| Author | Topic: Tohatsu Motors |
| fishinchips |
Whaler brothers, I am thinking about getting a Tohatsu 6-HP motor for use as a kicker on a 170 MONTAUK. Tohatsu makes the Nissan and Mercury 4-, 5-, 6-HP four-stroke outboards. |
| John Parry |
To tell you the truth, I don't like the motor. I don't like how Tohatsu and Nissan are made. You better go with a Yamaha or an Evinrude/Johnson. Evinrude/Johnson/Yamaha are a more well known engine everywhere. |
| nFL_Bosn69 |
quote: Could you elaborate on this statement please? I've been looking into purchasing a Tohatsu or Nissan for my boat, and am curious as to what you mean. Thanks, |
| nFL_Bosn69 |
Also, which state is your Quincy? I'm in Tallahassee, FL, and there is a Quincy, FL about 20 miles from here. |
| brisboats |
I have a 2001 Tohatsu/Nissan 18-HP two-stoke tiller. I use it on my 13 and it never misses a beat. Power to weight and the price point are excellent. Tohatsu is the most popular engine in many countries and just may be the most popular engine worldwide. My uncle has an 8 hp Tohatsu kicker on his Catalina 22 and he is also very pleased. Brian |
| fishinchips |
Give me more details why you don't like Tohatsu. |
| c_mccann |
I own a Tohatsu 6, it is a nice motor. It is, though, a light-duty motor for a 6 hp, only 1 cyl, that is why it is only 50 lbs. For a kicker, it wouldn't be a bad motor. I've had the motor for 2 years and I use it for my dighny all around. I've seen them used at rental docks (the Mercury small four-strokes are Tohatsu's with Merc paint) everywhere, so the long term reliability seems to be good. It is the same block as teh 4, 5hp, just a bigger carb. On thing I do not like is that oil drips out the air intake when I set it down on it's side. I thought it was because I over-filled the oil, but no. I also thought it was because I was setting it on the wrong side, but no. Just a quirk. Hope this helps. |
I think that ought to read "To tell you my opinion..." Is there anything to this opinion like informed research? Generally if someone wishes to defame a manufacturer, they will get held to some reasonable test of explaining themselves, so please go right ahead. |
| art9234 |
no problems w/ Tohatsu after 5 years and rough use> Common maintainance items available at West due to the Tohatsu is also badged as Nissan. I travel the world on my job and this brand is big in other countries. |
| bigjohn1 |
Ditto....Tohatsu is one of the most used brands in Asia and in Japan specifically, I saw that outboard on more boats than any other single brand. Have not owned one personally but knew scores of people with them and they never once complained about them. I always had trouble getting parts for my 25hp Merc in Japan and in retrospect, should have gone with a Tohatsu. |
| John Parry |
I apologize. The way I said I don't like the motor it did sound like an opinion. I don't like how there made because my friend had a bad encounter with tohotsu. it was a fairly new engine but he had a lot of problems with the electrical stuff in the motor. His electric starter wouldn't turn the motor over and things of that nature. |
| ryanwhaler |
I know two people who run Tohatsu engines, one of them on a 17' BW Haven't heard any prolbems from either, but they do seem to be slower then other brands of the same HP |
| PFSQUAN |
I had excellent performance with a 1993 70 hp Tohatsu on my 17 Tashmoo. I owned the engine and used it in saltwater for 8 years without a problem. The new owner has had similar performance. Tohatsu builds a good motor based on my experience. Peter |
| fishinchips |
thank you guys. The information was very helpful. |
| bspencer |
I have a Nissan 2001 9.9 HP 4S and have never had any issues with it as others have stated above. Frankly In 2001 saved 400.00 by not buying the Merc (same motor made by Yamaha and sold as Tohatsu, Nissan, and Merc). Anyway, for whatever it is worth my opinion is that I would consider a Tohatsu as a kicker engine. Brent |
| SpeedBump |
I know you are looking at a low HP kicker but I have been really pleased with my nissan 70. I have a 5 year old Nissan 70 Hp on my Nauset, I have run it for the past three years. Changed the water pump when I purchased the boat with motor as a precaution. The old pump looked as good as new. Had a high heat warning alarm once during a long hard run, could not figure out why the alarm went off, may have been sea grass on the intake as that is normal in our bay, but clearly no adverse effect to the engine. Otherwise the engine has been perfectly reliable in all ways, I would consider another Nissan /tohatsu when repowering. Good luck with your choice. |
