| Author | Topic: OUTRAGE 18, Honda 150: Propeller Selection |
| djd35de |
I have an 1987 OUTRAGE 18 [soon to have a HONDA 150-HP four-stroke outboard motor]. What propellers are recommended? I sometimes fish 50-miles offshore. It can get choppy or rough. I have a 22-gallon bait tank mounted towards the [stern] of the boat, dual batteries mounted in console, swivel seats, and front cooler. I normally fish with three people that weight over 200-lbs, a full tank of gas, and gear. I'd like a propeller that performs well at lower speeds. Being able to plane at the lowest speed, lower the bow in the wind chop, and good trolling behavior would all be good. I've had a few suggestions on a prior thread; just looking for more information. Thanks To all. David |
| Tonym |
David, That was a lively discussion with a lot of good information. I can't give you any advice specifically for your rig but we do have some similarities. My Raider is, from what I have been told, basically an 18-foot 6-inch Outrage hull with a different interior.The Honda 130-HP weighs 510-lbs and I believe yours weighs 485-lbs. I have a 9.9-HP kicker (also a Honda) which adds an additional 117-lbs. So I have a boat whose hull is heavier to start with, plus an additional 142 lbs of engine and at least 20-HP less. To help compensate for this I have Bennett M120 trim tabs installed. I had both batteries installed in the console, and I have a Kodiak 32 gallon live well installed in front of the console. All of this has helped, but I still am looking for better mid-range performance. I think from what you have mentioned we are looking for similar things. I don't think you have to worry about the low end of your range (trolling 5 to 8 mph). If you are like me you are more concerned about the mid range and good ride and economy at 18 to 22-MPH. Tom was saying that in order to give you good advice everyone here needs some actual performance information from you and some actual data points about how your rig performs with a certain propeller at each range, i.e. boat speed at 1,000-RPM, at 2,000-RPM, etc. Tom posted a form for keeping prop data in a previous thread. You may want to find it and print some copies to fill out when your running your tests. I recommend you talk to Eric and explain what kind of boating you do and ask him to prop it with a decent aluminum prop. He will do his best I'm sure. Then take the boat out and get the data in several different sea conditions. This will give you the information you need for people to offer good recommendations. You are going to need at least one spare prop so after you have all your information (and borrowed a few test props) you can go out and buy a good stainless steel prop that suits your rig. I shouldn't complain about the way Eric propped my boat. It hits the 6,000-RPM level. It gets up on plane without much difficulty. The problem with my rig is to maintain the 20 to 22-MPH level I have to run 4,800 to 5,000-RPM. I believe this has more to do with being overweight and underpowered than with the way it is propped. Good luck, Tonym |
Because your boating emphasizes operation in rough conditions, I recommend you start with the engine mounted low on the transom. This will give the propeller plenty of "bite" with perhaps a small sacrifice in top speed. Next, choose a propeller that will let the engine wind up to 6,000-RPM. A good place to start would be with a three-blade propeller of moderate pitch and plenty of blade area. I don't think your boat will be a high speed rocket under your normal conditions with over 600-lbs of crew, full fuel, lots of gear, and coolers full of ice. |
| Tom W Clark |
What is the Wide Open Throttle (WOT) range of a Honda BF150? What is the gear ratio of the lower unit? Do we have any baseline performance data on for this boat yet? |
| Perry |
WOT range is 5000 to 6000 RPM and gear ratio is 2.14. If you asume the BF150 will give you a maximum speed of 47 MPH at 6000 RPM, and you insert 2.14 as the gear ratio and 6% slip, you end up with a prop with around 19 inches of pitch. The Honda 3 blade (Powertech OFS) in 18 pitch I recommended in the other thread actually performs like a 19 pitch prop. I know this because I have one. It has a large surface area and works great in offshore coditions. When running a 4 blade prop, you generally need to drop one inch of pitch which in your case should be around 18. Since the 4 blade Honda "turbo" model you ordered does not come in 18 pitch, I recommended you try the 14.25 X 17 pitch 4 blade. This should give you good acceleration, good grip in rough seas, good cruise fuel economy and also enable you to maintain plane at a lower speed than a 3 blade prop. I don't claim to be a prop expert but I have the same basic motor as you on a similar boat and have tried these props that I recommended. Others here have experience with different brands of props like the Stiletto and may give you good advice about which of them may work well for your application. Good luck... |
How'd we get to 47-MPH? If we use a hull factor of 180 and 150-HP, that combination implies a boat weight of only 2,200-lbs (from Crouch's calculator). |
| Peter |
I think 47 MPH for an 18 Outrage powered by a Honda 150, even if it were lightly loaded, is very optimistic. Try 42 to 44 MPH which suggests using a 17 inch pitch propeller to make sure the motor spins up to 6000 RPM. This might be slightly underpropped for a light load but since DJD says he will be running his boat on the heavy side for fishing, this should be OK and his Honda will thank him for this. Based on Honda's published power curve for the BF 150, I would expect it to be more sensitive to propeller choice. A 4-blade propeller will be harder to turn due to increased drag. So there is a general rule of thumb that the motor will lose 200 to 300 RPM using a 4-blade propeller of the same pitch and style/shape as a 3-blade propeller counterpart. Thus, if going with a 4-blade propeller, it might be that a 15 inch pitch is necessary to allow the motor to turn up to 6000 RPM. Unfortunately, the only way to know what is the best propeller for a particular combination of boat and motor is to try a bunch. Part of the problem is that there is no standard for designating pitch that has been adopted by propeller manufacturers. Thus, the actual pitch of one manufacturer's 17 inch pitch propeller is not necessarily going to be the same as the actual pitch of another manufacturer's 17 inch pitch propeller. Jimh's propeller test report is excellent evidence of this. |
| Tom W Clark |
I tend to agree with Peter that a 19" would be too much and a 17"-ish is probably going to be a better fit, but it entirely depends on WHICH 17" propeller we are talking about. A large surface area prop like a Power Tech OFS may be too much propeller unless pitch is reduced even further. The OFS is similar to the Mercury Mirage Plus and is an excellent prop for larger heavier boats. It *might* be good for this boat but only in a 17" size. If the motor can spin a 17" I would expect it t be an excellent choice given David's sated application. In a four blade Honda prop like the Four Blade OFS I would think he would have to drop all the way down to the 15-1/4" x 16" model. That is a big prop and may be too much for an Outrage 18 though it would have to stick like hell. If the Honda BF1590 can turn a big pro like that, then it should be able to turn a Mercury Revolution 4 in a 15" or 17" pitch. A Mercury Offshore/Vensura four blade would worth trying too. In the Stiletto Line, the Advantage II 14-14" x 17" would be the ticket and probably the fastest prop of all. A Stiletto Bay Pro (four blade) III in the 14-1/4" x 15" may be a good fit. Note that the Stilettos tend to overstate pitch so choose a lower pitch model than you might otherwise. I have sold a lot of Advantage IIs but only two Bay Pros and I have not tried the Bay Pros on my own boat. The reports I have gotten are good. Here is the feedback I got from one CWer on a 15" Bay Pro III on a 150 HO powered Outrage 17 II: 'Got to use the prop over the weekend for a couple of days. Very impressed with the performance. The boat came up on plane very quickly and I was able to stay on plane at a lower speed. I could see a two or three mph reduction at top end, but the rpm went up to about 5800. I even think I am getting better gas mileage, but I couldn't prove it." He had formerly been running a 19" BlackMax aluminum propeller and wanted a prop that would grip well. |
| Perry |
Peter, maybe 47 MPH was a bit optimistic but I assumed an 18 Outrage with a strong 150 HP motor (160 HP?) would be able to hit 47 MPH. But only 42 MPH? Come on. The weaker BF135 pushes my 190 Outrage to over 46 MPH and it is longer, has a larger beam and is much heavier than an 18 Outrage. I disagree on the BF150 not being able to swing a larger prop. Once again, my BF135 can swing a 15.25 X 17 Powertech OFS to 6300 RPM and a 14.25 X 17 4 blade Honda prop to 6000 RPM. I think a 15 pitch prop will not be enough and make his motor bounce off the rev limiter. I know I'm comparing two different boats and I'm interested to see what size prop he ends up with. |
| Peter |
Perry -- 42 to 44 MPH is what I predict. If the revs don't get right on 6000 RPM, then the HP is less than 160 and it progressively falls off with each RPM below 6000 RPM. This is different than your BF 135, the E-TEC 150 or the Yamaha F150 where peak HP is made below the redline for the motor. I'm not aware of any performance data on the BF 150 on an 18 Outrage so its just an educated guess at this point and it will be interesting to see what happens. |
| Perry |
I found an earlier post from a member who has an 18 Outrage and a BF150: bwc8418 says:
quote: |
| Tom W Clark |
Perry that is good data, thanks for researching it. Again I recommend a 1`4-1/4" x 17" Stiletto Advantage II if a fast three blade prop is desired. The 17" Advantage II will perform (pitch-wise) like the 19" Ballistic. |
| djd35de |
Ok guys here's is the baseline test.Eric did a sea trail and started with a 15.25x19" 3 blade made for honda by Solex I think.It only could turn 5000rpms .He just got the 4 blade turbo 14.25x17" in and installed it.Also both props are stainless.Iam going up tomarrow to pick up the boat but first will try maybe 2 or 3 different props.Any suggestions would be great. Iam thinking a 15.25x 16 would put me right at 6000rpms.But i believe the props are either 17" or 15" . thanks David |
| Perry |
David, how high did he mount the motor? Is it one hole up? You have recieved lots of suggestions. But again, try the 4 blade 17 pitch and also a 3 blade 17 pitch and maybe even a 15.25 X 16 Powertech OFS made for Honda. Make sure to trim the motor all the way out (up) until the speed does not increase. Do you have a GPS to measure speed? Also, try to proof read and spell check your posts, the spelling and punctuation erroes make it difficult to read. A space comes after a period. Let us know how it turns out tomorrow. |
| djd35de |
I just want to say i appreciate all the suggestions from everybody here.Tom Clark,Tony,Jim,Perry everybody. Iam very impressed with the vast knowledge people share on this site. When i get back tomarrow hopefully i'll be able to give a thumbs up and report all the data. Wow what passion we have for our beloved Whalers. thanks David |
| djd35de |
