ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Marketplace 1993 Boston Whaler Rage 14
Author | Topic: 1993 Boston Whaler Rage 14 |
barber107 |
posted 02-01-2011 08:51 AM ET (US)
A good friend of mine is liquidating his collection of toys. I am interested in a 1993 Boston Whaler Rage 14 he has. We haven't discussed price yet, but I know he only has $500 in to it as he basically stole it from a rich neighbor that bought it and never used it. He is willing to bring it to me and let me play with it before I make up my mind and we discuss terms. I know what they say about buying something from a friend, but we don't have to worry about that here. The reality is that the $1000 or so I'd have to pay would never damage our friendship even if I just threw the money away. Back to the boat: the hull is in great shape (always stored indoors), the engine runs well (needs the choke cable setup worked on), the steering is a little tight (probably needs the steering cable replaced), and really the only issue is with the jet drive. He says the impeller should be replaced as it seems to pull in air sometimes and kills the thrust. He said it isn't really an issue on flat water, but he uses it on Lake Erie, so that doens't happen all the much up there. I plan on using it to do a litttle fishing and recreational boating on Buck Creek (a 2,120-acre lake with no hp limit). In all honesty I have an urge to tinker and I think this might be a good project for me. The only thing I am not sure about is parts. There is a Boston Whaler dealer within an hour, and a few other non-Boston Whaler dealers within 30 minutes. I just wonder if parts for the jet drive and engine are easy to come by and how much they run. Looks like an entire engine could be purchased from http://www.shopsbt.com/ for a reasonable price if I ever wanted to get more power or just have a "new" motor in it. What do you all think? Are parts easy/cheap to come by? What about shop manuals or other expertise? What is a fair price for a boat that I would rate in good working order and great condition? Anything else I shoudl consider? Any and all opinons are welcome. Sincerely, |
Waterwonderland |
posted 02-01-2011 11:44 AM ET (US)
There is a great deal of feedback on the Rage at this site. You should be able to get a good idea of the advantages and disadvantages of the Rage. Some newer feedback would help as well. Some samples: http://continuouswave.com/ubb/Forum8/HTML/001980.html The Rage is the least valued of all BWs. Since the jet is very inefficient the higher hp models, like 175, tend to hold better value than the lowest powered 50 hp. The 115 hp OMC models seem to have the most durability problems. The Rage has been customized with things like newer motors and adding outboards. Since they weren't designed for outboards I would be reluctant to tinker that much.Typically good condition Rages are priced in the $3,500 to $5,000 dollar range. I don't think the Rage would be a good for anything but an occasional fishing venture. Touring around would be it's strength. Given your interest in tinkering, I think the $1,000 would make for a fun project. |
Tohsgib |
posted 02-01-2011 02:22 PM ET (US)
Down here you can't give those things away. |
adlert |
posted 02-01-2011 02:58 PM ET (US)
barber107, I assume that the Rage you are looking at has the Yamaha powerplant and pump? If so, I believe we've heard many owners say many positive things about that particular set-up. Maybe a tad low on power for some, but that is a relatively easy fix if it turns out to a be problem for your particular use. I could see enjoying a Rage very much if I could find the smaller, Yamaha powered version as you appeared to have done. On top of the handling capabilities, I must admit I feel more relaxed when sending my teenagers and their friends off on our jet skis versus the prop-powered crafts. You can just never tell what silliness they might wind up getting into with friends along... Get a manual for your powerplant and pump. I'm sure they're available. If you need to replace the impeller, I wouldn't worry much about it. Mine have been quite easy, I imagine the Rage isn't much different. |
adlert |
posted 02-01-2011 03:23 PM ET (US)