I am curious how many Tohatsu outboard motors John Parry has owned, and how they have performed for him in comparison to all the other outboard motors he has owned. John, can you elaborate on this? |
| DWE |
In defense of Mr. Parry: The fact that Mr. Parry wasn't the captain of the Titanic doesn't invalidate the fact that it sunk. The fact that Mr. Parry knows a friend whose Tohatsu experienced “a lot of problems with the electrical stuff” doesn’t alter the fact that it actually had problems. If Mr. Parry sees his friend struggle with the electric starter and “things of that nature” on the Tohatsu, is he supposed to assume that what he’s watching isn’t real because he’s not the owner? I guess I don't understand Mr. Hebert’s fixation on the theory that only direct, personal experience carries any validity. |
| Sheila |
Perhaps the point is rather that even a machine built by a widely-respected and well known manufacturer may occasionally fail. In other words, a single poor copy does not a bad motor make. |
| WT |
I have a 6 hp Tohatsu kicker that is repackaged as Mercury. It's brand new and so far has worked flawlessly. I just wanted my kicker cowling to match the cowling of my main motor. I also have a 3 year warranty for the kicker. So if you can save a few hundred bucks by buying a Tohatsu instead of repackaged Mercury, go for it.
Warren |
Everyone always has a friend who had something happen. I say let the friend tell his own story. Judging from the replies, there are people participating who have first-hand knowledge or actually own these motors. I think they are better sources of information. As for the comparison to the Titanic, it would go more like this: "To tell the truth, I don't like Harland and Wolff shipbuilders. I don't like how Harland and Wolff ships are made. You better go with Saint Nazaire. Saint Nazaire are a more well known ship everywhere." Then you ask the person giving this opinion if he has owned a ship built by Harland and Wolff, and he says "no," but his friend had a "bad encounter with a Harland and Wolff ship". Now if you asked someone who owned a ship made by Harland and Wolff for their opinion, say the head of the White Star line, you might get a more informed answer. We all know that the Titanic sank, but don't all know that every Tohatsu outboard has problems with its electricals or that it can't be started with the electric motor. That's the root of the problem with you trying to make this comparison to the Titanic. |
| DWE |
Agreed. Just because the Titanic (sorry, I don’t know how to italicize words on here) experienced problems, grave problems, doesn’t mean we should assume that every ship constructed by Harland and Wolff was problematic. In the same sense, just because Mr. Parry’s friend had valid problems with his Tohatsu outboard doesn’t mean every Tohatsu outboard is, in fact, problematic. To quote Sheila, “in other words, a single poor copy does not [make] a bad motor.” Regards, |
| BOB KEMMLER JR |
have a brand new 40 on my fathers 13 and can't say enough good things about them. |
| nFL_Bosn69 |
Bob, Is that 40 of carbed or injected persuasion? What kind of performance stats do you get out of it. Top speed, hole shot time, fuel consumption, etc. Thanks, |
| BOB KEMMLER JR |
it's a carbed version,15" shaft PT&T etc.With just me (200 lbs) and a 6 gallon tank,i got about 40 mph gps with the standard aluminum prop,it jumps up on plane loaded or unloaded.Very good on fuel as well.i can ride around all day long on 6 gallons.Quiet and very little smoke on startup.I never really timed the hole shot but would guess about 3-4 seconds at most?we're very happy with it. |
| placerville |
I had a 6hp Nissan/Tohatsu kicker on my Montauk that is now on the 19' Revenge I bought recently. I was afraid that it wouldn't push the bigger Revenge well. It still drives the boat close to 5 mph in flat conditions. Which is fine with me. |
| SpeedBump |
Why does everyone pick on the Titanic. One shouldn't say Harland and Wolff didn't design and build one of the greatest ships ever built or that the Titanic wasn't a great ship. White Star lines shouldn't have defamed the builder or boat. It was the off course iceberg for crying outloud it had no business being there - just like a drunk driver. |
| Outrage22Cuddy |
