  1988 Montauk with E-TEC 90
Author Topic:   1988 Montauk with E-TEC 90
divtruk posted 09-15-2011 11:40 PM ET (US)   Profile for divtruk   Send Email to divtruk
I was able to spend some time yesterday morning on Lake San Antonio in southern Monterey county. I was playing with different height settings on the jackplate on my Mountauk. I also did a comparison of the SS Stiletto 13-1/4”x15 prop vs. the stock Evinrude aluminum 13-3/4”x15 prop. I started with the jackplate set at 2-1/2” above the bottom of the hull based on input from others here on this site. I tried settings slightly below and above that mark.
Bear in mind that all these numbers have some error factor. I was getting RPM numbers from an analog tach and that it’s sometimes hard to set the throttle exactly on a number. The fuel flow numbers tend to jump around during a run so I was writing down what looked like an average number on the display.
After the third change of the jackplate height I got bored and wanted to have some fun so I stopped testing and went exploring. Spotted a beautiful pair of Golden eagles perched on a tree over by the dam.
1988 Montauk
Rite-Hite 5” Jackplate
2006 Etec 90 hp Motor
1 Person (195 lbs)
Approx 18 gallons of fuel
Water Temp was 74 degrees
Wind was 5-10 mph dying off later in the morning.
These numbers are an average of two runs. One upwind and one downwind. Speeds are from the GPS and fuel consumption (gallons per hour) was from the Lowrance EP-60R fuel flow sensor. All these runs were with the engine trim in neutral. The cavitation plate was set parallel to the bottom of the hull. The final top speed numbers were obtained by playing with the trim for top speed. (trimmed way up)
Jackplate set at 2-1/4” above the bottom of the hull. Stiletto 13-1/4”x15 prop
1500 rpm 6.3 mph 1.0 gph
2500 rpm 15 mph 2.2 gph
3500 rpm 27 mph 4.0 gph
4500 rpm 35.4 mph 6.8 gph
4900 rpm (WOT) 38.1 mph 8.3 gph
Top Speed was 39.7 mph at 5300 rpm with motor trimmed up.
Jackplate set at 2-1/2” above the bottom of the hull. Stiletto 13-1/4”x15 prop
1500 rpm 6.6 mph 1.26 gph
2500 rpm 15 mph 2.25 gph
3500 rpm 26.5 mph 4.44 gph
4500 rpm 34.7 mph 7.0 gph
4900 rpm (WOT) 38.3 mph 8.46 gph
Top Speed was 41.5 mph at 5400 rpm with motor trimmed up.
Jackplate set at 2-3/4” above the bottom of the hull. Stiletto 13-1/4”x15 prop
1500 rpm 6.3 mph 0.95 gph
2500 rpm 15 mph 2.39 gph
3500 rpm 26.6 mph 4.07 gph
4500 rpm 35.3 mph 6.85 gph
4900 rpm (WOT) 38.2 mph 8.4 gph
Top Speed was 40.8 mph at 5300 rpm with motor trimmed up.
Jackplate set at 2-1/2” above the bottom of the hull. Evinrude Aluminum 13-3/4”x15 prop
1500 rpm 6.5 mph 1.2 gph
2500 rpm 14.5 mph 2.08 gph
3500 rpm 24.1 mph 3.84 gph
4500 rpm 32.4 mph 6.36 gph
5100 rpm (WOT) 36.2 mph 8.20 gph
Top Speed was 38.5 mph at 5400 rpm with motor trimmed up.
dgoodhue posted 09-16-2011 06:37 AM ET (US)     Profile for dgoodhue  Send Email to dgoodhue
2 1/2 seems low for a jackplate. My 5" setback jackplate is set at 4" above the keel with a stiletto (3 1/4" for a OMC sst) prop. I have a classic 15' hull so I know that can be apple and orange comparison. That being said if your Aluminum prop can handle atleast a 2.5" height, your Stilletto will handle atleast a 3.25" ride height.
jimh posted 09-16-2011 09:05 AM ET (US)     Profile for jimh  Send Email to jimh
I am surprised that a change in engine height of 0.25-inch produced a 1.8-MPH improvement in speed. That is quite a nice speed improvement. I guess when racers talk about "dialing-in" their engine mounting height, that is what they mean.
Tohsgib posted 09-16-2011 11:35 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
My Montauk setup was 4.5" above the keel. I doubt it did much more in performance than 2.5 but it allowed me to run 2" skinnier which is a lot by me.
Tom W Clark posted 09-17-2011 02:06 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
I agree that you have probably not yet begun to find the best height for that motor. It can go higher, though you will loose the ability to run the aluminum prop at some point.
I do note, however, that it amazing what a difference the stainless steel Stiletto makes over the OEM aluminum prop of the same pitch.
Same WOT engine speed, 5400 RPM, but 41.5 MPH vs. 38.5 MPH. That is a 9 percent increase in speed right there with nothing but a simple change of prop.
divtruk posted 09-18-2011 01:39 PM ET (US)     Profile for divtruk  Send Email to divtruk
I doubt I will do any more testing or adjustment. It was more out of curiosity than anything. Another mile per hour is going to make no difference to me. 90% of my boating is on Monterey Bay and the chances of having flat enough days to go WOT are few and far between. It was a fun excercise to see the difference between the aluminum and SS.
L H G posted 09-19-2011 03:14 AM ET (US)     Profile for L H G
It[']s interesting to once again read that a small cube E-TEC 90 on a Montauk will only do 41.5-MPH jacked up and with a good SS performance propeller. If anybody here thinks that engine is putting out 90-HP at the prop, I've got a bridge to sell you. Sounds more like about 82-HP to me.
Haven't we seen reports here that a Suzuki 70 will do 39-MPH on a Montauk?
jimh posted 09-19-2011 08:24 AM ET (US)     Profile for jimh  Send Email to jimh
Larry--Please contact me via email with your offer on the bridge. Thank you.
jimh posted 09-19-2011 09:24 AM ET (US)     Profile for jimh  Send Email to jimh
I don't think that all outboard engine purchases are made on the basis of whether or not the particular engine can produce the highest boat speed among all engines with a cowling decal of the same figure. Some people are interesting in other aspects of engine ownership and engine operating besides reaching the absolutely fastest boat speed with an engine of a particular horsepower rating.
When discussing boat speed, we also see many factors influence. For example, as noted by Tom Clark, a very substantial change in boat speed was produced by a change in the propeller material to stainless steel from aluminum. The boat went 3-MPH faster with a propeller change. The engine was still making the same horsepower.
And we know that on a small boat like a MONTAUK 17 there can be considerable influence from weight. An extra 200-lbs might take off 1-MPH, or some such relationship.
I think Larry should also explain the method by which his is able to deduce the horsepower of the E-TEC by reading reports about its performance on a particular boat. I would like to be able to develop a calibration method whereby when someone tells me a motor of a particular horsepower on their boat produces a particular speed, that I could then tell them the exact horsepower the motor was producing.
prj posted 09-19-2011 09:31 AM ET (US)     Profile for prj  Send Email to prj
[Said E-TEC motors lacked horsepower.]
jimh posted 09-19-2011 10:59 AM ET (US)     Profile for jimh  Send Email to jimh
My own experience with the E-TEC outboard engine contradicts the theory put forth by prj. When I replaced my existing motor with an E-TEC of the same rated horsepower, my maximum boat speed increased. Also, a great number of other things increased, too, such as my fuel economy.
I am not sure it is possible to make broad statements about the E-TEC horsepower as have been proposed here which will be accurate in all cases.
I do note that there is a lot of folk lore about engine power and engine decals, and I would hate to lose that important part of our boating history.
Tohsgib posted 09-19-2011 12:58 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
41.5 is what my Montauk would do with bottom paint, mounted on transom and a painted SS Yamaha prop on a 90hp Yamaha. My 88SPL would do about 43.5. My 70 would do 39.5 so yes I would agree with LHG that this engine is below 90hp or that most older engines were above 90hp. I am not sure if Len has broken 40 with his 90 E-Tec Montauk. Tons of torque off the line and midrange but it just peters out...sad...so sad.
L H G posted 09-19-2011 04:07 PM ET (US)     Profile for L H G
Jim - With the Yamaha 2-stroke 90 also running the same top end as the Evinrude E-tec 90 reported here, remember that Tom Clark pointed out to us that Yamaha shows that engine as an actual 82 or 83HP.
Thank you Nick for your report of actual experiences with various Montauk power.
I think Jeff has reported that his Dad's Montauk ran 47 MPH with a Mercury 2-stroke 90 "Tower", and I remember Rob Schmidt saying he got smoked in his 90 E-tec powered Montauk by a Montauk running a Merc 90 tower. Several people have reported their Montauks ran 44 MPH with an OMC V-4 2-stroke 90.
It seems to me that a really smart choice of E-tec for a Montauk would be the 75, for less money. I'll bet it is very close in top end speed to the 90.
jimh posted 09-19-2011 06:16 PM ET (US)     Profile for jimh  Send Email to jimh
I hate to bust up the dock talk, but on the EPA website the certification data for all marine outboard spark ignition engines is available. Using the listing for September 2010, I find the E-TEC 90-HP listed with a measured power of 66.19-kW at 5,000-RPM. In horsepower that becomes 88.8-HP.
Given the choice of seat-of-L H G's-pants estimate of the horsepower based on his personal interpretation of anecdotal boat speed data, or the EPA certificate of compliance, I put more faith on the dynamometer test data. The E-TEC 90-HP engine produces 88.8-HP at the propeller as tested on a dynamometer.
