  Power Curve for Two-Stroke-Cycle and Four-Stroke-Cycle Outboard Engines
Author Topic:   Power Curve for Two-Stroke-Cycle and Four-Stroke-Cycle Outboard Engines
jimh posted 08-17-2013 01:14 AM ET (US)   Profile for jimh   Send Email to jimh
[This topic has been separated from another discussion so as to not completely change the topic of that discussion. This new topic is now presented here as its own topic.
silentpardner posted 08-14-2013 03:35 PM ET (US)     Profile for silentpardner  Send Email to silentpardner
[Quotes jimh as having said:]
"It is also seen that engines of four-stroke-cycle design must reach very close to their maximum rated engine speed to develop their rated horsepower, while two-stroke-cycle engine tends to be able to develop their rated horsepower at lower engines speeds and to deliver that horsepower over a wider range of engines speeds."
AHEM!
I cannot find ANY data ANYWHERE that supports this statement. All manufacturer's that I have researched, including Evinrude, list the horsepower of their engines at as a function of their engine's RPM at WOT. Please enlighten me with evidence if I have failed in my research.
Remember, horsepower and torque are two entirely different measurements. I have never seen a Dyno report showing rated horsepower of an entire stock line of 2-strokes being achieved before WOT, nor have I seen the same anomaly in the 4-stroke Dyno reports. I would certainly assume that if any outboard engine manufacturer was able to achieve this fantastic result, they would certainly advertise this and it would not be hard for me to locate on the internet...or for that matter, see on large billboards across the country.
Commander Coo1 posted 08-16-2013 04:08 PM ET (US)     Profile for Commander Coo1  Send Email to Commander Coo1
silentpardner,
i have two images here that i have found on the web from a quick search that show the power and torque curves of a 2 stroke vs a 4 stroke 150hp modern outboard motor. This is probably some of what jimh uses to come to the conclusion that a 2stroke raches peak power earlier (around 4500 rpms) the the 4 stroke (around 5500 rpms) I am not sure who collected the data or how it was collected.
[Links to some unknown person's website hosting images created by jimh have been deleted.--jimh]
silentpardner posted 08-16-2013 06:23 PM ET (US)     Profile for silentpardner  Send Email to silentpardner
The only chart there that purports to show anything about HP indicates that a 150HP E-Tec reaches 165 HP at 4500 RPM. You are just posting that in jest, right? I am not real smart, sometimes sophisticated humor goes right over my head, I apologize.
jimh posted 08-17-2013 01:02 AM ET (US)     Profile for jimh  Send Email to jimh
The power curves of two-stroke-cycle and four-stroke-cycle outboard engines are shown in
http://continuouswave.com/whaler/reference/graphics/150-HP_Engines.png
which is a graph I created based on some published data for engine horsepower as a function of crankshaft rotation speed. I believe the data is representative of the general characteristics of the outboard engines described. One of the links given (above) to some other person's website that has that same image is apparently someone who stole the image from my website and is hosting it on his website without any sort of attribution to the source.
The graph I created appears as an illustration in an a copyrighted article I wrote about propeller power curves. That article appears at
Propeller Power Curve
http://continuouswave.com/whaler/reference/propellerPowerCurve.html
Please note that there is another thread which is intended as a follow-up thread for discussion of the propeller curve article. That thread is available at
http://continuouswave.com/ubb/Forum4/HTML/005903.html
The other graph at the other person's website is also a graphic from CONTINUOUSWAVE. It appears at
http://continuouswave.com/whaler/reference/graphics/torqueGraphETEC.jpg
and is linked from an article I wrote several years ago:
Bombardier Publishes Torque Curves
http://continuouswave.com/ubb/Forum4/HTML/004627.html
The data in the graph was taken at the Ralph Evinrude Test Center in 2007, testing an Evinrude 150-HP E-TEC, and a 2006 Yamaha 150-HP four-stroke using a dynometer.
