, and not worry about it? By disconnecting I have eliminated many concerns and added no extra effort. Some may argue that I'm using more oil than I need to at certain speeds, but I'm still only using 50:1 no matter what. Not 100:1 PLUS whatever the VRO pumped the way it was before. My routine is easy. I always have half a gallon of gas in the mix can at home. 2 qt oil and 2 qts gas in the small can, agitated before taking the boat to the pump. Dump it in the tank, add 24.5 gallons and then another half gallon back in the can. Ready to go. Or any other combination of 1:1 for every 12.25 gallons I plan to put in. |
| homey |
Binkie, You asked about proper maintenance of VRO. Periodically check under Cowling, run motor without cowling and check connections or dry rotted hoses/fuel lines etc... After years of use, a sludge may build up at the bottom of the oil tank. This may cause a blockage in the pick up hose. Its a good idea to empty oil tank every few seasons and check for debris. If you keep your boat on a trailer at your home, Start it up every week or so. It keeps fluids/lubrication moving and you will see the blue exhaust smoke and know the VRO is working. Im not a mechanic but, these motors are reliable due to their simplicity and they have a great reputation. That being said, they also require basic maintenance. DE-CARB every year, Replace-plugs every year, fuel filters every year, lower gear lube every year, water pumps and thermostats every 2 years...... I don't believe this is a issue of any design flaw. The VRO's on my motors have worked flawlessly for years with no problems...You won't find me sitting at the gas pump trying to figure out proper oil mix ratio, when pumping 120+gallons of fuel... |
| wjriling |
Thanks for the words of encouragment Sheila. My new mantra is going to be, no matter what's happening, things are still good. As far as I recall the stream was coming out fine but in all honesty I don't think I was checking when the alarm was sounding (I was spending my time trying to reassure my passenger that we weren't sinking). When we got back to the marina I washed the engine and the stream was fine so maybe it was something blocking the intakes momentarily. Am I safe to assume that if no water is coming out of the engine it's overheating? And if the stream is coming out fine then it's not overheating? I don't have an opinion either way regarding the VRO, I do not know enough about it and, not being particularly gifted mechanically, probably never will. I think I would lean towards disconnecting it for two reasons, as efduffer said I am already pre-mixing and have no issue with the science of ratios also I would feel more at ease knowing that the oil was there because I put it there (it's along the same lines as packing my own parachute). Once I replace the prop I will have another go with it (sans passenger). Speaking of props are there any recommendations? Regards, |
| prj |
Wendy: "fine" in regards to the water stream telltale is far too subjective. If you are not absolutely certain that the water pump / impeller I was under the impression that my telltale was "fine" |
| newt |
Wendy, you don't mention which OMC motor you have, but on some engines (my 150 hp V6 for example), a continuous alarm indicates either an overheat condition or an excessive vacuum pressure in the fuel system - a fuel restriction. Neither one is related to the VRO. |
| hauptjm |
As I said half way up the ladder, we have passengers freaking, VROs being disconnected, whole companies being sold down the river and we don't even have the alarms correct. |
| wjriling |
I bought the boat last year and the seller said he had rebuilt everything on the engine, so I would assume that meant replacing the impeller, etc. I have no problem with replacing it myself just to be sure and have just placed a call to the dealer to get a price. It is, by the way, a 1986 Evinrude 90 HP. Some members seem a bit defensive when it comes to the VRO and lack of knowledge regarding it. Please bear in mind that many, like myself, bought used and most did not come with an owner’s manual. And please accept my apologies for making excuses based on gender, but when my mind was young and much more absorbent I had to sit through sewing and cooking (Home Economics) whilst the boys got to learn small engine repair and woodworking. I'm starting at almost 50 years old to just get a base knowledge of all things mechanical (I can, however, make a hell of a meatloaf or fashion a lovely frock out of your old curtains!). Regards, |
| newt |
