  Reliability of 2004, 2005 Verado Motors
Author Topic:   Reliability of 2004, 2005 Verado Motors
paddyt111 posted 02-11-2008 09:01 PM ET (US)   Profile for paddyt111   Send Email to paddyt111
There has been some discussion in other posts about a new generation Verado in 2008. I have just last month purchased a 2005 Boston Whaler boat Ventura with a 225 Verado. Are the 2004 and 2005 Mercury Verado motors good and reliable motors? Have they caused problems which has resulted in the change? Is the [motivation for any change in the Verado motor] mainly better fuel economy? Or are there reliability [problems]?
sosmerc posted 02-12-2008 01:32 AM ET (US)     Profile for sosmerc  Send Email to sosmerc
As new engine releases go, the Verado has been one of the more successful launches that I have been aware of regarding Mercury motors. Yes, there have been some glitches and the product is constantly under improvement. But the overall performance and running quality and reliability has been stellar. Also, it is nice to know that a qualified dealer can give you a printout showing the status of your engine and can even make updates to your engine software should any be available or required. You can look at the run history and fault history of your engine. Have the recommended service performed at the recommended intervals, keep your electrical system in good order, run clean, properly treated and filtered gas, make sure you are propped so that your engine can reach the recommended rpm range with your normal load and you should get many many hours of reliable service.
paddyt111 posted 02-12-2008 05:33 AM ET (US)     Profile for paddyt111  Send Email to paddyt111
Sounds great, I'll look forward to my next print out.
tombro posted 02-12-2008 07:45 AM ET (US)     Profile for tombro  Send Email to tombro
I love all the Ventura and Verado talk here these days. I have the same boat and engine, both 2005. I am running great at 300 hours so far.
The propeller [problem] is one I grapple with, as I cannot seem to get to the lower end of the recommended RPM with the Mirage that is stock. I am considering a REVOLUTION4 with 2-inch less pitch. Sosmerc, your thoughts on this?
paddyt111 posted 02-12-2008 03:55 PM ET (US)     Profile for paddyt111  Send Email to paddyt111
Tombro, I too have seen other discussions on the Mirage Plus SS prop. I don't claim to know but this fellow said it is the worst stock propeller Merc makes for the Verado. Unfortunately, it is the one that came with the my 225 hp Verado.
Here is what he said
Propping Correctly
It is vital to your engine’s long term health that you be propped correctly and yes, many mfr’s
don’t get it right. Many Mfr’s supply you with a “Mirage” propeller which is Merc’s worst prop, IMO.
Having the wrong propeller is like running around town in your car in 3
rd gear from stoplights.
Verados that are “over propped” - low RPM at WOT – have been known to “make oil” that is add raw fuel to the crankcase which raises the oil level over a period of time (BAD)…
1. Load the boat down with 50% gas and a light load for fishing, cruising, etc
2. Find a very flat piece of water a mile long and bring your trim tabs all the way up.
3. Trim your engines "in" and take it up to full WOT and start trimming up
4. Keep trimming up until the engine starts cavitating - losing speed (you can't hurt it - all new
engines have rev limiters)
5. Now drop it back down a bit until it "bites"
6. Now look at your rpm - For Verados it should be at least 6000, 6250 would be ideal.
compare the results on a propeller slip calculator - from cruise on up to WOT you should be less
than 10%---> go here: http://www.rbbi.com/folders/prop/propcalc.htm
I had every intention of starting a new threat on this very issue. I too would like to know whether I should consider loosing this propeller and buying another. Some discussion welcome .Pat
bluewaterpirate posted 02-12-2008 04:20 PM ET (US)     Profile for bluewaterpirate  Send Email to bluewaterpirate
Take the guess work out of this
http://appcenter.mercurymarine.com/propSelector/home.do
tombro posted 02-12-2008 05:08 PM ET (US)     Profile for tombro  Send Email to tombro
Thanks Pat and Tom (and glen e!)
