ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Whaler Performance Whaler Drive
Author | Topic: Whaler Drive |
pcrussell50 |
posted 10-15-2012 07:36 PM ET (US)
What is the benefit of Whaler Drive? I keep reading posts that mention it. I see that it is a really long moment arm off the back of the boat. Is that in and of itself a benefit? Or is there some other benefit, where that huge moment arm is a necessary evil to be endured in order to achieve some other benefit? A lot of folks over on the fast-boat forums use large setback jackplates as it appears some (but apparently not all) hulls can gain a fractional little bit of speed form it. But these are performance boats with double or more the power-weight ratio of your typical Whaler, where a level static float is not coveted as much as in our Whaler community here. Sooo anyway, what does Whaler Drive give you? Is there something about its design where that long moment arm doesn't ruin the level static float? Forgive my newbieness. Just trying to understand Whaler Drive. -Peter |
posted 10-15-2012 08:30 PM ET (US)
A Whaler Drive allows the transom of the boat to which it attaches to be closed, and a stern deck area created. |
Peter |
posted 10-15-2012 08:49 PM ET (US)
It also allowed them to: - offer a longer hull without making an entire new mold; |
posted 10-15-2012 09:28 PM ET (US)
A Whaler Drive make the boat ride much smoother, like a Cadillac BROUGHAM. Larry, L H G, gave my boat the nickname "The Brougham" after he rode in it and was amazed at the smooth ride. |
Tom W Clark |
posted 10-15-2012 09:34 PM ET (US)
Jim is correct. The Whaler Drive improves the ride just as trim tabs that are permanently deployed and cannot be retracted thus keeping the bow down. The Whaler Drive also kills the speed potential of the hull. |
menahaunt11 |
posted 10-16-2012 12:38 AM ET (US)
Whaler drive allows the stern to become far more buoyant. I have fished drifting in rough, following sea conditions where the extra buoyancy of the whaler drive has helped drive the engine up and over breaking whitewater behind the boat. It has proven me wrong on a few occasions where I have braced for water coming into the stern and watched the engine shoot up and over, completely unphased. It provides much added seaworthiness to the vessel in my opinion It also provides a softer re-entry at higher speeds travelling in bigger swells Superb swim platform/inshore fishing platform for 3rd angler as well |
martyn1075 |
posted 10-16-2012 03:08 AM ET (US)
Whaler Drives cost the owners additional moorage fees that we hate to pay! and think its a cheap way for the marinas to get more money. Otherwise they are a nicely configured brilliant piece of work. I feel the same about the bow extension as well different topic however. Martyn |
Russ 13 |
posted 10-16-2012 08:20 AM ET (US)
Why does the Whaler Drive kill the top end speed? Is it just too much additional drag?? |
posted 10-16-2012 08:36 AM ET (US)
Who says a Whaler Drive kills the speed potential? |
Mambo Minnow |
posted 10-16-2012 10:39 AM ET (US)
Speed potential of a hull is directly proportional to overall hull length. |
elaelap |
posted 10-16-2012 11:22 AM ET (US)
...in a displacement hull vessel, MM. Tony |
Tom W Clark |
posted 10-16-2012 11:47 AM ET (US)
No, it is the hull's waterline length that limits the speed potential of a displacement hull. Overall hull length has nothing to do with it. |
Tom W Clark |
posted 10-16-2012 11:53 AM ET (US)
quote: Boston Whaler does. They told Larry, when he ordered his Outrage 25, the Whaler Drive option would limit the speed and they recommended he order a full transom instead and install a bracket, which he did. |
Tom W Clark |
posted 10-16-2012 11:54 AM ET (US)
quote: Who said that? |
posted 10-16-2012 12:01 PM ET (US)
"Not I," said the dog. "Not I," said the cat. "Not I," said the pig. "Then I .." said the little red hen. Is this where I should start cheeping? |
posted 10-16-2012 12:24 PM ET (US)
In making comparisons between Boston Whaler boats with and without a Whaler Drive, I think one ought to not make the comparison between the same hulls, that is, one ought not to compare an OUTRAGE 22 to an OUTRAGE 22 Whaler Drive. The Whaler Drive adds a couple of feet to the length and it adds weight. To make a comparison between an OUTRAGE 22 Whaler Drive and an OUTRAGE 25 may not be particularly consistent, either. An OUTRAGE 22 Whaler Drive is only a few inches shorter than an OUTRAGE 25, so the lengths are close, but the beam is also smaller on the OUTRAGE 22 Whaler Drive, 7-foot 5-inches compared to 8-feet. I don't recall any really rigorous comparisons between Whaler Drive and non-Whaler Drive boats in which the only variable was the Whaler Drive. There are some anecdotal comparisons, but there are typically many other variables involved--different outboard engines, different propellers, different weights, different days, weather, environment, and so on. It would be interesting to see a rigorous comparison in performance. So far, there is mainly a lot of repeated anecdotes about the Whaler Drive and its affect. In one, as I recall, when the boat speed was pushed to very high speeds by maximizing horsepower, the Whaler Drive seemed rather fast. |
pcrussell50 |
posted 10-16-2012 01:53 PM ET (US)
Aren't there basic principles of naval architecture/marine engineering that tell us whether systems like Whaler Drive increase or decrease speed potential? What about the coveted "level float" attitude while at rest, that I've read so often about on these pages? How does WD affect that? -Peter |
Jerry Townsend |
posted 10-16-2012 03:16 PM ET (US)
Peter - et al - I am not a marine engineer - and I do not have a Whaler Drive - but: A WD certainly affects the dynamics of the boat - simply by moving the CG of the "system" aft. The boat (any body)moves and rotates about the CG. In view of these facts, a WD would tend to stabalize, to smooth the response of the boat. But, the response of the boat is affected by the water conditions - which has not even been mentioned in the discussion. So - with the comments regarding on the same boat with and without the WD, the water conditions have to be compariable. Regarding the "speed potential" - I doubt a WD would have any affect - because the speed of a boat is at the balance point of the thrust of the engine(s) and the drag of the boat. The WD does not increase the thrust and, I would think, not have a meaningful affect on the drag with the boat on plane. The WD does not significantly affect the mass of the "system" - therefore a WD should not affect the initial acceleration. --- Jerry/Idaho |
JMARTIN |
posted 10-16-2012 06:26 PM ET (US)
