| Author | Topic: 1992 Saltshaker Bracket |
| 6992WHALER |
Jeff R shot a video that showed his 1993 Walkround's engine while he was on plane. http://www.youtube.com/watch?v=ZzwbtRellM8 If I look at this picture of my 1992 Walkraound's engines from the side. It looks to me that the bracket would be out of the water when the boat is on plane. This would put the props in quieter water and improve performance. |
| conch |
I was wondering why you use two balanced cylinders plus a tie rod for steering? Is that a factory rigging? Any advantage? Chuck |
| 6992WHALER |
I never thought about it until you pointed it out. I see Jeff's boat only has one cylinder. I assume it was rigged that way at the factory but I am the third owner. Would there be any reason to install the second cylinder to help the autopilot pump control the boat? |
| L H G |
The Saltshaker bracket, like the Armstrong bracket that I am running, runs clear of the water when planing, improving top end performance over the original Whaler Drive. My guess is that is what VanLancker wanted to accomplish with his new Walkaround series boats in 1991. A Sea Star I (single cylinder) hydraulic is rated for 600 HP counter rotating. As an optional upgrade, you could add the quicker steering and duplication of the Sea Star II (twin cylinder system). Since front mount cylinders are blanced design, either system could operate an auto-pilot system. With the side mount cylinders required with the original Dougherty designed Whaler Drive, you did have to have the Sea Star II if you wanted to use an auto pilot, since a single cylinder is unbalanced. My 25 Outrage has the upgraded twin side mount balanced cylinder system, and I think it performs well. http://smg.photobucket.com/albums/v429/lgoltz/Outrage%2025/?action=view& current=MVI_0147.mp4 |
| conch |
I also use twin side mount cylinders. However I think I would prefer a single balanced front mount with tie bar.Less hoses,seals,and such.With the twin side mounts the hoses do not move in the transom well,and I have my hoses and all rigging and fuel lines encased in tubing to protect them from the sun. The set back hydraulic jackplates I use from CMC do not have the tilt space for front mount cylinders. |
The great advantage of the side-mount steering actuator cylinder is that the hydraulic lines are stationary; they are not dragged around the splash well with the engine as it is steered. The disadvantage--if any--is the unbalanced turns ratio. |
| TallyHo |
So how many turns is it stop to stop with a single cylinder, and how many with a dual cylinder? We have a single and i need to check, but it is quite a few turns stop to stop. |
| L H G |
I think it is something like 7.5 vs 5.0 turns. |
| conch |
About 5 turns with a single cylinder and 7 with twin cylinders. Cylinder volume divided by helm displacement equals the number of turns. Chuck |
| Jeff |
John, I do not think your boat would have been rigged at the factory. It was likely rigged at the dealership it was delivered to. Now our boat I know for a fact was rigged at the factory. Our boat was built and rigged by Whaler to be their showcase display boat for their 1993 Miami Boatshow booth. The first owner (we are the second) saw the boat at the Whaler booth at the Miami show and bought it right off the showfloor. Personally I like the single cylinder with less turns. While doing low speed maneuvers in cross wind situations it often takes a fair amount of throttle and wheel jockying to put this hull where you want it. The less time you spend spinning that wheel is less time the wind has to work against your intentions. Finally, your motors seem to be mounted low. Ours are mounted 3 holes up. This allows the flotation box of the bracket AND the anti-ventilation plates to run free of the water when on plane. |
| L H G |
Conch - You've got it backwards. The single side mount cylinder is 7.5 turns with the recommended Sea Star I (1.7)helm pump. |
| conch |
LHG I don't think so. Do you have a reference? Chuck |
| 6992WHALER |
7 1/4 turns stop to stop. Jeff, there are four mounting hole on the top of the engine bracket. Mine is mounted in the second from the top. |
| Jeff |
John, Our motors are mounted through the third hole from the top. So our's are one hole higher. |
| 6992WHALER |
In a following sea off plane do your props break free? |
| Jeff |
No John, We do not have any problems with the props ventilating while on plane. |
| 6992WHALER |
Sorry Jeff I will make my question clearer. When you are not on plan in a following (not dead on but from a quarter) do your props break free? |
| Jeff |
No, but the largest following, nor quartering seas we have been in were 3'. |
| Jeff |
Some detailed images of the SaltShaker Marine Bracket for refrence: http://img.photobucket.com/albums/v427/jeff_rohlfing/ 23%20Boston%20Whaler%20Walkaround%20Whaler%20Drive/DSC_2081.jpg |
