1985 Challenger 25 Makeover (continued)
peteinsf
Postby peteinsf » Fri Jul 29, 2016 7:22 pm
Hi All,
Work continues on the Katmai NP Challenger.
Old Forum: http://continuouswave.com/ubb/Forum3/HTML/021226.html
Some in-line photos from lost links...
Starting place.
peteinsf
Re: 1985 Challenger 25 Makeover (continued)
Postby peteinsf » Fri Jul 29, 2016 7:26 pm
Continued...
Interlux2000 after grinding out cracks.
Sitcky 1985 3m non-skid removal (tedious)
peteinsf
Postby peteinsf » Fri Jul 29, 2016 7:29 pm
5 inch transom extension idea.
Old forum: http://continuouswave.com/ubb/Forum3/HTML/021240.html
5 inch extension2.jpeg (106.01 KiB) Viewed 25394 times
peteinsf
Postby peteinsf » Fri Jul 29, 2016 7:38 pm
Continued...
Motors arrive
and get mounted.
peteinsf
Postby peteinsf » Fri Jul 29, 2016 7:46 pm
Awlgrip and bottom paint next...
peteinsf
Postby peteinsf » Sun Jul 31, 2016 12:47 pm
This week was priming all of the exposed areas where I removed the original paint around corroded areas. Also the aluminum deck was glued to the hull, screws set and then covered over...
Original Deck:
peteinsf
Postby peteinsf » Sun Jul 31, 2016 12:49 pm
Deck glued down.
MerchantMariner
Postby MerchantMariner » Sun Aug 07, 2016 1:42 pm
Hey looking great. Nice job. You are an inspiration!
nes4pres
Postby nes4pres » Mon Aug 08, 2016 4:15 am
Looks real good. What is the shaft length of the Evinrude engines? Did you extend the transom?
Postby jimh » Mon Aug 08, 2016 10:29 am
The details of the transom can be seen clearly in the several images above. The insert into the original notched transom that provides five-inches of higher splash well height does not appear to be attached to the original hull. It looks like it is held in place by the aluminum riser brackets holding the engine, and its thickness to much too small to be a structural support for engines of 500-lbs or more.
peteinsf
Postby peteinsf » Fri Sep 02, 2016 11:31 am
New tank arrives...
Acseatsri
Postby Acseatsri » Fri Sep 02, 2016 1:55 pm
The engines look like they're thru-bolted into 1/2" thick x 2 x 4 aluminum L-brackets, the bottom bolts going thru the original transom. I think the arrangement is strong enough as long as there are large enough backing plates on the inside of the transom. It roughly resembles a low setback jackplate in principle.
peteinsf
Postby peteinsf » Fri Sep 02, 2016 4:05 pm
Acseatsri,
It's a manufactured bracket good to 300hp.
See http://continuouswave.com/ubb/Forum3/HTML/021240.html
peteinsf
Postby peteinsf » Tue Sep 06, 2016 4:54 pm
Rotten plywood removed from the tank deck cover...
peteinsf
Postby peteinsf » Wed May 31, 2017 10:34 pm
Hi All,
After much delay the tank cover is finally repaired/improved. After days of cutting, sanding and grinding I turned over the thin fiberglass top to the boatyard to finish.
They used three sections of a glass/balsa sandwiched laminate and glassed it to the thin original decking.
My impressions are that it looks perfect, is much lighter, and much stiffer than the original. (I have not seen the bill yet)...
Hats off to the SF Boatworks for quality workmanship. Next step is to cover my new tank.
Bottom of tank cover
Top of tank cover
Postby jimh » Sat Jun 03, 2017 5:04 pm
I am enjoying the many comments and photographs of this renovation, and I am sure many other readers are, too. Keep the posts and pictures coming. I am looking forward to seeing the end results and the boat on the water.
peteinsf
Postby peteinsf » Mon Jun 05, 2017 8:54 pm
Thanks Jim,
Here are some other miscellaneous repairs:
For some reason CPD liked exposing foam on this rigging job. Maybe a deadline for shipping her to Alaska.
In any case two big holes for the fuel lines (using bent copper tubing), they ran in and then back out of the bait well. In addition, lots of holes for the tow bar mounting brackets (I did not get the actual bar).
Baitwell 1
Baitwell 1a
They also used white PVC pipe to line the big wire tunnel into the cabin (jagged sawzall cut, silicone calked). For that we installed a pre-made fiberglass tube and glassed it in (i'll add the pictures of that repair later)
peteinsf
Postby peteinsf » Mon Jun 05, 2017 8:57 pm
peteinsf
Postby peteinsf » Mon Jun 05, 2017 8:58 pm
peteinsf
Postby peteinsf » Tue Nov 06, 2018 12:31 am
After forever She is launched!!!
Initial "day-one" test: [4 blade Cyclone, 19 pitch]
70 Gallons on-board
Max Speed 54 WOT @5500
Happy Speed for SF Bay = 26mph @3050 RPM
Non-planing cruise 10mpg @ 1600
I have not done exhaustive testing (upwind/downwind, trim settings, etc) just a ferry ride from SF to Alameda. I did hunt down some choppy seas (between Treasure Is and Point Blunt) to find the most comfortable RPM.
These E-TEC engine just don't stop; set the RPM and they just plow along--I just love it.
Don SSDD
Postby Don SSDD » Tue Nov 06, 2018 7:23 am
Beautiful boat, wonderful work, congratulations. Don
Nova Scotia
frontier
Postby frontier » Tue Nov 06, 2018 8:05 am
AMAZING. Great job.
Postby jimh » Tue Nov 06, 2018 2:00 pm
Pete--very nice work and very nice of you to follow up with new pictures.
Re the E-TEC engines: my E-TEC runs like a diesel. You set the engine speed, and that is the engine speed. Steady engine RPM no matter what. I love that aspect, particularly when you have to run into some head seas. The engine speed is not hunting up and down.
Enjoy your new boat.
peteinsf
Postby peteinsf » Wed Nov 07, 2018 10:48 am
Thanks Jim...
I did have a question, can I retrofit my 2011 e-tecs with electronic shift/throttle?
Pete