If you have contradictory data that has been published by manufacturers of outboard engines regarding the nature of their power output as a function of their crankshaft rotational speed, you should give us a chance to see your data so we can learn from it that my characterization of the difference between two-stroke-cycle engines and four-stroke-cycle engines is not correct. My characterization is based on my experience with operating the engines and data such as I mention above. You might also give us your basis for declaring my characterization to be incorrect.
jimh posted 08-17-2013 01:32 AM ET (US)     Profile for jimh  Send Email to jimh
Evinrude's published data about the horsepower of their 150-HP E-TEC is completely congruent with the information in the graph I have drawn (see above). The specified crankshaft speed for the rated horsepower is exactly in the middle of the range of 5,300 to 6,000-RPM which is stated as the wide-open-throttle operating range. The inference, supported by the data in the graph, is that the engine produces the rated power (or more) over that entire range. I don't see anything contradictory about Evinrude's statement from the data in my graph. Of course, that is completely expected because Evinrude is also the source of the data in my graph. I believe that this completely disqualifies the criticism that my statement is in opposition to Evinrude's own statements. My statement is in complete agreement with Evinrude, the exact opposite of what is claimed by my critic.
silentpardner posted 08-17-2013 02:06 AM ET (US)     Profile for silentpardner  Send Email to silentpardner
I am sorry, apparently this got moved as I was typing my reply in the other forum...here it is here:
Jimh, Look at that chart you show here :
Along the left side of this chart we are shown HP, the bottom line is RPM. Look at that E-tec line. It clearly shows the 150HP E-Tec at 165 HP with RPM at 4500. Surely you don't actually believe this to be true?
Exactly where did BRP post any data saying this was true? Please link this, I am unable to find this ANYWHERE in my own research.
Just like I originally asked, PLEASE POST A LINK TO ANY OFFICIAL BRP STATEMENT SUPPORTING THIS CHART'S CLAIM, OR YOUR OWN BELIEF, THAT A 150 HP E-Tec MAKES 165 HP at 4500 RPM.
I know the E-Tec's are great motors, especially the 150 HP model, they have a fantastic torque curve, but I have never heard ANYONE claim they made 165HP at 4500 RPM until now. I still haven't seen a SINGLE shred of evidence from any outside source other than YOUR article that supports this. If it's true, there HAS to be some BRP data that clearly states this. Where is it?
There is a big difference in what a person believes and what is scientific fact. If a "belief" is all this fantastic HP is based on, well, I guess it's your right to "believe" anything you like, we have freedom of religion in our country. If you can support this fantastic claim with fact, I'll be the first to join your Church of the E-Tec. I see where you just posted the fact of HP being rated by BRP at a set RPM...and THAT SURE DOESN'T SUPPORT 165HP AT 4500RPM...
I believe you know the difference between Horsepower and Torque curves.
I refuse to argue with you about this subject, or any other, and I did not intend to argue with you in the first reply to your claims. I simply asked you to show me where the engine manufacturer had supplied any data supporting your statement. I still have not seen any.
Peter posted 08-17-2013 09:04 AM ET (US)     Profile for Peter  Send Email to Peter
and
See the powercurve plot on page 4, 2008 E-TEC brochure at www.vogt-kappeln.de/motoren/images_johnson_evinrude/evinrude_2008.pdf .
HP is simply a mathematical solution derived from the formula
HP = Torque x RPM รท 5252
where torque and RPM are measured. There is a direct mathematical relationship between torque and HP.
jimh posted 08-17-2013 10:33 AM ET (US)     Profile for jimh  Send Email to jimh
I don't know where the information on the chart happens to reside on the web at this moment. I don't know that it ever was on the web. The information was published by BRP in some literature or handout I read.
As for whether or not I believe it, I think that answer is obvious. Yes, I believe it. Why wouldn't I believe it? This information is just like any other information provided by a manufacturer. For example, Evinrude says their 150-HP E-TEC engine weighs a certain amount. That is how much I believe it weighs. They say it has a certain displacement. This how much displacement I believe it has.