Wendy, You may have picked up a plastic bag on the lower unit. When I sea-trialed my boat last year we had the alarm sound while idling thru the harbor. First thing the seller did when the alarm went off was to shift into reverse and apply some heavy throttle to clear whatever was there. Shortly thereafter the alarm stopped sounding. If memory serves me, an intermittent alarm sounding every 20 seconds means low oil, and a more urgent intermittent alarm indicates no oil -FYI. I think I saw in another post that you have a V4 engine, so I don't think you have the fuel restriction sensor, which means the constant alarm was an overheat. |
| Sheila |
Wendy, it sounds like you and I are following similar courses with our boats, in terms of age at onset :) Changing the impeller is more of a regular maintenance project than part of a rebuild. You can get an owner's manual for your motor. You can also get the OEM service manual. Reading these materials will increase your confidence about using and caring for your motor. Start by posting a "wanted to buy" post in the marketplace area here. Someone may have one available. Be sure to include your motor's year, make, model, and any serial number information you can find on the motor. If you don't find one among the membership here, you can order one. I recently ordered the service manual for a 1973 Johnson 65 hp. Ken Cook (do a Google search) is one source. Other members may have better ideas for where to look for one. If you're completely new to boating, as I am, I'd also recommend buying a copy of Powerboating: A Woman's Guide by Sandy Lindsey. |
| Joe Kriz |
Wendy, There are two connections on your engine that are connected to the warning horn system. 1. The VRO tank You can check that these are working via the article in the reference section on VRO that where2 mentions above. A Simple Test when your alarm sounds: 1. Disconnect the Overheat sensor via the Knife Terminal connector, if the alarm stops, then you are either overheating or your sensor is bad. 2. Disconnect the VRO wire from the tank via the Knife Terminal connector. If the alarm stops, then you have a short somewhere in the VRO tank sending unit. This could be an intermittent short so sometimes the horn might sound and sometimes it doesn't. Here are the sounds that should be normal for the alarm system for your motor. Those are the normal sounds, but as I mentioned above, you still could be getting a Constant sound if the VRO sending unit is grounding itself out internally. I had this happen to me. When I disconnected the VRO (Tan wire) knife connection, the constant alarm stopped. The VRO tank does not have a constant alarm so I knew something was wrong inside the tank. I replaced the tank and never had a problem after that. Does your alarm have a constant sound if you just turn the ignition on. If it does, try disconnting the VRO wire and see if it stops. I also wrote a small article on how to check the alarm warning system. |
| wjriling |
Sheila- I just ordered my copy of Powerboating: A Woman's Guide from Amazon. Thank you. Joe, thanks for the alarm info. I spoke with the mechanic that did my tune up/winterizing this year, he confirmed that the alarm was an overheating issue as you all have said, and he said that they replaced the thermostat but did not do the impeller/pump. He gave me a price of $65. for the impeller and another $200.00 for labor. That seems a bit pricey for something that should be done as regular maintenance. I would truly like to learn how to replace this part myself so I can afford to replace the impeller yearly. For those who change their own impeller/pump, is it a difficult job or can I hope, with a bit of focus and attention to detail, that I too could do this job without causing damage to my engine? Is it incredibly complex? Thanks! |
| JMARTIN |
Thanks to this subject, I have another item to put on the boat. A big funnel so if my 13 year old VRO goes kaput, I can pour the oil from the oil tank into the main fuel tank to get home. John |
| Joe Kriz |
JMartin, The tank did not go bad.. It worked just fine except that the alarm was sounding when it shouldn't. I disconnected the alarm for awhile before replacing the tank and had no problems. I have never had a problem with VRO system, Pump or VRO Tank... except for the alarm. It is always a good idea to test your alarm horn system every year or so on both the VRO and the Overheat... For those of you with older alarm horns, see the article above. The new horn give you audible notification that the horn is working. |
| JMARTIN |