I only get about 5500 doing all that he mentioned. At the NY Boat Show I spoke with a Merc rep, and rather than the 15p Rev4 he suggested an Enertia in the same pitch I already have 17". I'm confused.
But he said I may be able to trial a propeller free.
And the Merc link for propeller selection has been broke for the longest time keeps telling me my expected speed or pitch is incorrect.
I am planning more testing this coming spring.
paddyt111 posted 02-12-2008 08:08 PM ET (US)     Profile for paddyt111  Send Email to paddyt111
Tombro, Did your Mirage plus come with your Boston Whaler boat? Do you have a 225 Verado? If so, it [raises] the question on why Boston Whaler, with all its discussion on no compromise, why does it have a propeller that under performs?
We should stay in touch on our efforts to find the perfect propeller given that we have identical boats and engines.
I am talking with a Mercury Verado dealer in Fort Myers at the moment looking at adding a kicker (still not sure). I'll ask him about the Mirage propeller. He seems to know his stuff.
Pat
tombro posted 02-13-2008 06:01 AM ET (US)     Profile for tombro  Send Email to tombro
Pat, keep me posted on your findings. I can't imagine a manufacturer selling boats with lugging engines. It may be that the performance data they claim and that I found differ due to several reasons.
My bimini top and strataglas was up last time I checked had a full tank of fuel maybe I was opposing the tide, etc, etc.
As I said, I will try again this spring. The only reason I would consider a new propeller was due to this lugging issue, making oil, rather than speed or performance. I am rather happy with what I get out of this boat/motor combo as she stands.
Tom
boatdryver posted 02-13-2008 12:12 PM ET (US)     Profile for boatdryver  Send Email to boatdryver
tombro, try to do the test alone if you have full fuel.
Full fuel versus the recommended half fuel in your 21 Ventura is like having an huge NFL lineman standing behind the helm area.
it makes no difference which way the current is going unless an opposing wind is kicking up a significant chop.
Please let us know what you find. I'm going to be testing my new Whaler which will be delivered with full fuel.
JimL
glen e posted 02-13-2008 04:00 PM ET (US)     Profile for glen e  Send Email to glen e
many verados are also "buried" that is mounted too low which many mfrs do to keep things safe and adds a lot of drag .get the engine height right first and then start meesing around with props. A good source for propeller advice is over in sarasota - Ken Reeves at propgods.com - has propped a ton of verados - call him - he'll give you free advice over the phone. Download this and see the section on engine height and propping:
read this twice..it'll take a few min to download
http://www.veradoclub.com/images/Verado_Owner_s_Tips__3_.pdf
jimh posted 02-18-2008 07:24 PM ET (US)     Profile for jimh  Send Email to jimh
quote:
"There has been some discussion in other posts about a new generation Verado in 2008."
Mercury does not use model year designators. There was a distinct change in the Verado motor which occurred in mid-year of 2007. There is no way to differentiate the new motor from the older design except by the cowling graphics. Otherwise all the nomenclature used by Mercury for the engine seems to be the same. The "dock name" for the newer motors is "GEN 2" as in generation two, or second generation. The cowling graphics have a raised chrome look.
The precise differences between the Verado and the Verado GEN 2 have not been well documented, at least as far as I know, but one significant difference which has been widely noted is that the GEN 2 motors seem to have better fuel economy but a "worse" emission rating compared to the initial models. I put "worse" in quotes because the GEN 2 motors are still approved for sale in all states except California. However, in California they are being sold under the fleet average provisions of the California emission regulations which measures a brand's total product mix and its total emission output. So even though the individual Verado motor does not meet the emission rating in California, it can still be sold there as long as not too many of them are sold there. Solution of this problem of exactly how many can be sold in California will require some calculus, and I will leave that to the California regulators, the Mercury emission certification engineers, and the lawyers.