I am not certain why one would expect to not believe a manufacturer's statement, and, instead, to prefer to believe something completely opposite. Can you explain why it would be preferred to not believe data from a manufacturer and instead to believe something completely contradictory, and on what basis one ought to prefer to believe something that completely contradicts a manufacturer's published statement or literature? I realize that this is a new topic, and is not the topic of the power curve of two-stroke-cycle and four-stroke-cycle engines, but because of unwillingness of some to accept data from a manufacturer, I think this is a very corollary topic.
jimh posted 08-17-2013 10:49 AM ET (US)     Profile for jimh  Send Email to jimh
Publication by manufacturers of graphics showing horsepower or torque output of their outboard engines seems to be something that is not commonly done. I don't quite understand the reluctance of engine manufacturers to provide this information, but I have seen examples of their reluctance. The best example I recall was from Mercury. While the Project-X engine was in development--the engine which ultimately became the VERADO--the CEO of Brunswick met with investors to give information about Brunswick and its plans for the future. The CEO explained to investors the significance of their product development of the Project-X engine and how it was anticipated to be very successful. The presentation was made in person to investors attending a meeting, and investors were shown slides and graphs to support claims being made about the Project-X engine. When this presentation was being made, one could dial in to a telephone line and listen to the presentation. Later, the presentation was presented in a recording and made available on the internet.
In the presentation the topic of the power or torque output of the Project-X engine was raised by the CEO. The CEO informed investors that the Project-X engine would have unusual characteristics. The engine would be able to produce a wide band of power and torque, which the CEO characterized as being unusual characteristics for a four-stroke-cycle engines but characteristics that would match those of two-stroke-cycle engines. To convey this to those present at the meeting, a slide or graphic was shown that presented the power output of the Project-X engine compared to competitors' four-stroke-cycle engines.
A most curious thing happened when the presentation was prepared for distribution on the internet: the slide showing the power or torque output was omitted from the internet presentation package.
The above incident is the basis for my impression that some manufacturers are reluctant to publish information about the power output of their engines in a graphic that shows the power output as a function of crankshaft rotation speed. Further, the general lack of this information being published also tends to solidify my belief that manufacturers are reluctant to publish this information. However, when one manufacturer does publish this information, I am inclined to accept the information they provide as accurate.
Marko888 posted 08-17-2013 11:11 AM ET (US)     Profile for Marko888
Although I strongly agree that 2 strokes have a significant performance advantage when compared to an equal displacement 4 stroke, and agree the curves in the Evinrude graphs do vaguely illustrate the torque and HP characteristics, I highly doubt the graphs represent an accurate output comparison between these two 150's.
Until we can view a graph of the output prepared by a completely independent and unbiased body, I would consider this to require the "beware marketing" caveat.
jimh posted 08-17-2013 12:11 PM ET (US)     Profile for jimh  Send Email to jimh
It is just human nature to be skeptical of data which contradicts prior beliefs, and to be willing to accept data which reinforces currently held beliefs.
If Mercury, Yamaha, Suzuki, Honda, or Tohatsu have published graphs or tabular data that show the power output as a function of crankshaft rotation speed, I would be interested to learn of that data and to see it. However, the notion that they have not, and that Evinrude has, does not make me inclined to completely discard the information Evinrude provides.
It seems to go without saying that a manufacturer would tend to only release data which presented his product in a favorable manner. A corollary might be that manufacturers are reluctant to release data which presents their product in an unfavorable manner. One could speculate that this accounts for the omission of data about engine power or torque shown as a function or curve of engine speed by certain manufacturers.
The least-biased testing data that I know of is the data provided to the EPA for engine certification. Yet, even that data is routinely considered to be unreliable by skeptics for whom the data does reinforce their prior beliefs.