quote: -------------------------------------------------------------------------------- The Whaler Drive does not make for a very fuel efficient boat, either. -------------------------------------------------------------------------------- I was going to say that but jimh said I should not make that comparison and I was comparing his boat to mine. John |
posted 10-16-2012 08:39 PM ET (US)
A really interesting comparison could be set up as follows: --an OUTRAGE 20 The OUTRAGE 20 and OUTRAGE 22 have hulls of the same width. The OUTRAGE 22 is 2-feet longer. An OUTRAGE 20 Whaler Drive is very similar to an OUTRAGE 22. The comparison is most rigorous if all three boats use the same engine--literally the same engine moved from boat to boat. And, of course, the same propeller. The testing period would need to be short, perhaps only covering a matter of a few hours, in the same water, the same temperatures, and the same general conditions. It would be interesting to see the speed and fuel efficiency comparisons between these three boats. I think you could reasonably isolate the influence of the Whaler Drive in this test. If an OUTRAGE 22 was significantly faster and more fuel efficient than an OUTRAGE 20 Whaler Drive, it would establish a base line for much of the dock talk about Whaler Drives being inefficient and speed robbing. |
posted 10-16-2012 11:31 PM ET (US)
John quotes someone: quote: Who were you quoting? I don't think the speaker of this has been identified and the source cited. |
posted 10-17-2012 05:55 AM ET (US)
A Whaler Drive increases the boat's length, leading to a higher length to beam ratio. See my article on length-to-beam ratios at Length/Beam Ratio Readers interested in learning more about the design of the Whaler Drive should read my article which speculates about some of the reasons for the Whaler Drive at Whaler Drive Design Fundamentals The Whaler Drive added considerably to the price of the Boston Whaler boat. In c.1989 a Whaler Drive was reported to cost an additional $3,000. In later years the price of a Whaler Drive was reported to cost $10,000 on some hulls. |
JMARTIN |
posted 10-17-2012 12:22 PM ET (US)
quote: -------------------------------------------------------------------------------- The Whaler Drive does not make for a very fuel efficient boat, either. -------------------------------------------------------------------------------- I do not know who said this, but I concur if the hulls are the same. John |
L H G |
posted 10-17-2012 02:27 PM ET (US)
Well, let's just ignore what I said, and what I was "supposedly" told by Boston Whaler way back in 1989, and what I have learned from my own experiences. Even better, let's just call that statement that tom CVlark posted in my belhalf as "silly" and "baloney", as is often said about things I post here. So I am happy to see that the real experts here now agree with JimH, that the Whaler Drive appendage, discontinued by Boston Whaler when the 23 Walkaround came out in 1991, does not decrease top speed potential or fuel economy. So we have JimH, our esteemed Moderator, saying his 22 Revenge with WD does 44 (on a good day) with a 225 HP DFI Evinrude E-tec. Then we also have JimP, one of our esteemed contributors in Alaska, and former Coast Guard officer, who say his same 22 Revenge , without WD, and with a same HP 225 DFI Mercury Optimax, does 49 MPH, and gets better fuel economy than JimH. Since you experts here can't have it both ways, which is it? 1. The 225 Mercury blows away the 225 Evinrude in power and economy. or 2. The Whaler Drive kills top speed and economy. |
posted 10-17-2012 02:44 PM ET (US)
Larry--I think you skipped the part where I said we should avoid making a comparison between a 22-foot hull with notched transom and an 22-foot hull with Whaler Drive--because they are not the same hull, the same size, or the same weight. In the realm of Boston Whaler boats, the only reasonable comparison that I can find which would tend to isolate the Whaler Drive as the influence on speed and fuel economy is one where a 20-foot hull with Whaler Drive is pitted against a 22-foot hull without Whaler Drive. This comparison would have very similar hulls with a difference in only the last two feet of the hull. The comparison you cite with jimp's boat is flawed; the environments are completely different. I know you like to cite that comparison to try to draw an inference about the horsepower of a Mercury engine compared to the horsepower of an Evinrude with each having the same cowling decal, but, no matter how often you present it the same flaws spoil the comparison. Too many uncontrolled factors spoil the comparison. Also, I don't know why you have changed your statement about what an employee of Boston Whaler said to you. They either said it or they didn't--there is no "supposedly" about it. I don't see where anyone has questioned your recitation of that conversation, except you yourself. |
tedious |
posted 10-17-2012 03:05 PM ET (US)
Never having set eyes on a Whaler Drive boat, much less driven one, is some or all of the Whaler Drive still in the water when the boat is fully on a plane? Tim |
posted 10-17-2012 03:46 PM ET (US)
I can't help but noting that so far it seems like no one has any objection to the characterization of the Whaler Drive as improving the general ride or handling characteristics of the classic Boston Whaler hull. There seems to be a lot of grumpy old men debating whether or not a Whaler Drive takes 2- to 3-MPH off the top speed of a boat. Thanks to the engine history reporting feature of my modern outboard motor, I know with some certainty that I operate my boat at maximum throttle only a extremely small fraction of the total operating time. If indeed I have lost 2-MPH of possible top speed during the tiny fraction of operating time, I get the benefit of an improved ride the other 99-percent of the time. If there is a tiny window of operating conditions in which something is lost by having a Whaler Drive, I am comfortable with the trade-off. |
Peter |
posted 10-17-2012 03:54 PM ET (US)
Why would anyone need to be told that a larger, heavier motor boat (22 foot Whaler with Whaler Drive) would be slower and less efficient than a shorter, lighter motor boat (22 foot Whaler with notched transom) with the same HP? Isn't that rather obvious? It would also be obvious that marine service provider, which ordinarily charge for their services by the foot, would charge more to paint the bottom of a 22 foot Whaler with Whaler Drive than it would to paint the bottom of a 22 foot Whaler with a notched transom. What does the Whaler Drive do? It extends the hull length by 2 feet (or 3 feet in the case of the 27 foot hull) versus the models without Whaler Drive. |