Are there perhaps other outboard engines that produce more than 88.8-HP at the propeller and also have a cowling decal that says "90"? Perhaps there are. You can look for them in the EPA test data if you are curious about them. I am not.
I found a listing for my E-TEC 225-HP engine. It shows 165.49-kW or 222-HP.
ratherwhalering posted 09-19-2011 06:24 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
Larry, did you just compliment a Stilletto propeller?!?!
quote:
with a good SS performance propeller...
NOW I have seen everything.
ratherwhalering posted 09-19-2011 06:30 PM ET (US)     Profile for ratherwhalering  Send Email to ratherwhalering
...and I believe the term I used was smoked out by that Merc 90 2-stroke ;-)
prj posted 09-19-2011 06:59 PM ET (US)     Profile for prj  Send Email to prj
[Repeated his personal opinion that E-TEC engines lack horsepower.]
jharrell posted 09-19-2011 07:08 PM ET (US)     Profile for jharrell
My old inline Merc 90 tower came to me mounted all the way down on the transom on my classic Montauk and did 39 mph, I added a jack plate, raised it and now it does 43mph. This with an old cavitation pited quicksilver 19p and rough paint on the lower unit. I bet it could hit 44-45 with a new prop and cleanup up LU paint.
The E-TEC easily doubles the gas mileage of my tower but is seems to lack somewhat in top speed.
Based on first hand experience by Tohsgib with his Suzuki 70, and boat test reports of the the E-TEC 90 and Suzuki 90, it seems Suzuki's have better top speed for whatever reason.
Jeff posted 09-19-2011 07:54 PM ET (US)     Profile for Jeff  Send Email to Jeff
Larry, we were paced by Buckda running across Mullett Lake at 47 - 49 mph. He had the GPS on his 18 Outrage with the Merc 150 WOT and we ran side by side. He had 50-51 showing on his GPS and only gained about 1/2 a boat length over about a minute run. That was turning an aluminum Quicksilver prop and the motor was likely one hole too low.
http://smg.photobucket.com/albums/v427/jeff_rohlfing/dads%20whaler/ ?action=view¤t=IMGP2289.jpg
That said, you now have the right boat to get real numbers on a 17 Montauk powered by a 90hp Merc inline 6 with a good stainless prop and set at the right height. Be sure to get it on video to quiet most nay-sayers..
My 17 Newport with it's 1794 85hp (powerhead rated) Evinrude Starflite V4 turning an OMC SST 13 3/8" x 17" prop actually managed to show 41 mph for a run this past August. It's a solid 40 mph on any given day and it is still mounted 2 holes lower than it should be. See the video
http://www.youtube.com/watch?v=DCO2INErDUk
I think many here are missing the obvious...It is likely not about the horsepower but actually torque. The 90hp E-Tec could very well be putting out 90hp at the prop but, could have a great deal less torque at WOT that the earlier V4's and of course the mercury I6's. I have always maintained that horsepower figures for outboards have far to much weight put on them. I personally would want to see a torque output for a given motor over it's horsepower plot from a dyno if I was comparing outboards. Especially if I was considering a motor for repowering.
WT posted 09-19-2011 08:21 PM ET (US)     Profile for WT  Send Email to WT
sosmerc just installed a new Mercury 90 hp FourStroke (Veradito) on a classic Montauk. I hope he can get us some performance numbers after he gets back from vacation this week.
Warren
Jeff posted 09-19-2011 08:33 PM ET (US)     Profile for Jeff  Send Email to Jeff
1794 = 1974...sorry
jharrell posted 09-19-2011 10:08 PM ET (US)     Profile for jharrell
Sorry Jeff top speed is all about power, measured here in horsepower. The relationship between torque and horsepower is well known as follows: torque X RPM / 5252
So you can derive the torque of the motor quite easily if you know it's power output at a given RPM.
So if the E-TEC is doing 88.8 HP at 5000 then it's putting out 93.27 lbf-ft of torque.
So you see torque is nothing without RPM, put them together and you have the measurement we call horsepower. In fact dynamometer doesn't measure HP directly, just like a speedo doesn't measure speed directly. It measures torque and rpm to derive HP.
The simple fact is the Merc inline 6 has more peak HP than an E-TEC it seems.
jharrell posted 09-19-2011 10:11 PM ET (US)     Profile for jharrell
Here is a link to Wolfram Alpha to calculate torque from HP and RPM if you want to try different engines/values: http://www.wolframalpha.com/input/?i=88.8hp+to+torque& a=FSelect_**BrakingTorque-.RotationalPower.TorsionFormula-& a=*FS-_**BrakingTorque.T-.*BrakingTorque.S--&f3=5000+rpm& f=BrakingTorque.S_5000+rpm
jimh posted 09-19-2011 10:41 PM ET (US)     Profile for jimh  Send Email to jimh
The old fairy tales about engines with plenty of extra horsepower than shown on their cowling decal are over, due to the EPA and emission limits. An engine is granted a certain amount of emission based on its power output. You can't meet EPA ULTRA LOW emission with an engine that is allowed only the emission level of a 90-HP and then get 120-HP output. Modern engines make the horsepower they show on their cowling decals, and that is about it. Show me the EPA test data on another modern engine with "90" on the cowling. I'd be interested to see what it did on the dynamometer.
I know there is some fun and plenty of nostalgia in maintaining and running an old two-cycle with 1960's technology and 1970's parts. And considering how much gas they're burning it might very well be that some of the larger displacement engines with "90" on the cowling will crank out a few extra hosepower. However, I don't see them as any sort of competition to the E-TEC 90.
The E-TEC 90 is without much debate the best choice for re-power of a MONTAUK. You just have to ask the 100 or so people who have written about their re-power with the E-TEC, and you find just about all of them completely happy.
I do have to give Larry some credit for persistence. Every time someone mentions another MONTAUK that has been re-powered with an E-TEC--and what is this one, perhaps number 101?-- he tries to turn the discussion into a debate about the power output of the E-TEC. There is no real debate. The EPA has all the data. Look up any engine you like.
OK, back to the Mercury commercial. Maybe we're gonna get the pitch about the OptiMax 90 next.
jharrell posted 09-19-2011 11:21 PM ET (US)     Profile for jharrell
The EPA data certainly looks useful, however when browsing it there is an odd pattern, 90hp from BRP, Mecury, and Suzuki all have exactly 66.19kW or 88.8 HP at either 5000 or 5500 rpm. If these where truly dyno-tested you would normally some at least small variation in max HP between such different engines.
If you sort the spreadsheets by power you will see this trend across all engines, those in the same hp bracket having many times the exact same power to the 1/100th kW between various manufacturers.
Is there any information on how the EPA obtains these power numbers?
Jeff posted 09-20-2011 12:02 AM ET (US)     Profile for Jeff  Send Email to Jeff
J - The Horsepower vs Torque debate is an old one that can go in circles without a winner.
"Horsepower sells cars, torque wins races." -Enzo Ferrari. Yes, that is related to cars, yes cars have many gears, and have many acceleration cycles during a race....Still more torque will turn larger gears and taller pitched propellers at the same Horsepower and RPM range netting is a higher top speed.
I stated my opinion that torque is a forgotten factor in these debates. Can ANYONE provide real Horsepower AND Torque plots for the E-Tec 90, or any other "90" horsepower motor discussed in these __ Whaler powered by __ motor threads? Independent dyno plots would be the best and most objective looks at product to product comparisons as I am sure Outboard manufactures play the same "published" numbers game the auto industry does. That said, even manufacture dyno plots of Torque and Horsepower would be better than nothing.
BTW, Yes I know your formula...JimH posted it in an article back in 2007. The article is actually related to this thread.
http://continuouswave.com/whaler/reference/compare90.html
jharrell posted 09-20-2011 12:26 AM ET (US)     Profile for jharrell
"Give me a lever long enough and a fulcrum on which to place it, and I shall move the world." -Archimedes
This is the essence of torque. You can get any torque you want by gearing an engine a certain way, the problem is gearing the engine a certain way. That is, your transmission is a limiting factor especially in an outboard. In Archimedes case the lever would have to be 4.3 billion light years long, a very limiting factor.
jharrell posted 09-20-2011 12:31 AM ET (US)     Profile for jharrell
This is incorrect, horsepower rpm and torque are interrelated, if HP and RPM are the same, torque is the same.
If you run it through gears you can lower the rpm and increase torque, or increase rpm and lower torque, then end result is the same HP.
jharrell posted 09-20-2011 12:36 AM ET (US)     Profile for jharrell
I do very much agree, real hp, rpm, and torque plots would be very helpful.
I wish I had the resources, I would buy a marine dynamometer and go around to the dealer and see if they will let me test them. I would then publish the data on the web once and for all.
L H G posted 09-20-2011 01:08 AM ET (US)     Profile for L H G
The point about EPA regulations effectively preventing higher HP than the advertized rating makes sense, since presumably a higher-than-rated HP engine would put out more emissions, and not be able to meet decal emission regulations.
Conversely, these same regulations can be used to defraud the consumer by selling a lower HP engine, such as the E-tec 90 at 83HP and selling it as a 90. That way it can actually be a more polluting engine at 83 HP and the higher 90 HP rating gives it more leeway on emissions. Plus you can sell it for a higher price. Fair to the consumer?
My attitude is that if I'm paying top dollar for a 90 HP engine, I want true 90 HP or greater.