There seems to be a general linkage between improved fuel economy and increased emission levels (or "worse" emissions). That is, an engine which has been tuned to produce the absolutely lowest possible output of the regulated combustion products may not be able to produce fuel economy which is as high as possible if the engine were re-tuned for best fuel economy. This seems to be what has happened in the case of the GEN 2 Verado motor. The GEN 2 Verado will get better fuel economy than the original motor while emitting more combustion products in its exhaust gases. For most boaters this is an acceptable situation, even probably for Californians. For everyone else, it is a no-brainer. Give me better fuel economy, thank you. I imagine you will agree.
Regarding reliability problems, the Verado motor was introduced in February of 2004 and it did not ship in large numbers until later in that year. So we have had about three and a half years of production and field experience. In that time there have been very few reports of any problems with the Verado which have not been resolved to satisfaction. I believe that a few problems have been reported with the engine mount during extremely high speed transit in high seas, but those were very exceptional cases, and most boaters would never run their boats at those speeds in those conditions, so it was not particularly a Verado problem but more of a crazy boat driver problem.
I do not see anything about the Verado motor which would make selection of an appropriate propeller particularly different than in any other outboard motor. I do not think that the Mercury MIRAGEplus propeller is "the worst" propeller in the Mercury line, and I reject that notion. When the Verado motor was first introduced the Mercury propeller line did not have a REVOLUTION4 propeller with a pitch that was low enough to be used in some cases where a single Verado was powering a large boat. Later Mercury introduced a REVOLUTION4 propeller in 15-inch pitch, and this has become a popular choice for some boat and motor combinations involving a Verado.
My impression of the propeller testing done by Boston Whaler for their particular boat and engine combinations is that it is generally quite comprehensive, although limited to Mercury propellers--which, since Mercury makes 700 different propellers, is by no means particularly limited. For someone to characterize the propeller testing done by Boston Whaler as being " a compromise" I would suggest that all propeller selection is a compromise, and what is perfect for your application may not be perfect for another owner's application. But I completely reject the suggestion that Boston Whaler was deficient in propeller testing or sold you an inferior propeller because the boat has a MIRAGEplus propeller. That is just nonsense, and when I hear nonsense I will point it out.
The advice about propeller selection given above as being specific for a Verado is really just the usual general advice for selecting a propeller for any boat, and I don't find it particularly specific for a Verado and a Boston Whaler. The recommendation that propeller selection should permit an engine to reach the upper range of its rated maximum engine speed when a boat is lightly loaded and properly trimmed is applicable to all boats and motors, inboard, outboard, Mercury, Yamaha, two-cycle, four-cycle.
As far as the mounting height, this again depends on how the boat will be used. People who operate in rough seas, who like to proceed at slow speeds while on plane, and who are not particularly interested in getting the absolutely highest straight-line speed in calm conditions will often find that their preferred engine mounting height may be lower than if they had were seeking the maximum possible speed in calm conditions.
jimh posted 02-18-2008 07:49 PM ET (US)     Profile for jimh  Send Email to jimh
Regarding changing from a MIRAGEplus to a REVOLUTION4 propeller with a pitch which is 2-inches lower, I think you will find that the maximum engine speed will not change much. It has been widely reported that a REVOLUTION4 and a MIRAGEplus of the same pitch will produce different engine speeds, with the REVOLUTION4 producing a lower engine speed.
I have tested a REVOLUTION4 and a MIRAGEplus of the same pitch (17-inch). The difference in maximum engine speed on my test was quite significant.
MIRAGEplus = 5,400-RPM
REVOLUTION4 = 4,700-RPM
Others who have made this comparison have reported less difference, however in all cases I believe the REVOLUTION 4 gave lower engine speeds.
tombro posted 02-19-2008 08:57 AM ET (US)     Profile for tombro  Send Email to tombro
Jim, thanks. You just saved me about 600 bucks, as I was leaning toward your reasoning.
paddyt111 posted 02-19-2008 09:09 AM ET (US)     Profile for paddyt111  Send Email to paddyt111
Jim, What size (hp) engine did you test the two propellers. Secondly, what generation Verado? Pat
jimh posted 02-19-2008 09:42 PM ET (US)     Profile for jimh  Send Email to jimh
I tested the propellers on a 225-HP V6 two-cycle motor, not a Verado. Others have reported less difference between a MIRAGEplus and a REVOLUTION4 of the same pitch, however in all cases I believe you will find that the REVOLUTION4 will produce lower engine speeds. I would expect that you might find the difference to be more like 500-RPM. My tests produced a pronounced difference. I would actually like to re-test the REVOLUTION4 propeller, especially if I could find one in a 15-inch pitch.