Peter |
posted 10-17-2012 04:06 PM ET (US)
"...is some or all of the Whaler Drive still in the water when the boat is fully on a plane?" Yes. Here is a photo of a Whaler Drive on a Whaler 27 model. i177.photobucket.com/albums/w231/Whaler-Fleet/CW%20Posts/ FromStern-OutofWater.jpg and i177.photobucket.com/albums/w231/Whaler-Fleet/CW%20Posts/2187.jpg Note the V and trim tabs. |
posted 10-17-2012 06:15 PM ET (US)
A Whaler Drive creates controversy about its design and its benefits. |
fishgutz |
posted 10-17-2012 06:45 PM ET (US)
Wow, a Whaler Drive must work just like a Doel-fin. |
tedious |
posted 10-17-2012 07:06 PM ET (US)
No, it makes it act like a longer boat - meaning more wetted surface and weight, so it takes more power to run, and it also rides a bit better. Doesn't seem to be rocket science to me. Tim |
Tom W Clark |
posted 10-17-2012 09:31 PM ET (US)
Yep, the Whaler Drive offers advantages and disadvantages. You can decide for yourself if it is for you or not. And yes, it is no surprise that a boat that is longer and heavier will thus be slower and less fuel efficient. What I find surprising the disproportionate decrease in speed the Whaler Drive seems to inflict on the classic hulls, as much as 10 MPH or more. |
Tom W Clark |
posted 10-17-2012 09:40 PM ET (US)
Jim writes:
quote: Yes, I agree wholeheartedly. We have never had the same boat and motor tested with, and without, the Whaler Drive appendage. It is high time we put this silly speculation based on anecdotal reports to rest. Jim -- I suggest you remove the Whaler Drive from your boat and test your E-TEC with an aftermarket bracket like Larry's Armstrong bracket. If you could do this on the same day, it would be best. You are a resident of Michigan so that is good, though ideally you would also be a lawyer. That way could accept your report as valid. |
pcrussell50 |
posted 10-17-2012 10:09 PM ET (US)
Aha! I had missed a not-so-subtle aspect of the WD. Until I saw that picture, I had assumed Whaler Drive was a glorified jackplate. Now I have to ask: From the picture, it looks so well blended with the hull--is it fiberglass and foam like the hull, too? -Peter |
posted 10-17-2012 10:25 PM ET (US)
Tom--Are you drunk? |
Tom W Clark |
posted 10-17-2012 10:58 PM ET (US)
No, I am not. I am merely trying to meet the rigor you yourself have demanded recently. |
posted 10-17-2012 11:05 PM ET (US)
Using the same engine will be more rigorous, but no need for lawyers, or for the test to be conducted in Michigan [because we are not debating fine points of Michigan legal statutes]. Using two engines of the same type will also be more rigorous than using completely different engines. It is not fair to compare an E-TEC 225 to a Mercury OptiMax that has a "225" decal. We all know that a Mercury OptiMax with a "225" decal will have about 400-HP. |
Peter |
posted 10-18-2012 07:19 AM ET (US)
"What I find surprising the disproportionate decrease in speed the Whaler Drive seems to inflict on the classic hulls, as much as 10 MPH or more." Can you point us to the data where there is a 10 MPH penalty by having a Whaler Drive on the boat versus not having such? This link continuouswave.com/ubb/Forum4/HTML/002306.html provides a thread where we have top speed data reported for an Optimax 225 on a Revenge 22 WT WD and an Optimax 225 on a notched transom Revenge 22 WT. 44 MPH verus 45.4 MPH are the reported top speeds. In this case, the Whaler Drive does not appear to dragging along so much so that it knocks 10 MPH off the top speed. |
Peter |
posted 10-18-2012 07:26 AM ET (US)
"...is it fiberglass and foam like the hull, too?" Yes. Fiberglass and foam. Unlike an aluminum set back bracket like Larry has on his Outrage, there are no inspection plates providing access to the interior of a Whaler Drive. It's all sealed up. The 22 and 25 foot classic Whalers use the same smaller Whaler Drive. That Whaler Drive has a differently shaped bottom, more like a pad. It does not have trim tabs and the shape of it makes it virtually impossible to add tabs. This is too bad because the Whaler hull with its hard chines can really use trim tabs to soften the ride when running in quartering seas. |
posted 10-18-2012 09:01 AM ET (US)
Move to PERFORMANCE. |
posted 10-18-2012 09:27 AM ET (US)
Tim asks: "...is some or all of the Whaler Drive still in the water when the boat is fully on a plane?" In my observation most of the Whaler Drive is still in the water when the boat is fully on plane, but a lot of the Whaler Drive is in aerated water. I think the design of the Whaler Drive was done to intentionally induce air into the water running under the Whaler Drive. I think this was done for the same purpose that "steps" are put into the hull bottoms of boats which are intended to be very high-speed planing hull boats, that is, to get some air under the hull. I believe the purpose of getting air under the hull is to reduce hull drag and also create a bit of air cushion under the hull. I have posted some images that show the water coming off the transom of the Whaler Drive. Here are some links: http://continuouswave.com/whaler/reference/images/ETEC250HO/wake800x588. jpg As Peter notes, on the 22-foot hull with Whaler Drive the Whaler Drive has a flat pad on the bottom; it does not come to a vee like the rest of the hull. As Tom notes, a Whaler Drive can act like a rather large trim tab, and, as such, it keeps the bow from rising very high. It is typical in a Boston Whaler boat hull with a Whaler Drive that the transition from displacement mode to planing mode occurs with very little bow rise, and never with the sort of very prominent bow rise see in other boats (especially boats with long set back brackets that do not have a buoyancy box). There is a limit to how high the bow of a boat with a Whaler Drive can be raised by engine trim. In some sea conditions I have thought that perhaps it would be beneficial to get the boat trim to run a bit more bow-high, but one soon runs out of trim range. But, in complete opposition to that notion, there are also times when I would like to try running the boat with the bow lower, and, because I don't have trim tabs, I cannot push the bow down. Overall, however, I would say that the trim that results when running on plane with a Whaler Drive is not particularly bad. You have some control of the trim angle with your engine trim, and you can move the bow up or down within that range. |
dgoodhue |
posted 10-22-2012 01:26 PM ET (US)