Incidentally, I have recently determined that my own Montauk, with a Mercury 115 L6 tower is consistently giving me over 5 MPG at 25-30 MPH cruise. The 12 gallon Tempo on deck tanks makes this easy to determine. It's not as good as DFI/E-tec mileage would be, but I'm happy with it. As I have noticed at ramps and everywhere I go with it, the mint condition, same year 2-stroke Merc tower gives it classic appeal just not possible with a newer, larger and heavier 3-star engine. No comparison. This boat will cruise along at 41 MPH, the E-tec 90's top speed, at only 4200 RPM, and accelerates like a rocket.
jimh posted 09-20-2011 08:33 AM ET (US)     Profile for jimh  Send Email to jimh
Larry--Why do you keep repeating your nonsense about the E-TEC making 83-HP? Do you think people will believe you if you repeat this more often?
If you think that Evinrude is committing a fraud in the sale of the E-TEC, you ought to contact your state Attorney General and inform them of this crime.
Finally, thanks for all the information about your boat, your motor, your performance, and your fuel economy. Also thanks for the account of all the positive comments you have received about your boat and motor.
prj posted 09-20-2011 08:48 AM ET (US)     Profile for prj  Send Email to prj
I find jharrel's comment above worth repeating. I assert that its nearly impossible for three engines with radically different technologies to have the exact same output to within one hundredth of a point. This tells me that the EPA numbers that jimh is basing his entire argument of equivalency on are derived in some manner other than actual testing. Lets call it an EPA-seat-of-pants measurement.
In fact, when actual testing is reported on this forum, the numbers are most decidedly not identical. The ETEC tends to yield around 10% less WOT speed than other outboards reported. How can this disparity be explained?
Lets go back to [a personal opinion that the E-TEC engines lack horsepower].
cbone posted 09-20-2011 09:43 AM ET (US)     Profile for cbone  Send Email to cbone
We have been down the EPA dyno discussion before. Some people swear by them but they have no clue where the numbers are coming from. The only thing that everyone is certain of is that the EPA is NOT dynoing the engines.
http://continuouswave.com/ubb/Forum4/HTML/007372.html
Peter posted 09-20-2011 10:05 AM ET (US)     Profile for Peter  Send Email to Peter
"Larry--Why do you keep repeating your nonsense about the E-TEC making 83-HP? Do you think people will believe you if you repeat this more often?"
It's simple -- because it diverts attention away from the fact that an operational Mercury 90 FourStroke weighs over 400 lbs and its cousin, the Optimax 90, weighs 375 lbs. The weight of both of those motors makes them far less attractive as repower candidates for a Montauk transom.
The maximum power stated in the EPA database is certified by the manufacturers. The power is determined using the SAE J1228 standard.
prj posted 09-20-2011 10:17 AM ET (US)     Profile for prj  Send Email to prj
Thanks for that citation 'boney, it's a good and revealing read on the 83 HP ETEC 90 and the EPA's rigorous methods. Methods that yield the exact same power output from multiple engines of differing technologies. ; )
cbone posted 09-20-2011 10:49 AM ET (US)     Profile for cbone  Send Email to cbone
You can see from the majority of that discussion that no one knows who actually provides the HP/Kw numbers. As I have shown several engines were stated as exactly (within one hundredth) the rated the HP on the decal which is just not possible. Too many variables exist in an engine to have it perfectly on the number. Those numbers were selected for an emissions reason and they certainly are not peak hp.
Tom W Clark posted 09-20-2011 11:09 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
It is no mystery who tests the motors and provides the certified test data on the outboard's power, the manufacturers do. They do so in accordance with the strict standards outlined in this EPA document:
http://www.epa.gov/EPA-AIR/1996/September/Day-19/pr-23668DIR/Other/ maine.txt.html
The suggestion that the EPA horsepower data is somehow arbitrary or "made up" is absurd.
I still fail to see any credible evidence that other 90 HP outboard are more powerful than the Evinrude E-TEC 90 HP outboard.
As to Pat's hypothesis: "The ETEC puts out less HP than previous (or other) engine models." I am sure that is true. I am also equally sure that The E-TEC 90 puts out more HP than previous (or other) engine models, it just depends on exactly what outboards you are talking about. The E-TEC 90 is less powerful than the old OMC V-4 90 yet more powerful than the old Yamaha two stroke 90. Again, no mystery why.
cbone posted 09-20-2011 11:24 AM ET (US)     Profile for cbone  Send Email to cbone
They are not made up numbers, they are numbers that the manufacturer selected for testing purposes. There is logic behind the builders selecting those numbers but we just don't know what it is. People assume that its peak hp but have no proof.
Any logical person can see that three different engines let alone three different engines from different manufacturers can not possibly be exactly the same HP to within one hundredth of hp or that several engine will be exactly 225.0 hp.
Those Kw/HP numbers are selected for an emissions testing reasons as allowed within the regulation.
Tom W Clark posted 09-20-2011 11:35 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
quote:
...different manufacturers can not possibly be exactly the same HP to within one hundredth of hp or that several engine will be exactly 225.0 hp
They're not.
The Yamaha F225 is shown to put out 208.39 HP, not exactly 225.0 HP.
Mercury OptiMax 225 is shown to put out 221.94 HP, not exactly 225.0 HP.
cbone posted 09-20-2011 11:50 AM ET (US)     Profile for cbone  Send Email to cbone
Look back to past years. Several engines put out exactly the rated HP decal and some were exactly the same as engines from different manufacturers.
That is just not possible. The data is for harvested for emissions reasons.
cbone posted 09-20-2011 11:55 AM ET (US)     Profile for cbone  Send Email to cbone
Here is the example
E-tec E200 149.14KW@5250 = 200HP
E-tec E250 186.00KW@5150 = 250HP
Honda BF200 149.1KW@5500 = 200HP
Honda BF225 167.8KW@5500 = 225HP
jimh posted 09-20-2011 12:12 PM ET (US)     Profile for jimh  Send Email to jimh
Can you give us the example of where the E-TEC 90-HP makes 83-HP?
jharrell posted 09-20-2011 12:33 PM ET (US)     Profile for jharrell
Even if you go by the EPA power numbers the Yamaha F90TLR shows higher power at 68kW(91.1HP) than the E-TEC at 66.19kW. So there is some evidence.
I think any reasonable person would question power numbers that are exactly the same down to the 100th Kw between 3 manufacturers with very different engines. You can't get that level of consistency on the same engine run at two different times.
Also there are discrepancies between the models and power listed on on the "Family Info" sheet vs the "Models" sheet. The Honda BF90 does not appear in the family info and the Suzuki listed on the "Family Info" is the old 1.9L 90, while the newer 1.5L model is listed on the other sheet. What is the difference between the two sheets?
Also we all know the ICOMIA "rated" power is not peak power, from jimh's own commentary on ICOMIA 28-83: "This means that if the full throttle speed range is chosen to be a wide range, for example 5,000 to 6,000 RPM, it is possible that the engine's peak horsepower will occur near 6,000 RPM, but the rated horsepower must be that obtained at 5,500 RPM. The difference between these two horsepower ratings is recommended to not be greater than 6%. It appears that manufacturers have some room to fiddle with the engine horsepower rating by adjusting the RPM range which they declare to be the the full throttle speed range of the engine. Rating of the engine horsepower in this way accounts for some of the claims seen in which engines of a particular brand and rating can test at significantly higher horsepower in actual field tests."
The rated power submitted to the EPA will be chosen based on making the engine look good for emissions, however the true peak power could be from 0 to 6% higher. On top of that a 10% tolerance from rated to to propeller power is allowed for manufacturing variations, this allows even more wiggle room for a manufacturer to over or underrate an engine as it suits them.
jharrell posted 09-20-2011 01:17 PM ET (US)     Profile for jharrell
Using this sites Crouch's speed calculator we can get some insight into the peak HP of the engines discussed.
Using the divtruk's Montauk as a basline and Tohsgib's data on his Suzuki 70 and 88SPL and references to a Montauks average weight being around 2000lbs the most consistent setup on Crouch's calculator is 200 for the hull factor. This gives an E-TEC at 41.5mph 86HP, The Suzuki 70 at 39.5mph 78HP, my inline 6 at 43mph 92.4HP, The 88SPL at 43.5mph 94.6HP and Jeff's inline 90 at 47mph 110HP.
Extrapolating this to compare these two boat tests on identical boats:
http://www.evinrude.com/Content/Pdf/neutral/performanceReports/PE670.pdf
http://www.suzukimarine.com/uploads/Pro-Lite_Flats_18_DF90A.pdf
Would give the pro-lite flats a hull factor of 215.4. This is derived from assuming the 86HP of the E-TEC with the 2900lbs boat. Based on that the Suzuki 90 would have to put out 100HP to attain 41.6mph even with one less person, so 2700lbs instead of 2900lbs.
Tohsgib posted 09-20-2011 02:51 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Boat is more like 1600-1700lbs with fuel and 1 passenger. 950 hull, 350 engine, 200 driver(then), 100-200 in fuel and misc gear, etc. With my 70 I only carried a 6 gal tank that lasted all weekend.
pcrussell50 posted 09-20-2011 03:06 PM ET (US)     Profile for pcrussell50  Send Email to pcrussell50
Notwithstanding our differences in the politics behind the banning of carbureted two-strokes, Jharrell is exactly right in his description of what horsepower is and what it means.   A motor with a higher max torque in a speed contest with a motor with a higher max horsepower will lose every time, unless it is mis-driven or misapplied.   Ah, but the Enzo Ferrari quote... Enzo was a road racer, (as am I BTW), and his quote is one of the most misapplied bits of lore out there.   Torquey motors are easier to drive on road race courses, where surgical precision can be worth valuable fractions of a second.   Power is the biggie though.  I guarantee you, sure as I live and breathe, Enzo would NEVER accept a situation where his competition had a power advantage, even if HE had a torque advantage.  In top level racing, he would get killed. Period.