Iam not sure how high he mounted the engine. I told him about mounting it 1 hole up. He told me it depends where they mounted the first engine ,but that he would line up the skeg on the engine with the bottom of the boat. He only has 3 blade props in stock other than the 4 blade he ordered for me. Its a 4 blade turbo 14.25x 17 . I was hoping he had all different sizes but the props he has in stock are Honda Titen 3 blade stainless in sizes , 15.25x 19, 17 15 pitch. He also has the same pitch props but smaller diameter 14.25x 15, 17, 19 etc.... Thanks hopefully one will work for me. David |
| djd35de |
Oh and yes iam taking my GPS to test for top speed. |
| Perry |
In addition to the 4 blade 17 pitch, I'd try the 3 blade Solas Titan in 17 pitch and the 3 blade 14.25 X 17 as well. Don't even bother bringing along a 19 pitch prop. |
| djd35de |
Well guys long day to say the least. So i'll get right to it. Got there early about 6:30am. The wind was blowing real strong from the east(STANTA ANA) winds aprox 30mph. He had the 4 blade honda turbo prop in 14.25x17 mounted on the engine. We launch the boat and right away it has a real nice feel,boat is level even just cruizing along about 5-7 mph. We get outside and punch, it only manages to pull 5000rps. Darn, I was hoping to use this prop and just go home already. So we change to a 3 blade Honda Titin prop 15.25x17 pitch and once again make a run,Same thing about only 5000 rpms. So we go back and i suggested maybe lifting up the engine another hole. It was already mounted 1 hole up as everybody seemed to recommend. So now its 2 holes up and we opt for a 15.5x15 pitch 3 blade Honda Titin prop. Ok this time its just me and my friend and i punch it and the tach goes to about 5900rps a few times. We're in the right range and i tried to trim up the engine to just about level and was able to attain about 34-35 knts max. I just am not sure about this as i know its in the right range as far as rpms go but remember its very windy and choppy. So I Pay for it and talk to Eric some and we make the long trip back. By the time i get home there's no wind , flat calm so we launch again. Well this time in nice flat water it is bouncing off the rev limiter. I had a feeling this was going to happen. Oh well iam thinking og lowering the engine back down 1 hole like it was mounted before and see again. Otherwise i'll have to send this prop back and try again. Iam really leaning to the 4 Blade TURBO Honda Turbo prop in 14.25X 15 pitch. What do you guys think? i hope i've provided enough information.. Comments welcome guys thanks Oh and by the way i can't seem to trim the engine up at all not even level without it making that weird sound i guess cavition. Comments Welcome David |
| djd35de |
Maybe if you guys could look at the 4 blade props at honda Marine.com and help me make the right choice? I think the Honda turbo 4 balde prop 14.25 X 15 could be the ticket. whats your take guys. Thanks David |
| Perry |
David, of all the props that I've tried on my my current motor (about 7 in all) the Solas is the one that has performed the worst. These are relatively inexpensive props and I'm wondering why you didn't try a Powertech? If you didn't get any ventilation with the prop, I'd leave the motor 2 holes up. With a good cupped 3 blade prop or a 4 blade prop, you should get good grip in offshore conditions. I'd return that Solas Titan and try a 17 pitch Powertech or maybe get a 17 pitch Stiletto from Tom Clark. If you bounced off the rev limiter with the 15 pitch Titan, the 4 blade Honda "Turbo" in 15 pitch might not be enough pitch. Welcome to the fun of prop testing! I have a slightly used 14.25 X 17 pitch Honda logo 3 blade prop I'd sell for $175 if you are interested. |
"Vows made in storms are forgotten in calm waters." This is good advice to recall when propeller testing. |
| djd35de |
I believe the engine is up too high. Because i can't even trim the engine up to not even level without cavitation. So iam going to move the engine back down 1 hole. Which will set the engine back to 1 hole up. If this does'nt work iam going to have to sent this prop back and try another. Guys I tried what he has in stock. The price of all this includes a stainless prop from him so thats part of the deal! Does anybody think that the 4 blade 14.24 X 15 pitch would be the right one? If it lowers the rpms 200-300 that should be about right i would think. If you guys could suggest a Honda prop from their website that would be most helpful. At this time iam kind of frustated and a bit disappointed as i've spent lots of money and its not performing right yet!!!! Thanks Perry but i tried a prop like that already. This like picking the right camshaft for high performance engine. Its not so easy as i thought. David |
| Tom W Clark |
David, Feel free to introduce a double line break when you write thus creating paragraphs that make it easier to follow along with what you are writing. OK, we understand you want to stick within the Honda line of props because a stainless steel propeller was part of the purchase price of your new BF150. With that in mind and based on the performance data presented so far, I recommend the Honda "Turbo" 14-1/4" x 17" three blade propeller, (#58233-ZY3-A17H). This is a Turbo 1 propeller made for Honda by Precision Propellers in Indianapolis. Precision also makes Stiletto propellers so this would be the sibling of the Stiletto Advantage II and should be a very good fit. Yes, you need to lower the motor down one set of bolt holes. The best motor position for the Outrage 18 has always been one hole up. This has been well documented. |
| Tonym |
Dave, I¥¥¥m glad you made it back safe. That truly is a long drive thru traffic while hauling a boat. I know what you are saying about the wind. It is a strong offshore wind all the way down to Ensenada, B.C.. Gusts to 45 MPH. I was going to do some prop testing on 2 new props today but there was just too much wind. The bay is flat but the wind would seriously pollute my data. The forecast is for an onshore flow by Tuesday. Winds should drop to below 10 mph. If your prop is cavitating on a flat sea just imagine what will happen going over the top of 3 to 4 foot swells. Also Dave, record you speed at each rpm range paying particular attention to at what speed and rpm you come on plane and likewise at what rpm it takes to maintain the 18- 22 mph cruise that I believe you are looking for. Likewise, measure your speed and RPM at WOT. Do you have a Floscan installed? If you do it could be useful information if you note how many Gallons per Hour are indicated at each Rpm level. Good Luck, Tonym |
| Perry |
quote: What do you mean by this? How do you know what level is? If you are talking about the line half way on the guage, this does not necessarily mean the motor is level when it reaches the line. Put a carpenter's level on the anti-ventilation plate with the boat on the trailer and find out when it is level; then look at the trim guage. That Solas Titan is not a good offshore prop. I would put on a good offshore prop with lots of cupping or a 4 blade prop and try it before lowering your motor. It may save you lots of time. You don't raise or lower your motor to to adjust for RPM at WOT. This is done by trying differnt props. If it still ventilates after finding the correct prop, then lower the motor. |
| Tom W Clark |
I should add that if you wanted to got with a four blade propeller instead, the Honda "Turbo" four blade, 14-1/4" x 15" (#58234-YZ3-A15H) would be the right fit. This is (I believe) the Turbo Ultima and a close cousin to the Stiletto Bay Pro. |
| Tom W Clark |
What David's boat is suffering is ventilation not cavitation. Ventilation is caused by the blades surfacing and sucking air into the prop. Cavitation is a completely different phenomena. |
There will be a difference in the propeller's tendency to ventilate in rough water conditions compared to smooth water. In rough water the hull will be rocking up and down in response to wave motion, and this will tend to bring the propeller closer to the surface than would occur with the boat running at a steady attitude in smooth water. This is why I recommended that you begin the testing with the motor mounted low. You will give up some speed in smooth water, but you will not experience propeller ventilation in rough water. I am basing this on my experience with my own boat. I have the engine mounted as low as it can be, but I often find that in rough water I wish it were mounted even lower. The design of the Whaler Drive on my boat puts the engine mounting height at the equivalent of about "2-holes up," and, while this is fine in smooth water, it can be a problem in rough conditions. Another consideration is that a lower-pitch propeller will probably tend to hang on better than a higher pitch propeller of similar design. I found that a 15-inch propeller would hang on to its "bite" in all sorts of sea conditions, but that a 17-inch propeller would loose its grip. Often in rough seas it is desirable to be able to run the boat with a bow-high attitude in order to ease the boat's entry into head seas. The only way to get your bow up is via engine trim. There is no trim tab that will raise the bow. Therefore, if you have chosen a propeller which does not permit the engine to be run with it trimmed up (so that it would tend to raise the bow of the boat), you will find yourself in a miserable state in rough headseas. If you have to tuck the engine trim all the way down to keep the propeller connected, you will also be forcing the bow down and perhaps making a rough ride into the seas. You ought to base your propeller selection on the load and sea state in which you will be doing most of your operation. Earlier you indicated you'd be running far offshore (50-miles!) and carrying three other people. It does not make sense to select a propeller for that sort of service based on how the boat runs with just you in it and in calm water. |
| Peter |
David -- I hate to say this again but the only way to really find what is the best performing propeller and motor height combination for your rig is to try a bunch. I don't think you'll be getting terribly great advice by someone looking at Honda propeller offerings and suggesting one unless that someone has already traveled down the "road" you are now traveling with the same boat and motor and motor mounted in exactly the same way. Before adjusting the motor height further, let's establish where the anti-vent plate lies relative to the keel without regard to one hole or two holes up. Not all motors on Whaler transoms were mounted exactly the same and not all motor leg lengths are exactly the same either so the anti-vent plate position in your one or two hole up position might not be exactly the same as another's. So what is the height of the anti-vent plate in relation to the keel at the stern with the motor as it is currently mounted? Can you take a picture that shows the relationship and provide a link to that? Just as a frame of reference, on my current 18 Outrage, the 140 Johnson is mounted two holes up. This puts a 1 1/2 inch space between the top of the transom and the bottom of the mounting bracket. It also causes the anti-vent plate to be lined up with the keel. |
| Tonym |
My Honda 130¥¥¥s anti ventilation plate sits exactly 1 ¥¥ inches below the keel. My engine is set on the second hole. All of my boating is done in the Pacific Ocean. Should it be exactly even? Will changing this affect performance? Thanks, Tonym |
| Perry |
Peter makes an excellent point:
quote: Before you go changing the height of the motor, check the height of the anti-ventilation plate in relation to the bottom of the hull at the transom. My motor is 2 holes up which is about 1 3/4" above the keel and I boat mostly in rough water and rarely experience ventilation with a good offshore prop. Most good stainless props are designed to run up high. I would leave the motor mounted where it is until you find the prop that works the best. If a stainless prop was included in your purchase, it makes sense that the dealer wants to give you a cheap Solas Titan. Return that prop and ask for a 16 or 17 pitch Powertech or the 4 blade "Turbo". |
| djd35de |
Thanks Tony for the kind words. Yes it is a long haul. People iam not good at typing sorry. And i don't even know how to double space. Please give me a break. Ok first ,i went out to check the engine with a level. The gauge is not even close. With the engine level the gauge reads about 85% low or almost at the bottom. Thats great why even have a gauge if its not accurate. Second I took some pictures from different angles so you guys can see how the engine is mounted in relation to the transom. Iam pretty #$$%&%^ off but will remain calm to a point. I've driven over 850 miles my body is tired,ego somewhat damaged and this darn boat is making a fool of me. Iam going to go to a friends house and see if we can post some pictures. I hope Eric takes care of me,Iam pretty sure he will. Its just that he does'nt stock 4 blade props so this will need to be ordered. Maybe they can send it directly to me. Tom Clark the prop you're recommending the Honda 4 blade Turbo prop 14.25 X 15 should put me right where it needs to be. It just seemed to ride better,stick or just more stable is what iam trying to say. and thats exactly what type of handling iam after. that was the one i was looking at last night when i could'nt sleep. Thanks everyone and i'll let you guys know what happens.... David how do you double space ? |
| Tom W Clark |
Hit the button on your keyboard labeled "return" twice. |
| Tom W Clark |
Peter, Perry, Is there really that much difference between a Johnson and a Honda in terms of vertical positioning of the AV plate? Peter has his Johnson mounted two holes up and reports the AV plate to be even with the keel. Perry has his Honda mounted two holes up and reports that the AV plate is 1-3/4" above the keel. Now I know Perry has a Nantucket (Outrage 19) not a classic Outrage 18 but still, that is a HUGE difference. The bolt hole spacing on all motors is 3/4" so the difference between the reports is equivalent to 2.33 bolt holes! I would like to see some photos to help get to the bottom of this disparity. |
| Tom W Clark |
David, Relax, I know you have had along weekend. You will get it all worked out in due course. I, for one, am glad you are going to all this trouble and sharing what you have learned. While you are probably hoping to just figure out what is best for your boat, remember that what is written here will be revisited many, many times. Next year (or maybe next week) some guy will repower his classic Outrage 18 with a Honda BF150 and will do a search of CW for information about what the appropriate propeller is for it. This thread will come up. This is where all this discussion really becomes valuable. You are helping not only yourself but these future BF150 owners as well. This is one of the reasons I am so particular about what and how information is reported here. I think you are very close to finding h best pro for your boat. I would support your desire to try the four blade Turbo in the 15" pitch. That should work just fine for you. I will go out on a limb and predict a top speed of 44-45 MPH with that propeller. |
| Riverwhaler |
David, just a suggestion.....why don't you go and do what you bought the boat for, spend some time getting used to what it feels like in different conditions with whatever prop you have on. Get to know the boat a little. Then when you are comfortable with that then try a different prop. It took me a whole season with a three blade to realize what a difference a four blade Vensura made. Now I can see what it does even tho I tried it early in owning the boat. Relax. |
| Peter |
Tom -- These long links should show the relationship on my latest 18 Outrage. The anti-vent plate is even with the keel new.photos.yahoo.com/whaler186/album/576460762347092655/photo/ 294928803848807889/14 There is 1 1/2 inches from the top of the transom to the bottom of the bracket. new.photos.yahoo.com/whaler186/album/576460762347092655/photo/ 294928803850604774/15 A closer shot of the anti-vent plate even with the keel new.photos.yahoo.com/whaler186/album/576460762347092655/photo/ 294928803850576071/16 |
| Tonym |
Dave, Good to hear from you. The engine runs good right? So don¥¥¥t worry, be happy! Did he give you the 3 year or the 5 year warrantee? I¥¥¥m sure Eric will make it right relative to whatever deal you have with him. I assure you the Albacore won¥¥¥t be back until May 20th, 2007 so you have plenty of time to figure it all out before you need to worry about the offshore. It¥¥¥s more effective to spend some time with your rig than going out and spending money. There are a few shops here in San Diego that may loan you a prop if you want to try something different (if they think you are a paying customer). I will pass those names on I will be free anytime after this coming Friday afternoon so if I can do anything to help just let me know. I would be happy to help. Just cut down on the caffeine, please! I have a couple of props I need to get some data on anyway. I¥¥¥ll send you and email with my cell #. I wont be able to help you with your top end as my boat is somewhat of a ¥¥¥Dog¥¥¥. You will probably loose me at about 4500 or 5000 rpms. Let me know, Tonym |
| djd35de |
Well maybe i'll be able to post pictures in a couple of days. Ok i"ll relax. I had my 17ft whaler and also went through some growing pains but in the end it was dialed in perfectly. One down , one to go. i realize this information will help the next person that repowers with a honda. Thanks Tom for the tip with the double spacing. Anyways what does 34-35 knots = in mph? |
| Perry |
Tom, the anti-ventilation plate on my motor is actually 3/4" above the keel. I don't know how that 1 got in front of the 3/4 in my post. I will take a photo of it next time I'm at the marina. David, what are you going to do next? Send back the Titan and have Eric send you a different prop, if so which one? Will he let you borrow more than one? I bet the shipping cost will not be cheap. Tony has a good idea about going to a local prop shop in San Diego to see if you can try some demo's. Good luck and try not to get frustrated. |
| Perry |
35 knots equals 39.2 MPH |
| djd35de |
Thanks Perry Yes iam going to talk to Eric in the morning. David |
| djd35de |
Well guys, I spoke to Eric today and ordered the prop from him. My dealer does'nt stock this prop,Iam just glad he did'nt give me any problems about ordering it. He just wanted to be sure. So i look forward to giving some good reports soon. Mean while i guess i'll go through the engine break in period. thanks everybody for all the responses and information . David
| sternorama |
jFor rough offshore both my old 150 Merc 2smoke and my current 60hp Johnson 2smoke behaved much better (but a tad bit slower at WOT) with a reduced pitch 4 blade prop. Good luck-GS |
| sternorama |
scratch that-only reduced the pitch on the 60hp! Still running a 3 blade on the 60hp, but nice broad cupped blades. Not much help, I know... |
| djd35de |
I ordered the 14.25 X 15 four-blade stainless Turbo propeller. I just spoke to Eric and he received the propeller yesterday. He's sending it off today. Maybe if [I] am lucky it'll be here Friday, and, if not, Monday, [I] imagine. Waiting is the hardest part. I'll let you guys know how it performed after testing it. David |
| Perry |
I still think [the 14.25 X 15 four-blade stainless Turbo propeller] is not going to be enough pitch but I suppose you will find out for sure soon enough. At 6000 RPM, a 15-inch pitch propeller on your motor will top out at around 39-MPH and that is factoring in zero percent slip. It should provide excellent grip and a great hole-shot though. Make sure you trim the motor up until the speed measured on your GPS reaches its max. Hopefully you will have some calm water to test it. Good luck... |
| djd35de |
Perry--the three-blade 15.25 x 17 was too much. The four-blade 14.25 X 17 was too much, also. The three-blade 15.25 X 15 is too little and the engine speed bounces off the rev limiter. I am taking a good guess at this point. Since the four-blade is the same pitch but has more surface area I expect to see a reduction in [engine speed of] maybe 300 to 400-RPM [as compared to the] three-blade of the same pitch. That should put me right about 5,700 to 6,000-RPM, I hope. If this doesn't work then [I]'ll have to keep testing. But [I]don't think [I]'ll be able to ask Eric anymore. I'll just have to take Tony's suggestion and try a local company for demo propellers until [I] find the right one. Heck maybe [I] need a 14.25 X 16 pitch four-blade? But they don't make that pitch in this prop! As far as speed goes, [I] don't think it'll be a speed demon either way. I was thinking about your boat. It is 650-lbs heavier, but [I] think it cuts through the water better than the old classics. That is the only thing [I] can think of. What is your thought, Perry? |
| Riverwhaler |
Surprised on what doesn't work on your boat. I have Nantucket with 150 Honda and found 14 by 19 pitch Vensura by Mercury felt just right. Could probably use 1/2 inch pitch less as RPM didn't get to quite 6000 but thats probably better. Seems like we were doing 45MPH on GPS. As I said on previous posts four blades makes a world of difference. Maybe Vensura isn't cupped as much. And I am running tests in fresh water. Whatever that means..... |
| Peter |
DJD you are correct with your observation about "cutting through" the water. Let me explain using Crouch's speed predicting formula. Crouch's speed predicting formula uses three factors to estimate boat speed: 1) HP, 2) weight, and 3) a hull factor. A boat with a higher hull factor will go faster with the same HP and weight than a hull with a lower hull factor. Speed prediction for a given HP and weight for a classic 18 hull is best estimated using a hull factor of 180 to 185. Based on Whaler performance data, the hull factor for a 190 Nantrage ( Nantucket/Outrage) has been determined to be between 205 and 210. What this simply means is that the Nantrage is easier to push through the water. This is not surprising given that the hull shapes are quite different. Perhaps the most noticible difference is in the stern. The Nantrage has a softly contoured profile with several lifting strakes providing lots of lift running right to the edge of the transom. The classic 18 Outrage, on the otherhand, has a sharp V with 14 degrees of deadrise at the transom and the two sharply angled sponsons providing good tracking but causing some drag on either side. Basically, what this higher hull factor means is that Nantrage is going to be less sensitive to weight loading in the boat and a bit easier to prop. It is my belief that since the Nantrage has a different and higher hull factor, it may not be the best guide for propping the classic 18 Outrage. Again, the best way to find the right propeller is to try a bunch. The propeller manufacturers do not adhere to any standard when it comes to pitch designation for propellers so no two manufacturer's "17 inch pitch" propellers, for example, are necessarily going to be the same actualpitch.
