  Repower update - SeaDrives Off!!!
Author Topic:   Repower update - SeaDrives Off!!!
Billymac posted 05-17-2004 09:48 AM ET (US)   Profile for Billymac   Send Email to Billymac
In the process of repowering my 87 Revenge 22 WT (Originally with Twin SeaDrives), with an Armstong Bracket and an Evinrude 225hp. Sunday I, and I use that term loosely, removed the SeaDrives. Thanks to Stan and Matt, S&M Marine in Carol Stream, IL, for doing the job that was more than they expected. I gave them the SeaDrives for parts for doing the job, a bargin for me!
I was not aware that besides the 6 bolt holes per engine, they would also leave two larger voids. Each side has a round hole about 6 or 7 inches in diameter above the water line and a rectangular hole about 7x5 below the water line. Now what to do with those holes???
The round ones on top can probably be used for the engine lines, hydraulic steering hoses, etc., with some modification, althougth they are pretty far apart, 2 ft. or so.
The big ones below the water line, I assume, will have to be pluged/filled and glassed over before attaching the Bracket (Armstrong).
Any comments or suggestions at this point would be appreciated.
Bill
Chicago
jimh posted 05-21-2004 08:28 AM ET (US)     Profile for jimh  Send Email to jimh
I am sure this will be an interesting narrative of the repair process. Please append additional update to this thread so that they stay together. And take some pictures, too.
jimh posted 05-21-2004 08:31 AM ET (US)     Profile for jimh  Send Email to jimh
You started a second thread on this topic/repair process. Let's let that thread die and use this one for future updates.
Cf.: http://continuouswave.com/ubb/Forum3/HTML/006202.html
Billymac posted 05-21-2004 09:36 AM ET (US)     Profile for Billymac  Send Email to Billymac
Help!!! Anyone out there who has taken off twin seadrives?I have talked to two fiberglass guys, one described a classic fiberglass repair, enlarging the lower rectangular holes on the inside including the inside layer of marine plywood then plugging with appropriate wood and do the glass repair, finishing the outside with gelcoat. Taking the boat to him today but said his best guess would be $500 to $700.
The second guy who saw a picture of it, called it "Swiss Cheese" and insisted that the Transom needs to be rebuilt completely, $4500 with gelcoat finish, $3800 with just bottom paint. Obviously I felt sick to my stomach when he said this, but at the same time I felt like I was buying a new car from a guy telling me I could not live without the "acid rain protection coating".
After reading all the history on this site and doing as much research as possible with this repower, I have a hard time beleiving that a completely rebuilt transom is necessary??? If the holes are patched properly and the Armstrong bracket is installed properly, I feel pretty confident that the transom will be safe and solid. If anyone disagrees, please comment.
LHG posted 05-21-2004 12:55 PM ET (US)     Profile for LHG
I would start with getting in touch with Chuck Bennett at Whaler. If he can't help out, ask him to refer you to the G &CP division contact, since they still build these full transom WD 22-27's. They should be able to give you the correct word on this. I do know that there have been many Sea Drive re-powers using brackets. I think "Lewis" here did it. See if you can find him for information.
I had heard that G&CP was going to open up their services to owners whose boats are in need of factory repairs. Don't know if this ever happened
Plotman posted 05-21-2004 04:39 PM ET (US)     Profile for Plotman  Send Email to Plotman
a couple thoughts wrt dealing with the holes in the transom left by the sea-drives.
1) I'm not sure how big a structural issue these holes are - after all they were there when the sea-drives were mounted on the boat and the boat didn't tear apart. The arnstrong bracket is a huge bearing surface pushing against the transom compared to the relatively small area that the sea drives pushed against. If it were my boat, I would bolt the AB to the transom using the standard mounting bolt positions (as if you were mounting to a virgin transom) and then I would think about drilling additional holes in the bracket to match up with the bolt holes in the transom around the perimiter of the existing holes in the transom. The metal in the bracket is going to afford at least as much (if not much more) support, to the transom as having the sea-drives bolted on. I would think that your main concern would be getting a water-tight repair that looks decent from the outside (at least the part not covered by the bracket). The main thing in repairing the holes (and mounting the bracket) is to make sure that you aren't letting water get at the transom core to promote rot.
2) Armstrong advertises their brackets as a solution when dealing with the hole in a transom left when converting from an I/O to outboards. Talk to them about what they suggest for repairing the transom.
george nagy posted 05-21-2004 05:01 PM ET (US)     Profile for george nagy  Send Email to george nagy
Will the bracket neatly cover the seadrive holes? If so then just glass/epoxy the exposed wood in the transom cut-outs then 5200 the bracket to the transom. It might be re-assuring to be able to look in the inside of the bracket periodically for signs of corrosion or impending failure.
andygere posted 05-21-2004 09:46 PM ET (US)     Profile for andygere  Send Email to andygere
I think replacing the entire transom is overkill, and would certainly present some new structural problems. A well executed repair of the holes, some extra laminations of glass cloth and backing plates inside the transom to help distribute the loads should work fine. A wood-epoxy matrix can be extremely strong, and the loads will be distributed over a fairly large area. Perhaps Armstrong can give you some references for glass shops that have already done this type of repair. It would be worth traveling some distance to have the job done right.