Regarding whether or not manufacturer test data can be believed, that topic was the topic of another discussion, found at
Suspicion of False Testing by Mercury and Yamaha
http://continuouswave.com/ubb/Forum4/HTML/007931.html
jharrell posted 08-17-2013 03:17 PM ET (US)     Profile for jharrell
Why would anyone prop an E-TEC such that it went above 4500 rpm? Why does Evinrude recommend 5300-6000 rpm when the engine is clearly most efficient at 4500 rpm (highest power with less fuel usage) ?
The graphic that shows the E-TEC 150 torque curve clearly shows more than 195 lb ft of torque at 4500 rpm, this would be 167 HP.
According to Crouch's calculator a Outrage 18 should achieve 46 MPH with an E-TEC 150 @ 4500 rpm using 2500lbs weight and 180 hull factor. The propeller calculator shows you would need a 22 in prop to achieve this.
Has anyone propped their E-TEC 150 to max out at 4500 rpm and observed it propels their boat to a higher top speed than the recommended rpm thereby verifying the higher power output?
silentpardner posted 08-17-2013 04:02 PM ET (US)     Profile for silentpardner  Send Email to silentpardner
Now THAT would be a real test. I think the author of the aforementioned study actually owns one of these E-Tecs. Maybe he can perform this experiment for all of us with his own motor and boat.
Excellent idea jharrell!!
Since the author's boat is losing 15-17 HP after exceeding it's 4500 max HP, I am sure the re-propping will GREATLY improve the efficiency of this setup.
Peter posted 08-17-2013 07:30 PM ET (US)     Profile for Peter  Send Email to Peter
quote:
Why would anyone prop an E-TEC such that it went above 4500 rpm? Why does Evinrude recommend 5300-6000 rpm when the engine is clearly most efficient at 4500 rpm (highest power with less fuel usage)[ ?
Where do you find any information that says 4500 RPM is the most efficient for producing maximum HP?
The power curve simply says that that the E-TEC 150 is capable of processing enough fuel and air at 4500 RPM if forced to do so as to produce 165 HP. It says nothing about whether that is an efficient RPM for doing so. More particularly, the power curve is not saying that it will make 165 HP while only using 10.5 GPH (typical fuel consumption when the load allows 5600 RPM at WOT).
Marko888 posted 08-17-2013 10:07 PM ET (US)     Profile for Marko888
I do not feel disalusioned about any of the percieved facts noted above...I just don't blindly believe everything I read on outboard engine brochures.
The same brochure that contains the dyno graph, lists the e-tec 150's max HP output at 5350 RPM. The graph has been tweaked by the marketing department...
BTW, I am an E-TEC fan, and am likely to buy a 150, but suspect only the 150 HO is actually a 165hp engine.
jharrell posted 08-18-2013 12:22 AM ET (US)     Profile for jharrell
The typical method for getting an engines power/torque curve on a dyno is constant speed at WOT. I made the assumption that since the throttle is held constant that the same amount of fuel is being delivered at all RPM test points. Therefore given the most power is generated at 4500 RPM from a steady throttle, that by definition makes it the most efficient engine speed for that throttle position assuming throttle=fuel delivery and therefore the most efficient point on the graph.
Are you suggesting the E-TEC EMM supplied more fuel at 4500 than at higher points given the same throttle position? That would be surprising.
Regardless of the efficiency claim, it can not be disputed that it should go faster at 4500 RPM than at recommended RPM since it produces maximum power there, correct? This should allow easy verification by propping one for 4500.
jimh posted 08-18-2013 12:50 AM ET (US)     Profile for jimh  Send Email to jimh
Apparently some participants need to read my article on propeller power curves in order to answer their own questions. Many times propellers are selected so as to give a generous margin between power available and power needed by the propeller. When this occurs there is the possibility of rapid acceleration. Rapid acceleration is a quality that is often admired in boats.
