  Stern Light Holder
Author Topic:   Stern Light Holder
cubanwhaler posted 09-09-2007 03:08 PM ET (US)   Profile for cubanwhaler   Send Email to cubanwhaler
Photo: Boston Whaler stern light mount
I think this is what [is] left of the stern light, but I am not sure. I want to begin installing new lights and wiring, but I need to know if this is for the stern light. If so, how do I wire this thing? Do the [P]erko lights fit into this thing? I am really confused when I go to the store and look at the stern lights. They seem to fit into some recepticle or something.
I don't need to restore this section to original parts. I need it asap for night fishing. So ANY help is appreciated.
Dave Sutton posted 09-09-2007 05:41 PM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
It's the standard Whaler socket for the aft nav/anchor light. The aluminum mast drops in, and then the nut is tightened (those that aren't corroded) to hold the mast securely. Think Perko masts fit OK.... but check. The original Whaler ones are the right ones though, and ought to be able to be bought. There's a 2-pin maale connector on the light, and there ought to be a 2 pin female near the mount someplace. Poke around for it.
Dave
Casco Bay Outrage posted 09-09-2007 07:04 PM ET (US)     Profile for Casco Bay Outrage  Send Email to Casco Bay Outrage
You have the original stern light brackets. There is a broken stern light pole in the brackets. Often stern lights get broken right above the upper bracket.
Here is my thread (different user name back then) when I had a frozen pole in my light brackets. It lists the Perko part # you are looking for.
The photo links are dead since Yahoo shut down it's photo site.
http://continuouswave.com/ubb/Forum3/HTML/006349.html
There should be a box on the rear port quarter for connecting the bow and stern lights. From this box, wires run to the battery.
Hope this helps
CBO
Casco Bay Outrage posted 09-09-2007 07:32 PM ET (US)     Profile for Casco Bay Outrage  Send Email to Casco Bay Outrage
I added 3 or so photos to this album to show the wiring box and the light.
http://picasaweb.google.com/CascoBayOutrage/1987Montauk
FWIW, I replaced the Perko pole seen in these photos with a whaler replacement pole (different Perko pole) that is stainless steel, taller and not aluminum. Much better quality and less prone to break. Can order via dealer for approx. $125. I used Twin Cities Marine who are great.
Telephone (920)793-2715
email:tcmarine@lakefield.net
Tom W Clark posted 09-09-2007 08:44 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Affirmative, those are the stern light mounting brackets found in most small Whalers. It appears the remnant of an old stern light pole is these in there. It looks like aluminum.
Note that Whaler NEVER used an aluminum light pole. Whaler had Perko make custom stern lights for them using chrome plated brass tubing up until around 1983 and then when the lights need to be taller, they used stainless steel tubing.
The diameter of the pole is 3/4" so any light with a pole of that diameter will work, but the aluminum ones tend to corrode rapidly.
The brackets themselves are chrome plated bronze.
cubanwhaler posted 09-09-2007 09:05 PM ET (US)     Profile for cubanwhaler  Send Email to cubanwhaler
Thanks for the input! Does that top part unscrew tension on the light pole?
Dave Sutton posted 09-09-2007 09:36 PM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
The top part does unscrew to loosen up to accept or tighten to retain the pole.
I can confirm that a 1987 pole is Stainless. Aluminum in this application is no-good.
You can make a pole out of 3/4 SS tube sold to make handrails from any boat store. The top of the factory one is bent so that the light fixture at the top is parallel to the water.
Dave
jimh posted 09-10-2007 08:27 AM ET (US)     Profile for jimh  Send Email to jimh
[Removed many plotchered attempts to link to image and made it in-line.]
The clamp used on the stern light is very similar to clamps used on telescoping microphone stands. If you are missing the clamp or a part of it, try a music store or a guitar shop that sells microphone stands. But you will need to find an old fashioned one; the newer stands don't seem to have that big knurled nut anymore.
Tom W Clark posted 09-10-2007 09:47 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
The knurled nut clamps the stern light pole by tightening a "split ring" around the pole. The split ring is a currently available part. It is available from any Whaler dealer for about $3. Current versions of the split ring are made of plastic.