I haven't had a chance to respond earlier. In comparing a 20 vs 20wd, 22 vs 22wd , & 25 vs 25wd, the whaler drive is always slower withe same hp. I think jimh makes a good point about trying to compare 20 WD to 22 with same power. It's unrealistic that some one will swap motors onto 2 or 3 hulls unless someone wins the lottery. 20wd is a pretty rare model, so it makes difficult to get even a decent sampling of speeds especially given the different mountig heights and props. Might intuition is that the wd is less efficient speed wise than non whaler drive wih similar length. Recently their was a 20WD thread. In that thread someone mentioned they had a recent 200 Honda on 20wd outrage. He reported top speeds of low 40's. I am pretty sure 22 outrage with 200 hp would run mid 40's. obviously this is a sample size of 1 for the 20wd. The other 20wd or in the post says he has a worn out 225 that runs 42mph. Comparing 22wd & 25's. 22wd outrage with twin 150's, it seems like they run about 48mph (I did some research a while back trying to find 400hp on 22wd and found many examples of 300hp 22wd OR). Twin 150's on a 25 Outrage is usually a 50+ mph boat. The 25' whaler is wider and significantly heavier so it should be slower. I don't own any of these boats so I am just going by research on this site and my interest in classic whalers. |
Tom W Clark |
posted 10-23-2012 09:36 AM ET (US)
The Whaler Drive appendage on the 20, 22 and 25 foot models adds about 250 pounds to the boat. Jim's Crouch's Speed Calculator: http://continuouswave.com/cgi-bin/crouchcalc.pl ...predicts that that added weight will reduce speed by 1 - 1.5 MPH, yet we see speed reduction far in excess of that on boats that actually have the Whaler Drive. |
Peter |
posted 10-23-2012 09:44 AM ET (US)
Where are the examples of a 10 MPH or more difference? |
Tom W Clark |
posted 10-23-2012 09:51 AM ET (US)
Larry reports his boat can do 62 MPH. Are there 25 footer Whalers with Whaler Drive and 400 HP that can do more than 52 MPH? |
Peter |
posted 10-23-2012 10:20 AM ET (US)
So now we are throwing set back brackets into the mix? Well how much slower is a notched transom version of a Whaler versus the same hull with a 30 inch set back bracket with the same HP? |
Tom W Clark |
posted 10-23-2012 10:40 AM ET (US)
Good question. Who has a notched transom Outrage 25 with twin 200s? |
Peter |
posted 10-23-2012 10:43 AM ET (US)
Why are twin 200s needed? Twin 150s would be just as good for comparison purposes. |
Tom W Clark |
posted 10-23-2012 10:52 AM ET (US)
Because a 25 footer with twin 200s will be faster than one with twin 150s. I though were were trying to compare Whaler Drive vs. non Whaler Drive with all other things the same. |
posted 10-23-2012 01:52 PM ET (US)
Pat has a REVENGE 22 with a notched transom. I have a REVENGE 22 with Whaler Drive. We will have to conduct a flat-out top speed drag race run to see if his boat is 10-MPH faster. He'd have to hit 54.6-MPH to be 10-MPH faster. But until the race is run, we can have fun speculating. Do you think a REVENGE 22 with notched transom and a 225-HP outboard engine can reach 54.6-MPH? That seems awfully fast. I'd be surprised it it can hit 48-MPH. Any reports of other REVENGE 22 boats with notched transom and a 225 out there? |
posted 10-23-2012 01:54 PM ET (US)
Heck--we don't have to wait too long. Don has a REVENGE 22 with a full transom and an Armstrong bracket. We will have to drag race next Spring and settle this 10-MPH difference. And Don has a BRP-era Ficht engine, which from all reports are smokin' fast engines, probably more like a 250-HP. |
martyn1075 |
posted 10-23-2012 02:09 PM ET (US)
When we had our 1990 22 Revenge it was powered by a a 1999 Optimax 225. I would be lucky to hit 43mph with it. I know it should go faster correct? My hull was mint no water problems whatsoever not even a chip off the bottom and kept on a trailer all its time since new. It did have a Atlantic Towers hard top at one point. I would estimate about 300lbs it has aluminum rails and thin fiberglass top. I assume it would mess with the speed a tad but I would think not by all that much maybe a few mph only. The boat was equipped with trim tabs so I was able to keep the bow down and adjust to compensate movement. With our current boat that weighs nearly twice as much we run two newer Optimax engines and can get to 47mph. The other owner claims 50mph. Interesting the gas milage is far better than the single Optimax on the much smaller 22 Revenge. Martyn |
L H G |
posted 10-23-2012 03:30 PM ET (US)
I don't think you need to speculate about Don's or Pat's Revenge. I already posted JimP's results from several years ago: "Then we also have JimP, one of our esteemed contributors in Alaska, and former Coast Guard officer, who says his same 22 Revenge, without WD, and with a same HP 225 DFI Mercury Optimax, does 49 MPH, and gets better fuel economy than JimH." 5 MPH sounds about right to me on the difference between a cut transom and a Whaler Drive model. If transom brackets or jackplates improve performance at all, it would be an improvement over a cut transom model, not a WD model. |
posted 10-24-2012 04:56 PM ET (US)
Larry--I already told you years ago and every time you bring up that report that it is not comparable because of the environment. Cold saltwater and cold dry air are the factors that help jimp get those results, and warm freshwater and warm humid air are the factors that make it impossible to duplicate in the Great Lakes. I know you have an advanced degree in Science and you are completely aware of how those environmental factors make the comparison invalid, but I guess you keep bringing it up because you like the outcome so much. I think Pat is going to buy an E-TEC soon, so maybe we can have a real comparison with minimal difference. I am a bit nervous about Don's boat because that big Ficht engine is a beast and the Armstrong bracket will help him, too. But at least a run side-by-side at the same time, same environment, same sea state, and so on, will give a real comparison. I wouldn't mind visiting Alaska but I am not dragging the boat up there. |
posted 10-24-2012 04:58 PM ET (US)
And, case in point, Martyn's results with 6-MPH less speed with the same boat as Jim P's should make it clear that there is something unusual about the 49-MPH speed. |
AK153 |
posted 10-24-2012 06:51 PM ET (US)
Jim, I'll make you a great deal. Trailer your boat up here and perform all the tests you would like in Valdez and we can do comparisons to the other Revenges moored in Valdez. As a bonus which is my best selling point, you can sell me your Whaler when you're finished. We both win, CW receives more data for it's participants and I get my larger Whaler. I think this may be an extremely fair offer. (I'm hoping you have an elderly senile moment and accept my offer!) |