I had the chance to borrow a 6hp Mercury 4-stroke (same thing) on my Porta-Bote to buzz around the harbor. It was a nice motor and would push the boat faster than my 5hp Honda. I don't know what the durability of the Tohatsu is, but the Honda is definitly super durable. If anyone could kill it, I would have already. I really like the prices on the Nissan brand motors. BTW, before you buy the 6hp, they now make an 82lb 9.9 hp 2-cylinder 4-stroke. Thats the one I'd get if I got a Tohatsu/Nissan/Merc. |
| fishinchips |
outrage22cuddy, yes, i saw that. Tohatsu/Nissan has that new featherweight motor (8 hp and the 9.8 hp) weighs in at 81 pounds. |
| ConnorEl |
I have the 9.8 hp four-stroke lightweight Tohatsu. I use it for my 13.5-foot aluminum (utility) boat. The bare boat weight is 140 lbs. I am over 200 lbs. Last season I taught my two boys (ages then of 5 and 6 years) how to ski by pulling them behind this boat and engine. The engine has been perfect so far. Very quiet and clean. |
| fishinchips |
I have been reading articles on this 9.8hp (4 stroke) by tohatsu and there was one line that says it trolled well. Able to push a 20-24 foot boat from 4 to 6 mph. My main purpose of this motor is to be able to use it as a kicker motor for a 22 foot boat. Use it for trolling for salmon on nice days and as an emergency kicker/go home motor. anyone can confirm that this motor can do that ? I do noticed that tohatsu has a different prop to push heavier loads 8.5 diameter X 6.5 pitch. Part number 3B264-5130M. Is this prop worth getting ? Suppose to push 1500 - 3000+ range. |
| Crew Chief |
I own a nissan 3.5 two stroke. I use it on my compac sailboat and I have never had a problem with it. I just purchased an 18 hp four stroke for my war eagle fishing boat. Price was right and dependabilty is great. I will admit that the honda is probably the best outboard made. If I was a commercial fisherman, a honda would be my only purchase. But I am not a commercial fisherman, and I chose nissan for the price and dependability. many of my friends run a nissan, and I have yet heard a complaint. |
| GMan |
I don't have any information about the small motors, but I have to second what Bob says about the 40 Tohatsu. I just bought one, carb version, for my 15 Striper. I did a lot of shopping, I wanted a 40 for 2 reasons. Right now, I don't want my kids going to fast, in 3 or 4 years it will go on our 13 SS. It is a perfect motor for a Whaler. It weighs a little over 150 lbs., saving 100 lbs. over the 60 Johnson I took off. I also save another 50 lbs. by only having to carry 6 instead of 12 gallons of gas. As Bob stated, it starts quickly, runs quietly and has good power. It planes very easily with any of the props listed below. My tired 60 would go about 36 mph. I get- 32.0 mph @ 5700 rpm with a 12 pitch PowerTech prop 32.5 mph @ 5400 with stock 13 pitch aluminum 31.5 mph @ 5100 with 14 pitch Michigan Wheel stainless Would have to be almost the perfect motor for a 13. Unfortunately, most 2 strokes are going away. The parts man at my dealer says they never have Tohatsus in for service, this is an area where 25's are used very hard in the marsh. |
| born2fish1282 |
[Solicits comments about a Tohatsu] 140 two-cycle motor. |
| fleedermouse |
I was all set to pick up a [Yamaha] F6 or F8 as a for kicker on 18-foot [unrecognized acronym] when a friend suggested the Tohatsu or Nissan 8-HP [because of] its two-cylinder configuration. He believes that it runs smoother at idle due to this, especially in chop and that it is a better value than any one-cylinder engine that I may be considering. |
| RandyV |
When restoring my 1979 Montauk this winter getting ready for the spring walleye in Lake Erie, I bought a new Tohatsu 6-HP four-cycle with a 20-inch shaft for $1,200 to my door (a good price in my book). It now has probably 50-hours on it, and I love it for a kicker and trolling motor. My only gripe a bit of vibration, but that is what I expected out of a single cylinder engine. However, it still trolls [more smoothly] than my main motor will idle, burns about one-quarter of the fuel, and gives me the peace of mind that if I am out 10 miles and my main motor quits, I will get back. This spring, I have fished in winds up to 20-knots and it pushes the Montauk without a problem. I work [in] construction, so unfortunately when the weather gets really nice, I have to work. That puts me on the water early spring and late fall, and often when conditions are less than ideal. I go when I can. That is why I have a Whaler so I am not worried like I might be in a lesser boat. |