The split ring and knurled nut work on exactly the same principle as the collet of a woood working router.
cubanwhaler posted 09-10-2007 05:21 PM ET (US)     Profile for cubanwhaler  Send Email to cubanwhaler
Okay, I removed the knurled nut without much problem with a pipe wrench. Now I have the threaded section that was underneath the knurled nut. Does this come off the pipe and the brackets? The pipe looks pretty damn bonded to the brackets. How can I get this out?
cubanwhaler posted 09-10-2007 05:22 PM ET (US)     Profile for cubanwhaler  Send Email to cubanwhaler
PS- There wasn't a split ring under the knurled nut.
Dave Sutton posted 09-10-2007 07:27 PM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
Soak the entire mess down with a good penetrating oil and go do something else for a few days. Keep re-soaking it daily. If you can get it apart after that, great. If not... then it's down to trying to grab bits of the tubing with vise-grips and breaking them out bit by bit. Aluminum can almost literally weld itself to the brackets thru corrosion. Use a sharp chisel if needed to cut the tubing down into the bracket and start breaking out pieces. It'll come out.
Dave
Dave Sutton posted 09-10-2007 07:30 PM ET (US)     Profile for Dave Sutton  Send Email to Dave Sutton
Forgot: Hacksaw the damned thing off top and bottom of both brackets before you start the above process. Once there are just two small rings of aluminum left (one in each bracket) a punch and hammer might do the trick, if not the chisel and hammer and vise-grips will surely do the job.
Dave
cubanwhaler posted 09-10-2007 07:41 PM ET (US)     Profile for cubanwhaler  Send Email to cubanwhaler
Gadzooks! That seems like a lot of work! Can't I buy replacement brackets?
Whale1 posted 09-10-2007 08:08 PM ET (US)     Profile for Whale1
When I rewired the lighting on my Sakonnet I discovered that my nav light brackets are upside down. By that I mean that the knurled knob and collar are in the top position and the plain standoff is at the bottom.
I tried to put them back as these photos show and the holes in the brackets don't line up. They are different distances on center and can't be reversed. The holes appear to be original.
Did Whaler ever install them in this fashion?
Thanks for any input.
OPNH2O
Whale1 posted 09-10-2007 08:10 PM ET (US)     Profile for Whale1
I messed that up. I meant to say that the knurled knob and collar are on the bottom and the plain standoff is on the top.
Sorry about that:-)
ONH2O
Casco Bay Outrage posted 09-10-2007 08:34 PM ET (US)     Profile for Casco Bay Outrage  Send Email to Casco Bay Outrage
Okay, let's clarify some things before you go any further.
The "threaded part" you have "left" is all one piece of the upper bracket
Here is a photo of what the brackets look like.
http://picasaweb.google.com/CascoBayOutrage/1987Montauk/ photo#5108735523299201714
Photo came from whalercentral.com. My apologies for posting without permission
At this time I must ask if you have unscrewed both the upper and lower bracket and removed them (with the pole frozen) from the boat. If not, do this now!!!!!
Just to test how stuck the pole is, try putting the assembly between your knees and try twisting the top bracket off. Grab the top assembly close to the threaded part and not down near the base (where it screws into the boat) and twist.
Flip the piece and try twisting off the bottom.
If stuck, cut the pole with a hacksaw about 1/2 inch below the top bracket and 1/2 above the bottom bracket.
Take the hacksaw and cut a X on the TOP of the cut ends. Remember not to cut into the bracket.
Use vise grips or a pipe wrench and crush the pipe close to the bracket. Use a smal/medium width flathead screwdriver and hammer and drive the screwdriver between the bracket and the pole.
If it is fighting you, STOP. SOAK in PB Blaster or penetrating oil (Liquid Wrench) overnight.
Questions?
Casco Bay Outrage posted 09-10-2007 08:46 PM ET (US)     Profile for Casco Bay Outrage  Send Email to Casco Bay Outrage
Forgot to answer your question:
The part #'s for these are:
The one on the left is the Upper Support, Part #12007904
The one on the right is the Lower Support, Part #12007900
I would call Twin Cities, a whaler dealer and great for parts no matter where you live (listed above). If not available through them, they were made by CMI
In the reference section here, I found this:
CMI MARINE
55 Woodrock Rd. Weymouth, MA 02189
Telephone: 781-337-0733
Fax: 781-337-0734
Email: cmimarine@verizon.net
[Call them on telephone--much better than email.]