-Peter
Tohsgib posted 09-20-2011 03:24 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
From what I have known since a kid...Torque is what an engine can do, Horsepower is how fast it gets there.
I think the smaller E-tecs might do better with a taller gear ratio but then again I think the designers at BRP know more than we do. Normally I would blame it on the lack of a cylinder but Merc's 3cyl 90 was a brute.
Peter posted 09-20-2011 03:42 PM ET (US)     Profile for Peter  Send Email to Peter
It's been a while so I guess its time to drag this out of the closet again ==> www.bwbmag.com/output.cfm?id=943183 .
I guess we can conclude from this article coming from Larry's favorite, but now defunct magazine (Bass & Walleye Boats) that if Larry says the E-TEC 90 only makes 83 HP, then the Mercury Optimax and the 1st generation Suzuki DF 90 (with 1.9L displacement, now called a DF100 in their lineup) made something less than 83 HP because both had slower top speed.
Tohsgib posted 09-20-2011 03:48 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Yeah but the Suzuki was 100lbs heavier....not fair.
L H G posted 09-20-2011 03:51 PM ET (US)     Profile for L H G
I can't believe that anybody here would trust the EPA.
These are the people that first brought us MBTE in our gas, then banned the conventional 2-stroke because MBTE got into the water, then brought us 10% ethanol in all of our gasoline, and is now bringing us 15% ethanol in our gasoline.
What a bunch of idiots, and I don't even belong to the Tea Party.
But getting back to the poor old E-tec 90, as many know there are a few dissidents here who buy MOntauk 170's and then complain about having to have a Mercury Verado block 90 on it, preferring an Evinrude instead.
Please, please, please, one of you guys, get rid of the Merc and put an E-tec 90 on that Montauk 170 of yours, and let's see if it will make even 38 MPH. I doubt it, but it sure would be nice have the proof.
I am also surprised to see the Evinrude people ignoring Jeff's experience here, with his 85HP POWERHEAD rated OMC V-4 engine, (about 80 HP at the prop?) giving 40 MPH on his Newport. That seems to fit with the estimated 83HP rating of the E-tec 90.
I happen to think the E-tec 90 is a fine, nice running engine, a brilliant marketing idea, and a good fit on an old style Montauk. I am happy to see people buying an American manufactured product. But after years of seeing the same old "how do I get more speed out of my E-tec powered Montauk?", and the same old answers "jack it up and install a 15" Stilletto prop", and then seeing repeated top speed ranges of 40-41
MPH, it gets a little old. It's time to take off the rose colored glasses, and see it for an engine over-rated in HP and therefore overpriced for the HP you actually get. That's it, and only it, which is why I suggested that the 75 HP E-tec is probably a much better buy for what you get for the money.
jharrell posted 09-20-2011 04:30 PM ET (US)     Profile for jharrell
The article specifically states they could not find a tall enough prop for the DF90, it was running a 26p and still over revved at 5800 and 49.5mph(.4 less than the E-TEC), on top of that since 5800 is above the engines rated red line, they
discarded that and went with 44.5 at 5500.
If they could have got a taller prop bringing the engine down to 5500rpm at WOT it would have easily bested the E-TEC.
Remember the old 1.9L DF90 can still be bought today as the slightly tweaked 100hp model.
jimh posted 09-20-2011 05:13 PM ET (US)     Profile for jimh  Send Email to jimh
A nice thrust and parry from L H G, but his foil misses the mark. These anecdotal boat speed reports are just that: anecdotes. They come from a wide variety of boats, with different propellers, run in different sea conditions, under different atmospheric conditions, producing uncorrelated results which are then carefully selected to build a house of cards to prove that the E-TEC makes, what is it, 83-HP, a watery figure pulled out the air. Against this we put a certified 88.9-HP measured on precision machinery.
As for the EPA, I say HOORAY. Were it not for their demands for low emission, we'd still be running cranky, smokey, noisy, two-cycle outboards (and automobiles) with 1960's technology.
Really, it is time to take of the blinders--to continue Larry's metaphor--and see the world for what it has become. If for no other reason, Larry ought to get a modern outboard engine like the E-TEC so he can finally free himself from the burden of guilt he must carry around from all the exhaust pollution his old cranks create.
pcrussell50 posted 09-20-2011 06:40 PM ET (US)     Profile for pcrussell50  Send Email to pcrussell50
[Deleted misquote attributed to me. Please make your point without trying to twist my words.--jimh]
L H G posted 09-20-2011 07:30 PM ET (US)     Profile for L H G
I love my collection of Mercury outboards! You guys can pull your superior "my engine is better than yours" attitude routine any time you like, but I could care less.
I have noticed that most onlookers at a boat ramp have no clue, or do not care, whether an outboard is a 3-star verions or not. It means nothing.
My Merc 2-strokes are not cranky in the least, and perfrom beautifully at all speeds, and although they have a "throaty" idle sound,(which is strictly a value judgement only - some people like quiet, some poeple like throaty) are not any noisier at running speeds than a 2-stroke DFI or 4-stroke, and some are actually quieter, Above 800 RPM, they are no smokier than a DFI, and below that I control smoke with the new low-smoke oils.
In many respects they are better, particular on power-to-weight ratios and classic looks (for our classic Whalers). Spending huge amounts of money for the overpriced 3-star engines is by and large a waste which has simply been forced upon us by know-it-all big government. The fuel savings come nowhere close to paying for these very expensive engines.
So until the old machines wear out, I'm staying with what I've got. But I do have to admit I'm intrigued with the brand new Merc 150 4-stroke EFI! Looks like a real winner, but currently I have no need for one.
Peter posted 09-20-2011 07:40 PM ET (US)     Profile for Peter  Send Email to Peter
I figured you'd defend the Suzuki. But how do you conclude that if it had a taller prop it would have easily bested the E-TEC? They spun the 26P to 5800 RPM and obtained 49.5 MPH. Are you saying it hit a rev limiter?
jharrell posted 09-20-2011 08:18 PM ET (US)     Profile for jharrell
Oh and what a surprise your defending the E-TEC, Do you have nothing good to say about a Suzuki, I think if you look back at each of our posts we will know who has the more balanced opinion on the E-TEC and Suzuki engines.
That's essentially what they are saying: "Matched to Triton’s fleet, 17-foot bay boat, Suzuki’s 131/4x26-inch stainless three-blade — the tallest available from the manufacturer — was simply not enough wheel to rein it in on this application."
The DF100, which is basically the same engine shows 6000 for top rpm, which would yield 51.21mph and that with the ridiculous 10% slip that prop had. If the old DF90 had a decent prop with half the slip it would have hit 52 at 5800.
2manyboats posted 09-20-2011 08:33 PM ET (US)     Profile for 2manyboats  Send Email to 2manyboats
I don't have a Montauk anymore but we do have a 90hp Etec. It is on a 2472 Sea Ark aluminum boat we use for swamp and river tours. The boat came with a 2005 90 Johnson 2stroke 60 degree block. We usually have 4 to 8 people on board. The boat is 24 ft long and 8ft wide at the gunnels. It weighs about 1400lbs empty. With the old 90 top speed was low 30s, with the Etec 90 speed is the same, boat planes quicker and uses almost half the fuel. We are running the same prop a 13.5x 14 power tech.
We were a little worried about going from 4 cylinders to 3, but the Etec is equal to or exceeds the old 90 in every way.
Our new tour boat (26 ft long 11ft wide pontoon boat ) has a 150 Etec and runs 29mph with no passengers, and will still run 19 with 5600 lbs onboard .
SC Joe posted 09-20-2011 08:37 PM ET (US)     Profile for SC Joe  Send Email to SC Joe
After comparing almost every boat/engine performance report Evinrude publishes to similar weight/ size/length/style/horsepower Yamaha boat/engine performance reports, I found that the E-TEC generally doesn't seem to have the same WOT speed that the 4 stroke Yamaha tests do on similar boats.
Of course, this is conjecture and speculation..but we see here that in a WOT competition between the OP's smaller, lighter hull with an Evinrude 90 HP E-TEC (that Jimh has stated in the past has more torque than the Mercury 90 HP Four Stroke) would not be faster than the larger, heavier 170 Montauk with a 90 HP Mercury Four Stroke. The 170 Whaler performance specs reports achieving a 42.8 MPH top speed.
To the casual spectator, it would seem that E-TEC engines do not produce the same WOT speed when compared to a similar HP four stroke engines on similiarly sized weight and length hulls.
Tohsgib posted 09-20-2011 09:17 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
My Whalers will run 40+. My Donzi will run 65+....who really cares? Anyone want to run pinks?
jimh posted 09-20-2011 09:48 PM ET (US)     Profile for jimh  Send Email to jimh
L H G says:
quote:
"You guys can pull your superior "my engine is better than yours" attitude routine any time you like, but I could care less."
Larry--You entered this thread about an E-TEC to boast about your non-E-EC engine, to make patently untrue statements about the E-TEC, and to accuse Evinrude of criminal fraud. Exactly who do you thing is playing the role of "my engine is better than yours" in this case, and in just about every other thread you barge into with data about your boat and engines?
Personally I think it is incredibly rude to jump into a thread where someone is talking about their boat and engine, then tell them how much better your boat and engine performs. You need to lay back and wait for the threads where people are talking about re-powering their boat with some 1980 Mercury and then you can jump in.