Again, I invite anyone who has information about the power output of an outboard engine as a function of its rotational speed to contribute the data. So far all I see is people suggesting that data from Evinrude is to be treated as unreliable, simply on the basis of it being provided by Evinrude. In the total absence of any other source of data, how do people arrive at the conclusion that the Evinrude data is in error?
jharrell posted 08-18-2013 10:31 AM ET (US)     Profile for jharrell
It would seem to me given the E-TEC's far superior torque and power throughout the band, if it where propped such that it's max RPM where 4500 rpm, it would have similar if not still superior acceleration as it's 4-stroke counterparts while having a higher top speed than if it where propped to attain recommended max RPM. Would this not be desirable to some users?
Also in your propeller power curve article you state:
quote:
If a propeller with greater pitch were used, its power curve would increase more rapidly, and it would rise to meet the engine power sooner. This would result in a lower maximum RPM for the engine. The general effect would be to reduce the shaded area of the curve where the engine has excess power. This will improve the fuel economy (because turning a higher pitch propeller tends to always improve the fuel economy)
This seems to confirm my maximum efficiency claim that was disputed.
I am also suggesting given the warranted skepticism when a manufacturer claims their engine produces 10% more power than rated and at a lower than max RPM, that a simple verification could settle the matter. Perhaps someone could be loaned a prop to verify the E-TEC 150 in fact produces max power at 4500 rpm, they might even like the higher top speed and better fuel economy!
jimh posted 08-18-2013 10:53 AM ET (US)     Profile for jimh  Send Email to jimh
The topic here is the general nature of two-stroke-cycle and four-stroke-cycle engine power output. If you want to have a discussion about how propeller load and propeller pitch can affect engine performance, please start a new thread.
I am still awaiting any pointers or URL's for information about the power output curve of four-stroke-cycle engines which would provide something contradictory to my initial statement, which is claimed by one critic to be in error.
To get back to the power output of a four-stroke-cycle engine, we see that modern four-stroke-cycle engines are using a variety of methods to try to widen their power output range. These methods include:
--use of much larger displacement engines to obtain equivalent horsepower;
--use of variable valve timing and cam phasing to alter the engine characteristics across the engine speed range; and,
--use of boosted air induction, either with supercharging or turbo-charging, to improve power output.
When Brunswick was developing their Project-X engine, they told the same story, over and over, that their goal was to be able to provide the same performance as a two-stroke-cycle engine in this new four-stroke-cycle engines. Brunswick said that in order to obtain the same kind of performance as a two-stroke-cycle engine, their Project-X four-stroke-engine had to employ a supercharger to boost the power output of the engine. Brunswick spent a reported $100-million in development of the Project-X engine, which became the VERADO.
Now, if we are to believe some of the boaters participating here, the use of a supercharger was not needed. Some boaters here are suggesting that any sort of notion of a two-stroke-cycle engine having a wider power output range than a four-stroke-cycle engines is incorrect. It seems odd that Brunswick would spend $200-million developing a supercharged four-stroke-cycle engine that could have the same performance as a two-stroke-cycle engine, it there really was no need for that.
It is clear to anyone who has driven a boat with one of the early generation four-stroke-cycle engines, that is, four-stroke-cycle engines without supercharging or without elaborate variable valve timing and cam phasing, that the performance of a conventional four-stroke-cycle outboard engine is not nearly as good as a two-stroke-cycle engine of the same horsepower and displacement. This is such a widely known and widely experienced fact that I can hardly imagine we could have an argument about it.
The outboard engine manufacturers know it. Why else would they have been working on new generations of four-stroke-cycle engines which use supercharging, variable valve timing and cam phasing, or extremely large displacement to try to compensate for the lack of performance of the conventional four-stroke-cycle engine?