I looked at the rear view (in the first image linked above) to see the relationship of the anti-ventilation plates of the engines compared to the bottom of the buoyancy box on the Saltshaker bracket on the Boston Whaler 23 Walkaround. Then, I looked at Jeff's video (linked in the first article in the thread) to see where the water plane surface was in relationship to the anti-ventilation (A-V) plates. What I see is that when the boat is running on plane the A-V plates are right at the water plane surface. Using that as a mark, I look at the rear view image and I see that the buoyancy box is mostly out of the water when the 23 Walkaround is running on plane. |
To compare the Saltshaker bracket to the Whaler Drive--which I want to mention in reply to the early comment by L H G (see fourth article in thread) that there is a big difference between the two in terms of performance from the buoyancy box drag--I will offer this image: http://continuouswave.com/whaler/reference/images/propellerTest/ whalerDriveDimensions600x450.png This is a side view with vertical dimensions shown. It is from my 22-foot hull with Whaler Drive. In the view seen the engine is mounted at the lowest position. My present engine mounting is one-hole-up, or 0.75-inch higher. I have observed that the A-V plate on my boat runs in a position similar to that shown in Jeff's video, that is, the A-V plate is near the water line--just at it or just a hair above. You can see this in another picture: http://continuouswave.com/whaler/reference/images/propellerTest/AVPlate600x450.jpg (This is the old engine and the old mount. The new engine and the new mount is 0.75-inch higher. If you add 0.75 to the 0.25-inch clearance shown, it looks like the A-V plate on my new installation will be 1-inch above the bottom of the Whaler Drive lower side.) Using these photographs to make the same comparison I did with Jeff's boat and the Saltshaker bracket, I see that the Whaler Drive is also running mostly clear of the water when the boat is on plane, or at least about in the same clearance as the Saltshaker bracket runs on Jeff's boat. This leads me to question L H G's assertion that the Saltshaker bracket runs differently than a Whaler Drive. It looks to me that both the Whaler Drive and the Saltshaker bracket have a buoyancy box, and when on plane in both cases the buoyancy box is mostly out of the water. Am I seeing properly? |
| Tom W Clark |
I don't think you are Jim. I'm in agreement with Larry on the performance difference between the classic Whaler Drive and the Saltshaker Marine bracket (very confusingly and unfortunately, also called Whalerdrive). There is a dramatic loss of speed on classic Whalers with Whaler Drives vs. notched transom or bracket installations. We have not seen a corresponding loss of performance with Whalers equipped with the Saltshaker Marine brackets. I speculate that may because the Saltshaker Marine brackets have less surface area and are less in contact with the water while at planing speeds. The Saltshaker Marine brackets certainly have less volume than the classic Whaler Drives and are constructed of aluminum, not foam fiber fiberglass and plywood. |
| Tom W Clark |
Regarding hydraulic steering: Conch is correct when he said: "Cylinder volume divided by helm displacement equals the number of turns." Whalers equipped with twin cylinders typically used the Teleflex SeaStar II helm which has a 2.4 cu. in. volume. Single cylinder equipped Whalers usually use the SeaStar I helm (1.7 cu. in. capacity). I should be remembered that Teleflex now makes SeaStar helms in 1.3, 1.7, 2.0 and 2.4 cu. in. volumes so you can fine tune the amount of effort and number of turns you are comfortable with. One big disadvantage of a side mounted steering cylinder not mentioned above is that it sticks out quite a bit and is vulnerable to damage from an impact or being stepped on. |
| 6992WHALER |
Why would you mount twins cylinders over a single one? Jimh, looking at the pictures I think your Whaler Drive would not get clear of the water on plane. A lot of the drive would be out of the water but I think most of the bottom of the drive would be in the water. Until I saw Jeff's video, I did not believe that the Saltshaker drive could be out of the water on the 23 Walkaround. Now I think it is running almost, if not clear of the water. |
| Jeff |
John, I will try and get video this summer with a GoPro showing the water flow at the back of the bracket. Last year I stuck my head down between the motors while on plane and remember seeing the back of the floatation box running above the surface of the water. I believe the floatation box actually starts to loose contact with the running surface of the water a pretty low speed. This means of course it no longer can assist with providing floation at the stern. I firmly believe this is the reason the 23 Walkaround Whalerdrive will squat a lot in the stern while coming onto plane if you do not have the trim tabs in the full down position. |