Tohatsu makes nice motors. They have a beautiful manufacturing facility at Komagane, Nagano Prefecture. In addition to selling their motors under the Tohatsu brand world wide, Tohatsu also sells their motors to Mercury, who then sells them in North America under the Mercury brand name. |
| L H G |
Jim - Your above post is not correct. An equally not correct post would be: "MERCURY makes nice motors. They have a beautiful manufacturing facility at Komagane, Nagano Prefecture. In addition to selling their small 4-stroke motors under the MERCURY brand world wide, MERCURY also sells their motors to TOHATSU, who then sells them in North America under the TOHATSU brand name." Why are both of our statements incorrect? According to Brunswick, Mercury and Tohatsu have a Joint Venture, which constructed a brand new plant in Japan, operated by both companies jointly, and in manufacturing Joint Ventures the production is then shared by both of them. So when you buy a Tohatsu 4-stroke, it is half Tohatsu, half Mercury, same for the Mercury models. One does not sell to the other. I think Tohatsu was smart to get into business with Mercury, and I think Mercury was smart to get into business with Tohatsu. Mercury's 4-stroke EFI technology is used by both brands on the 25 and 30 HP engines. I think the output from this Joint Venture facility are probably the best small 4-strokes on the market today. |
| Tom W Clark |
Jim & Larry, When was the last time either one of you were in Komagane? |
On Friday afternoons, when the workers come out of the Komagane plant at 4:30 in the afternoon, and they stop at the local bar for a drink and to cash their paychecks, before heading home for the weekend, is there anyone who really thinks on the upper right corner of those paychecks it says "Brunswick Corporation of Illinois?" Tohatsu makes absolutely no public reference to the plant in Komagane as being anything but their plant, built by them, run by them, and owned by them. If there is any public declaration by Mercury that they own that plant, please, let's see it. I have never seen more than one single mention in a corporate footnote from Brunswick about Komagane, and it simply says that Mercury engines are made there in a joint-venture with Tohatsu. As far as I am concerned, the joint venture is this: Tohatsu makes the engines and Mercury buys them. |
Tom--Yes, Larry and I have plowed up this ground before. Every few months this topic goes fallow then gets replanted. The last time it came up I laid out all of the reasons and the basis for my opinion, which is primarily the public announcements of Tohatsu and Mercury on this topic. Please see this prior discussion: http://continuouswave.com/ubb/Forum4/HTML/005877.html If you add a lot of fertilizer and water, maybe you can grow two words, "joint venture" into a whole crop of words, nurturing it into joint-ownership, or 50-50 ownership, or equal partners, or co-development, or whatever you'd like. I just tend to take people at their word. Tohatsu is telling the world they built, own, and run the plant in Komagane. Mercury never contradicts them. |
| L H G |
Jim - My information came from you: (first post) I hope you're not denying it now! http://continuouswave.com/ubb/Forum1/HTML/009762.html . That sure doesn't sound anything like Mercury being a CUSTOMER of TOhatsu. And as indicated, Brunswick confirms it on their corporate website, and Tohatsu has never denied what Buckley and Brunswick are saying, and I have since confirmed it elsewhere. I suggest you investigate how these large Joint Venture manufacturing projects work, and they are almost always 50-50. The workers would not receive a paycheck check from either Mercury or Tohatsu. It would be from the partnership (Joint Venture). Tohatsu claims to have invested heavily in this new facility, as does Brunswick. It's a State of the Art manufacturing facility both companies can be proud of. And a smart move with the soaring price of fuel. These economical little engines can offer a great deal of water recreation, and should have increasing popularity as people downsize and buy kicker engines to save on fuel for fishing, etc. A huge, and growing third world market also exists for them. I have had considerable experience insuring corporate manufacturing Joint Ventures in the automotive world, and this one is probably structured