My VRO has never had a problem either. I asked the mechanics to check it out last winter when we were changing out the thermostats, water pump, and tuning up. Who knows if they did it. I get an alarm test when I turn on the key, a beep. The over heat alarm works, sucked up a piece of kelp last year. Will see if I can get an oil alarm test next time out to the boat. The engine is a 1992 200hp Evinrude. John |
| Binkie |
Wendy Changing an impeller is an easy job, once you see it done. If I were you, I would make arrangements with your mechanic, to have it done, and tell him that you want to watch and learn. Then the day before, read the instructions in your manual so you have an idea what has to be done. If you run your motor in salt water it can be a bit of a challenge to not only get the nuts off the studs, but to get the gearcase seperated from the mid section. Everybody has their little ways of seperating those two pieces, so you can learn his. If he reaches for the crow bar start screaming. Pay special attention as to how he gets the pump housing over the new impeller, and which direction the impeller vanes are facing when the housing is installed. Some people use K-Y jelly on the rubber impeller as it makes it easier to install the housing and lubes it. Its then easily disvolved by water. If the mechanic won`t let you watch, find another one. For some reason some men are intimitated by female wrench turners. Then next time you will be ready, and have the confidence to do it yourself. |
| wjriling |
Binkie, As luck would have it I spoke to the fellow who helped rebuild the engine before I bought it, he is a marine mechanic, has the identical year/engine Montuak as myself, and he invited me up to a local lake to go over the workings of my engine this weekend. While he does not feel that it's the impeller (they replaced it when they rebuilt the engine right before I purchased it) he promised to show me how to do mechanical maintanence, how to check for overheating, go over the workings of the VRO, thermostats,impeller, etc. I definitely know for myself that I learn much better from watching & listening rather than just reading alone. I'm very excited and hope, in short order, to be taking care of my boat, down to the last nut and bolt, with a decent amount of know how (bear in mind that I do not mean know all)and a fair amount of confidence. One thing I realized today regarding my lack of knowledge with both the VRO and the engine itself, I am really failing myself. If a mechanic says I need this, this and this, and I don't have a good idea about how things work, then I won't know any better than to just nod my head and pull out my credit card. I hate that scenerio. Regards, |
| Sheila |
Wendy, That sounds like a fantastic opportunity! I do hope you'll post the results of your session with the mechanic here so that other folks (like me) can benefit, too. |
On older OMC outboard motors the aural alarm is an aggregate of several sensors. The cadence of the alarm signal has to be interpreted to deduce which sensor is signaling the alarm. About c.1993 the OMC motor was improved by the addition of the SYSTEM CHECK® gauge. This alarm annunciator separated the four sensors in the motor and reported them separately with a visual warning, while still sounding a common aural alarm. You can re-fit some older OMC motors with an upgrade to add the SYSTEM CHECK feature. This will help you distinguish which sensor is causing the alarm. Or, you can familiarize yourself with the different cadence of the aural alarm for each sensor in your exiting system, and interpret it that way. In spite of what appears to be an unstoppable amount of dock talk about the VRO system, its poor design, its role as the root cause of millions of dollars of engine damage, etc., in my opinion it seems to be a rather decent system which works well for most people. Far more than any other engine brand, its operation is closely monitored and provided with several alarms to warn of problems. Because OMC was the first to introduce this feature, they were the first to be adversely affected when alcohol was introduced into marine fuels. Deterioration of rubber components in the fuel system of many outboard motors contributed to expensive problems for the engine owner, but I do not believe you can lay all of them at the doorstep of the Outboard Marine Corporation. |
| Binkie |
Wendy I hope my daughter reads your last post. I`m trying to get her to take over the maintainence of her Whaler instead of just relying on Dad. |
| wjriling |