| conch |
John twin unbalanced clyinders are mounted in opposite directions (one on each tilt tube of twin motors)to make a balanced system, and then a autopilot can also be used. But Tom is correct in pointing out that they are very vulnerable to being damaged. To passangers/swimmers they seem to scream out "step on me". Chuck |
| 6992WHALER |
My question is referring to what is the reason to mount 2 balanced cylinders. There must be a reason. We know it adds turns to the wheel, but does it make the wheel easier to turn? Less stress on the system? |
| conch |
I don't know the answer,which is why I asked the question I did in the secnd post of this thread. Someone here will know.My guess is the extra volume smoothes out the autopilot.Do you have an autopilot? Chuck |
| Tom W Clark |
Two cylinders were used on twin installations of 200 HP or larger motors to handle the added torque and make them easier to handle. It just creates a more robust steering system and was generally used on high horsepower, high performance boats though I have seen Whalers with as little as twin 150s using twin cylinders as well. With modern counter rotation twins, it is less critical, especially for the sub-50 MPH Whalers. |
| 6992WHALER |
Thanks Tom, Jeff's boat has 150s and I have 200s so that is probably the reason for the difference. I have counter rotating and an auto pilot. |
Again, re the Whaler Drive and the Saltshaker Bracket comparison, I want to acknowledge that there is a significant difference in the amount of hull rise that occurs during the transition to plane from displacement speed between boats with those different appendages. As was suggested above by Jeff (several articles above this one), his 23 WALKAROUND has a tendency to stern squat when getting on plane, and I have also see this in John's very similar boat. In contrast, on my boat with Whaler Drive I don't see any stern squat, although, to be fair, I do not have twin engines. This difference could be explained by the amount of buoyancy being contributed by the buoyancy box--I use the term "buoyancy box" because that is the term that the designer, Bob Dougherty used when he explained to me in person how he designed the Whaler Drive. On the Whaler Drive there could be more buoyancy compared to the Saltshaker Bracket, and this would have to come from a greater volume being immersed in the water. If there is more of the buoyancy box in the water, it is reasonable to think there could be more drag from that immersed volume. On the other hand, with the boat on plane the Whaler Drive seems to act more like a giant trim tab, not like something being dragged through the water. The Whaler Drive tends to limit the amount of bow-up trim that can be applied with engine trim. You can only get the bow to rise so far, then the trim tab effect of the Whaler Drive begins to limit any further rise. Perhaps we need to make some GoPro movies with the camera on a boom and held over the transom looking forward. |
| L H G |
Jim - A couple of other things regarding this discussion. First of all, the development of the Whaler drive had to accomplish two things for Boaton Whaler by the time 1987 rolled around. They had three hulls, the 20, 22 and 25 that needed to compete in the rapidly improving world of outboard boating. Armstrong type setback brackets on full transom hulls were all the rage, boats were going faster, and Whaler did not have anything except the terrible Sea Drives. 1. Counter rotating 25" engines were now on the market, and these BW hulls could not accompdate any of them! They all took 20" twins and only the 25 was rated for 300 HP. 2. They had to find a way to accomodate twin 25" engines, which none of these hulls could handle. So the Dougherty Whaler Drive solved both problems, and the WD had to be designed to give the boat ADDITIONAL LEGAL HULL LENGTH to get the higher HP ratings. That's why it runs in the water while on plane, hurting top end speed potential. After I bought my Sea Drive Blank 25 Outrage, and intalled the Armstrong bracket, in many ways making the boat similar to a WD model with 450HP rating, both myself and the selling dealer trined to get BW to give me a 450HP plate for mine. They refused, saying the free running bracket did not add to legal hull length, which left me with the 300 HP plaque (which I had already ignored!) Regarding the VanLancker era 21 and 23 hulls, they are notorious for "squat" on getting up to plane. It is simply a characteristic of the hull design. They take more HP to plane than the classic boats do, and the older 70's era boats take even less than the 2nd generation hulls. My ribside and the 19 Outrage "slide" up on plane very easily. The Dougherty Whaler Drives also facilitate planing from my experiences, while I think my Armstong/BracketSaltshaker configurations requires greater effort when compared to a cut transom hull. |
| 6992WHALER |