The initial premise was that going from a MIRAGEplus of 17-inch pitch to a REVOLUTION4 of two-inches less pitch would result in a net INCREASE in engine speed. I would be surprised if that result was obtained.
The general rule of thumb with propellers is that in a line of propellers of similar design, decreasing the pitch by 2-inches will produce about 450-RPM of engine speed increase, and vice versa.
When changing from one style of propeller to another, you cannot rely on getting the exact same engine speeds with the same pitch. I think there is general agreement that the REVOLUTION4 is harder to turn than the MIRAGEplus. In my tests, I found it much harder to turn. Others have found it harder to turn, as well, but not found such a big difference in engine speed. I think Tom Clark has tested both and might have more data to report, albeit like mine, not with a Verado motor.
glen e posted 02-19-2008 10:56 PM ET (US)     Profile for glen e  Send Email to glen e
call ken at propgods.com and stop all this long diatribe...he is the master for verado propping.....has propped maybe 100 verado boats including a bunch of whalers...that's why he's my sponsor...free advice over the phone...
Jim, love ya, but honestly if you never propped a verado, why expound on it?
jimh posted 02-19-2008 11:13 PM ET (US)     Profile for jimh  Send Email to jimh
I don't believe that the rule of thumb about engine speed and pitch makes any special exceptions for the Verado. As far as I can tell, the Laws of Physics still work, even for the Verado. If you drew a propeller power curve for a REVOLUTION4 and a MIRAGEplus, the curve is the same no matter what engine you connect to the propeller.
You can see a graph of my propeller power curves for those two propellers in my article on that subject:
http://continuouswave.com/whaler/reference/propellerPowerCurve.html
If we had a power curve for a Verado engine we could predict the engine speeds by seeing where the curves crossed.
Glen--sorry if I didn't immediately think to put in a plug for one of the sponsors of your website. It did not occur to me.
Tom W Clark posted 02-20-2008 11:16 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Not to derail this thread further, but I do have some experience with both the Mercury MIRAGEplus and the Revolution 4 propellers after trying both the 17" and 19" pitch Rev 4 and 19" MIRAGEplus on my own Revenge 25 with twin 150s and a 19" and 21" pitch MIRAGEplus and 19" Rev 4 on a 22 foot Mako with a single 225.
For the record, here are the maximum engine speeds for each propeller:
Revenge 25 WT with twin 1989 Mercury 150 HP:
17" Revolution 4 -- 5900 RPM
19" Revolution 4 -- 5400 RPM
19" MIRAGEplus -- 5500 RPM
Mako 215 with 1994 Mercury 225:
19" Revolution 4 -- 5300
19" MIRAGEplus -- 5600
21" MIRAGEplus -- 5000
You can see that differences between the same pitch MIRAGEplus and Revolution 4 are much smaller than what Jim has reported.
Thirsty Whaler posted 02-20-2008 07:22 PM ET (US)     Profile for Thirsty Whaler  Send Email to Thirsty Whaler
I have run the Mirage and Revolution propellers on my Verado 225-HP. Yes, Jim, the laws of physics do hold true across the board and the space-time continuum is not altered. The Revolution posted just under a 500-RPM lower engine speed.
Jim, ther are times when your patience and understatement of the obvious make me wear an ear-to-ear grin!
jimh posted 02-21-2008 12:01 AM ET (US)     Profile for jimh  Send Email to jimh
Tom and Thirst--Thanks for adding your results. I think I need to re-test the REVOLUTION4 on my boat. My data is quite aberrant compared to yours.