in a similar manner. I have also had experience in dealing with the Japanese corporate culture in both of these (Toyota and Mitsubishi) and I can tell you the Japanese think and operate differently than we do as far as confidentiality. As is known, they are a very proud people, and really don't give Americans in the buiness world credit for much of anything, or admit to buying anything from us that goes into their products. How many cars, or outboards, do they buy from us? We are only expected to buy their products, but not visa-versa. For years Honda bought their mid-range lower units from Mercury, but never once owned up to that shortcoming of not having their own. Then there is the Yamaha 40, 50 & 60 4-stroke engine blocks being IDENTICAL with Mercury's, being produced in China now. The predecessor to these 40-60 current engines, the first Mercury and Yamaha 10Hp and 50 HP 4-strokes, introduced by BOTH companies in 1994, and built through 2002, also had ALL short blocks manufactured by Mercury, in Fond du Lac, and heads/valve trains manufactured by Yamaha in Japan. But Yamaha never admitted the major Mercury block component, and still doesn't. It sure looked like the deal was Yamaha developed the 75-115's, and Merc developed the 30-60's. Yamaha's 25 HP 4-stroke was also built by Mercury, which YOU indicated was Mercury's only complete 4-stroke engine built in the US years ago. When Mercury stopped making it here, in favor of the new Joint Venture engines, Yamaha lost out for a few years, and had a 25-30 HP void until they got their own produced. Incidentally, the Marine news these days is that once again Yamaha and Mercury are getting along fairly well. I guess it's those blocks they're still buying out of the Merc China plant! |
Larry--George Buckley made those statements, not me, as I clearly indicate with quotation marks. But thanks for digging up that quote. It certainly is a far cry from the current corporate position, which just list Komagane as one of about thirty locations where Brunswick products are made, and says nothing of ownership, management, and operation. I will write to the public relations departments of both and see what they will say. A look at Brunswick corporate SEC filings should show any real controlling interest in Komagane. |
Larry--You must disclose the source of your "confirmed elsewhere" information. Please tell all, if you can. |
| L H G |
I can't publically, Jim. The readers here, and others like you, are just going to have to determine whether they want to believe the information Brunswick discloses to it's stockholders regarding assets and manufacturing facilities. |
I've emailed Tohatsu, Mercury, and Brunswick and asked for clarification on who owns the Komagane plant, and who manages the day to day operation of it, such as hiring the workers, scheduling the production. I will let you know the what the replies have to say. If you read George Buckley's remarks, he says absolutely nothing about Brunswick being the builder, owner, or operator of the plant. He just says that production began there with their joint-venture partner Tohatsu. I don't think that Buckley's remarks are like the magic seeds of "Jack and the Beanstalk", which, with some careful nurturing, can be grown so high they reach into the clouds. |
| Kingsteven18 |
Pretty durable: http://www.tohatsu.com/news/seiko.html |
| erik selis |
Would Nissan outboard engines also fit into this collaboration somewhere? The specs of these smaller engines also seem to be very, very similar to these of the Tohatsu and Mercury engines in this range. I wonder...now that Nissan is actually owned by Renault would Nissan outboards be French? Or even worse, would Tohatsu and even Mercury be mutating some French DNA into their engines? :-o :-), Erik |
| Tohsgib |
YES and YES Erik. LARRY OWNS BC STOCK! hahahahahaha! But hey look at all the money you saved with E-Trade on commissions. PS..Larry what BC tells it shareholders would HAVE to be public information unless you are an insider. Unless you have to file under 144 rules, you are NOT an insider, etc. |
| seabob4 |
Hey guys, Just thought I'd chime in here on this Tohatsu thing. We did ONE Tohatsu install, twin 115's, last year, so I had to deal a little with their engineering department as far as some questions on harnessing. These guys are good, they are goading upper management to take any of the Nissan automotive V6s and let them create some serious horspower, but all in all tremendous people to deal with. And the sea trial of the twins? Excellent motors, felt and reacted very similar to Honda's. Maybe because I drive a Nissan Maxima...just wanted to put my 2 cents in. I'll go away now... |