I certainly will agree that Jim's 22 Revenge with a Whaler Drive just rises out of the water when you go on plan. There is no stern squat. This might confirm Jeff's idea that the 23 walkarounds squats because the Saltshaker bracket comes out of the water while the Whaler Drive stays in the water eliminating the stern squat on the 22 Revenge. |
| Tom W Clark |
Regarding horsepower limits, the only "legal hull length" that has anything to do with horsepower is 20 feet, the length beyond which boat manufacturers are not obliged to place calculated horsepower limits on their boats. Boston Whaler could have given any horsepower limit they wanted to their 22 and 25 foot Whaler models. The Whaler Drive has nothing to do with it. |
| L H G |
TOm - They could, but they didn't. I was told the WD was the reason they increased the HP rating, and without it, they wouldn't. |
| Tom W Clark |
That is correct Larry. Whaler chose to give their boats HP limits. If a manufacturer puts a HP limit on a model, there it is. The law has nothing to do with it as you implied when you wrote:
quote: Only boats 20 feet in length or under are obliged by federal law to have calculated horsepower limits on them. |
| Jeff |
John, To get back to your initial hypothesis of the bracket running free of the water while on plane, I can for certain say that it does. I shot video from my GoPro a couple days ago from under the deck of the Salt Shaker Marine bracket that clearly shows the floatation box at displacement speeds and how it transitions to running free of the water once on plane. Here are a few images of the camera. I am up north and on vacation with limited internet access and due to the size of the video files can not upload them at this time. When I get home I will post them for you. |
| 6992WHALER |
Jeff, I am looking foreword to seeing your video. John |
ASIDE--Jeff--I admire your trust and faith in that suction cup mount. |
| 6992WHALER |
Look close Jim he tied it on with some fishing line. |
| Jeff |
John is right. I do use a tether on the rig made of 50 lbs test fishing line and snap swivels when using the camera on the outside running areas of the boat. That said, I have never had the suction mount fail on a fiberglass surface of the boat. Even when mounted on the hull side and it being beaten with spray off from pounding through waves. Here are the videos: Under the swim deck of the Salt Shaker Marine Whaler Drive: 32:35 we back down off plane Video of the gear cases running from the stern of the Salt Shaker Marine Whaler Drive: |
| 6992WHALER |
Interesting videos. I think they support the premise that the bracket is out of the water when the boat is on plane. It is interesting to note the relative calmness of the water in front of the engines. Thanks for taking the time to make this video. |
| Jeff |
No problem John. I am kicking myself today for not rigging the cameras yesterday. After pulling our gear from Salmon Fishing we had a great high speed run where the waves were timed perfect to just ever so slightly loft the hull free of the water a couple times while at speed. That would have made for some good footage. |
| Jessielove |
Jeff, If Jim doesn't mind this sidebar, how was the Salmon fishing? |
| L H G |
"Stern Squat" on acceleration was a known problem with the Van Lancker designed 21 and 23 Walkarounds. The problem is exaggerated on those with Saltshaker brackets. The boats take a lot of power to achieve plane. They also tend to be hard to control with a stern quartering big sea, leaning heavily to downwind side. All of which tends to define their relatively short 3 year model run, but they are still the highest quality cabin boats that Whaler has ever made. I have experienced good performance in these hulls when equipped with Mercury Vensura/Offshore 4-bladed props, which give good stern lift on acceleration. |
| L H G |
I found this old Cetacea related discussion that might be of interest here: |
Vis-a-vis the comments that L H G has linked to about the seakeeping of a 23 Walkaround, it is probably more prudent to get an impression from owners of the 23 Walkaround who have been at the helm for a hundred hours or more than to rely on the impression of someone who rode on one for a few hours or who once drove one for a short time. I am in that last category, and when I drove one I did not notice anything particularly odd about the way the boat handled. There are sea conditions and boat speeds that can combine to produce unusual motions on any boat, and the remedy for that is often to reduce boat speed. In any case, I doubt the cause is the Saltshaker Bracket we are discussing here. I would not characterize the hull design of the 23 Walkaround as anything radical, and you can see the same lines more or less continued today in some of the Whaler Accu-Track hulls. As for why Boston Whaler no longer makes that exact hull, it probably has more to do with the egos of the boat designers than anything else. When you hire a new boat designer the first thing that is going to change is the design of the new boats. |