| Tom W Clark |
Peter is correct. Pitch is a relative term. I suspect the Turbo 15" pitch will perform like a 17" from most other manufacturers, just as all the propellers made by Precision Propellers I have tested have. For speed predictions, I would use 17" in the Propeller Calculator for this prop. It may well be that David's Outrage is heavier than most. David, have you weighed your new boat yet? |
| Perry |
David, didn't you first try the props in 30 MPH Santa Ana winds in Ventura? Didn't the same 15 pitch 3 blade Titan gain 400 to 500 RPM after you tested it in calm conditions in San Diego Bay? I don't believe your first test to be very valid. If what Tom says about the 15 pitch 4 blade Turbo prop behaving like a 17 pitch prop is true, you may be in business with this new prop. Let us know how the test turns out. |
| djd35de |
Well, No i have'nt weighed my boat. It does feel pretty heavy but i've never been in an 18ft outrage. The only other boat i have to compare to is my 17ft striper. This is a different animal all together! Where would i be able to weigh my boat? would i disconnect the trailer form the boat? And i would guess come back and weigh the trailer separate. What should it weigh? It has a center console with duel batteries, Swivel seats,22 gallon ,front cooler seat,bait tank and of coarse the new Honda 150 4 stroke. As far as testing the props, Yes it was diffcult do to the high winds but i did the best i could. I was looking at the honda off shore 4 blade but i don't think he stocks them. Anyways this is all speculation until i retest this prop. I'll be sure to record the data this time starting at 1000 rpms all the way up to 6000. Then we'll see. Until then guys David |
| Tonym |
David, There is a truck stop here in Otay Mesa near where I work. They have big truck scales. You just drop the trailer on the scale and have them weigh it. You do need to know how much your trailer weighs though or at least have a good guesstimate. I need to weigh my Raider in the near future plus my new addition, a 22 foot Guardian. Let me know and I¥¥¥d be glad to take you over there. Good luck, Tonym |
| djd35de |
Yes tony ,I'll have to take you up on that. give me a call 619-420-3727 or 619-213-2191 thanks David |
| djd35de |
Well Guys, I i just received the prop today. Its the honda 14.25 X 15 pitch 4 blade turbo. I installed it and hopefully i can do some testing wednesday or thursday.
| Peter |
Record fuel consumption if you happen to have a fuel flow monitor. |
| djd35de |
No ,I don't have a fuel monitor. |
| Peter |
Too bad because WOT speed and WOT RPM only tell a part of the story about what is a good propeller. You might have two propellers that are equals at WOT speed and WOT RPM but one is a more efficient cruiser. Or one might be the best WOT speed/RPM propeller but the other, while coming in a close second on WOT speed/RPM, is a more efficient cruiser. Or the one might be the best WOT speed/RPM propeller and the most efficient cruiser. You'll have a hard time telling which is really the better overall prop without a measure of fuel flow to indicate efficiency. |
| djd35de |
Ok Guys here's the data so far. 14.25 X 15 4 blade honda turbo prop. Engine mounted 2 hole up. Ok winds about 15mph,less then 1 ft wind waves.
4000rpms- 21.3knts 4000- 22.4 5000- 28.3 knts 5000- 28.7 knts Well its either stay with the 15 pitch,or go with the 17 pitch. |
| Perry |
Just as I predicted. That prop doesn't have enough pitch. With 2 people, 1/2 tank of fuel and a full 22 gallon bait tank you were able to reach 6200 RPM. With a light load, you will probably have the motor bouncing off the rev limiter with that prop. Your motor will probably gain another 50 to 100 RPM at WOT after it loosens up (after 50 hrs). Mine did. Did you trim the motor up (out) when testing at WOT? How was the hole shot? Did the prop break loose at all (ventilate)? What was the speed at 6200 RPM? The same prop in 17 pitch will probably give you around 5800 RPM and 43 MPH with the same load you had today. |
| djd35de |
Perry, I did trim the engine up, the max speed was 34.8 knts. The hole shot was good, the prop did'nt ventilate. It did'nt pick up any speed after 6000 rpms. I wish i had the 17 pitch to try here. I think your right though, if the engine loosens up the 17 should be just right. I'll call Eric tomarrow. Almost done i hope. David |
| Perry |
Yea David, you are getting close. I suspect the 17 pitch 4 blade will probably get you close to 6000 RPM and 44 MPH at WOT with just you and a light load, especially after the motor loosens up. Tom Clark brought up a good point about the weight of your boat. If forum member bwc8418 gets 48 MPH and can swing a 19 pitch prop on his 18 Outrage with a BF150, maybe your boat has some water in the hull. It might be a good idea to put it on a scale like others suggested. |
| Tom W Clark |
To convert to MPH and average the results for the sake of the discussion let me repeat what David has reported in his most recent trial: 1000 RPM --- 3.7 MPH David has reported that the motor hit 6200 RPM which, if we assume the propeller slip was constant between 6000 and 6200 RPM, would have resulted in an ultimate top speed of 41.2 MPH. OK. I agree with Perry's comments about the 17" Turbo being the next prop to try. The reason why I did not make that recommendation in the first place is because David already tried this very propeller and reported: ...had the 4 blade [H]onda [T]urbo prop in 14.25x17 mounted on the engine. We launch the boat and right away it has a real nice feel, boat is level even just cruising along about 5-7 mph. We get outside and punch, it only manages to pull 5000 [RPM]. There is no way in hell a 15" version of a propeller will yield 6200 RPM while the 17" version of it will only yield 5000 RPM. Something is grossly inconsistent. Given David's growing experience with his new boat and motor I am inclined to take the most recent data as valid and discount the original data. The motor being broken in, the change in mounting height and the water conditions may all have some partial bearing on the wide divergence of data. I suspect the 17" Turbo will yield 5800-5900 RPM and a top speed of 43-44 MPH as Perry has already predicted |
| Peter |
Sounds like you are hitting the rev limiter with that propeller. I agree with Perry's guestimate -- same prop make, model in a size 17P would probably produce 43 MPH. The big unknown, however, is that we don't know how "hard" the motor is hitting the rev limiter. If just barely scraping it, then the motor will likely drop back about 400 RPM by moving up to 17P. If its hitting it hard, then the motor might only drop back 200 RPM by moving up to a 17P. Finding the right prop is like finding a comfortable pair of shoes -- you've got try a bunch on. |
| djd35de |
Ok guys When i first bought the boat, I did'nt notice the drain tube where the bilge pump sits was leaking. This boat was always trailered but still, It could've taken in quite a bit of water i suspect. I drillrd a hole at the bottom of the stern right at the rear bottom corner. About a 2 cups of water came out. I also drilled a couple of holes around the drain tube, and jacked up the boat and leaned it towards that side. No water came out. I hate to think about removing the entire deck,console,and fuel tank. From what you iam hearing,maybe i should go back to the 17 pitch prop. The first tests were'nt valid. Too much wind 45 mph at time. Pretty choppy . So i think that i'll try the 17 once more and that should conclude this.