In your data the REVOLUTION4 turns about 100 to 500 RPM slower than the same pitch MIRAGEplus. Therefore, if the REVOLUTION4 had its pitch dropped by 2-inches, the engine speed ought to tend to increase by 450-RPM. The net would be (450 minus 300 or) about a 150 RPM increase compared to the higher pitched MIRAGEplus.
If anyone has a REVOLUTION4 in 15-inch pitch, I would love to test it.
ASIDE: When we were at the Boston Whaler Owner's Event at Torch Lake last summer, there was a new CONQUEST sitting on the lot on a trailer. It had a Verado with a REVOLUTION4 15-inch pitch propeller. I was very tempted to ask the dealer if he would mind if I took the propeller off the new boat and did a quick propeller test run with it, but I did not have quite enough chutzpah to ask him.
The REVOLUTION4 15-pitch seems to be a popular set up on larger boats rigged with a single engine.
Tom W Clark posted 02-21-2008 10:29 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
I have to append some data to what I contributed above. One the the test results from John's Mako was from an earlier test run with the 21" MIRAGEplus that he reported to me but I found my results from the single morning when we ran four different props on his boat so the more accurate representation of his data would be:
21" MIRAGEplus -- 5200
19" Tempest Plus - 5800
glen e posted 02-21-2008 01:09 PM ET (US)     Profile for glen e  Send Email to glen e
Jim - I get no money from my sponsors....they are puely people that can answer questions as that is their job...Just like I tell people constantly the CW is the place to go for whaler info, there are other sites that know more about certain things that you wanting to build content and if you search THT or FL sportsman, Ken is a great source for free for verado propping info....
L H G posted 02-21-2008 01:59 PM ET (US)     Profile for L H G
Here's some real test data that will really botch you guys up:
25 Outrage, with Armstrong bracketed twin Mercury 200 EFI's, 1.87 gear ratio, counter rotating. This is a relatively high power to weight rig, and the twin Rev-4's give the hull great lift, better than the other lines of props.
23" Laser II -- 5600
21" Laser II -- 6000
21" Revolution 4 -- 5900 (lg vent plugs, FT IV hub, 62MPH)
21" Mirage Plus -- 5600
19" Revolution 4 -- 6300
My thoughts: Rev-4's really turn on when they are driven by twin HIGH power engines, mounted high, on lighter boats where the twin props can achieve the overall hull lift, greatly reducing drag, and increasing top end speed. I would not recommend a Rev-4 on a single engine low power-to-weight boat, instead preferring a Vensura 4-blade, Vengeance (surprisingly good prop) or Mirage Plus.
On my boat, I actually think a pair of 23" Tempest Plus or Enertia's would provide even higher top end.
Here's some more data:
21 Ribside Outrage, single Merc 2.0 liter 150, 2.0 gears:
23" Laser II -- 4800, 47 MPH
21" Laser II -- 5200, 47 MPH
21" Revolution 4 -- 4900, 47 MPH
19" Vensura -- 5500, 45 MPH
19" Alum Black Max -- 5500 45 MPH
19" Laser II -- 5600 47 MPH
For these 1st generation Outrages, 19 & 21, the Laser II is a great prop. Will also be trying a Tempest Plus, which might be better however.
jimh posted 02-22-2008 12:53 AM ET (US)     Profile for jimh  Send Email to jimh
Larry--Those data are interesting. It looks like the REVOLUTION4 must have lifted the boat and propellers out of the water--they ran faster than the MIRAGE propellers, and that is contrary to everyone else's data. Quite unusual.
Now on your 150-HP Outrage, we're back to the 300-RPM difference (slower) with the REVOLUTION4. That's more like the rest of the results.
Glen--that comment was with a big "wink wink"--If PropGods were local to me, they'd be on the speed dial on the office telephone.
tombro posted 02-22-2008 06:32 AM ET (US)     Profile for tombro  Send Email to tombro
Now, how about those Enertia props. Factory rep says their thinness and design can turn a couple hundred more RPMs--in the same pitch--as the MiragePlus.