Talk with Fred Caldwell; he can supply excellent replacement railings for most all classic Boston Whaler boats.
Hope this helps.
CBO
Tom W Clark posted 09-10-2007 09:43 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Whale1,
The knurled nut always goes on top, or at least that is how they did it at the factory.
The screw hole spacing if the same for the top and bottom stand offs, but not all pieces of this hardware were exactly the same over the years so your boat may have had a mixture of old and older.
Tom W Clark posted 09-10-2007 09:48 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
As the aluminum tubing corrodes, it effectively expands within the stand offs. The creates an incredibly tight fit. It is not so much a bond to the chrome or bronze but a really tight compression fit.
To remove remnants of an aluminum pole from the light mounting brackets, it is best to cut the tubing off close to both sides of the stand offs. If you can make one clean saw cut longitudinally through the short piece of tubing, this will release the pressure and the tubing will come out.
Alternatively, you can leave a little of the tubing sticking out the the stand off and try to twist the tubing in on itself to collapse it. This is how we remove the brass drain tubes from a Whaler hull; once collapsed, it will slide out.
Whale1 posted 09-11-2007 10:06 AM ET (US)     Profile for Whale1
Tom W Clark,
Thank you for shedding some light on the positioning question.
I couldn't find any shots of the fixture on your great Whaler catalog CD.
I wonder why the holes in the upper position are spaced differently than those in the knurled knob/collet?
Thanks again,
ONH2O
cubanwhaler posted 09-13-2007 08:18 PM ET (US)     Profile for cubanwhaler  Send Email to cubanwhaler
First, thanks for all of the input on this matter it has been very helpful! I successfully removed what remained of the old stern light. It was pretty easy actually! I removed the assembly and used my bench vice to squeeze the shaft above and under the brackets making quater turns after every "squeeze". This loosened things up to start. I then proceeded to anchor the pole remnant in the vice and took a flathead screwdriver and a hammer to chisel the aluminum away from the inner wall of the brackets. Then, with the end of a socket wrench extension bit, I placed it over the aluminum and whacked the pole out of the brackets. Took about 15 minutes! I sprayed some wd40 and used a wire brush to get the rest of the oxidized aluminum out of the brackets. Worked like a charm!
Now that I have that out of the way I threaded the bow light wire through the rubrail. Is the wire supposed to go through the rail and out through those holes I filled in with marine-tex that you can see in the posted pic above? If so I guess I hurt myself by filling those in huh? What are my options at this point?
Casco Bay Outrage posted 09-13-2007 09:15 PM ET (US)     Profile for Casco Bay Outrage  Send Email to Casco Bay Outrage
That is great news.
In looking at your photo, I am guessing the single hole, forward of the set of holes is the one that goes through to the rub rail. Did you seal the hole from the rubrail side? That is where it should go.
I recall the cover was right on top of that hole. While an OEM cover may be hard to find, any kind of a cover will do. At this point, join the two sets of wire at a bus bar. A single set of wires runs from there.
While I see your battery is in the stern, do you have an existing switch on the dash? Is there a bus bar (two parallel brass strips with screws) inside the console (original location was on the back of one of the instrument panels
IF yes, then -
run the wire through the tunnel and attach negative to the negative strip. Run the positive to the switch. You will also need to feed power to the switch by running a single wire from the positive terminal to the switch.
If not, what do you have?
CBO
cubanwhaler posted 09-14-2007 07:09 AM ET (US)     Profile for cubanwhaler  Send Email to cubanwhaler
I have nothing in regards to any electrical components on the dash. In order for me to get the wire through the gunnel I would have to remove part of the rubrail track which has been riveted on. Its a brand new rubrail too. Bummer!! Because I really dont want to mess with it!!
cubanwhaler posted 09-22-2007 10:11 PM ET (US)     Profile for cubanwhaler  Send Email to cubanwhaler
...but I did! I successfully Mounted an aftermarket bow light (atwood) and a 24" stern light by the same manufacturer, so I am entirely ready to tackle night fishing. I already have 4 night trips under the belt. I gotta say its a big difference on how well you must know the area to drive around. Its easy to get disoriented at night for sure! The only unsuccessful part of the entire electrical rig (which included a fuse strip i used over the bus bar)was the way the wire from the bow light ran to the fuse block, which was encased in a plastic box inside the battery box. Originally the wires ran through the hole into a box mounted on the inside of the stern as far as I have gathered from the responses here. Instead of ripping up the track from my rubrail, i looped the wire end out from the end of the rubrail instead of threading through the hull. It will have to be another project for another day, but for now I can catch fish at night! Or at least try!!! :) Thanks for all the help!!