Another thing, Is there an easy way to test for water intrusion in the hull? thanks you guys
| djd35de |
Ok guys, Iam going to test the 17 pitch 4 blade turbo prop as soon as i receive it. This is the last time for these props. If this one is'nt the right fit iam going to go to a prop shop. The guy i bought my engine from is getting tired i guess. It is a hassle for him as he has to mail them to me. On the other hand i also spent a lot of money so i just want it right. So all and all its your felling that i'll pick up speed? and it will work better then the 15 pitch? I hope so, |
| Tonym |
David, Aside from visually observing water in the foam you would need to weigh the boat to determine how much over it is from the published weights for the model you own. Factor in battery weight, fuel weight, engine weight etc. I¥¥¥m assuming you will weigh it on your trailer so check the weight on the tag that¥¥¥s attached to it and subtract that from your total. I will give you a call this week end. Tonym |
| djd35de |
Thanks Tony, That would be cool. David |
| Tom W Clark |
David, It is not unusual for a Whaler hull to have some water in it. I suspect almost all old Whaler hulls do, but there is a very big difference between having a few cups of water in the hull because of a leaking old O-ring around the drain tube or a poorly installed transducer mount and a hull that has gained hundreds of pounds of water in the foam core. If the foam core of your Whaler has significant amounts of water in it, you will not be able to simply drain it out. I know of no way to remove water from a waterlogged hull. Before we decide that you have a waterlogged hull, you need to make an accurate estimate of the hull's weight. The only way I know of to do this is to weigh the boat on a certified scale. I have done this with my boat and it is a tedious and laborious process. Start by stripping everything you possibly can out of the boat that is not original equipment. You will be surprised how much his gear amounts to. Fill the fuel tank so you know how much fuel is in the tank. There is no way to make an accurate estimate of the fuel amount without filling it to capacity. Tow the boat to a certified scale and weigh it. Then you have to launch the boat or otherwise unload it and return to weigh the trailer by itself. DO NOT rely on published tailer weights. They will not be accurate. Now you need to do the math with the two weight measurements. Subtract the latter from the former to arrive at a net weight for the boat and motor. Subtract the weight of the fuel (63 gallons will weight about 400 pounds). Subtract the published weight of the motor. Subtract about 15 pounds for the stainless steel propeller (if you did not already remove it.) Subtract the weight of any gear that was bolted down and you were unable to remove. Compare this weight with the published weight of a 1987 Outrage 18, which is 1250 pounds. This will give you an idea of whether or not your hull has water in it. |
| Tonym |
Tom, I know this is a little off topic but I was interested in your opinion on using Crouch's Speed Calculator as a way of estimating gross weight for a boat. For example With a new engine with a known hp and a know prop pitch and a fair assumption of the hull type, for example my raider has a 130 horse power on a broken in but low hour engine and assuming a hull factor of 180 for an 18 foot 6 inch raider that I assume has a hull factor of 180 and a known top speed of 30 miles per hour, Plugging this information in I come up with a gross hull weight of 4680 lbs. what level of confidence do you have in the in the results of crouch¥¥¥s formula? Just wondering¥¥¥¥¥¥¥¥¥¥¥¥.Tonym |
| djd35de |
I'd like to do that Tom, Just to be able to know what it weighs. Iam sure it has some water just not sure how much or if its hundreds of pounds worth. On another note i received the 17 pitch prop but the weather is no good for testing at this time. Maybe next week hopefully. Iam going to fill up the tank and retest the 15 pitch, then test the 17 pitch prop. Hopefully be done with this and just decide.
| djd35de |
Tony , I believe the Gaurdian hulls are rated for approx 50 more HP then a normal hull. So the 18 ft would take a 200 HP i do believe. Give me a call tomarrow if you can. 619-213-2191 David |
| Perry |
David, the commercial version of you boat is the 19 Guardian and it has a maximum HP rating of 150 HP. http://www.brunswickcgboats.com/default.asp?content=boats&boatid=40 What are you going to gain by retesting the 15 pitch prop? You might ding it and not be able to return it. Also, you should test the 17 pitch prop with a light load in the boat to see what the max RPM are at WOT. I would leave the tank half full and drain the bait tank. Otherwise you wont know what the max RPM will be with a light load. You can always fill the bait tank later and add another passenger to see how it performs with a heavier load. |
| djd35de |
Ok Perry, I'll take your advice, but it looks like i won't be able to test until monday or tuesday at the earlist. If i did ding a stainless prop, Are'nt they fixable? David |
| djd35de |
Ok Guys Did more testing today. Slight wind maybe 5 mph-10 max. One half a tank of gas, My friend and me aboard. I weigh 250lbs, friend weighs 280lbs.
I did try the 15 pitch 4 blade again just to be sure. Slips too much and still hits the rev limiter but goes slower, and does'nt plane as easy. Planes at about 3600 rpms. |
| Peter |
David -- 37.9 NMPH is 43.5 MPH so it sounds like you have it dialed in pretty well now. I think 5600 RPM with a 4 blade propeller and that kind of speed is great. A three blade version of that propeller would turn a few hundred more RPM but probably wouldn't add too much more speed. The reported performance difference between the 15 and the 17 inch prop tends to confirm my belief that the general rule that 2 inches of pitch means a 400 RPM difference doesn't necessarily apply to a motor with a gear ratio over 2 and speeds over 40 MPH. I think that is why Suzuki, with its 2.29:1 final drive ratio on its V6s 4-strokes, uses 1.5 inch pitch spacing between its propellers rather than the traditional 2 inch pitch spacing. |
| djd35de |
Thanks Peter I wish they would make the props in 1 inch increments. But they don't, so I'll just have to settle for what it is. But i must say , It jumps out of the hole and on plan real easy with the 4 blade and i would highly recommend them for this hull. I've been told that they perform good in a following sea also. Has real good grip on turns. The engine has a nice humm at 3200-3600 that just sounds like good gas milage (I hope). Though i have no fuel flow meter i do remember how active that fuel gauge was with the 150 YAMAHA 2 smoke cough cough LOL It has 10 hours now and iam going to do the 20 hour service now, instead of waiting.
what if any, would be the difference? Thanks guys David |
| Perry |
David, 43.6 MPH isn't too bad with 530 lbs of people on board. Your motor may gain another 100 RPM and 1 mph after it loosens up. Did you trim the motor up when testing at WOT? The main reason you lower a motor is because of prop ventilation. If you don't experience ventlation with this prop, I would leave the motor mounted 2 holes up. Lowering it one hole will give you better grip but your RPM at WOT will drop as well as top speed. |
| djd35de |
Perry, I did trim the engine up until i did'nt gain speed, so i think the data is correct this time. It really does jump up on plane easy and seems to cruise at about 3200-3500 real sweet. I'll take your advice and just leave the engine mounted the way it is and just run it. One thing i have noticed is at idle i get a vibration. I do believe the honda engine has a balance shaft so not sure what would be the cause. Maybe the weight of the prop who knows. It Idles about 700-750 rpms iam sure its in specs. I wish they would make a 16 pitch as iam sure iam missing just a few ponies. Probley about 10 but oh well. Maybe some other time down the road i'll try other props but for now iam just waiting for spring fishing!!! ( Next project raw water washdown and downriggers) . Perry one question? Did you get the fuel management smart gauges? If so satisified? Just a note guys. I've never owned a Honda product so i hope its a long and lasting love. Unlike the typical CAliforina Marrage say five years. LOL David |
| djd35de |
Again i just wanted to extend a BIG THANKS to all who contributed their knowledge. JIM,TOM,PERRY,TONY,RATHERWHALING Its a great family here keep up the good work and MERRY CHRISTMAS
| Peter |
I agree with Perry. Leave it where it is. For what its worth, both of the twin Honda BF 150s on the Everglades 240CC that I was on a couple of months ago had some vibrations (sounded like something rattling) in the no/low wake speeds. The cure was to bump the throttles up to raise the engine speed. Might be something inherent in larger 4-cylinder 4-stroke. |
| Perry |
David, Honda Marine sells a stainless 16 pitch 4 blade prop. It is made by Powertech and is a very good prop but it is different than the Honda "Turbo" 4 blade prop that you have on now. Maybe you can try one later on. I have a Navman 3100 fuel flow meter not the digital one that is offered by Honda. I also have a vibration at idle speed when running a 4 blade prop; it isn't present when running a 3 blade prop though. Kind of strange. |
| djd35de |
Perry, My dealer does'nt stock these 4 blade props. From what i know he only stocks the 3 blade Solas props. I like the performance of the 4 blade much better than 3 blade. It seems to have a much better grip and jumps up quick on plane. I wish they had all the different types but that just was'nt the case. Its just difficult being such a far distance from the dealer, and like i stated he had to order the 4 blade props so i guess it can get expensive for the dealer. But on the other hand. I think for a dealer its best to have the widest selection of props so customers can have the best performance out of their new engines. And be satisfied. Maybe later on sometime someone here( HINT HINT ) might have that off shore prop your talking about,And possibly lend it for testing someone LOL. I would like to say that i liked the Dealer and would recommend him to anyone thats going to repower with a Honda. By the way Perry, Is that fuel flow meter mechanical? or electronic? and did'nt you state that you got 6.3 MPG . If i can get 5 I'll be happy for sure. |
| Perry |
David, there are 5 Honda Marine dealers in the greater San Diego area. You don't have to buy a prop from Speciality Marine in Oxnard. You can always contact one of them in the future to buy/try a new prop. My fuel flow meter has a paddle wheel in the fuel line which sends an electronic signal to the small computer in the unit which then gives a digital display. I hook this unit to my GPS and it gives a speed readout as well as MPG, range etc. I have recorded readings in excess of 6 MPG at cruise speeds. |
| Perry |
Here is a link to the fuel flow meter: http://www.navman.com/Navman/Templates/productinformation____39327.aspx |
| djd35de |
Thanks Perry, I realize there's dealers here its that the prop was included with the engine. I have'nt contacted any yet but if iam able to borrow a prop or 2 without buying then i'll do some further testing. thanks for the web site for the fuel flow meter. I'll have to check it out. David |
| djd35de |
Well guys, iam still trying to find the right prop and get rid of an idle speed vibration. I just received a 15.25 X 16 4 blade Power tech cushion hub. My last prop was a Honda turbo 14.25 X 17 and turned about 5500 RPMs. But the thing thats been driving me nuts is this vibration at idle in gear.
This is the smallest 4 blade that power tech offers, so if it does'nt work i guess i'll have to go with a 3 blade.