If I had PropGods here in New Jersey I would try a few on for size.
I'll be in Fort Lauderdale come July, but alas, will be Whalerless while there.
Peter posted 02-22-2008 07:25 AM ET (US)     Profile for Peter  Send Email to Peter
Tombro -- What speed do you achieve at 5500 RPM?
tombro posted 02-22-2008 08:10 AM ET (US)     Profile for tombro  Send Email to tombro
I believe about 32 kts.
Peter posted 02-22-2008 08:53 AM ET (US)     Profile for Peter  Send Email to Peter
The numbers don't make sense to me. According to Whaler data, you should be seeing nearly 44 MPH at 5500 RPM with a 17 inch MiragePlus and that the Verado 225 should be able to turn it to 6150 getting 49 MPH.
What was the fuel consumption rate at 5500, if you know?
tombro posted 02-22-2008 09:25 AM ET (US)     Profile for tombro  Send Email to tombro
No, the numbers don't make sense to me, either! I have never been close to either that RPM or MPH on the website.
But...have not done a load of testing, and am rarely, if ever running WOT.
At condition dictated common running speeds of 3200 RPM I am traveling 22kts or so on the GPS, and if calm and trimmed up, am getting 2.7 MPG as per my Smartcraft guage. Numbers I am happy with.
bluewaterpirate posted 02-22-2008 09:27 AM ET (US)     Profile for bluewaterpirate  Send Email to bluewaterpirate
Tombro ......
These are interesting stats. I run a Mirage Plus 17 prop on my 225 Opti. Here are my numbers. This is with 3 souls on board, 85 gallons of gas, 10 gallons of water, fishing equipment. Figure the boat comes in at about 5100 lbs.
3500 ..... 27.8 mph 7.9 gph
4000 ..... 33.1 mph 8.8 gph
4250 ..... 34.9 mph 10.5 gph this is the sweeet spot
4500 ..... 36.7 mph 11.7 gph
5000 ..... 41.9 mph 14.9 gph
5725 ..... 46.9 mph 19.6 gph
These are gps numbers using Smart Craft SC 1000.
Not only do I use engine trim but my tabs to level the boat for best fuel economy. How you load your boat makes a big difference.
What engine holes is your Verado mounted on?
Tom
tombro posted 02-22-2008 12:05 PM ET (US)     Profile for tombro  Send Email to tombro
Tom, I have no clue what mounting holes, but suspect lower rather than higher.
I will come back this spring with a performance chart.
Tom W Clark posted 02-22-2008 12:12 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Tom B.,
I am rereading this thread and note that you do not say what propeller is on your Verado 225 power 210 Ventura, but the implication is that it is a 17" Mercury MIRAGEplus. Can you confirm this?
Whoever said the MIRAGEplus is Mercury's worst prop obviously doesn't know what he is talking about. Propellers do not care what brand of outboard they are on, but some boats will make better use of some models of propellers than others. The MIRAGEplus is unusual in that it has far more applications where it is a good fit than most other models of propellers.
This is why the MIRAGEplus has been made for so long, in so many pitches (from 15" to 29", an unequalled range) and continues to be supplied as original equipment by manufacturers who can choose any prop made today, and by high horsepower, high performance powerboaters.
Running the numbers with the data you have provided and assuming the prop in a 15-1/2" x 17" MIRAGEplus it looks like the prop is suffering terrible 23 percent slip at WOT of 5500 RPM and 37 MPH. I have a very hard time believing this.
Yet your cruise numbers make more sense, 3200 RPM at 25 MPH is about 10 percent slip, more in line with what I have come to expect from the MIRAGEplus.
The perplexing thing is that *if* there was something amiss that was causing your prop to slip terribly at WOT it would tend to make it easier for your Verado to achieve higher RPM; it would NOT be a factor in holding it back.
Could you confirm the data you have presented? On the face of it, it appears there is something wrong with the motor itself or the prop is badly damaged.
tombro posted 02-22-2008 01:05 PM ET (US)     Profile for tombro  Send Email to tombro
Wait...hold the presses. I am running the 15 1/2 x 17 Mirage, as on the Whaler Ventura 210 performance pdf.