| 6992WHALER |
I can say I don't think the hull has any extreme or radical response concerns. It is a pretty deep V so it handles differently then a cathedral hull. This last Lake Huron trip, we had lots of rough water. On the roughest day, I spent about 1 hour behind a 22 Revenge with a whaler drive. I never felt the revenge was out driving my boat. I found that I had to slow down and run at slower speeds than the Walkaround wanted to run to keep from running up on the revenges stern. whaler23 who comments in LGH's link is the person I purchased my boat from. This is the same guy who broke off one of the outriggers on a slip, put his foot through the battery compartment door the day I pick up the boat, left the fish box drains out and had trouble docking during the test drive. Is it the boat or is it the operator? I think any of the guys who were on the North Channel trip will support the statement that the Holly Marie with her twin engines can maneuver in tight spaces at slow speeds. Her weakness is moving backwards with a wind pushing on her bow. It would be interesting to get an owner of a notched transom to comment about the stern squat. Does it effect all 23 walkarounds or just the whaler drive version. I do not have the feeling that David Hart's 21 walkaround squats when going on plane. So I am not confident in the statement that the squat is a problem with all of the walkarounds. |
| Jeff |
Jim, speaking from 2 years of experience operating a Boston Whaler 23' Walkaround Whaler Drive I can say that the comments Larry pointed to can be experienced. That said, they are experienced when the operator is running the hull at an improper trim angle and speed for the conditions. When trying to run the boat over and through following quartering seas the boat will try to steer itself into then out of an oncoming wave if the hull it trimmed with the bow running to far down. This will then require a lot of muscling of and working the wheel to keep the boat on course. In those quartering conditions I have found it best to run with the tabs up and motors trimmed up / out to bring the bow up. This keeps the bow from plowing into the next oncoming wave as you surf down the previous one and will require far these steering input on the approach and cresting of the next have. I too will have to agree with John, the 23 Walkaround does have more of pronounced squat just before achieving plane than some but, the standard 21 Walkaround, 23 Walkaround, and the subsequent 21 and 24 Outrages built on these exact same hulls do not. And lets be honest, these hull designed lived for more than 3 years. The 21' hull design that the Walkaround and Outrage was built on ran production from 1991 - 1995. The 23'9" hull design that the 23 Walkaround, Walkaround Whaler Drive and the (24') Outrage where built on ran production from 1991 - 1997. Larry, can you point me to any reference data you have on the 23 Walkaround Whaler Drive with the Mercury Vensura/Offshore 4-bladed props you (or someone else) ran and saw a marked improvement? I would be interesting in hearing a detailed account of how these props helped the performance of their boat. We are considering moving to 4 blade props ourselves. |
| 6992WHALER |
Jeff, I agree with you, if you run at too high a speed with trim tabs down you are asking for trouble in a following sea. Of course that is true with any boat. I found that if I trimmed the engines almost all the way in, the props held the water better after the bow drops down the wave and your stern goes up. Doing this did not effect the bow position negatively as far as not nosediving into the next wave. |
| L H G |
Jeff- The 4 bladed Mercury Vensura/Offshore prop revolutionized the performance of "Backlash" (21 walkaround with 200 Yamaha) and JimG's 19 Outrage II. It was a huge improvement over the Yamaha 3-bladed SS props they were using, and no loss of top speed either. I would think they would run extremely well on the 23, much better than those old Yamaha 3-blades, but don't know how they would be in comparison to a set of more modern Revolution-4's. You should definitely try both. As you know, I am running 21" Rev-4's on my 25 with wide open vent holes, and they are sensational as far as I am concerned. Fast with incredible total hull lift. They may actually be too much prop for the relatively lightweight 25 Outrage, but at the time I bought them the Enertia was not yet out. |
| K Albus |
Here's a picture of John's 23 Walkaround with Saltshaker Bracket: And here's a picture of a 23 Walkaround with a standard notched transom - note the single engine application: |
Three transoms:
Note that the buoyancy box on the Saltshaker Bracket is confined to the center section, but on the classic Whaler Drive the buoyancy box is almost the full width of the hull.