JMARTIN |
posted 10-24-2012 07:55 PM ET (US)
Could it be that without a Whaler Drive, the boat is able to be trimmed up higher? A shot of my notched transom V22 Revenge at optimum full economy trim. The power is a 1992 200 Evinrude TXENE, rpm is 3600, speed 28, mpg 2.8. I was surprised at how high the bow looks. http://i34.photobucket.com/albums/d137/jmartin-/150ee78d.jpg Now somewhere on this site is a picture of jimh's Whaler Drive Revenge 22 on plane and maybe we can compare. John |
martyn1075 |
posted 10-24-2012 11:27 PM ET (US)
John I am a bit surprised as well but maybe the shot was just taken at a time where you hit a wave that lifted the hull just a bit. Im not sure, but the mpg numbers seem reasonable even if the hull plains out that way. Martyn |
andygere |
posted 10-25-2012 01:17 PM ET (US)
quote: My notched transom Outrage 22 Cuddy (with a T-top and enclosure, and bottom paint) runs right at 40 mph with a 200 hp outboard. I'm running a 4-blade prop for better holeshot and holding in rough water. I might be able to squeak a bit more top speed if I optimized my prop selection for that. Mid 40's might be tough the way my boat is configured. The point here is that it's tough to get an apples to apples comparison in terms of rigging, props, weight of gear on board, etc. I imagine that at some point Whaler must have done some performance tests on the hulls with the boats configured with the same engines, props, etc. Has anyone made an inquiry with Boston Whaler about the availability of such test results? Finally, how much does it matter? I don't think very many of us own these boats for top speed, or pure fuel economy. You can get much more dramatic improvements in fuel economy by installing a fuel flow instrument and adjusting your throttle to the optimal setting. A Whaler Drive offers benefits such as additional buoyancy for dual engines, improved ride characteristics, a full transom with some storage, and built in swim platforms. Notched transom boats will drain more easily if waves are taken over the bow, are lighter, were less expensive when new, and will generally cost less to moor in a marina based on the shorter overall length. This is the stuff to consider. |
martyn1075 |
posted 10-25-2012 03:44 PM ET (US)
Its true Andy, and if you buy a full transom Whaler you pretty much accept these advantages and disadvantages. Should probably not worry too much about the other stuff. There is no perfect boat I have found some might just work better for what you need it for overall. Saying all this so you think a notched transom design would offer a better quicker hole shot over the full transom? Martyn |
posted 11-02-2012 02:37 PM ET (US)
The only method to learn the effect of the Whaler Drive on the top speed potential of a classic Boston Whaler hull is to design an experiment to test the influence, conduct the experiment as carefully as possible, and then make very careful measurements. From such data a reasonable inference could be drawn about the influence of the Whaler Drive on the top speed potential of the hull. It is all well and good to dredge up from memory chance remarks made by various people about their various theories of the influence of the Whaler Drive on the top speed potential of a Boston Whaler classic hull, but such recollections are not particularly dispositive--that is, they do nothing to settle the issue. It takes only the briefest moment of thought to consider the inherent conflict of the suggestion that a Whaler Drive removed 10-MPH of speed from a hull. This is a radical suggestion, and I can counter it with just a simple argument: If after inventing and experimenting with the configuration that has become known as the Whaler Drive, if Boston Whaler had found that it reduced the top speed of their boats by 10-MPH would they then have gone to the bother of adding it to their products? Imagine this situation: Bob Dougherty spends six months developing the Whaler Drive, and shows it to the top guys at Boston Whaler. "Here it is," he says, "and it's going to add several thousand dollars to the cost and cut 10-MPH off the speed." Do you think Boston Whaler would have ever put the Whaler Drive into production on that basis? Now we can let the philosophers and the grumpy old men continue to tell us that the Whaler Drive is going to cut 10-MPH off the speed, or we can behave like rational men of science and conduct a few tests. By conducting a few tests I do not mean that we call up random anecdotal reports that so and so said his such and such boat went X-MPH on one certain run--never to be duplicated--under special certain conditions, and then point to another poor fellow who said his boat with Whaler Drive went (X-10)-MPH under completely different conditions. That is just more random chance anecdotal recitation. Now some like to build their positions atop random chance anecdotal recitations, but I like to build my position in firmer ground. |
Peter |
posted 11-03-2012 05:11 AM ET (US)
It is expected that the Whaler Drive model of a given hull would be slower than the notched transom version. Afterall it is a bigger boat. It is possible that the difference in speed could be as high as 10 MPH. But it might require loading the transoms with 1000 HP or more to get that spread. |
L H G |
posted 11-03-2012 01:06 PM ET (US)
Just to get rid of this ridiculous non-scientific discussion and unproved speculation about an old fashioned idea, this grumpy old man is now convinced and would be willing to stipulate that the short lived Whaler Drive boats circa 1987-1990 go faster, ride better, get better fuel economy and are generally superior in all respects to any cut transom Outrage or Revenge Whaler ever built. Now that we all agree, has anybody ever noticed what an ugly duckling these Whaler Drive contraptions are, and even worse when partially bottom painted? From a design point of view, they have no relation to the shape of the hull to which they are attached, look completely like the afterthought they are, have a really strange rounded shape, look totally obsolete and out of date, and generally detract from the lines of the 2nd generation Outrage hulls. I guess that's the appearance price one has to pay for the higher top end speed and superior fuel economy, and for trying to pretend a 22' WD Outrage is really a same size boat as a 25' standard Outrage. A prudent buyer would have simply skipped the ugly duckling 22 with the WD appendage, and bought a cut transom 25 and have achieved the same speed and same fuel economy for your HP dollar, plus a lot more boat, beam, and sea keeping ability.