cubanwhaler posted 03-01-2008 04:12 PM ET (US)     Profile for cubanwhaler  Send Email to cubanwhaler
I am revisiting this thread becuase I have become aware of a short in the fancy electrical wiring of my lights/depth sounder that was making my horn sound. Everything is dismantled as far as wire goes and I plan on running the bow light wires through the hull as originally done. I drilled out one of the holes that I had caulked up last year and will take a shot through the rubrail.
My question is what kind of cover was mounted to the hull to gang the incoming wires from the bow? If you look closely at the picture above, there are a set of smaller holes that must be for screws attaching the cover. What cover do I use? What does it look like? Thanks!
Casco Bay Outrage posted 03-01-2008 06:04 PM ET (US)     Profile for Casco Bay Outrage  Send Email to Casco Bay Outrage
There is a rectangular cover. Inside the cover was a terminal block with 2 bus bars like this http://www.boatersworld.com/product/198422602msk.htm
The positives go on one bar and negatives go to the other bar. A single positive and negative go to the switch/battery.
Here are a photo of the cover. http://picasaweb.google.com/CascoBayOutrage/1987Montauk/ photo#5108348774379098770
CBO
cubanwhaler posted 03-01-2008 08:05 PM ET (US)     Profile for cubanwhaler  Send Email to cubanwhaler
Hmm...looks rather large don't you think? Well, I still need a cover. any ideas on a replacement?
Casco Bay Outrage posted 03-01-2008 08:56 PM ET (US)     Profile for Casco Bay Outrage  Send Email to Casco Bay Outrage
This conversation is giving me a serious case of deja vous.
After 20 minutes with the handy dandy search engine, I think I found THE thread.
It lists (read the whole thread) the original maker, source for replacement and two alternatives.
http://continuouswave.com/ubb/Forum3/HTML/006511.html
Man that brings back memories.
CBO
Casco Bay Outrage posted 03-01-2008 09:20 PM ET (US)     Profile for Casco Bay Outrage  Send Email to Casco Bay Outrage
Forgot to answer your question.
To skip the terminal block/cover just run the two sets of positive wires to the switch and 2 negatives to the battery.
For routing, have the wires that come in from the rubrail go over and follow the wires from the pole. From the base of the pole, run them over to the sump cover etc. You can cover them with white wire loom for a clean look.
CBO
cubanwhaler posted 03-02-2008 10:55 AM ET (US)     Profile for cubanwhaler  Send Email to cubanwhaler
CBO, thanks for the input. I'm still staring at the 15 and scratching my head. I want the cleanest look possible, so I think I'm going to just screw a small busbar where that box belongs and be done with it for now. I also plan on improving my wiring technique. I must admit the electrical atrocity that I have commited last summer, and let me know how bad it really was of an idea. It was a quick job to get me out in the water so:
I went with pigtailing wires together, and used some hardware store wires (copper single strand and stranded)mixed in with tinned strand (like I was supposed to). I had to get the job done quickly so I resorted to sub par quality wires.
I knew the mistake I was making, but I was pressed for time.
By the end of the fall I was getting an electrical short in my wiring, because the engine horn was sounding right off the start (checked sensors everything OK in engine). When I disconnected everything the horn went away. SO, I assume that my fancy wiring created a short. (Or water in the horn? Who the heck knows!) It obviously is an issue anyway, and it's (hopefully) related to the horn problem.
Now the job this spring will aim at fixing the wiring. (set aside bow hatch project...grr) This will first be to re-tap a hole thru the hull.
The questions?
-bus bar covers or appropiate styles for integrity of boat, saftey, and over all quality.
-If I use a bus bar where do my fuses for the lights and the ff/gps radio ect go? Under the dash?
-Are inline fuses better than a fuse block?