Looking at the prop though it looks like it has less pitch then the 17 4 blade i have so we'll see what happens. What i was wondering is, what RPMs do you guys think i'll pull with this thing ??? 87 ft outrage,2006 honda BF 150,and just me at 245 lbs this time. all the other testing was done with about 550lbs of man weight in it. |
| Perry |
87 ft. Outrage? Wow you will need more than 150 HP to move that boat :-) All kidding aside David, I think that prop should be a good fit. Powertech makes quality props. I'm very happy with mine and the cushioned hub may make that vibration go away. It's an inch larger in diameter but also has one inch less pitch than your other prop so hopefully it will give you about 200 more RPM at WOT. Don't forget to remove the thrust washer that came with the other prop and replace it with the Powertech thrust washer that came with the new prop. They are not interchangeable. Hopefully you will have god weather this weekend for testing. Remember to bring your GPS and log your results; then post them when your done. Good luck! |
| Peter |
Again, just my opinion but I'll say it again, I think a 4-blade propeller is overkill for an 18 Outrage. |
[Consolidated another discussion on this same topic into this original discussion.] Rather than solicit predictions, test the new propeller and report the results. |
| djd35de |
I hope your right Perry as far as the vibration and 200 rpms gain. Well Peter, Iam not real worried about the top speed just good handling and nice lower planing speed in the ruff stuff. Ok Jim , I guess i was just excited to do some more testing but can't until Sunday. I just hope this engine has the grunt to turn this prop. |
Vibration from four-blade propellers may be due to the fact that two blades at a time are shadowed by the gear case. On a three blade propeller only one blade at a time is shadowed by the gear case. This may give rise to a vibration frequency which is lower with a four-blade than with a three-blade, a somewhat counterintuitive result. If the propeller were turning in an open environment, the four blade would probably have a higher vibration frequency as compared to a three blade. The only way to tell if the vibration problem will be attenuated or amplified is to try the propeller. |
Also, please use miles-per-hour as the unit of speed measurement for your data. It would be nice to see all of the data you have accumulated presented in a consistent tabular form. |
| djd35de |
Ok Guys here's the latest testing. About a 1/3 of a tank of fuel. No wind and flat calm in the morning. A friend and me aboard about 450 in pounds. I can't figure out how to change my GPS to MPH,so all these numbers will be in knots. Power tech prop 15.25X 16 pitch 4 blade stainless. Idle-2.6knts Boat planes nice about3000 rpms, will hold plane down to about 2800. Has lots of power and acceleration. Maybe more then before. Next prop 14.25X 17 honda turbo 4 blade stainless. Idle-2.2 knts This engine should rev to 6000 rpms max.
| djd35de |
Ok guys more testing with just me aboard. Power tech prop 15.25X16 4 blade off shore. The wind is up a bit maybe 10 mph. Engine mounted up 2 holes. With the wind i got these numbers. Idle- 2.6knts 1000- 4.1 knts Pulls strong, real strong and iam impressed with this honda. ok against the wind I also tried the honda turbo again and it won't go past 5600 |
| Tonym |
dAVE. I TOOK THE LIBERTY OF LIDTING THE MPH EXUIVILENT IN THE FIRSPower tech prop 15.25X 16 pitch 4 blade stainless. engine mounted 2 holes up. Idle-2.6knts 1000rpms - 3.8knts 4.4 mph 2000rpms- 6.6knts 7.6 mph 3000rpms-16.0 knts 18.4 mph 4000rpms- 25.1 knts 28.8 mph 5000rpms- 31.6knts 36.3 mph 6000rpms- 37.4 knts 43.0 mph 6200 rpms38.5 44.3 mph Boat planes nice about3000 rpms, will hold plane down to about 2800. Has lots of power and acceleration. But i still have a vibration at idle in gear. Maybe more then before. Next prop 14.25X 17 honda turbo 4 blade stainless. Idle-2.2 knts 1000- 3.7 4.25 MPH 2000- 6.6 7.59 MPH 3000- 18.0 20.7 MPH 4000- 27.3 31.4MPH 5000- 34.1 34.24 MPH max rpms is about 5550 rpms all trimmed out. I also trimmed out with the Power tech prop also. Y OUST |
| djd35de |
Thanks Tony, What does a knots = in mph? |
| Perry |
Dave, is there still a vibration at idle? It sounds like you found the right prop. 45 MPH at 6000 RPM is a good top speed. With a full tank, ice, gear, etc. you should be able to reach 6000 RPM and around 43 MPH. |
| djd35de |
Yes Perry, I still have a vibration at idle. If that does'nt solve the problem, maybe try an aluminim prop. If that does'nt solve the problem, well maybe i'll jump off the Coronado bridge i don't know. Maybe Honda will have to take a look. |
| Tom W Clark |
To convert knots to MPH multiply by 1.15. |
If you carefully read the instructions for your GPS, I bet you can find a way to convert the units of speed into statute miles per hour. |
| Perry |
David, that's too bad it still vibrates. Mine is as smooth as silk from idle to redline. Maybe there is a problem with the motor mounts. You should be pleased with the performance. I re-read the begining of the thread where I predicted a 47 MPH top speed which others thought was very optimisic. I suppose with a good 3 blade prop like a Stiletto or Powertech, 47 MPH could be achieved. You can hit over 45 MPH now with that 4 blade and they tend to be around 2 MPH slower than a similar 3 blade prop. Good luck on the vibration issue. |
| djd35de |
Thanks Perry, I believe you're on to something as far as the motor mounts go. That could be the probem. I mean it only does it at idle in gear!!!! I was thinking about it today ( EVERYDAY FOR A MONTH) and this is what i came up with. Bent prop shaft, but if its bent won't it still vibrate at rpms higher then idle? I don't know. Need it checked. Prop out of balance, I've tried 8 different props. Broken motor mount or missing or loose bolt or bolts in mount. Could very well be, as under load or in gear thats when a mount has to work and hold back the pulsations of the engine. Maybe its not mounted correctly. Could be, Incorrect mounting could cause the same symtoms as defective engine mounts. Guys if anybody has any other suggestions as to this vibration PLEASE give me some other ideas. Thanks Guys David I |
| Tonym |
Dave, Before you start looking at all the least likely possibilities look to the most likely which is you have a 4 cylinder engine and when mounted with a stainless steel prop some models will make noise. Try and find, borrow, buy an inexpensive aluminum prop of the correct size and take it out. If the aluminum prop doesn¥¥¥t rattle or whatever it is currently doing than you at least will know it¥¥¥s a prop thing. If it is still making noise than it¥¥¥s a warranty issue and you need to bring it in. Good luck, Tonym |
| djd35de |
Well guys, I think i found the source of the vibration. Iam going to see my dealer this weekend and will report what the problem is then. And if it was cured by my dealer. Until then David |
| djd35de |
Hello guys I went up the coast to take my boat back to the dealer. Ok, About this vibration i've been having at Idle. My dealer tested prop run out, Seems to be a lot about 7-9 thousands when you push the prop shaft from side to side. We went down to the water and drop the boat in and fire it up. It feels like its not fully ingaging in gear at idle. So we try 4 different props and it does this with all the props. This is something my dealer has'nt heard or seen before. So we go back and change to whole lower unit for a new one. I must've done something really wrong in my life to deserve this. LOL Just can't think of what it is at this time. Hmmmm. A Honda Rep is going to be showing up sometime mid week. See what happens then. Hopefully a new dam engine or proper diagnosis and repair. Thing i do know. I just want to be happy with my purchase but i can't be at this time. But in spite of this i do have a smile for , If nothing else. My dealer stepped up and did all he could at this time.
But this is personal now, I want this darn thing to be smooth as silk like i know they can be. If not there's always Suzuki but not yet anyways. Guys feel free if you have any suggestions. David |
| Tonym |
David, I am sorry to hear about your continuing problem but I am glad Eric stepped up and tried to make it right. The first question that comes to mind is, were any of the 4 additional props you tried aluminum? Or were they all stainless steel? Maybe this is a design flaw in the engineering of the 150 hp Honda? I am watching this very closely as I want to put a stainless steel prop on my 130 hp when I get it figured out what size I need but I am not looking forward to these type of problems. Please keep us informed. Good Luck, Tonym |
| Perry |
Tony, I can assure you it is not an engineering problem with the BF150. Don't you think we would have heard by now if it was. Honda has sold thousands of them over the last few years. Mine has no vibration at idle and I run a heavy 4 blade stainless prop. |
| djd35de |
Hey Perry, i'll trade you LOL |
| djd35de |
Maybe its where the engine and shaft meet, Clutch dog iam not sure how it works and i don't have a manuel.