I think this guilt about the smoke and exhaust emission is getting to you, old friend. I know it is shameful to start those old smokey two-cycle engines at the dock and see people turn away in disgust at the pollution.
Peter posted 09-20-2011 09:50 PM ET (US)     Profile for Peter  Send Email to Peter
Interesting interpretation. But I don't read it that way. When I read the entire paragraph including the last sentence in the paragraph
quote:
That’s why in our performance charts you’ll see the official speed capped at 5500 rpm, where the Suzuki was running 44.4 mph
which you left out of your quote, I read "rein it in" as meaning that Suzuki did not have a propeller with enough pitch to bring the revs at or below the top of the manufacturer's specified operating band -- 5500 RPM -- so as to be within the rules of engagement.
The rules of engagement per the article
quote:
The engine manufacturers were to supply an outboard and a representative to ensure the engine was properly rigged and propped. Each outboard had to remain within its recommended wide-open-throttle (WOT) operating range, and the prop had to be available through a dealer’s parts catalog.
If the Suzuki had bounced off the rev limiter, I think BWB, being the experience boat/motor testers that they were, would have said so. They didn't. And to speculate that the motor would have pushed the boat to 52 MPH is, well, just speculation.
By referring to the BWB article I was not trying to argue that the Suzuki or E-TEC is the slowest or fastest, but simply to point out that if the E-TEC only produces 82 HP as Larry argues, then so did all the other 90 HP motors they tested because none were any faster.
pcrussell50 posted 09-20-2011 09:58 PM ET (US)     Profile for pcrussell50  Send Email to pcrussell50
ESPECIALLY when it comes to utility boats like Whalers. I'm pretty sure the Merc 90 FourStroke on my 17 Alert is too low. But I'm not about to waste a precious second of my life raising it to get an extra couple of mph. It has an immacualte, stainless prop, and I don't know the brand or the size/pitch. It's a Whaler. A utility boat... like a truck or an SUV. Who cares?
My Hydrostream Viper goes 65'ish with a v4 crossflow, (bubbleback version, mind you), and that doesn't even get noticed over on a certain other forum.
Jeff Rohlfing! I've said it before and I'll say it again... AMAZING stuff with your boat and your stalwart, strong motor. If I weren't already so invested and committed to my V4 crossflows, I could see myself taking the "tower" route. If I knew for sure I won't be forced by the jack-booted, spirit-crushing dreadnought, that is supposedly here to help us, to give up my carbureted two-strokes, I might one day start to dabble in Merc "towers".
-Peter
Tom W Clark posted 09-21-2011 12:24 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
OK, I'll ask again, is there any credible evidence that any other 90 HP outboard is more powerful than the Evinrude E-TEC 90 HP outboard? I mean significantly, beyond some trivial difference like the 91.1 HP Yamaha F90 vs. the 88.8 HP E-TEC 90? Any motor on any given day will produce more or less power based on any number of environmental factors as well as motor state itself.
Let me rephrase the question to accommodate Continuous-Wave's preeminent provocateur, L H G: What credible evidence supports his assertion that the E-TEC 90 is only good for 83 HP?
The answer is, obviously, there is none. You can claim some boat someday long ago once went so fast but until somebody shows me how the E-TEC 90 on a boat we are all familiar with, like a classic Montauk, somehow is significantly and consistently slower than the same boat with a different motor, it is all a bunch of hooey.
How many of the participants in this discussion have spent time running a classic Montauk? How many of you have owned one, or two...or three?
How many of you have run a classic Montauk with an E-TEC 90?
How many of you have run one with a Mercury 90?
Six cylinder Mercury 90?
Three cylinder Mercury 90?
Three cylinder Yamaha 90?
How many of you have owned a classic Montauk with a three cylinder Mercury 90?
OMC V-4 90?
I have done all of the above, in fact I have operated some of the actual boats cited in this thread.
Fellas, I am here to tell you, a 90 HP outboard on a classic Montauk is good for a top speed in the low 40s. Higher or lower top speeds can be achieved under a variety of varying conditions, but there is no remarkably slow 90 HP motors, though the two stroke Yamaha 90, like my brother-in-law had on his 1988 Montauk, was a little weak. That should come as no surprise as the EPA test certification data indicates it is only good for 83.3 HP.
I almost regret digging up that EPA data on the 83 HP two stroke Yamaha 90 some years ago because it seems Larry has now latched onto that number and is tenaciously trying to convince everybody that it is the power of the E-TEC 90 every time a thread pops up discussing the Evinrude E-TEC 90. The irony is that it is the EPA data that Larry is simultaneously trying to discredit.
You can't have it both ways Larry.
L H G posted 09-21-2011 01:33 AM ET (US)     Profile for L H G
Tom, I'm sure Jim wishes you would quit urging me on, but OK, you're right. Also Tom, you Evinrude guys can't have it both ways either.
OK, you all love and trust the EPA as Gospel, 15% ethanol and all. That opinion I can accept, although personally, I disagree with that Agency's Big Brotherism.
1. Old fashioned, throwback Yamaha 90 2-stroke does 40-41 on a Montauk. Lots of Montauks have this very popular engine.
2. Hot new, high tech, ultra modern E-tec 90 does 40-41 on a Montauk, with high performance prop needed.
3. Yamaha/EPA say the Yamaha 90 is 83 HP.
4. Therefore, with same output at the prop, E-tec 90 is 83 HP also.
I learned this simple stuff in high school.
I can think of at least six 90 HP engines apparently more powerful than an E-tec 90:
1. Mercury 2-stroke 90 model years 2000-2006 . Several people have indicated this who have run both on a Montauk. Eric(?) in Europe comes to mind. Clark Roberts has indicated he managed to get 48 out of his on a Montauk.
2. Mercury "YamaMerc" 4-stroke. Boston Whaler showed this Yamaha engine to run 44 on a classic Montauk.
3. Mercury Verado block 90. Kind of big on a Montauk, but Sos Merc just installed one, so let's see what it will do. Any bets on power, since WT has said it's faster than the old YamaMerc 90 he used to have on his 170? Boston Whaler says the same thing.
4. Old Mercury L6 "Tower of Power" 90. I doubt if anybody really doubts this old engine (in good condition) will not easily outrun an E-tec.
5. Old OMC V-4 90's. Same comments apply as to the "Tower" above.
6. Yamaha 90 4-stroke, since it still is the same engine sold to Mercury as the YamaMerc. I have no information on relative power of the Honda and Suzuki 90's.
All of this, other than the Yamaha 90 2-stroke, is showing the E-tec 90 to be one of the slowest 90's around, regardless of year or technology. With all of the supposedly 100 or so Montauks running E-tec 90's out there, isn't there at least one owner, somwhere, who can indicate his has done 45 MPH. Not even one?
divtruk posted 09-21-2011 02:12 AM ET (US)     Profile for divtruk  Send Email to divtruk
Until someone spends a week or two swapping out different engines on the same boat for a true apples to apples comparison, this argument will go on forever.
Wish I had never posted the damn numbers to begin with. I was never trying to say this motor was any better or worse than any other. I was just telling you what I got.
I am having to much fun with my boat to worry about all this crap. Some of you guys need to get a life.
I'm done!
Peter posted 09-21-2011 07:01 AM ET (US)     Profile for Peter  Send Email to Peter
"Until someone spends a week or two swapping out different engines on the same boat for a true apples to apples comparison, this argument will go on forever."
Exactly. No two boats of the same model are exactly the same in dry weight, or in hull shape, or in bottom condition, or run in the same environmental conditions, or loaded with the same gear, or have the weight of the gear and peopled carried in the boat distributed in the same way, or have their motors trimmed out the same, or have their motors mounted to exactly the same height.........
prj posted 09-21-2011 09:57 AM ET (US)     Profile for prj  Send Email to prj
I'm sorry that forum member divtruk has been offended by this friendly sparring amongst long time members. Perhaps the direction this article has taken should have been separated and re-titled E-TEC 83 HP Performance Report.
The latest tack taken here is to dismiss all performance reports of 90 HP engines because they aren't undertaken on the exact same boat in the exact same conditions. Sure, thats one method to shield or dismiss consistent results from the 100 or so E-TEC / Montauk repowers.
You could also assert, Peter, that the E-TEC repowered boats are all set up inferior, with engines low and excess water weight and fouled bottoms, while every other 90 HP Montauk combo is a refined rig running in perfect temperature on rippled and aerated water. [More personal opinion that E-TEC engines lack horsepower.]
Tom W Clark posted 09-21-2011 10:40 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
I'm still waiting for some credible evidence Larry, not your "made up" data or unattributed "I remember once reading..." data.
pcrussell50 posted 09-21-2011 11:08 AM ET (US)     Profile for pcrussell50  Send Email to pcrussell50
Re the EPA's testing I'm surprised nobody brought up the variability in output between one engine and another off the same production line. Some will be less powerful and some will be more, simply because you cannot make such complex things as exactly as you'd like to.
What I don't know is, when the EPA tests the E-TEC 90 say, do they grab several at a time and test them all and report the average result? If they only take one, do they pick it at random? Or does Evinrude get to pick it for them, thus inducing the possibility they sent up a "ringer" for the testing? Not picking on Evinrude here. This line of questioning applies equally to all of them.
FWIW, If I were in the market for a repower, I'd probably get an E-TEC 90, too. Even if they were a little less powerful than the others (not saying they are), because I don't care about the last tittle of speed in a utility boat like a Whaler anyway.