Matt, I forgot to mention that expertise should not be hard to come by - certainly not for the engine and driveline. If indeed you have the Yamaha setup you'll find lot's of good tech help on the main PWC websites such as PWC Today. Also, SBT has quite a few good technical articles they've assembled and keep on their website. Parts availability and price should not be a problem. If your engine is the one that puts out 50 hp I imagine it is Yamaha's 650 cc engine. A wonderfully reliable and durable engine. Just as great is their 700 cc engine which, in dual carb form puts out over 70 hp. I wouldn't be surprised if the 700 would directly replace the 650 with very little hassle. It does on all the Yamaha PWCs and is a switch that is commonly done. Lastly, on the PWC websites you'll see many options available to raise the output of the 650 engine. Regardless, if the engine is running well now but turning an aluminum impeller (worn out or not), your best bang for the buck performance gain will likely replacing the aluminum with a same pitch stainless. Talk to the men at Impros impellers for that need. Great folks. If your engine has 140 - 150 psi now and sounds good, no need to replace unless going bigger is needed. It would be very hard to wear out the Yamaha 650 or 700 cc twins given proper care. Tim |
barber107 |
posted 02-03-2011 01:06 PM ET (US)
Thanks for the replies. I have to admit that I am getting a little excited about this project (both a good and bad thing as it sometimes leads to rash decisions). If the engine and pump are indeed Yamaha (I am almost 100% sure they are) can anybody verify the exact model of each? I'd love to find a shop manual for the boat/engine/pump if possible. That'll make life much easier. Also can anybody verify what engine upgrades are available? If the unit is indeed a little sluggish I'd like to upgrade it if possible. Of course, that will depend on the price of doing so. Thanks, adlert, for the suggestions! Sincerely, |
Tohsgib |
posted 02-03-2011 02:39 PM ET (US)
If the engine is under the console and usually silver in color it is a yamaha and will most likely say it. If the engine is under a rear hatch and looks like a crossflow OMC V4, it is the 115 but that was on the 15's. Whaler "invented" the jetboat with the Rage in 92 or 93, unfortunately they took it further(up to 18' V8's) and shot themselves in the foot. |
contender |
posted 02-03-2011 04:22 PM ET (US)
Maybe your friend really did not steel it.... Why do you think the rich are rich... |
adlert |
posted 02-03-2011 04:32 PM ET (US)
barber107, You're welcome. It's almost certain you have the Yamaha 650, a very good thing. It's an amazingly compact 2 cylinder engine; easy to tell the difference between it and the other, larger engines. Assuming you have a Yamaha powered Rage, I've heard many times that the engine, pump, and I assume associated electronics required to run the engine and charge the battery, are likely the exact same as that used in the 1993 Yamaha "Waverunner." Others on this site with that boat will hopefully chime in. In the mean time, do a search for "Tuna1"; I believe he owns, or owned 2 of the Yamaha powered Rages. I also think a member under the name of "Where2" knows a lot about the Rages. I'll bet they'd help if you drop them a line. I'll suggest taking the craft out first and taking things one step at a time. If cavitation is indeed a problem, solve it first, probably via a new stainless impeller as mentioned before. Replace pump bearings if necessary but don't be surprised if they are just fine. Then, if performance is still not satisfactory for your uses, get into the PWC forums and you'll find tons of stuff regarding squeezing more HP safely out of the 650. Also check out what a company called "Group K" does for its customers. They really know their stuff. Common upgrades include higher compression heads, higher performance exhaust systems, smoothing out ports and carburetor restrictions, etc. If I ever decide to raise the performace of my Kawasaki 650, I'll probably just go the route of finding a used 750 engine and drop it in. Healthy 750 engines from early to mid 1990 Kawasaki and Yamaha jetskis are plentiful and not too expensive (often ~$750 or less). Buy a complete ski if you have to. I think I'd go that route just to make sure I wouldn't have any associated electronic issues. They can also be had, with trailers you can sell off, for $1,000 in my area this time of year. |
adlert |
posted 02-03-2011 04:40 PM ET (US)
Here is an example of the good information available from Tuna1 regarding this particular Rage: http://continuouswave.com/ubb/Forum8/HTML/000378.html Hope I did that link correctly... |
drno503 |
posted 09-09-2011 03:31 PM ET (US)
I BOUGHT A 15 FT RAGE IN FLA WITH 115 HP OMC OUTRAN SEAFOX V8 NOW IN WESTERN NY AND NOT IN WATER CAN THE PUMP B FIXED YES WITH A LITLE HELP FROM YOU LOCAL MACHINE SHOP DOES ANY 1 WANT 2 WORK ON THEM,,, NO IS A MINT WAHLER RAGE WORTH 4000 HELL NO R U A MASCHIST ??? GET IT 4 1000 Y NOT |