| prj |
Without knowledge of shaft length, mounting height or engine dimensions, the top cowling of Jim's E-TEC appears 2" higher than Kevin's Yamaha and 8-10" higher than John's Yamahas. |
The argument that the hull of the 23 Walkaround was not made for a long time or is no longer being made is not much of an argument. You can say the same about the classic 22-foot Boston Whaler boat hull--it is no longer being made, either. Now you can say that the classic 22-foot hull was in production longer, from about 1978 to perhaps 1993, or 15-years, but there are other considerations. At that time, making molds was a slow, difficult, and expensive process, done mainly by hand by skilled labor. You first hand-made a plug, then made a mold from the plug. These days plugs for molds are cut from foam and computer controlled multi-axis machines, and modern boat builders like Boston Whaler seem to think nothing of tooling up a mold with a unique hull design for every boat in the their catalogue. Previously a hull might be used under several different models, and not because the hull was perfect for each model but because the business plan called for re-using a hull for a long time to get the cost of the molds in line with production. So the classic hull designs tended to have longer lives. Was that because they were perfect hull designs? Or was it because it cost too much to make a new mold? If you look at the hulls shown above in the picture of the five bows, you can see which hull design is the odd-man out--it's the classic Whaler hull. The other four hulls all seem to be similar in design. The four are all more recent hull designs. Are we now saying all modern hulls have flaws that were not in the classic Whaler hull? |
Just for prj
What is your inference? |
| L H G |
The inference is that these 3-star engines are HUGE in relationship to the older 2-stroke Yamahas. The 4.2 liter 4-stroke Yamahas are very large engines, and it's surprising to see that the big E-tecs are the same size. Without going down in power, the 23 Walkaround WD has very limited re-power options at the 400 level. |
| Peter |
"The inference is that these 3-star engines are HUGE in relationship to the older 2-stroke Yamahas. The 4.2 liter 4-stroke Yamahas are very large engines, and it's surprising to see that the big E-tecs are the same size." LOL. Larry is it time for a new prescription on your glasses? One can easily see from two photos that the E-TEC is not the same size as the 4.2L Yamaha. The Yamaha 200s in the picture are 2.6L outboards. The 3-Star E-TEC 2.6L 200 is no bigger than that old Yamaha and weighs about the same too. They would be perfect repower candidates for the Yamaha 200s when the time comes (which may still be a long, long time from now). |
To help some of our readers gain a better comparison, here are the three engines from the initial image, but now normalized to their transom mounting height. The blue line shows the water line;
And for even more help in making a comparison, the same three engines overlaid atop each other. Notice that the Yamaha Offshore F250 is much taller than the others. The E-TEC 225 is taller than the older Yamaha, but actually that portion of the cowling of the E-TEC is mainly an air-water baffle and sound insulation. All three are about the same width. I think I cropped off an inch or two of the Yamaha Offshore when I cut it out.