posted 11-03-2012 03:07 PM ET (US)
It would be interesting to make a survey of how many people bought Boston Whaler boats with a Whaler Drive, and then compare that number to how many people bought Boston Whaler boats with a Sea Drive blank configuration and added their own engine brackets. You have to wonder about the marketing people and what they were telling customers. If Boston Whaler were telling customers that the Whaler Drive -- was an expensive way to slow the boat by 10-MPH, --added at least $3,000 to perhaps $10,000 to the cost, and --created an unattractive appendage to the stern that ruined the boat's lines, did they then instead tell the customers they ought to get a Sea Drive blank and make their own engine bracket? In either case, why did so many people buy Whaler Drive boats? It has been my opinion for a long time that the most reasonable application of the Whaler Drive should have been on the 25-foot hull. It made the 25-foot hull two-feet longer. The jump to the 27-foot hull is much too great. You cannot easily trailer a 27-foot hull due to the beam, but you can easily trailer a 25-foot hull with Whaler Drive. It did not make sense to me why someone would order a 20-foot hull and add the Whaler Drive; just get the 22-foot hull would be the more logical choice. The same more or less applies to the 22-footer; just get a 25-footer. I have said this before. However, it seems like the real attraction of the Whaler Drive is the closed transom, the swim platform, and the improved ride characteristics. Some people get too obsessed with top speed. Top speed is just horsepower, and if you want top speed get lots of horsepower. By the way, it is I that has been proposing to toss overboard all of this old palaver about whose boat when how fast and actually have some head-to-head testing on a same-day, same-place, same environment, same-condition basis. A little bit of decent testing ought to make clear what the affect on top speed might be for a Whaler Drive. |
L H G |
posted 11-04-2012 07:37 PM ET (US)
Jim - Don't waste your time with that survey. Someone at Whaler told me that they believed I bought the only customer purchased Sea Drive Blank they ever sold! Mine is literally one of kind, so any perfromance data from mine should be compeletely ignored as irrevelent and a poor sampling. In the late 80's, an Outrage buyer had the choice of a full transom boat with OMC Sea Drives, a cut transom boat, or a Whaler Drive boat. With twin engines, Sea Drive and the Whaler Drive boats were uncompetitive and slow sellers because of the cost, so the dealers started selling a cheaped out WD version with single engine, once they got approval to remove center support bar. |
posted 11-04-2012 07:57 PM ET (US)
Thanks for your remembrances. I will add another characteristic of the Whaler Drive: --the single-engine Whaler Drive boats are cheapened-out versions This is good to know. We can add that to the list of all the things wrong with the Whaler Drive. And my congratulations on being able to see through all of those insurmountable problems with the Whaler Drive and be the only person to avoid them with your Sea Drive blank version. |
martyn1075 |
posted 11-04-2012 11:54 PM ET (US)
Interesting, I have always liked the look of them they offer a platform on both ends which are very usefully unlike almost any other design at the time. They look very smart in the water which of course is the most important. After all they are designed to be used in the water and not stared at out of the water so much. They suck for moorage! If you have 25 foot boat you now have a 27 plus a bit more with engines set back further. If you have the bow extension which most do you are now in a 30-32 foot long boat. 32 foot boat is very expensive to keep in the water vs say a 25 foot model with cut transom. That boat might stretch out to 27ish with motors and bow extension. Several hundreds of dollars a year. Martyn |
Jessielove |
posted 11-05-2012 06:02 PM ET (US)
I'd have to imagine a Whaler 27 whaler drive with bow pulpit and engines tilted up should be about 35' OAL. Luckily, some marinas and yacht clubs charge by manufacturer's stated model length and not actual OAL. |
Peter |
posted 11-05-2012 06:54 PM ET (US)
From WD transom to pulpit, the Whaler 27 WD is about 31 feet give or take an inch. The motors add about 3 feet when tilted up making the LOA about 34 feet. With the motors down, the LOA is about 33 feet. The nice thing about the Whaler 27 model is it says 27' on the side. |
posted 11-05-2012 07:35 PM ET (US)
My REVENGE 22 Whaler Drive with a bow pulpit and the engine (that is "engine" in the singular, hence the really cheapened version of the Whaler Driver per Larry) tilted up probably measures 29-feet. I always tell the harbormaster I my hull is a 22-footer. Once I got a slip that was actually only a 20-foot slip, and the boat was sticking out about ten feet into the fairway. I had to ask for a larger slip, and I explained the boat was "a big-22." By the way, I have been thinking about the set up with the Sea Drive blank, an engine bracket with no buoyancy box, and twin engines. What I see in that rig is as follows: --dramatic shift in static trim to very bow high --strong tendency for bow rise in transition to plane --great concern for swamping engine when coming off plane --no added running length to hull so no gain in ride characteristics, and perhaps a loss due to shifting of so much weight so far aft without any support from buoyant force in the hull I think there is a reason that only one person ever rigged a Whaler that way. |
L H G |
posted 11-05-2012 11:15 PM ET (US)
Not too long ago I came to same conclusion myself, that I had made a terrible mistake in buying a 25 Outrage Sea Drive Blank. I even had a broker in FL list it for sale two winters ago, for 12K, with no takers. The boat has only been used once since and remains stored in a barn in Northern WI. Of the Whalers I own, it has become my least favorite. |
posted 11-06-2012 07:40 AM ET (US)
Larry--don't fret. Your boat still has the closed transom and stern deck, perhaps the best parts of the deal. I do worry about you when it comes time to re-power. With no buoyancy box, you will never be able to put a pair of VERADO engines on the bracket. The weight increase would be tragic. The OptiMax might still be available, but there will be an increase in weight compared to those relatively light 2.5-liter engines you have now. But I think you'd have to settle for a pair of 150-HP OptiMax engines, as the big block V6 OptiMax engines would be too heavy and too much power--you know they make about 50-percent more horsepower than the cowling decal says. With your unique set-up, what would you re-power with? |
Peter |
posted 11-06-2012 11:20 AM ET (US)
The cantilevered engine bracket is an engine weight multiplier when underway. Being cantilevered, either adding or substracting weight from the transom bracket will have far more drastic changes to ride and handling than a simple notch transom version or a Whaler Drive version. In the new emissions compliant era outboard motors, keeping the weight of the 440+ HP* on the bracket the same so as not to change the balance of the boat, about the best you can do is about 350 HP**. * Estimate of output of emissions non-compliant twin 200 HP Mercury outboard motors by owner of emissions non-compliant twin 200 HP Mercury outboard motors. ** Single "gianormous" V8 4-stroke outboard. |
martyn1075 |
posted 11-06-2012 01:35 PM ET (US)
On our 25 the plate says 25 feet but are dock masters laugh in our face. They have me at 32.2 They squeeze everything out they can including an anchor that may stretch 6-7 inches beyond the bow extension. They are ruthless and because of our wait list problem the demand is high it gives these dock managers another excuse to charge the big dollar. Martyn |
posted 11-06-2012 01:41 PM ET (US)