-Peter
Tom W Clark posted 09-21-2011 11:11 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Peter -- Those questions are all covered in the document I cited above. Test results come from numerous well broken in motors. There are no "ringers"
pcrussell50 posted 09-21-2011 11:20 AM ET (US)     Profile for pcrussell50  Send Email to pcrussell50
I wondered about that, Tom. I had not read those documents. Mostly because I don't care.
Divtruk, you should spool down a little, mmmbrah. These guys are a group of curmudgeons who have been jabbing and jousting for years. They like it... it's fine. Frankly, I like it, too. :)
-Peter
jharrell posted 09-21-2011 11:26 AM ET (US)     Profile for jharrell
If you can't get the proper prop setup the engine will be handicapped, as it was here, they even said so. I got 52mph by running it through the prop calculator on this site and reducing the slip from 10% to 5%. 10% slip obviously means an incorrect prop. It should have probably been a 13 3/4 to 14" diameter like all the propellers Suzuki recommends for that engine. 13 1/4 is too small for the large 2.59:1 ratio and they don't even list it in their prop catalog for that engine? The 26x14 or 28x14 would have been a much better choice for that boat.
This same block revs all the way to 6200 in the 140, to get 90 out of this engine it obviously was artificially limited, 5800 makes a lot of sense for a rev limiter, again the same engine re-badged to a 100 HP revs to 6000.
Then why do the EPA number show exactly the same power down to the 100th kW across 3 brands of 90? This doesn't seem even a little unusual to you?
Tom, I trust your experience, probably having more than most of us with various 90hp motors on various Whalers, but there is no way completely different motors have exactly the same power.
divtruk posted 09-21-2011 11:35 AM ET (US)     Profile for divtruk  Send Email to divtruk
I am not offended. :-)
I was smiling the whole time I wrote that last post. You guys just remind me of the group of old guys that sit at the donut shop every morning complaining about something. Anything. They just aren't happy unless there is a debate going on.
WT posted 09-21-2011 11:36 AM ET (US)     Profile for WT  Send Email to WT
I'm actually dying to see the performance numbers from sosmerc's recent installation of a new 90 hp Mercury FourStroke on a classic Montauk.
Will the new Mercury 90 FourStroke top out at 41-42 mph too? If so, it might end some arguments of horsepower ratings.
Warren
Tom W Clark posted 09-21-2011 11:36 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
No, that is incorrect. There is nothing wrong with slip. If a boat is faster with a prop with more slip than less slip, so be it. There is nothing magical about low slip numbers. The slip calculation is useful for relative comparisons. Every model of propeller will tend to fall within different range of slip.
Slip calculations of 5 to 15 percent are pretty normal.
Tom W Clark posted 09-21-2011 11:41 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
jharrell -- Why do the EPA power numbers NOT all equal exactly the HP ratings of the motors?
Why do all motors in a HP range NOT share the exact same Kw numbers?
For example, how do you explain the Yamaha F225 at 208.39 HP and the Mercury OptiMax 225 at 221.94 HP?
Tohsgib posted 09-21-2011 11:56 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
I am not sure how the rev limiter works on a Suzuki as I have never hit mine. The old 90 which weighs a hefty 416lbs redlines at 5500 so 5800 might be limited. A light on the tach should illuminate telling it is overreving. My 115 redlines at 6k and I have hot 6200 w/o hitting the limiter or at least I think it never hit. With th 22" Stiletto I now hit about 58-5900 full tilt boogie and about 40mph. What is my slip on that? Lastly I have said this many times here, Suzukis NEED to be raised high for some design reason. My 40 is all the way up on my 13 and needs to go higher.
L H G posted 09-21-2011 12:31 PM ET (US)     Profile for L H G
Tom - I made up no data. Just what I have read here on CW.
Others seem to report similar sightings. But I suppose that those shady contributors could be making it up? I even counted on the accuracy of your statement that the Yamaha 90 is shown as 83HP.
If you guys think all of this is baloney, be my guest, and I won't be offended.
We already have a legitimized "VERADOSAURUS" here, Jim's sole creation. Maybe we should label this engine an "ETECOSAURUS" also, just to keep things on an equal footing, although it appears the VERADOSAURUS is a more highly evolved creature.
Tom W Clark posted 09-21-2011 12:42 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Larry -- That's it? No attributions? Who are these "Others"?
Tohsgib posted 09-21-2011 01:10 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
I kinda have to agree with Larry. If a 90 Yamaha produces the same top speed as a 90 E-Tec they should be close in hp or whatever it takes to fetch 40-41mph. I had a 1985 powerhead rated 115(100@ prop) OMC that only did like 45 and was plum noisy and ugly and probably worn out. Damn thing sounded like it was going to chunk a rod...for years.
Peter posted 09-21-2011 02:04 PM ET (US)     Profile for Peter  Send Email to Peter
-- L H G
Ahh, now we are getting to the bottom of it. Calling the Valurado a Veradosaurus has put a bee in Larry's bonnet.
-- JHarrell
No, what they said is:
[quote]Unofficially, it would have posted the third fastest top end, clocking 49.5 mph at 5800 rpm.
They could have said that "we think the Suzuki could go even faster but we hit the rev limiter at 5800 RPM". But they did not.
Perry posted 09-21-2011 02:23 PM ET (US)     Profile for Perry  Send Email to Perry
The marina where I keep my boat has at least a dozen classic Montauks with ETEC 90's on them. I use them often. They all have stainless props and have great low end torque but seem to loose that power at higher rpm. I carry my handheld gps and 40.7 MPH is the fastest I have been on one of them. Before repowering these same Whalers, they had V4 OMC 90's on them and would do 45+ MPH.
Here is a quote from Teak Oil:
Teak Oil posted 09-22-2009 10:53 PM ET (US)
"I run an older style 20" Raker on my 90hp V4 with good results, with a top speed of over 47 at 5300 rpms."
It has been reported over and over here that the old Yamaha 2 stroke 90 could push a classic Montauk to 40-41 MPH. Nick verified a first hand report of this. Others have (including myself) provided first hand reports of the same speed with an ETEC 90 on a classic Montauk. I know it's not a scientific test using the exact same variables but come on guys, the 2 stroke Yamaha 90 and ETEC 90 seem to have VERY similar results.
jharrell posted 09-21-2011 02:32 PM ET (US)     Profile for jharrell
Too bad BWB didn't list all props used and not just Suzuki. divtruk's Montauk is showing -8% Slip at 41.5mph, The Pro-Line Flats that had both an E-TEC and Suzuki 90 showed nearly 0% for the E-TEC and -%5 for the Suzuki, yet +10% is normal?!
Suzuki doesn't even list a 13 1/4" prop for that motor, they are all 14" in that pitch, hmm why would you want more diameter, I think that would help with something...
They specifically said the prop "was simply not enough wheel to rein it in on this application." You can try and twist this any way you want, but they themselves said the tallest prop they could find was not enough for that boat. Suzuki doesn't even sell a 13 1/4" for that motor, and they have all the way up to 28p, hmmm.
jharrell posted 09-21-2011 02:37 PM ET (US)     Profile for jharrell
A question answered with another question. Ok, because Manufacturers obviously have some leeway in what they submit meaning the power numbers are useless for determining actual peak power of any engine listed.
Now what your theory on how Merc,Suzuki and Evinrude got the exact same numbers since you think they are accurate power figures?
jharrell posted 09-21-2011 02:45 PM ET (US)     Profile for jharrell
It would make more sense that the E-TEC puts out 83HP. If you apply that to the two boat tests on the Pro-Lite boat, the Suzuki would be putting out 97HP instead of 100HP using Crouch's speed calculator.
This would put both engines at the slightly outside extreme ends of the 6% recommended peak power ICOMIA variance.
Tohsgib posted 09-21-2011 03:05 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
I would not doubt that engines of the same breed are roughly the same hp. Yamaha and BRP both have/had 3 cyl 75 & 90hp engines on the same block. It makes sense that each would produce 83hp and just have different decals. Problem is that is not the case or nobody would buy the 90. The Suzuki 90 is the same as the 115 with detuned computer who really knows what has been detuned. When OMC had the V4's they also had a 115 so it would make sense that the 90 was hotter than if it was the other way around. A detuned engine I believe is hotter than buying the highest HP of the breed. In other words I doubt you would see much difference between an older 90 vs 115 just like I don't see much difference between my 115 and the 140 on similar setups. I also think they will last longer but that is another story.
Peter posted 09-21-2011 03:23 PM ET (US)     Profile for Peter  Send Email to Peter
Or it could make just as much sense that the -5 percent calculated WOT slip in the Suzuki report means that there is an error in the data. It could be that the tachometer reading was off and the speed was correct or it could mean that the tachometer was correct and the boat speed through the water really wasn't 41.6 MPH. As the disclaimer at the bottom of Suzuki's report says
quote:
Results may vary.
andygere posted 09-21-2011 04:43 PM ET (US)     Profile for andygere  Send Email to andygere
Attention Montauk 17 90 h.p. class drag racers:
The only motor that will win any races in this class is the Mercury Tower of Power 90 h.p. outboard. If you wish to be competitive in this class, please proceed to your nearest Mercury dealer and ask him to install a new Mercury Tower of Power 90 h.p. outboard.