Also, re the width and height: The three engines are not all perfectly normal to the camera. They're just at random positions, not necessarily aligned perfectly straight. This can affect the apparent width of the cowling. An engine steered a bit off-center might look wider. Also they are not all perfectly trimmed to level. Trimming up or down might affect the apparent height of the cowling. |
| 6992WHALER |
Man do my engines look dirty. I think I know what my winter project will be this year. Jim can you photo shop in some new cowlings? |
| 6992WHALER |
Something else to think about, this picture was taken after I topped off the fuel in Little Current. With almost 180 gallons on board The Holly Marie is riding low. I bet the waterline on my engine would match Kevin's Yamaha if I had less fuel on board. |
| L H G |
[Tried to change topic of discussion to another engine which is not shown in any of the photographs and made speculative claims about the engine not shown in any of the photographs compared to the engines which are shown in the photographs. This distracting sidebar has been deleted.--jimh] |
| 6992WHALER |
The 200 Yamaha engines on my boat are mounted one hole lower than Jeff's 150 Yamaha egines. So I could move them up one hole. That would also change the relationship pictures. |
The dimension that I found to be the most different among the three engines as pictured and the most interesting--more so than all the hoopla about which engine's cowling was two inches taller or wider--what I found in the pictures was the apparently large difference in draft or position of the propeller relative to the waterline. Look at the first of the three-panel images above, where I have shown the three engines with the waterline as a uniform level in all three views, and you can see that the Yamaha twin engines on the Saltshaker Bracket are immersed more deeply than the others, and especially so compared to the Evinrude on the Whaler Drive. I have not measured the distance photogrammetrically, nor have I put an Architect's scale on it, either, but just by eye--and not a trained eye--it looks to me like the Yamaha twins must be immersed about a foot or so deeper than my Evinrude. I am assuming that all the engines are 25-inch shaft engines--that's right, isn't it? This means the tip of the skeg of the engines on the 23 Walkaround have to be a foot deeper in the water. I did not realize that the 23 Walkaround had so much more draft than my REVENGE 22. I think the deeper draft must be in part from a deeper V-hull. Have we ever figured out what the deadrise angle is on a 23 Walkaround hull? It would be interesting to compare to the classic 22-foot Whaler hull deadrise angle. As best as I can determine, the deadrise on a classic 22-foot Whaler hull at the transom is about 14-degrees. There was a quite a discussion about deadrise angle of a 22-foot hull a few years ago. See |
| 6992WHALER |
Here is a picture of the 23 walkaround while on the trailer. |
I worked with John's image to better show the depth of the hull below the waterline on the Saltshaker Bracket:
There is a lot of hull under that bracket. |
I used Photoshop to photgrammetrically measure the hull deadrise at the transom and found the 23-Walkaround to have a 20-degree transom deadrise angle. |
| 6992WHALER |
You can see from this picture how you can trim the engines up at slow speed to the point were the keel will hit the bottom before the props. |
| Peter |
Jim -- The height above the waterline(or draft) comparison is a bit on the side of apples-to-oranges because your Whaler Drive was intended to have something between 750 and 850 lbs of outboard hanging on its transom. If your Whaler Drive had the maximum HP at the time -- a pair of 150 HP V6 2-strokes -- the waterline would be considerably higher on the Whaler Drive. Based on what I've seen of twin powered Whaler Drives on 22 foot Whalers, there is a good chance that the waterline would be at or slightly above the lower mounting bolts on the transom bracket. By eyeballing it, looks like the waterline at the transom would be an inch or two higher than it is currently the case. |
Re waterline on a Whaler Drive: I have seen a 22-foot hull with Whaler Drive with a pair of V6 OptiMax outboard engines, and the water line of the Whaler Drive was significantly higher than on my boat, that is, the Whaler Drive was submerged deeper into the water. I agree, with a single engine on a Whaler Drive, and particularly on the REVENGE model where there is more weight forward from the cabin superstructure, the water line on a Whaler Drive will be quite low, that is the Whaler Drive will he higher in the water. My boat floats with rather shallow draft in the stern, as the chines of the hull are just submerged about two inches into the water. It is hard for me to get much stern lift from a propeller because the stern is riding rather high already. |