Let's look at the weight distribution that Peter has mentioned. With a long set back bracket and no buoyancy box the engine weight is really hanging far behind the boat hull where there are not any buoyant forces to support it. As the boat goes faster and faster, more of the forward part of the hull comes out of the water. In the real go-fast boat design the hull that remains in the water is just a small pad near the stern. The rest of the forward part of boat is out of the water. Hanging all the engine weight three feet behind the boat at that point is a bonus. The engine weight is multiplied by the lever arm of the set back to help balance the boat while it runs on the pad and goes 75-MPH or more. However, there are absolutely zero moments in my Boston Whaler boating life where I want to run 75-MPH. First, I am usually in some water attached to the Great Lakes and the water is seldom that calm. Next I don't want to power my boat to run 75-MPH. And third, if I did have the calm water and the power to run 75-MPH I would not want to burn that much fuel. Typically the ride characteristics of a boat are related to the length of the boat hull, with it being generally appreciated that longer boats ride better. A longer boat encounters the waves in multiples. If waves are spaced at ten-foot intervals an 18-footer can only be on two waves at a time. A 25-footer can be on three waves at once and that makes the ride smoother. It is well known that keeping weight out of the ends of the boat improves the ride. If you want to reduce pitching in a hull, get the weight out of the ends and move it toward the center. A boat with inboard power will ride differently than the same hull with outboard power because the engine weight is located inboard and low. The times when I really appreciate my Boston Whaler boat and its Whaler Drive are those times when we are slogging along in some rough seas and making about 18-MPH but having a rather comfortable ride. I never have once said to myself in those circumstances, "Gee I wish I had a boat that could go somewhat marginally faster in really calm water." |
martyn1075 |
posted 11-06-2012 01:43 PM ET (US)
Peter I tried the whole my boat is 25 on the plate thing, but he said nothing while the tape was drawn out in front of me. I gave it my best effort to minimize the pain, his response was, "well I tell you what, I technically can charge you for the anchor sticking out but I will withdraw it from the total" Wow! thanks how generous of you. Martyn |
Peter |
posted 11-06-2012 02:30 PM ET (US)
Fortunately for me, my municipal marina only charges by category (large, medium, small). My large slip will allow 36 feet long by 12 or 13 feet beam. With about 33 feet LOA with the motors down, it was very tight getting in and out of my slip. For the first few years I had my Whaler 27 WD in the municipal slip I was quite fortunate not to have a boat in the slip directly across. That changed in the last year and made entering and exiting the slip a bit more difficult, requiring more precision manuevering. I'm now down to a boat that has a 26'7" LOA and only an 8'6" beam so less precision is needed. But the funny thing is that for me the smaller boat almost seems harder to back into the slip than the Whaler 27 WD because there is almost too much room. ;) |
contender |
posted 11-08-2012 08:16 PM ET (US)
For any of you looking for something like the whaler drive, Dusky Marine here in Ft Lauderdale now makes a Fiberglass Dive Platform. They can mate this platform to a whaler stern and make it look like one piece. The platform itself is very well constructed and goes all the way across the stern of the boat. This also gives you room for a dive platform and a nice boarding ladder that fits on the platform as well. They make the platform for single, twins and triple engines. At first when I looked at it I though it was a joke but after examining it I would pick one over an Aluminum or stainless one, like I stated it is very well made... |
posted 11-08-2012 11:47 PM ET (US)
I was browsing some photographs posted taken of new boats at the Ft. Lauderdale Boat Show. I noticed that it is just about universal now on the big Florida center-console offshore boats to have the stern of the boat set up very much like a Whaler Drive. All the boats I looked at in the photographs had engine brackets with large buoyancy boxes quite similar to a Whaler Drive arrangement. This is probably an artifact of the much higher weight of the modern four-cycle engine. These boats typically had at least two or three four-cycle engines of 250-HP or more, and in some cases four engines! There is no way in the world a cantilever arrangement like an Armstrong Bracket can work any more with the weight of modern engines. Many of the hulls tended to have steps in the bottom to help get some air under the hull. The longer boats had three sets of steps. Of course, the new boats had the engine bracket molded into the hull as part of the structure, not attached like a Whaler Drive. But, interestingly, there was an Everglades boat with something that looked like a two-piece Whaler Drive bolted on to the transom. I think we have to thank Bob Dougherty for the foresight to make the Whaler Drive have plenty of reserve buoyancy. A Whaler Drive will be able to handle the weight of the heavier four-cycle outboard engines of today. It is my opinion that a Whaler Drive boat would be a good choice for re-power with a VERADO L6. It could tolerate the weight, and the enclosed transom and stern deck will be a perfect place to hide the power steering pump and other accessories (such as black boxes and distribution boxes for the wiring harnesses). In the photo gallery I think there is only one boat shown with an Armstrong Bracket. This is probably a good indication that the Armstrong Bracket approach is no longer the way to go with heavy four-cycle engines. Here is a link to the photos I mention: |
posted 11-09-2012 12:33 AM ET (US)
Here is a link to the photo of the Everglades boat with an unusual stern bracket set up. It reminds me of a Whaler Drive but in two pieces: |
Peter |
posted 11-09-2012 09:32 AM ET (US)
The Everglades' Whaler Drive like hull extension is quite different in that the outboard motor is still mounted to the hull transom. This reminds me of a small (about 10 foot) speed boat we ran around in as youngsters with an 18 HP Evinrude that had a pair of extensions which we called pontoons. They allowed an oversized, heavier motor to be put on the transom of the short boat and kept the boat from flipping over while underway. |
Tom W Clark |
posted 11-09-2012 10:53 AM ET (US)
I see you guys are still at it. Has anybody come up with a 25 foot Whaler with Whaler Drive and twin 200s that can top 52 MPH? |
Tates |
posted 11-10-2012 12:08 PM ET (US)
I can get 44 gps 25 revenge hard top , 2, 200 Optimaxes |
posted 11-10-2012 06:32 PM ET (US)
If I had 400-HP on my REVENGE 22 Whaler Drive I should hit 54-MPH with ease. |
martyn1075 |
posted 11-11-2012 01:48 PM ET (US)
52? no but the previous owner claimed 50 from twin 225 Optimax motors on our 25 Whaler Walkaround. I don't have any reason to not believe him as we are still friends. Boat is much heavier as well wider than a 25 Revenge. It stretches out to 32 feet and probably weighs close in the 8000lbs range. My best is 47-48mph. It may be alright but Im not a speed demon so it doesn't mean much to me other than a pain of spending more money on gas. If we take the time to compare the two boats or at least relevant to this discussion of whether whaler drives are causing the haul to be up to 10mph or more less than a notched transom, it doesn't seem to hold much truth in my situation. The theory does make sense that it could hold the boat back Im not convinced 10mph or more and my boat proves that. I have not experienced on any of my whalers. For example our 22 Revenge non whaler drive haul was lucky to get 44 but our much heavier 25 (30-32) gets better speeds and yes far better gas milage. I just need two large V6 engines to achieve that. At that point we can make our own personal opinions if its is actually worth it or not. Will whaler drives cause a haul to burn more gas? Yes, I think there may be some truth to that in some situations. Do the engines have to work harder in some cases yes I think they might. For example in a following sea climbing up a backside of a wave. This kind of sea in our boat proves to be very stable safe comfortable ride but boy it will drag a great deal and burn tremendous amount of fuel to clime up and down large swells. Martyn |