Tom W Clark posted 05-23-2004 01:41 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Oh for the love of Pete! You DO NOT need to replace the transom. That's ridiculous. If the holes were compromising the transom as it is now, how on earth would the Sea Drives have worked at all?
The Boston Whaler transom is not particularly hi-tech. It's just plywood and fiberglass. Find a shop that knows how to work with both those materials and patch the holes.
Billymac posted 05-24-2004 09:38 AM ET (US)     Profile for Billymac  Send Email to Billymac
I did call Chuck Bennett at Whaler and he assured me replacing the tranasom was definitely not necessary. He basically said just do a good repair using proper fiberglass techniques...big load off my mind (and pocketbook).
Took the boat to the coin op carwash Sunday and got all the grease and oil out of the bilge and cleaned it up, removed all the wood off the transom and floor, and got her ready for the fiberglass guy, Leon Thompson of Boat Doc's in Fox Lake, IL (not the one who wanted to replace the transom). Hope to he has room for it this week, doubtfull but still hopefull to make my AM salmon fishing date with my boat partners June 4 followed by an afternoon at Wrigley with the Cubs and Pirates. More to follow...
BEACHPANDA posted 05-24-2004 11:08 AM ET (US)     Profile for BEACHPANDA  Send Email to BEACHPANDA
Billy,
I'm not sure if this is OverKill, or not, but some forum members commented on:
http://www.transomrepair.com/
This stuff may go a long way in strengthening the transom for you, without going broke, and yet assuring you that it will hold the new AB without compromising the Transom strength and integrity.
A search on CW for transomrepair , came up with six hits. The product is called SeaCast.
Below are two of the CW links.
http://continuouswave.com/ubb/Forum3/HTML/005771.html
http://continuouswave.com/ubb/Forum3/HTML/004757.html
Good Luck
BEACHPANDA
jimh posted 05-24-2004 11:21 AM ET (US)     Profile for jimh  Send Email to jimh
SeaCast may be a fine product but I would never recommend it for the type of modification being discussed here.
Watch that 30-minute home movie video on their website and you may get that same idea.
PMUCCIOLO posted 05-24-2004 12:22 PM ET (US)     Profile for PMUCCIOLO
Billymac,
As Larry mentioned, it is my understanding that Brunswick Commercial & Government Products provides the services to recondition Boston Whalers. I am not sure, however, if this service is limited to commercial users only. It might be worth a phone call; perhaps they can provide you with advice on your retrofit.
Another great resource is Jimmy Sauliner at Harpoon Marine: http://members.tripod.com/harpoonmarineinc/index.htm
Best of luck on your project!
Paul
Billymac posted 05-25-2004 10:11 AM ET (US)     Profile for Billymac  Send Email to Billymac
Guys,
Thanks for all the input! I have looked at Seacast and it looks like a great product but not for this kind of repair. If I had to replace rotten wood it would be ideal.
I am going to call Brunswick C&GP for a little more input but I am feeling good about the guy @ Boat Doc's who is going to do the repair. Not only does he know his stuff, he has been doing this for 25 years, he is really working with me to get it done even though he is pretty booked right now (a good sign that he has a lot of work).
I will update when I get it back with the transom repairs, pre engine install...
Billymac
Billymac posted 06-15-2004 03:00 PM ET (US)     Profile for Billymac  Send Email to Billymac
Project moving along like a herd of turtles...Picked up the boat today from Boat Doc's in Fox Lake, IL (transom and fiberglass work) and took back to my marine center (Ahlstrand). The fiberglass work looks excellent! You can't tell those white elephants (Sea Drives) were ever on the Transom.
Total bill for the transom/fiberglass work with tax, $893.00, ouch! Labor was $792 (11 hours x $72) and $95 in supplies. But better than the $4500 I was quoted from the guy (Bottom's Up Boat Repair) who told me I had to replace the transom, HA! I guess he saw the boat at Boat Doc's...as they are both in Fox Lake :)
I was able to pick up a new OEM OMC System Check Tach and Speedo on EBAy for $70 shipped. The Tach alone goes for $160+ so I saved a few bucks there. I am taking pics along the way which I will put together somewhere when complete. While waiting for the bracket and engine install I am restoring most of the wood. I found the forum discussion on the "Wood Care" reference article as well as the article itself a big help.
Getting closer...
Billymac
Plotman posted 06-15-2004 04:44 PM ET (US)     Profile for Plotman  Send Email to Plotman
Have you decided on a bracket to use?