I will definitely post everything I learn this weekend, I'm even thinking of packing the photo equipment and doing step by step photos. I'm sure that will help me retain everything. Binkie, it's funny that you mention your daughter, many times when this sh*t is hitting the prop I wish dad, a career sailor and avid boater/mechanic, were here. I'm sure the only thing I would need to concern myself with would be "where should I take the boat today". Still, there is always a sense of accomplishment when I'm able to do what needs to be done. And, if I'm going to get into trouble out on the water then I would like to know I can get myself out of that trouble, too. |
| Binkie |
Wendy It would be good if you post the pics.,also. A picture is worth a thousand words. I see your from Bristol. I had a little run-in with the Bristol Chief of Police, back around `58 when I was going to college in Mass. He looked and dressed just like Broderick Crawford, on the old TV series, Highway Patrol. He even wore the same brown leather jacket and hat. Even had the same raspy voice. Seemed he didn`t like college kids with NY tags and loud mufflers, speeding on the Wilber Cross Parkway. Said it was his road. Real mean dude. Scared the hell out of me. I still remember this incident almost 50 years later. I hope he wasn`t your grandfather. LOL |
| crabby |
I disconnected the VRO on my 1986 70 hp Evinrude in 1990 after discovering several inches of water at the bottom of my oil tank (that was being injected in lieu of oil)(it got in after a nasty rainstorm had flooded the boat (17 Montauk) and found a faulty gasket under the cap of the oil tank). And as I discovered last summer that two out of three emulsion tubes were cracked on my carbs (likely causing a lean running condition) the extra oil I have been adding over and above 50:1 is one of the things that has kept that motor alive. |
| where2 |
With the OMC service manual, and a decent friendly helpful mechanic willing to show you the ropes, you should be all set. I learned none of my mechanical know-how in public school (or college for that matter). Fortunately, I did have home-ec, and can find my way around an old sewing machine if I need to convert a set of curtains into something different. (didn't hurt that my mom actually has a college degree in Home Economics). I can bake an awesome batch toll-house cookies straight off the recipe on the bag... The shop manual should be a lot like reading a recipe out of a cookbook (since we're on the home-ec analogy). You'll want to read a particular section through once or twice, then go shopping for parts after making a list of the extra items you'll need (take the service manual when you go shopping, just in case the parts counter has no clue what you're trying to accomplish). Once you're done shopping, the fun really begins. The manual will not necessarily mention what size wrench to pull out and use, but they will be american fractional inch increments on all the OMC engines I've ever touched (upto 1995). Reading through the manual before you head for the service department also allows you to ask "Do you have any recommendations to use in place of OMC Special Tool "X", or do I need to order one of those?" |
| elaelap |
Yeah, it's tough: Every seventy hours (the manual says every hundred hours)--give or take a few--I put my seat (whoops, I mean my motor) in a full upright position, twist off the drain bolt, get black dirty oil all over my hands with most of it going into a plastic recycle container, check the drain bolt's rubber O-ring while the oil is draining completely, replace the drain bolt and torque it down 1/4-1/2 turn past finger tight, remove the oil filler cap and add four quarts of fresh Yamalube. Et voila...it really doesn't take much more time to do than to tell. Oil filter element? The dealership wrench replaces that per manual specs every two hundred hours when my boat is in for her bi-annual two hundred dollar 'tune-up' (the very best $35/month sleep-at-night insurance this mechanically disinclined off shore fisherman can ever have). Hope I haven't derailed this fascinating thread, you two smokers...and I love you, beaufort; I chuckled at your first comment and almost fell off my chair at your second. Tight lines, you Whalers. I sort of envy your arcane knowledge of and patience with those "classic" motors, but then again... Tony |
| elaelap |
No, wait. I didn't realize this was your topic, Chips...I chuckled at your second comment, etc. |
| jamessta |
Hi, I have just had my boat diagnosed with a VRO problem and am wondering if I am being ripped-off. I have a 1996 90hp Johnson. I was told that the reason it would not start a week ago(the first trip this spring) was that the VRO failed. A back pressure problem caused it to push raw oil into the carbs. This is the same place that winterized my boat last fall. They said that the seals must have deterriorated over the winter. What do you guys think? |