| TOHATSU GURU |
Brunswick and Tohatsu formed a joint real estate company. That company owns the land, building and a couple of pieces of manufacturing equipment. Tohatsu then leases that plant back from the jointly owned company. The plant itself is 100% under Tohatsu management and control with zero oversight by Brunswick. It builds Tohatsu engines and then labels them under Tohatsu, Nissan or Mercury depending on who is buying what. The designs are from Tohatsu engineers. The sole exception to that is on the 4-stroke, 25-30 EFI model..Some Mercury engineer did have input at some point on its EFI system....It worked anyway so he must not have had too much say in it's design:) |
Thanks for the information. I still think that too many people see the words "joint venture" and somehow make a transformation to "50-50 equal partners". You can have a partnership where the investment is weighed 99-1 and still call it a "joint venture." By the way, email inquires to Mercury on this topic have never been answered. |
| TOHATSU GURU |
Sometimes I think Miss Information actually works at Mercury :) Tohatsu began making the 5-HP and small engines for Mercury in the early 1990's. Up until a couple of years ago it was still routine for [Mercury] to deny any relationship with Tohatsu at all. Even today I hear Mercury employees, dealers, and confused consumers spouting some of the funniest dumb things you can imagine. Some of my favorites [dumb things being said] are: --Mercury owns Tohatsu --Mercury uses different aluminium in their engines--that one still cracks me up --Different parts, built to higher Mercury standards. (Different shift controls on some models, as a whole, Tohatsu parts have a lower failure rate than domestic Mercury parts) --Tohatsu has a secret plant in China for their own labels and all the Mercury's are built in the Japanese plant(s). In the U.S. Mercury motors from 30 hp and down are Tohatsu production. In other countries Mercury sells larger Tohatsu models under their own label. It's a world economy now and loyalty to one brand or another because it's "home built" is a thing of the past. I don't particularly like it that way, but it is what it is. |
| Tohsgib |
Actually I thought the 1976-up 4hp gnat by Mercury was a Tohatsu. If not it was a Yamaha because it was made in Japan. |
Komagane is an odd place to locate an outboard motor factory. Komagane is in the Nagano Prefecture, and it is about as far from the sea as one can get in Japan on Honshu, the main island. Here is a GOGGLE EARTH .kml file that shows Komagane-shi, the city region in the Nagano Prefecture: (Download that file and open it in GOOGLE EARTH to go to Komagane. You probably cannot open it just by clicking on it.) Let me know if you can spot the Tohatsu plant in the satellite view. |
| Tom W Clark |
Jim, What does proximity to the ocean have to do with manufacturing outboard motors? |
| Tohsgib |
What about the Gnat? |
| L H G |
What's really strange, if we are to believe Tohatsu Guru's unsubstantiated information, is that Mercury has gotten out of the outboard building business, and entered the REAL ESTATE LEASING business. It does correct Jim's previous statement, however:
If there is any public declaration by Mercury that they own that plant, please, let's see it. I have never seen more than one single mention in a corporate footnote from Brunswick about Komagane,.." Incidentally, Jim, you mentioned that Mercury did not respond to your request. I guess, in all fairness of not giving Mercury a bad name, that means Tohatsu did reply. What did THEY say? |
| Tohsgib |
PS...Jim what does the proximity to the sea have to do with ANYTHING. Baja boats are made in Bucyrus OH...how far is that from the sea? Mercury outboards are made in Wisconsin...how far is that from the sea? C'mon...what are you thinking? |