duf |
posted 11-12-2012 09:42 AM ET (US)
Tom, in what i consider a poor example of checking your speed as i hadn't put new electonics in, was to have a friend of mine pace my boat, and he claimed i was doing 50 with my 25 twin 2001, 200 Yamaha's. Best i can offer. Duf |
duf |
posted 11-12-2012 09:44 AM ET (US)
bdb |
posted 11-13-2012 09:33 AM ET (US)
RE: Everglades...those additions are called "lifting platforms" and yes, they are available to provide additional bouancy for the heavier outboards. The boat shown is a 243cc which is one their early designs and still one of the most popular models today. With two stroke engines wieght was not an issue but now with the universal application of four strokes it is. The lifting platforms are an option at about $2,300 msrp. |
L H G |
posted 11-13-2012 02:32 PM ET (US)
Brian - Just goes to show how brilliant the design of the 1971 Outrage 21 hull turned out to be. Lifting boxes built right into it. |
posted 11-14-2012 07:43 AM ET (US)
Larry--I see you switched your opinion 180-degrees. Welcome to the Whaler Drive is great club. |
L H G |
posted 11-14-2012 12:37 PM ET (US)
A Whaler Drive afterthought is no Ribside. |
posted 11-14-2012 12:43 PM ET (US)
You are right about that. The Whaler Drive is on a v-hull, not a surf board, and its sides don't look like a dump truck. |
posted 11-15-2012 09:14 AM ET (US)
I see Larry has added a new negative comment about the Whaler Drive: it is an "afterthought." This new accusation joins the many prior negative comments he has made. Let's review them. So far, Larry says the Whaler Drive: --robs the boat of 10-MPH of speed --turns the boat into "an ugly duckling" --makes the boat look obsolete --ruins the lines of the classic hull --is purchased by owners who want to "pretend" they have a bigger boat --has inferior seakeeping characteristics compared to other models --if used with a single engine represents a "cheap" installation --is an afterthough. Let's look at afterthought. The word means "an idea occurring later." I think that is a good definition. Larry uses afterthought as a pejorative, but that shading is not mandatory. In the case of the Whaler Drive, the idea for it did occur after the classic hulls were already designed. The brilliance of the Whaler Drive is its ability to be added onto the existing hulls. To mold the Whaler Drive into the hull form would have meant creating entirely new molds for three or four lengths of hull. Boston Whaler molds for Unibond hulls are very elaborate and expensive constructions. We have already seen that Boston Whaler at this time in its history was very stingy with money to make new molds. Boston Whaler was using the same basic hull mold for many models of boats, adding different superstructure or deck arrangements to the same hull. It would have been very radical to create an entirely new hull mold to provide for a molded-in engine bracket. With Unibond construction there is also the concern for the hull design being able to be filled with foam without creating voids. This is a problem unique to Boston Whaler's method of hull construction. Any hull shape or appendage has to be made in such a way that it can become foam filled. This criterion may have influenced hull design. Perhaps the dreaded Eurotransom look employed by Whaler is in part due to the foam filling process. Larry's latest potshot at the Whaler Drive as afterthought exposes all Boston Whaler owners to criticism of anything added to a Boston Whaler boat after it leaves the mold. For example, is the addition of an arch also an afterthought? Why, yes, of course. It was an idea that occurred later. If not made part of the original design, then by Larry's critical eye it becomes an afterthought. And to Larry, who has added arches to his boats, welcome to the afterthough club. |
Peter |
posted 11-15-2012 10:16 AM ET (US)
So as to be all inclusive, adding an Armstrong bracket to a full transom Whaler hull is no less of an afterthought. I suspect that in its "afterthinking" process, and having had experience with Gill bracket and OMC SeaDrives, Whaler came up with some very good reasons to offer the greater buoyancy of the Whaler Drive rather than the lesser buoyancy of the off-the-shelf Armstrong bracket.
posted 11-15-2012 11:21 AM ET (US)
I think most amazing in the marriage of the off-the-shelf Armstrong bracket to the classic Boston Whaler hull--even if it does constitute an afterthought--is apparently there is no harm done to the appearance. Apparently just grabbing an off-the-shelf engine bracket and bolting it onto the transom does not: --turn the boat into an ugly duckling --ruin the lines of the classic hull --make the boat look obsolete We should explore this more deeply to see if the magic is in the design of the Armstrong bracket. Is there something about the Armstrong bracket that makes it able to be bolted on to a classic Whaler hull without any aesthetic harm, yet something Whaler themselves designed for the hull turns it into utter ruin? |
martyn1075 |
posted 11-15-2012 11:43 PM ET (US)
But seriously does it really slow the boat down by 10mph? I don't think so my boat proves that. Are there others out there that are experiencing the same? Martyn |
posted 11-17-2012 10:23 AM ET (US)
Martyn--I sense that as a result of reading this discussion you may now have fear, uncertainty, and doubt about your boat. I can understand this. Before this discussion took place I was very pleased with my boat, my Boston Whaler with Whaler Drive. I loved my boat. It was, in my naive and unsophisticated mind, a perfect boat. But now I have learned the truth, and now I, too, have fear, uncertainty, and doubt about my boat. I wake up in the middle of the night thinking about the ugly duckling appearance of my boat, about the complete travesty of the total ruination of my boat's lines from the afterthought of the bolted-on Whaler Drive, about the loss of all seakeeping ability brought on with the obsolete and outdated Whaler Drive, and about the ignominy of having a only a single engine on a Whaler Drive--a cheap installation I am told, and about the perpetual shame of pretending I have a larger boat than I really do. But, dear Martyn, I never have lost a moment's sleep or even imagined for a second that I have lost 10-MPH in speed. Those imaginary thoughts are only in the minds of other people, not in my mind. And you should keep them out of your mind, as well. |
martyn1075 |
posted 11-17-2012 01:25 PM ET (US)
I know Im just getting over social stigma of owning Optimax engines. Now they are bolted on to a dinosaur Whaler Drive. Sleepless nights ahead. Martyn |
posted 11-17-2012 04:19 PM ET (US)
Martyn--I know your pain. I have an E-TEC. I have to live in constant fear of BRP going bankrupt, of BRP not having sufficient research and development, of the E-TEC not being as efficient, of the E-TEC not be reliable, of the E-TEC not having as much horsepower. Oh how I long for the chance to get rid of my boat, get a notched transom boat and get some reliable two-cycle engines with the engineering and sophistication of the late 1970's or early 1980's bolted on. That would be heaven on Earth, or so I have read. |
Peter |
posted 11-17-2012 07:03 PM ET (US)
Having been the owner of a Whaler with Whaler Drive for 9 seasons, truly, no one should have to endure such pain and suffering inflicted by the Whaler Drive. I will make the supreme sacrifice to bring an end to that by generously giving each of you a dollar in exchange for your Whaler Drive compromised vessels including their inferior propulsion systems. You will be thereafter rid of your insurmountable Whaler Drive burdens. This is surely a fair and just result. ;) |