Any Honda Techs see this problem? Iam just grateful that iam not 50 miles off shore with it.
| Peter |
As I have said before, both Honda BF 150s on the Everglades 240 CC I was on last Fall had the in-gear idle speed vibration you describe. It was impossible not to notice it as it was causing some sympathetic vibrations on the boat. It disappeared when the salesman bumped the thottles up a bit. It didn't strike me as abnormal, but rather something just inherent in a 4 cylinder 4-stroke motor which only gets 2 bangs instead of 4 bangs (each being 1/2 the size of the 4-stroke bang) every flywheel revolution. To the extent this vibration is not being isolated well, I would be looking at all of the rubber motor mounts where the pivot of the mounting bracket attaches to the motor shaft -- just above the gearcase and usually just under the power head. Perhaps one of the mounts is not right. |
| djd35de |
Peter , Its not just a vibration but a low pitched growl at times. Makes me think that maybe the shift selector cable is maybe out of adjustment. (not fully releasing) Almost as if you have a clutch thats not fully releasing on a car, when you go to shift it ,can grind etc... I realize it might have a slight vibration but this can't be normal as it also makes noise. Just not all the time but mostly as you put it in gear at idle. I wish i had a service manual. As i don't really understand how the outboard and lower unit work together, as in how the power is generated. There is a long shaft that runs down from the engine to the lower unit. But how does it connect to the crankshaft? I know how cars work, clutch or automatic but how does it tranfer the power of the engine?
| Peter |
Are you sure that low pitched growl you are hearing isn't just 4-stroke exhaust noise being blown underwater. Again, realize in a 4-stroke 4-cylinder you've got only two big exhaust pulses being blown underwater per flywheel revolution instead of 4 exhaust pulses that are approximately one-half the size of the 4-stroke pulse in the case of a 4 cylinder 2-stroke or 6 exhaust pulses which are approximately one-third of the size of the 4-stroke pulse in the case of a 6 cylinder 2-stroke in the same flywheel revolution. If you are used to 2-strokes sounds, the 4-stroke is going to sound and feel different. The first time I heard a 4-cylinder 4-stroke running at wake speeds it sounded sort of like an OMC V4 with a bad power pack running on 2-cylinders. |
| Perry |
David, I just e-mailed you a copy the BF150 shop manual in pdf format that my mechanic gave me. Only factory Honda mechanics are supposed to have it so don't let it be known where you got it. Let me know if it doesn't work and I'll mail you the CD. Good luck. |
| djd35de |
Perry my email has errors not sure whats going on there. My # is 619-420-3727 If you can call me that would be great. |
| Tonym |
Perry, What brand of prop are you running on your 150 hp and is there any special hubbing set up you have installed? David, |
| djd35de |
Yes Tony one prop was aluminum but it still made the noise. David |
| Perry |
Tony, I run a Powertech prop with cushioned hub but also have a Solas and Honda "Turbo" prop as well. No vibration with either of them. |
| galtsfan |
Perry I'd sure like a copy of that BF150 shop Manual in pdf format. I just bought an 05' BF150 off ebay, brand new with a 5 yr. warranty. |
| Perry |
galtsfan, I'll e-mail it to you tomorrow when I get home from work. |
| Riverwhaler |
Perry could I add my name to the list for the shop manual PDF ? allan@vtstudio.com |
| Perry |
Look for it in your inbox this afternoon Allen. |
| Tom W Clark |
David, Perry, I would be interested to know at what RPM your respective Hondas idle at. Could it be that Perry's Honda BF135 idles just a tad higher than David's BF150 and thus just escapes the harmonic vibration David is experiencing? |
| Perry |
Good question Tom, according the the shop manual, both have the same recommended idle speed of 750 +/- 50 RPM in neutral. I don't recall off hand what my actual idle speed is but next time I take my boat out I will see what it is in neutral and in gear. |
| djd35de |
My Idle speed is right at 750 Rpms. But as far as when you try to shift in foward gear , it kind of lingers and there's no positive clunk. Unless you give it a tad bit of gas about 1000 rpms. Tomarrow is the big day as a Honda Rep is going to see another engine that has problems. And mine also why he's there. What i expect from HONDA is either they can fix it,OR Replace with a new engine, or a refund and i'll go get a Suzuki. I hope it does'nt get ugly i do like the engine and it is still new 13 hours. About 3 hours just flushing it. Plus i've gone though the time to prop it with help from you guys. So iam still hopefull they can fix it now!!!!! or replace real soon. As this has gone on too long. |
| galtsfan |
In researching props(in the event mine doesn't work) I found this in an old discussion here on CW. http://continuouswave.com/ubb/Forum4/HTML/004131.html Of particular interest is what LHG says in the last post. quote:Could this be the problem? |
| Tonym |
Good luck David. Let us know what the tech and Eric figure out. Tonym |
| djd35de |
Well guys, My Dealer and the Honda Tech or Rep went for a test drive today. I spoke to my dealer after they did this test drive and iam just hoping for a fast resolution. As my engine has about only 13 hours. I just want a smooth engine,in gear ,at idle,all the time thats all i want. I believe my dealer has done all he can and now its Time for HONDA CORPORATION To STEP UP and BACK THIER PRODUCT!!!!! I just hope its quick, easy and painless. I don't feel any ill will towards my dealer as he did'nt build it, HONDA did. So the waiting game begins. I'll keep you guys posted and thanks for all the suggestions. David |
| tkbsurf |
It sounds from your description that the noise is "torsional". This is common with engines that have a lot of torsional activity at low RPM. Engines with 3 or 6 cylinders are odd firing and it is harder to contain the torsional vibration than a 4 or 8 cylinder. I do not know how many cylinders your engine has. The transmission teeth are the only place in the drive line that has backlash. So, it is influenced by torsional activity from the engine as well as from the other direction with the prop. Every time the piston fires the crankshft turns a small increment until the next event happens. The result is the teeth in the drive line "Bounce" or "refract" back with the influence from the prop thrust. At low RPM this is more pronounced and audible because the frequency is much shorter. When you raise the RPM the noise goes away because the freqency is shortened and no longer audible to our ears. The engine vibration is typically isolated with a torsional dampener of some sort. I doubt Honda manufactures one of their own. They probably use one from an outside vendor to help absorb this vibration. I have found that adding mass to the flywheel will help this tremendusly.Probably not going to happen in this case! I do not have any experience with your engine but I have a lot of experience with direct coupled engines and gearboxes (inboards). Your description is a very textbook complaint with newer Diesel and gas engines that idle low or have chosen the incorrect coupling (dampener)for the package. I will bet that Honda will raise your RPM at idle as a resolution. Are there other complaints about this with your exact set up? |
| Tom W Clark |
tkbsurf, You are talking about prop rattle. We've already discussed that extensively. I do not think that is David's problem. After talking to him on the phone a few times, and exchanging email and following this thread, I suspect something more is at work here. If simply increasing RPM was the solution, the mechanic and the Honda folks would have suggested that. If the prop rattle was caused by a heavy stainless steel propeller, Perry would be experiencing it too and the aluminum prop David tried would have solved the problem. It has not. Prop rattle is common on four strokes with heavy stainless steel propellers. The "torsional damper" you allude to would be the Mercury Flo-Torq III and IV hubs discussed above. |
| tkbsurf |
Tom, I am not a very good writer!! I am referring to "torsional" vibration from the engine not the prop. If he has tried numerous props with the same result in idle vibration it is not in the prop. It is in the engine. The coupling I am referring to is in between the engine and transmission on inboard applications. Since the outboard doesn't have something in between the engine and drivetrain the vibration will be transmitted right through the drivetrain. I was being sarcastic in that Honda will probably recomend to up the idle as a resolution. That cost less than finding a slight misfire that is not showing up on the laptop. |
| djd35de |
Hello Guys. I spoke to Eric and they did some more testing today. With the boat in the water they disconnected the cables and shifted it manually. I guess to make sure its not some type of adjustment or such. He informed me that it has the same problem. So at this point there're going to replace with another brand new engine that he has in stock. I've noticed he has mostly stratch and dent engines so my hope is that he did'nt get a bad batch. Maybe it'll be installed tomarrow and hopefully they can test it. He will be using the same controls and cables. I was hoping for a new engine straight from Japan , but if this works I'll be relieved and hopefully finished with it. One good thing is I don't have to spend anymore time propping it. That Power Tech prop 15.25X 16 with engine mounted one-hole up should be perfect. With the engine mounted two-holes up I got 6,200-RPM. I am guessing 6,000-RPM mounted one-hole up. --David |
| Tonym |
David, That¥¥¥s great news. Hopefully you will have some good weather up there to really give it a good test run before hauling it all the way back to San Diego. I would ask Eric about the engine he is planning on replacing it with. What are the defects in the particular engine he is swapping out? A lot of the ¥¥¥scratch and dent¥¥¥ specials have just a small cosmetic defect. Did they speculate on what was the cause of the vibration in your original engine? I¥¥¥m just curious. Good luck. Tonym |
| djd35de |
Tony, Imagine how curious iam, but really i just want to be done with this all. If this engine has any defect in how it runs i'd have to demand a new engine from Japan or my Money Back!!! Then it would be time for a Suzuki, just hoping i don't have to cross that bridge. David |
| Perry |
David, I'm sure he will replace your motor with a new "defect free" one because that's what you originally paid for. Honda sticks by their product and it is good to hear that the rep from Honda is trying to make you a satisfied customer. You said that he is going to mount the new motor 1 hole up instead of 2 holes up. Was your prop breaking loose when it was mounted 2 holes up? If it didn't ventilate before, why not just replace the 16 pitch Powertech with the same 17 pitch model and leave it 2 holes up? You would probably drop the 200 RPM you desire at WOT and pick up a couple of MPH top speed. |
| djd35de |
Hey Perry, Thanks for the CD Sweet As far as the prop goes, i don't even want to ask for another as he does'nt stock them and it performs just right. About 6200 with a lite load. About the engine I bought a blem as far as it had a few scratches so he gives pretty good discounts. Its kind of funny in a sad way that i really think highly of Honda products but this is the first i've owned. So iam just waiting on good news hopefully today. |
| Perry |
[QOUTE]it performs just right...About 6200 with a lite load.[/QOUTE] That's my point. If it performs just right, why drop the motor one hole? With a moderate load, it should rev to 6000 RPM at WOT; just where you want it. |
| Tonym |
David, Did you buy the Power Tech prop here locally? I'm going to be on the market for a stainless prop very soon and I am starting to look for more sources. Tonym |
| djd35de |
Well Guys This has gone on a while now and still have the same problem. The dealer can't find the problem, He says he tried installing another engine but still has the same rumbling at idle. I was'nt there so i did'nt see a new engine mounted ,but he did mention that its possible Honda Corporation might replace with a new crate engine. Or dispatch some engineers from Georgia to do some testing. That would be good Honda. Iam a bit fed up but am willing to stick it out for a little while longer but i expect prompt action. I don'; want to be without my boat too long, a couple of weeks is fair i think. If not iam getting a full refund and will probley go with a Suzuki. This is sad as i've ne I'd like to know if you guys think this is fair for me to ask for????? 1. I'd like a new crate engine installed. 2. If this solves the problem how about throwing in a fuel monitoring gage for all my hassle. Maybe? Now that would be sad.