Four-stroke-cycle outboard engines today are approaching the performance of two-stroke-cycle engines by using advanced methods like supercharging and variable valve timing. In contrast, two-stroke-cycle engines continue to deliver superior power output while retaining their simple fixed-port designs. Whether or not modern four-stroke-cycle engines have reached the same performance as two-stroke-cycle engines might be best demonstrated by publishing of a power or torque curve for these engines. I would very much like to see one.
pcrussell50 posted 08-22-2013 12:24 PM ET (US)     Profile for pcrussell50  Send Email to pcrussell50
Isn't the 150-HP E-TEC also the same 2.6-liter motor as the 2.6-liter E-TEC 200-HP? If so, it should be no surprise that the 150hp version is very stout indeed for a 150... Probably right at the 10% "limit" we keep hearing about. As such it is no surprise to me that it might pull 165hp at a lowish 4500 rpm.
-Peter
jimh posted 08-22-2013 04:46 PM ET (US)     Profile for jimh  Send Email to jimh
Yes, the 150-HP model and the 200 H.P. model are built on the same 2.6-liter block. I don't know for certain if there are any physical differences between them. Many people speculate about that sort of thing.
R DAVIS posted 08-22-2013 05:50 PM ET (US)     Profile for R DAVIS  Send Email to R DAVIS
What I've not seen addressed here is the length of time it takes these various engines to REACH the RPM level for maximum thrust output (be it torque or horsepower). To some degree it is propeller dependent, however THAT is still dependent on power (horse and / or torque).
Here in the shallow bays of south Texas, getting a boat up on plane quickly, in the shortest distance is not only important, it is imperative. Uprooting seagrass is a crime in certain areas, and come September 1, 2013 it will be a crime state wide, in saltwater.
While it is legal to uproot seagrass with an anchor or electric trolling motor, or as necessary to get a boat up on plane, it is important to minimize damage by planning as quickly as possible. I've owned several larger (22 - 23 ft. center console bay boats) all 2 stroke cycle powered, with power jackplate and trim tabs, which would get completely on plane in an honest 2 or 3 boat lengths. I doubt any 4 stroke cycle motors would accelerate quickly enough to accomplish that.
My current boat is a little 1982 Boston Whaler Sport 15, with power trim / tilt, but no jackplate or tabs. It is powered by a 1983 Johnson 50 HP with a deeply cupped 15 in. pitch prop. This boat will jump up on plane in it's own one boat length, even when heavily loaded. My top end speed is 32 MPH, which is quite sufficient for my needs, and the hole shot is so quick it's startling.
If I ever have to replace this old motor I will be looking for another 2 stroke of 50 to 60 HP.
I'm not putting down 4 stroke cycle motors, but for my needs, it would be lacking.
For the curious, my rig can be seen at: [url]http://k5rcd.org/Whaler%202.htm [url/]
jimh posted 08-22-2013 07:15 PM ET (US)     Profile for jimh  Send Email to jimh
quote:
To some degree [the ability of the engine to accelerate] is propeller dependent, however that is still dependent on power (horse and torque).
The ability of any engine to accelerate its crankshaft speed is dependent on the load. The lighter the load, the more easily the engine can accelerate. In propelling a boat with a propeller, the propeller determines a great deal of the characteristics of the load.
R DAVIS posted 08-23-2013 01:44 PM ET (US)     Profile for R DAVIS  Send Email to R DAVIS
I suspect a two stroke cycle engine has an acceleration advantage, since every second stroke produces power as opposed to every 4th stroke.
I am concerned here only with initial acceleration to quickly lift a boat onto plane, and not really with acceleration or power production beyond that point.
Russ 13 posted 09-01-2013 03:06 PM ET (US)     Profile for Russ 13  Send Email to Russ 13
R.Davis IF you ever have to repower the Yamaha 90 two stroke
is roughly the same weight as a 70 Hp. The hole shot w/ a 17P stainless prop is INSTANT...HANG ON!
Not to derail the thread, in actual use the power to weight performance of a two stroke far exceeds a four stroke...
Thus the supercharging & variable valve timing tech. added
to several four stroke engine brands...