| JMARTIN |
Have you read this? |
| BillS |
I bet a lot of the bad rap that VRO gets is due to owners not reading the owners manual and pumping the primer bulb before starting the motor. Pumping the primer bulb causes the carbs to be filled with oil which causes a no start condition. Then the motor is taken in for repair and the service guy blames that darn VRO pump. It is kind of a bad design because it is a natural reaction to want to pump a primer bulb but it is only to be used for initial setup or after cleaning the tank or replacing the oil line. |
| Jazzinc |
My experience with my favorite outboard motor machanic is this. He rebuilds outboards and is the best in his field. Upon buying a used rebuilt he has a awsome guarentee and totally stands behind his product and reputation. Only caviat that he has is he will not guarentee anything with a VRO, he disconnects them, makes you pre-mix oil, and smiles alot because nothing comes back to haunt him. Enough said. |
Thanks for the description of the business model used by your local mechanic. His business practice is somewhat akin to a doctor I know. The doctor believes that most people's left arms are useless, and he recommends removing them. Now not everyone agrees with the doctor, and as a result he does not get every patient that he could, but the ones he does get are darn glad to find him. |
| pglein |
Don't most VRO OMC outboards run at 100:1? Wouldn't everyone premixing their fuel at 50:1 be doing damage not only to their engine, but the environment and their wallet as well? |
| pglein |
For the record, my 1988 Evinrude 40hp made it ten years before the oil tank cap got cracked and allowed water to get in without my noticing or realizing it was a problem. I didn't get an alarm, but eventually the cylinder wall became scored and the engine died. I've been much more careful about the integrity of the oiling system ever since, although on the japanese engines, it's less problematic. |
| LHG |
Based on "pglien's" post above, please review this thread where I was flamed and took a lot of gas for saying Mercury had a superior oil injection tank and system design to OMC. The credit actually goes to Bill Grannis's article, who confirmed that what "PGLIEN" said DOES indeed happen and causes engine failures. |
| bubbers |
Wendy. I watched my mechanic last year replace my water pump for over 200 bucks. He put the throttle to full forward, removed the nuts and bolts holding the lower unit on, slid it off, took four screws out of the impeller housing, slid it off the end of the main shaft, greased the new impeller, put it in angling the new impeller the same as old one and took one hour. I assume putting the throttle full forward kept the shifting shaft from getting miss aligned. I did it yesterday again since his impeller split in half and the only problem I had was he over torqued all the nuts and bolts so much I needed an impact wrench to get one off so he probably damaged the impeller putting it in too. From now on I will do it myself. Doug |
Thanks for adding the brief description of how to change a water pump impeller to this thread discussing oil-injection systems. The thread is fifteen months old, and is no longer in active discussion. It is much better to begin a new discussion when the topic is different and when the prior discussion has been dormant for a long time. |
| keltonkrew |
my 1986 Merc 35 is still running strong and I haven't ever use the VRO.....I alway pre-mix with synthetic Amsoil! |
| The Judge |
FYI...Suzuki INVENTED oil injection so I think theirs is the best. Yamaha is next and Merc is 3rd(only because plastic impeller) because they copied Yamaha I think. OMC is the worst. I am a believer though in the oMC unit IF I bought her new or it is above 70hp. Reason for that is I don't know if buzzers still work if buying used and anything over 70hp will burn so much fuel that 50:1 is not going to be cheap. My 225 would burn 13gph at cruise. So lets just say 12gph. Not only was that pig sucking up $40 worth of fuel an HOUR but also about $5 worth of oil. With the VRO I would burn about 6-8 gals per 100hours, w/o make that 25 gallons on pre-mix...WOW! That is about $300 more a season in oil, not to mention how much more pollution. My new to me 1994 VRO 40hp Evinrude will probably be disconnected. 1) it takes up too much space in a 13'. 2) If boat swamps/heavy rains, oil res is under water. 3) How much oil does a 40hp burn a season....about 4gals per 100 hours pre-mixed. This will happen especially if I need a new fuel pump which I think I might. |