I was in contact with Tohatsu, but I got the impression there was a bit of reticence on making details public so I did not. The impression I get is that the precise nature of the deal between Mercury and Tohatsu is not intended to be made public. Each seems to be spinning their own version, in which they are the principal element in the deal. In regard to Tohatsu, an email to a corporate headquarters did not elicit a reply, although there may be some language barriers, more so than with a Wisconsin company. With Mercury having a collective bargaining agreement with its workers in Wisconsin, and with many of those workers on furlough, Mercury probably have structured the deal as described above, in which they are only participating as real estate investors, not in outboard motor manufacturing. Otherwise Mercury could possibly put themselves into a bind regarding exporting (more) work overseas, displacing their workforce, and so on. It does seem clear, from my conversations, from information above, and just from common sense, that Mercury has very little if anything to do with the operation of the Komagane plant. It is not a reasonable conclusion that a plant in a remote region of Japan is building product designed and engineered in Wisconsin, unless there were a strong presence of Mercury engineers and production supervision at the plant. And it fits with Mercury's past practices, in which they have been buying motors from competitors and putting their name on them for decades. Again, my impression of the "joint venture" is that Tohatsu designs and manufactures the motors in Komagane, and Mercury buys them and resells them as their own. |
| TOHATSU GURU |
"What's really strange, if we are to believe Tohatsu Guru's unsubstantiated information" Not to be pretentious, but, if I say it's so....It's so. I've been heavily involved with them since 84 and know from whence I speak. I communicate with the top management at Tohatsu on a daily basis and know a lot more than I have a right to about....Things. Do I know everything there is to know about the relationship between Mercury and Tohatsu? Nope. Tohatsu Japan and Mercury blindside Tohatsu U.S. on occasion and what is secret rarely leaks and if it was a secret I wouldn't be spilling it out on the net anyway. But, everything I have related here is public knowledge. You just have to be inside that group of the public that hears, reads and asks the right questions at the right time to the right people. It also helps that I have a friend who was a Director at Mercury in years past when all this was initiated. Now for anyone who really feels froggy and has the time...Get a look at the Federal Trade Commission hearing records on the Mercury complaint about Japanese outboard dumping. It has actual info about who makes what, where it is made and actual non-massaged numbers. If your an "outboard conspiracy theorist" your dreams will be realized:) P.S. If I preface anything with "I think" or "in my opinion" it should not be construed with a guarantee of 100% certainty...Only 99.99%. I think that is the right percentage:) |
| TOHATSU GURU |
Federal Trade Commission should have read as the Federal International Trade Commission. You can bring up some of the docs online, but those copies have blacked out areas on some of the jucy tidbits. |
I have read about 500 pages of transcripts of the United States International Trade Commission (USITC) hearings on importation of outboard motors from Japan. I agree, there is an awful lot of very interesting information in there regarding Mercury Marine and its relationship with Yamaha, however, I do not recall reading much about Tohatsu. I believe that the relationship between Tohatsu and Mercury may have been structured differently than the relationship between Yamaha and Mercury. Mercury probably learned from their nasty situation with Yamaha how vulnerable they could become when a source of engines on which they were very dependent suddenly decided to play hardball. That's what happened with Yamaha. When Mercury Marine launched their complaint with the USITC, it was clear that they were firing a shot across Yamaha's bow. This was probably perceived by Yamaha as a strange way to treat an important supplier. When Yamaha returned the salvo and informed Mercury it was not going to supply them with motors, Mercury had to take Yamaha to court to force Yamaha to continue to sell them motors. I suspect that Mercury learned a lesson from that. Perhaps when Mercury made the strategic decision to abandon manufacture of small engines in the United States and began to seek an Asia supplier, they wanted some way to get more leverage in the deal than they had with Yamaha. Of course, they could not turn to Yamaha--they had just ended a long relationship with them on very nasty terms. Tohatsu already had a relationship with Mercury, so they were a natural