Attention all normal recreational Montauk 17 owners: You are free to choose any motor that meets your immediate needs based on price, efficiency, environmental compliance, sound, color, country of manufacture or other criteria of your choosing. You may even choose to install a motor of less than 90 h.p. and one that will not propel the boat in excess of 47 m.p.h.
jimh posted 09-21-2011 05:03 PM ET (US)     Profile for jimh  Send Email to jimh
I have a boat and it has an outboard engine. With the same outboard engine, I have seen the top speed of the boat vary depending on various factors, including the weather, the water, the set-up on the boat (of things like gear, canvas, people on board, and so on), the propeller, and the wind. If I pick the absolute highest speed I have ever seen at wide-open-throttle and compare it with the lowest speed I have seen at wide-open-throttle, I will have a range of at least 3-MPH and perhaps 4-MPH. So what is the top speed of my boat? All this variation occurs on with the same boat, the same motor, and the same driver. The variables that are affecting speed are just environmental or boat set-up. If we can get this much variation from those variables, it should not be surprising that if we change boat hulls and change motors, we could get more variation.
jharrell posted 09-21-2011 05:56 PM ET (US)     Profile for jharrell
So divtruk has an error in his data at -8%, and Evinrude has an error in their data with -3.9% at 5000 on Pro-Lite? Only an error when a Suzuki has negative slip right?
More likely the props are just cupped. +10% is way out there, +5% is being conservative, if it had +%1 like the E-TEC on the Pro-Lite at 5800 it would have hit 54mph.
SC Joe posted 09-21-2011 08:27 PM ET (US)     Profile for SC Joe  Send Email to SC Joe
Of the 17 boat/engine performance tests that Evinrude publishes for the E-TEC 90 HP, only 5 of them go faster than 40 mph at WOT. Of those 5, 3 of them are inflatables that have a dry weight <930#. The fastest of the 5 at 43.6 mph is not surprisingly the lightest, at 560#.
The heaviest, and also the longest boat with a 90 HP E-TEC that goes over 40 MPH (it reached 42.4 mph) is the Sea Ark Stealth 186, an aluminum hull that is 18'6" and weighs 1100#.
In contrast, the Mercury 90 HP Four Stroke is published to push the Boston Whaler 170 to 42.8 mph..and the boat weighs a full 824 pounds more than the Sea Ark Stealth.
In your opinion, if you added 824# to the E-TEC powered Sea Ark, could it reach 40 MPH?
I doubt it.
jimh posted 09-21-2011 09:52 PM ET (US)     Profile for jimh  Send Email to jimh
It is crazy to compare different boats with different motors. Did you read my comment where on the same boat with the same motor I get 4-MPH variations as the weather changes?
Peter posted 09-21-2011 10:34 PM ET (US)     Profile for Peter  Send Email to Peter
Or different boats, different motors and different propellers. If you switch propellers on the same motor and pick up 2 MPH or drop 2 MPH, does that mean that the motor with one propeller produces different propshaft HP than the same motor with the other propeller? Of course not.
SC Joe posted 09-21-2011 10:46 PM ET (US)     Profile for SC Joe  Send Email to SC Joe
834# difference.
I'm not very good at making a boat go faster..but I can sure make one go slower.
Tom W Clark posted 09-21-2011 10:46 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Oh boy! Let's have fun with dissimilar data points:
If the 1100 pound Sea Ark Stealth goes 42.4 MPH with the E-TEC 90 then I suppose we can conclude that, according to the Crouch Calculator and the novel logic recently employed here, that the 900 pound Montauk should be good for 44.3 MPH.
Sounds about right.
SC Joe posted 09-21-2011 11:42 PM ET (US)     Profile for SC Joe  Send Email to SC Joe
900# Montauk?? Who stated that?
That's 834 additional pounds. The Montauk weighs 834 pounds MORE than the Sea Ark.
Does anyone have a formula for the hull factor in Crouch's formula? I could not quickly find it.
Tom W Clark posted 09-21-2011 11:53 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
The manufacturer's specified weight of the 1988 Montauk the subject of discussion in this thread is 900 pounds.
Tom W Clark posted 09-22-2011 10:05 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
OK, now that the silliness has died down, let's get back to divtruk's boat.
It is good for 41.5 MPH now, not 40. It is hitting 5400 RPM when the E-TEC 90's optimal engine speed range is 5000-5200 RPM.
If a 13-1/4" x 17" Stiletto Advantage 4.25 were substituted and the motor were raised on the jackplate as I have already recommended, I am sure divtruk's Montauk would exceed 44 MPH at 5000-5200 RPM.
Again, this is perfectly consistent with any other 90 HP outboard motor and is more than fast enough for the vast majority of the Montauk owners.
cbone posted 09-22-2011 10:16 AM ET (US)     Profile for cbone  Send Email to cbone
From reading this it seems like all of the reported performance results from classic 17ft Montauks/90 E-Tec are 2-4mph slower then with other engines (besides the 90 2 stroke Yamahas). Obviously there are a ton of other factors that come into play but out of the 100+ claimed repowers with this engine, no one has come forward with a vessel that breaks 43mph where several other engines can easily break that mark.
The displacement of the 90hp E-Tec does make it the runt of the litter regardless it maybe just about the perfect engine for a repowering a classic 17 montauk. The compact size, lack of smoke, quick response and weight makes it just about perfect. It is a nice fit between the 70hp's and the big boy 90s.
Bigshot has sold me on the 70hp combo on this hull but the Evinrude 90hp [E-TEC] does seem like a great overall fit. I have not met many people that would go from a DFI/Four Stroke back to a carb. The only way I would ever want another carb would be below 25hp.
jharrell posted 09-22-2011 11:37 AM ET (US)     Profile for jharrell
44mph would be great, has there every been a confirmed Classic Montauk that can consistently hit 44mph with an E-TEC?
This is the closest I could find: http://continuouswave.com/ubb/Forum4/HTML/003510.html
It's a 70's Nauset with a 19p prop, and even Peter said: "The Nauset here is showing a little better speed than a comparable later model Montauk. I think that is consistent with the understanding that the older 16' 7" hull shape is a little faster, but a little wetter than the newer 16' 7" hull shape."
divtruk posted 09-22-2011 12:00 PM ET (US)     Profile for divtruk  Send Email to divtruk
Anyone in my area have a 13-1/4" x 17 Stiletto I can borrow for a day to compare?
Tom W Clark posted 09-22-2011 12:28 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
So, if every 90 HP outboard other than the E-TEC 90 is supposed to make a Montauk go 45 or 50 MPH, where are they?
Why didn't the the three cylinder Mercury 90 on my last Montauk push it past 42 MPH? And that was after I installed a 13-1/4" x 20" Quicksilver Lightspeed (aka Mercury Laser II).
Hell, when I test drove the boat on Lake Sammamish with its original 19" aluminum BlackMax propeller, we could only get 40 MPH out of it. And that is with me at the helm watching the GPS milking it for all it was worth.
prj posted 09-22-2011 12:40 PM ET (US)     Profile for prj  Send Email to prj
In the article jharrell references above, I found this little gem from jimh:
quote:
44-45 MPH is excellent. It jives precisely with predicted performance of the 17-foot hull with that horsepower.
This statement is in perfect agreement with all the comments made within this article; that 44 MPH is both the expected and predicted performance of the Montauk with a 90 HP outboard.
Unfortunately, this expected speed came on a 1970 16'-7" Nauset, a hull that weighs substantially less than a Classic Montauk (Either 5 or 700 pounds versus 900 pounds bare hull, someone else might provide the exact difference).
Its getting quite difficult to pin down those E-TEC supporters that assert their favorite engine brand produces a peak HP equivalent to other 90 HP engines.
To recap, we have the following reasons for the disparity in performance results suggesting the E-TEC 90 is not as powerful as most other 90 HP outboards.
1. The E-TEC puts out less peak HP than other engines (jimh 9.19 6:16 PM)
2. Performance reports are unreliable and merely anecdotal. Too many variables (jimh 9.20 5:13 pm)
3. Performance reports are worthless because they aren't done by repeatedly swapping engines on the exact same boat in the exact same conditions over and over (Peter 9.21 7.01 am)
4. E-TEC owners may not know how to set up their rigs for WOT bragging rights (I get this one! prj 9.21 9:57 am)
5. Larry is pissed about jimh's derogatory nickname for Mercury's new FourStroke, a near genius and humorous deflection to protect the E-TEC (Peter 9.21 2:04 pm)
6. Data input error, related to sidebar of different boat, same engines (Peter 9.21 3:23 pm)
7. Criteria other than peak HP matters more to Montauk owners (Andy Gere 9.21 4:43)
8. One of my favorites: WOT speeds vary up to 3-4 mph when a specific boat is rigged different, from canvas to load difference, and run in different seasons, climates and water conditions. Therefore, no one can truly know WOT speeds. (jimh 9.21 5:03 pm)
Did I get that right?
prj posted 09-22-2011 12:42 PM ET (US)     Profile for prj  Send Email to prj
And Tom, it seems pretty obvious to me that your Mercury was only running on 2 cylinders for the test.
Tom W Clark posted 09-22-2011 12:48 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Pat -- Ah, of course! That explains how "People" can keep telling me a Mercury 90 on a Montauk is good for 60 MPH.
Tohsgib posted 09-22-2011 02:15 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
A '90 Mercury 150 might be good for 60...I doubt that, make it a 200. Guy came to one of my rendezvous with a 200 Yamaha on a Smirked Montauk. Said it was too squirrely over 57 to go much faster. I think he put a 3cyl 90hp Merc on it and it was just shy of 57.
Tom my 1978 Brochure states 38mph with an 85hp. I guess 41.5 with a 90 is pretty good.
L H G posted 09-22-2011 02:31 PM ET (US)     Profile for L H G
On ContinuousWave, when you run out of facts, the next move is to turn to sarcasm and subtle personal attack.