Casco Bay Outrage posted 03-02-2008 12:28 PM ET (US)     Profile for Casco Bay Outrage  Send Email to Casco Bay Outrage
As a "get on the water" repair, it was fine. Using marine tinned wire and marine connectors is key. Keeping all the connections waterproof is the key.
IMO, skip the bus bar and cover. It is not necessary and only adds to the number of failure points. If the wires are not long enough, you can add a longer section of wire by using butt connectors like this: http://store.hamiltonmarine.com/browse.cfm/4,14615.html They crimp and then you heat the plastic connector ends with a hair dryer and they shrink, sealing to the wires.
I am not clear on a few things. Is your battery still in the stern? Do you have switches on the console? Do you have an existing buss bar at your console or is it in the battery case?
A link to photos will help me help you.
CBO
cubanwhaler posted 03-02-2008 10:35 PM ET (US)     Profile for cubanwhaler  Send Email to cubanwhaler
CBO, I will try to explain what I have, and you tell me if you can improve it.
Battery is in stern.
Bow light wires (speaker wires) funnel behind rub-rail and out though the rear right corner of the stern (see above) through the top larger hole (filled in with marine tex in pic).
I was using a fuse block at this point to connect the stern light, bow light, and 3 pole switch from the dash. The fuse block was in a small plano box and stuffed into the battery box.
I couldn't figure out how to connect my gps to the fuse block so i directly connected it to the battery with an inline fuse, which failed on me a few times in the short few months i used it.
The corner where the battery was located had a small mess of wires which I hope to clean up with some help. It all ran perfectly, when it ran. So other than the improper techniques I used I don't think the connections were wrong, but there were many areas of possible failures.
If I eliminate the fuse block I could use inline fuses I suppose, but I am wondering at this point if I need them, becuase in all the stuff i'm reading here nobody says anything about a fuse block, just about bus bars. However, my gps manual says to use one, and I imagine that the lights need to be fused in order to avoid blowouts. Right?
Casco Bay Outrage posted 03-03-2008 10:05 AM ET (US)     Profile for Casco Bay Outrage  Send Email to Casco Bay Outrage
I will have a comprehensive suggestion in a day or two. Give me till then to write it up.
CBO
cubanwhaler posted 03-03-2008 04:51 PM ET (US)     Profile for cubanwhaler  Send Email to cubanwhaler
Appreciated. I'll be here waitin' :)
cubanwhaler posted 03-08-2008 10:07 AM ET (US)     Profile for cubanwhaler  Send Email to cubanwhaler
Just an update to this stern liGHT. I never removed the Perko stern lamp when i winterized the boat. To my suprise this morning the same situation occured to my 6 month old stern light, CORROSION!!!! It is completely bonded to the original stern light holder again. It's proof that the corrosion between aluminum and chrome plated brass doesnt take long. Sucks to be me.
home Aside posted 03-08-2008 12:30 PM ET (US)     Profile for home Aside  Send Email to home Aside
I had two stern light poles for my 1982 Montauk, neither were Aluminum, both were stainless. I had a short straight one approx 36" and a longer one with a slight bend at the light end approx 48". I never had any problems with corrosion. I very rarely left the stern light in the brackets when the boat was not in use.
That particular system was used on the 17' and under Whalers, the Outrage 18 and up had a completely different system.
I'd definetly opt for a stainless or Chrome replacement pole next time around.
Pat
cubanwhaler posted 03-08-2008 01:58 PM ET (US)     Profile for cubanwhaler  Send Email to cubanwhaler
Well, I'm just going ahead and using what I have left of the replacement for now. My brackets are brass over chrome. I don't think stainless will work well against it. If I can get a hold of a chrome over brass tube I can use the lamp from the Perko. Anyone have a link to a company that sells 24" of it?
cubanwhaler posted 03-10-2008 07:37 PM ET (US)     Profile for cubanwhaler  Send Email to cubanwhaler
Okay, I installed a buss bar on that back corner using theold screw holes. I used all ancor wire, connections, and heat shrink. its a work of art! Took me all day in the middle of a mild nor'easter. i am very pleased:) I have one question, and I swear this thread will finally fade into obscurity.
If water came splashing over the stern and comes into contact with the block, will it short the circuit?
I noticed that while working on the busbar i routinly came into contact with both pole, and didn't recieve any shocks. Why?
okay I asked two questions!