choice. It seems that Mercury's partnership with Tohatsu is structured so that Mercury has a bigger stake in the process--they apparently own a portion of the plant. Being the landlord is a good way to keep the tenant in line. This relationship may also have been more attractive to Tohatsu. Tohatsu perhaps saw how Mercury turned on its former partner Yamaha and tried to attack them with import tariffs, and Tohatsu may have demanded that Mercury show its long-term intentions and good faith by paying up front for the manufacturing plant that would be making the engines Mercury needed. But it seems perfectly clear that Mercury has shifted its engine production away from Wisconsin, away from American workers, and away from its own direct supervision and control, and is now buying engines from Tohatsu. Yeah, yeah, it's a "joint venture." That is corporate-speak to keep the Union from howling. Not long ago someone tried to make a point that the engines might be made overseas but the profits come back here. That is a joke. Mercury has been telling us that the profit margin on engines is small and shrinking. The margin is less than 5-percent, I believe. Here is what that means about wealth distribution: If you buy a Mercury engine that was made in Komagane for $4,000, your money flows around the global economy like this: --the dealer who sold it probably keeps $400 and sends Mercury $3,600. --Mercury keeps $180--that's 5-percent of $3,600 or their profit margin--and sends $3,420 to Tohatsu to pay for the engine that Tohatsu made. --Tohatsu keeps some percentage as profit, let's say 10-percent or $342, and the rest is paid out in Komagane to workers, suppliers, taxes, rent, and so on. "The rest" is $3,078. OK, maybe some of that comes back to Mercury as their share of the rent. We'll give then 5-percent or $154. Now we add up where all the money landed: Money that stayed in US Money that went to Asia A lot more of your $4,000 "Mercury" engine purchase ended up going to Asia than it did to Wisconsin or Illinois. |
The final report from the USITC on the matter of outboard engines from Japan is available from http://hotdocs.usitc.gov/docs/pubs/701_731/pub3752.PDF As mentioned, some of the material has been redacted in the public version, and we are left reading tantalizing tidbits like this: "Mercury imported some of its ***-produced engines and powerheads *** and some ***-produced engines through its ***." However, you can imagine it originally read: Mercury imported some of its Yamaha-produced engines and powerheads *** and some Tohatsu-produced engines through its ***. Or you can imagine missing charts and graphs like this one: Table IV-1 (The chart has been completely redacted.) The report also contains a few statements of monumental proportion but left obscured in footnotes like this one: "At petitioner’s request, Commerce excluded imports of 75, 90, and 115 hp powerheads from Japan from the scope of the investigation." The "petitioner" was Mercury Marine who had imported 70,000 Yamaha power heads from Japan in the horsepower range, but wished to exclude that data from consideration in the findings. But, even with some of the best stuff redacted (to protect vital competitive data it was claimed), the report still makes for interesting reading. |
| swist |
To add another reply to the original query (I have neither the knowledge nor inclination to contribute to this international trade digression): I have owned 2 small Tohatsus - flawless operation with real minimalist self-maintenance. As you go up the Maine coast, service facilites for any kind of motor get fewer and farther between. But at the same time, you see a higher and higher percentage of Tohatsu engines on small working boats in the little isolated fishing villages. That should say something. If you add in Yamaha, that covers about 99% of the more recent (last 10 years) motors on small working craft in the above-cited areas. The remaining 1% are things like 1951 Evinrudes which still provide service because the (82 year-old) owners knows exactly where to hit it with a big wrench to get it to start on the 47th try :-) |
| sea_stork |
I own a NS70A2 Nissan 70HP, and a M40C Tohatsu 40 HP. They are awesome. I'll tell you why I don't like Tohatsu... They discontinued head gaskets for that 70. I could understand some odd part that you could get from a junk motor, but a maintenance part. I will never buy a new motor from them again. Greed has reared it's ugly head. |