| Tonym |
David, That is so strange! I feel for you and you are absolutely correct. They need to make it right. They need to provide a new engine that doesn't rattle. Thats what you paid for so thats what you should get. Please keep us informed. I am getting ready to buy a new engine for my 22 foot guardian from Eric so you can imagine I am watching this with great interest. Tonym |
| galtsfan |
Perry, I got the disk, I owe you one. If your down this neck of the woods it's my treat. Thanks, Marv |
| Perry |
You're welcome Marv, I may just take you up on that offer some day. |
| djd35de |
Guys the latest on my 2006 BF150 with 13 hours. Another engine was mounted on my boat and there saying it has the same problem . Possible boat harmonics could be the cause they say. My thoughts on this are. I think they just can't figure out the problem and there're digging in the bushes for a reason or something else to blame. Any thoughts on this or is this shop or tech and rep from honda incompentent. |
| djd35de |
Perry, I second that, if your ever in the San diego area please let me take you fishing or maybe some beers,dinner etc... you pick thanks for all your help David |
| JayR |
I've actually experienced just that on an older Madetauk some years ago. At 1100 RPM's the boat shook like crazy. It seemed to resonate at that point. It is a plausable explanation to me. I would try a different brand motor. |
| cwolf |
Probably very little consolation at this point but I've had no such problems with a new Yamaha F150 on an Outrage 18. |
| djd35de |
I don't believe this explanation as far as harmonics ,from a fiberglass over wood boat. Does'nt make sense to me. My engine with 10 hours had about 9 thousands play or run out on the prop shaft. Thats just with pushing it with your thumb. I think i just got a bunk engine, maybe it was made on friday. |
| djd35de |
Granted i don't know what the specs are for propshaft run out. But seems to be excessive. Anyone know specs on something like that? |
It is likely the boat is a major influence in the vibration problem. In my experience, my boat and my motor will exhibit annoying vibration at certain speeds with certain propeller configurations. With different propellers there is no trace. It is not the motor. It is the combination of: --the boat |
| djd35de |
Well, Iam thinking about asking the rep to take my boat to another dealer. Where they know how to do a proper diagnosis of the problems iam experiencing. Maybe a new set of eyes could help. David |
| JayR |
"It is the combination of: --the boat I couldn't agree more. |
| tkbsurf |
Like I said before, I believe it is a "TORSIONAL" vibration not harmonic. Directly associated to the firing of the cylinders. There may not be a resolution unfortunately. Some engines are more torsinally active than others. Some others in this thread reported the same "rattle" or vibration at idle as well. Here are a few questions to ask your Honda factory rep (not the dealer). 1.)Does the engine management system manipulate the firing of cylinders to accomodate any emission requirements? 2.)If so, is it a California market only requirement? 3.)Are you (personally) willing to pay for a vibration consultant to "instrument" the boat and find the frequency of the vibration? 4.)If so, is Honda willing to reinburst you for the charges if the result of the findings are engine related? A vibration consultant normally runs about $600.00 (in FL) for a half day plus travel charges. They produce a nice printout with very exact info. The program takes in consideration: the number of blades on the prop, engine cylinder #, ratio of reduction, flex of the boat, etc. and comes up with a frequency configuration for each. Many engine companys have torsional issues just like yours that have to come up with a "Mask" of some sort to get rid of the noise and vibration. Some of them feel that it is not cost effective to do anything at all. They will tell the customer they have to just live with it. It really doesnt hurt anything as much as it is anoying to operate. |
| djd35de |
I spoke to my dealer today. Iam expecting Honda Corporation to step up. Guys, its not only vibrating but sounds like its grinding coffee beans. I've got it, an expresso coffee maker that gets 5 mpg , has a 5 year warrany, and goes approx 45 mph. I think i'll patent this, Wow iam gonna be rich. |
| Tom W Clark |
I have spoken with both David and Eric Peterson (the owner of Specialty Marine, the dealer) on the phone and via email. At this point I do not think there is anything defective about either of the two Honda BF150s that have been mounted on Davids Outrage 18. The "problem" occurs with both motors. Furthermore, before Eric installed a second BF150 on David's boat, he replaced the lower unit to no effect. He also tries shimming the lower unit gears to eliminate any unnecessary play. None of this made any difference in the vibration...at all. I have to conclude that what this boat is experiencing is merely prop rattle, plain and simple. Why it is so prevalent with this motor I do not know. According to Eric, the prop rattle and accompanying harmonic vibration within the boat is present at idle speed of 800 RPM. Once the throttle is advanced to 1000-1100 RPM it goes away completely. This prop rattle has been present with every stainless steel propeller tried but notably NOT when using an aluminum propeller. I have to go back to my very earliest recommendation to try a Mercury propeller with a Flo-Torq III or IV hub, which is specifically designed to accommodate and eliminate "prop rattle" and "shift clunk". Eric also told me that the Honda Technical Representative for the five state region including California has visited his shop and run David's boat and witnessed the vibration. I am quite frankly astounded at the length to which this dealer has gone in trying to solve this problem. My hat is of to Specialty Marine. But I really think that a simple hub kit may provide enough spring to dampen the prop rattle and eliminate the vibration. If it does not, then we have to consider that this problem is unique to the design of the Honda BF150 for some strange reason and the fault is Honda's but certainly not the dealer's. |
| Perry |
Tom, while I don't disagree with your thought that this problem is unique to the design of the Honda BF150; woulbn't you think this vibration problem would be reported by more owners? Honda has sold thousands and thousands of these motors and I have heard few reports of this problem. I'll call my mechanic today. He is Honda certified and attends bi-annual training on the mainland by Honda and would know if there is a design flaw. If there was a design flaw I would think Honda would address it with a recall or service bulletin. Honda remains atop JD Powers for customer satisfaction for a good reason. |
| Tom W Clark |
Perry, Yes, I share your sentiments. I am perplexed. i should point out that Eric told me both he and the Honda rep. have seen other BF150s with this problem but that it is rare. It is NOT entirely unique to David's boat. |
| Peter |
As I have mentioned here previously, the pair of BF 150s on Everglades 240 CC demonstration that I rode on a few months ago exhibited the same behavior described by David. The salesman was quick to bump the throttle position up slightly as soon you could sense the vibration. I don't know what propellers were being run on those BF 150s but suspect they were Honda offerings. |
| djd35de |
Guys Its not just the vibration, but it also feels like there is no positive clunk in gear. Unless you give it more gas. And as far as the aluminum prop, thats not true. And i did'nt read anywhere that said oh by the way. Honda needs to step up, straighten it out,fix it. I just want it right thats all i ask.
Maybe i will just say forget this, Here i come Suzuki!!! |
| Perry |
quote: Well I took my boat out yesterday and it idled in neutral at 750 RPM and in gear in idled at 600 RPM. What was your idle RPM when in gear David? |
| djd35de |
Perry My 150 idles smooth at 750 in neutral, Probly the same in gear about 600-650 or there abouts. I thought maybe the shift cable could be out of adjustment. So i suggested shifting without it meaning disconneting it. But very poor in gear ,forward and reverse. |
| Tom W Clark |
I remain perplexed. I have no reason to doubt the veracity of either David or Eric. Given the anecdotal evidence told elsewhere including Perry's comments above and this thread: http://continuouswave.com/ubb/Forum4/HTML/005154.html ...it certainly seems as though a "normal" BF150 should not experience the vibration that David is experiencing. Yet, at the same time I have difficulty reconciling how a one motor could suffer this phenomena, then a new gearcase replaces the existing one and the behavior remains the same and then the gearcase is shimmed and fine tuned to no effect and then an entirely different motor is mounted which changes absolutely nothing. Logically, how can that be? Extraordinarily bad luck? I don't think so. |
| djd35de |
Yes Tom I too am baffled to say the least. Exhausted, dissatisfied with my Honda engine at this time. I heard they have a five year warranty so they say. Its odd that the new lower unit did'nt fix it. Or maybe its too lean in gear at idle causing what seems to be an inbalance but really could be a lean misfire. Doubtful. Hope Honda makes it right. I just don't have the energy to start all over but might have to if thats the case. What i don't like is the wording with the Suzuki warranty. Which Honda was so quick to point out. When i was searching for a repower. NOT ONLY WAS it NEVER HEARD BEFORE BY THEIR OWN ADMISSION BUT THE DEALER HAS TRIED ALL HE CAN. HE'S UNABLE TO DO A PROPER DIAGNOSIS OF SAID PROBLEM. HE'S DONE ALL HE CAN. WHEN IS IT TIME FOR HONDA CORP TO NOT ONLY GIVE THEIR DEALER SUPPORT BUT SATISIFY A CUSTOMER!!! If a problem is found and cannot be fixed. And i won't except a bandaid like just use an Aluminum prop. I feel very strongly if there ever was a time for a factory to step up and support their product its now. |
| djd35de |
Guys if anybody has any suggestionsfeel free to email me at djd35de@cox.net Thanks David |
| JayR |
Lemmon law? Just thinking out loud.... If it is fact a motor problem. |
With this thread and the one which preceded it we are now at 225 articles discussing this topic. The originator has now requested that replies be sent to him via email. At this point I think that is the best approach to resolution of his problem, so following his suggestion, I will close the thread and let everyone participate via email to give more advice. When there is a resolution to this problem, please let us know what the remedy was. At that time it would be best to begin a new thread. |