I searched back in my logs and see that top performance was just under 41 kts at WOT, which seems in line speedwise with Whaler data.
My only worry is that my top RPMs were nowhere near the 6150 that their chart claims the test boat Verado 225 achieves, and that I am lugging the motor. As I stated previously, I am going to do some beta testing this April, after spring commissioning and report back.
Tom W Clark posted 02-22-2008 01:53 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
OK, that makes a little more sense. 47 MPH at 5500 RPM with a 17" pitch prop on the 1.85:1 gears of the Verado 225 calculates to a very low 1.5 percent slip.
That is such a low slip figure that I am skeptical of the data. It could be your tach is off by a few hundred RPM and/or you actually have a 15-3/8" x 18" MIRAGEplus.
Best to verify everything the next time you run the boat.
L H G posted 02-22-2008 03:22 PM ET (US)     Profile for L H G
Some thoughts regarding the Mercury MIRAGE PLUS prop:
I think it is *not* Merc's worst prop by a long shot. Those honors go to the aluminum 4-bladed Alpha 4. Stay away from that one. Nor is it one of Mercury's best props, from my experience. On most boat/power applications, you can do better with something else. Personally, I have tried it, and don't like it since if offers practically no lift, doesn't hold all that well, and I have talked with *many* others who also don't like it. I do think it's one of Merc's reliable, all around good performers, a notch above the Vengeance. Mercury says it's best suited for HIGH HORSEPOWER, HEAVY BOATS, as it was actually designed to run fully submerged as a sterndrive prop.
This link is worth reading, for Mercury's own recommendations on applications for each prop line:
http://sites.mercurymarine.com/portal/page?_pageid=126,51007,126_51013& _dad=portal&_schema=PORTAL
Tom Clark says:
(Mirage Plus) "continues to be supplied as original equipment by manufacturers who can choose any prop made today, and by high horsepower, high performance powerboaters."
Well, that is not what i am seeing, as any anyone who looked around the Miami Boat Show recently, and observes higher performance outboard powered hulls in the SE Florida Gold Coast area, knows. Mirages are not that popular in this market segment, and are considered a tamer, older design, like the big hub Laser II's. Used Mirage Plus props are a dime-a-dozen. What you see on these bigger twin, triple and quad rigs are Revolution-4's, Enertia's, Tempest Plus's, and Bravo I's. This is where the action is, and my own prop testing bears this out. I note the big Whaler Outrages are all running Rev-4's. Boston Whaler seems to like the Mirage for their mid-range boats, with single engines. And remember, BW tends to set up their boats for conservative performance and HP ratings. For that application, it could be fine, but for big, multi-engine rigs, with high HP, definitely not.
Tom W Clark posted 02-25-2008 09:53 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
It is interesting that I seem to have a very different experience with the MIRAGEplus propeller than Larry.
While it is pointless to make blanket statements about what props are good or bad because it all depends on what boat/motor combination one is talking about, I can say that on a twin engine 25 foot Whaler, the MIRAGEplus is a superb performer beating out all the other props I have tested including the Revolution 4, Laser II, Offshore, Enertia, High Five, Black Max, Stiletto Advantage II and the original Mirage.
The large diameter of the MIRAGEplus provides excellent stern lift, something a large diameter propeller are known to do, as well as offering nearly the top speed (which is of little concern to me) of the Laser II and Advantage II.
At cruising speed no other prop yields the same fuel mileage. While the MIRAGEplus will not grip as well during acceleration as the four blade props or the Enertia, it is more than good enough for even waterskiing and tubing, and really, with 300 HP, no 25 foot Whaler is going to have any trouble leaping on plane regardless of what prop is used.
L H G posted 02-25-2008 02:23 PM ET (US)     Profile for L H G
It is looking like Jimh is now starting to observe some of the same things I have been indicating:
http://continuouswave.com/ubb/Forum4/HTML/005969.html .