Tom W Clark posted 09-22-2011 02:33 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
That is certainly your modus operandi, Larry.
Tom W Clark posted 09-22-2011 02:35 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Nick -- I just looked at the 1980 Boston Whaler catalog. It lists the 17 foot models as good for 38 MPH with an 85/90 HP motor.
Peter posted 09-22-2011 02:55 PM ET (US)     Profile for Peter  Send Email to Peter
In 1978 and 1980, motor HP was powerhead rated. If an 85 powerhead rated outboard was expected to get the boat to 38 MPH then 100 HP powerhead rated motor should get to 41.5 MPH. 100 HP powerhead rating equals what in propeller shaft rating? 5 to 10 percent lower? That would make a 100 HP powerhead rated motor about 90 HP at the propshaft, right?
Tohsgib posted 09-22-2011 03:06 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Yes it is about 10% on outboards and 7% on I/O's.
jharrell posted 09-22-2011 03:14 PM ET (US)     Profile for jharrell
Here are two test reports of the same Alumicraft boat one with an E-TEC 90 the other a Yamaha F90.
The E-Tec had one person and 60 deg air temp: 38.6mph
http://www.evinrude.com/Content/Pdf/neutral/performanceReports/PE850.pdf
The Yamaha 2 people and 70 deg air temp: 39.1mph
http://www.yamaha-motor.com/assets/products/otb/bulletins/ bulletin_4stroke_midthrustjetport_al_alm-dominator165cs-f90tlr.pdf
At least the E-TEC got better mileage for the most part in this one.
Peter posted 09-22-2011 03:26 PM ET (US)     Profile for Peter  Send Email to Peter
Ok, and some of contributors here like to dig up old threads so here's what someone who put an E-TEC 90 on their Montauk had to say about it:
quote:
Well I did it. Put the Evinrude E-TEC on my 1983 Montauk. WOW Smooth sweet power with a flawless motor. I went with the white salt water series E-TEC 90. The boat gets up real quick on plane and sounds awsome. GPS measured 42 MPH out of the box but I still have to adjust a few settings.
See continuouswave.com/ubb/Forum4/HTML/004593.html
So let me see if I get this right,
1. An E-TEC is an 82 HP propshaft rated motor according to Larry.
2. The 82 HP E-TEC 90 can push a Montauk 42 MPH out of the box .
3. Nick says an 82 propshaft HP is the equivalent of about 90 powerhead HP.
4. Whaler (per Nick and Tom) says 90 powerhead HP (which is 82 prop rated HP) should only fetch 38 MPH.
Somebody is lying.
K Albus posted 09-22-2011 03:38 PM ET (US)     Profile for K Albus  Send Email to K Albus
Keep 'em coming, Patrick. I love it!
Tom W Clark posted 09-22-2011 03:47 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Peter -- In that same thread, make34 wrote:
quote:
I put the white E-TEC 90 on my 69 Katama, I get about 42 WOT on flat water, with 2 adults and 2 kids aboard.
Also contributing to that thread (and this thread) is Rob Schmidt who owns a 1987 Montauk powered by an E-TEC 90 (l think the ninth one ever made.) He reports that his boat is good for 42.5 MPH.
I have actually spent operating Rob's boat both with him and by myself as well as with my wife and with Tony Wilde on different occasions. I remember once running the boat at WOT with Rob at Richmond just off Brick Yard Cove.
And that is a fact.
jimh posted 09-22-2011 03:49 PM ET (US)     Profile for jimh  Send Email to jimh
[Mis-quote attributed ot me has been deleted]
I did not say that. I only speculated that it might be possible that there is another modern EPA certified engine with a cowling decal of "90" that makes 89-HP.
He also notes:
quote:
...jimh's...nickname for Mercury's new FourStroke [is] near genius and humorous....
Thank you. I thought VERADOSAURUS was good. JURASSIC FOURSTROKE was also a good alternate, but does not seem to have caught on as well.
I think you can summarize my position regarding horsepower rating as this:
The jimh Postulate
Certified dynamometer measurement is likely to be more accurate horsepower measure than selective third-party interpretation of anecdotal results of completely uncontrolled comparison tests.
You can quote me on that, thank you.
Tom W Clark posted 09-22-2011 03:57 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
jharrell's test reports of an Evinrude E-TEC 90 and a Yamaha F90 on the same aluminum boat are interesting.
The 88.9 HP (acccording to the EPA certifcation data already cited) E-TEC 90 was good for 38.6 MPH
The 91.1 HP Yamaha F90 was good for 39.1 MPH.
Interestingly, this is exactly what Crouch's Speed Calculator predicts:
http://continuouswave.com/cgi-bin/crouchcalc.pl
And that is a fact.
cbone posted 09-22-2011 04:02 PM ET (US)     Profile for cbone  Send Email to cbone
Propeller technology has come along way in the past 30 years. I wonder if most of the past performance numbers were old aluminum props vs modern stainless.
jharrell posted 09-22-2011 04:06 PM ET (US)     Profile for jharrell
Tom you forgot to subtract 200lbs for the extra person on the Yamaha, run it again and tell me that fact.
Tom W Clark posted 09-22-2011 04:14 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Oh I am sure that is true. A lot of things have changed in the last 30 years, especially how we measure speed in our boats.
30 years ago this fall, I bought my second new Boston Whaler, a 1981 Montauk. It was powered by the (then new) 1982 Johnson 90. For 1982 OMC dropped the 85 and the 100 and simply offered a 90 HP model.
That boat was fast. Back then everybody claimed their 90 HP powered Montauks were good for 50 MPH. Of course they weren't but the pitot tube speedometers we used back then, and like I installed in that Montauk, would often show 47-48 MPH if everything was just right and you were going downwind in a light chop trimmed way out. We just rounded up and claimed 50 MPH.
Of course today we know those pitot speedometers always over registered and the amount they erred went up as speed increased. Had we had GPS back then, I suspect we would have found our boats traveling in the low 40s.
Incidentally, back then my Friend Jim Hommel owned a smirkless Montauk with a 1979 Mercury 90 HP six cylinder outboard. In 1981 and 1982 we spent a lot of time together fishing, skiing and SCUBA diving. His boat was no faster than my boat but when it came to water skiing, we always took my boat because it had so much more grunt out of the hole.
jharrell posted 09-22-2011 06:23 PM ET (US)     Profile for jharrell
Since Tom is leaving me hanging, here are the factsfrom Crouch on the Alumacraft Dominator 165 CS:
E-TEC 90: Supposedly 88.8hp according to EPA, 1 man so 1955 lbs, 38.6mph: yields 181.1 hull factor.
Yamaha F90, 2155lbs with two men 39.1mph with 181.1 hull factor: 100.1 HP
Whoops! 100hp out of the Yamaha seems kinda high probably because the E-TEC isn't 88.8hp. Let's try it the other way:
Yamaha F90, 91.1HP from EPA, 2155lbs with two men 39.1mph: yields 190.2 hull factor.
E-TEC 90: 1 man 1955 lbs, 38.6mph, 190.2 hull factor: 80.5HP!
Ouch that's pretty low, let try LHG's 83 HP:
E-TEC 90: 83hp according to LHG, 1 man so 1955 lbs, 38.6mph: yields 187.3 hull factor.
Yamaha F90, 2155lbs with two men 39.1mph with 187.3 hull factor: 93.9 HP
Now that's more reasonable. SO unless the E-TEC had one big guy at 300lbs and the Yamaha two skinny guys at 150lbs, it's seems the Yamaha has more HP.
L H G posted 09-22-2011 06:52 PM ET (US)     Profile for L H G
I'm very happy to see that I am referenced so much of the time in this most spirited of discussions on CW, and that most people agree with my observations! I guess I didn't realize what I was initiating in my first post of 9/19/11.
Continuing, has the Evinrude 90 now earned the name of E-TECOSAURUS?
jharrell posted 09-22-2011 07:32 PM ET (US)     Profile for jharrell
I personally like cbone's [derogatory term for E-TEC]---that's not derogatory is it?
It seem to just represent the facts like the "SAURUS" postfix.
Tohsgib posted 09-22-2011 07:46 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
"Whaler (per Nick and Tom) says 90 powerhead HP (which is 82 prop rated HP) should only fetch 38 MPH."
No Peter....85hp pwerhead rated is 76hp prop which would explain why my 70hp prop rated engine on a jackplate could do 39+.
cbone posted 09-22-2011 08:06 PM ET (US)     Profile for cbone  Send Email to cbone
It all depends on when the strict enforcement of HP ratings went into effect. I would theorize it was 1983-1985 when they swapped over from crank to prop ratings??? I know in the past Kiekhaefer totally disregarded HP ratings and normally underrated his OBs by much more then 10% and the marine industry had very little oversight. I suspect the 1970s/early 1980s had the same lack of oversight. There have been several engines where the higher HP models have been the exact same as the lower HP versions and only the decal was different.
jimh posted 09-22-2011 08:41 PM ET (US)     Profile for jimh  Send Email to jimh
quote:
I personally like cbone's [derogatory term for E-TEC]--that's not derogatory is it?
I don't see where anyone tried to introduce the model name for Evinrude. Evinrude preempted people from inventing model names by providing one, just as Mercury did when they introduced the VERADO. It is only when Mercury can't figure out anything better than "four-stroke" to call their four-cycle outboard engines that we have had to resort to helping them out with fabulously descriptive names like VERADITO and VERADOSAURUS.
Tom W Clark posted 09-22-2011 08:57 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
jharrel -- Good job with the data manipulation. It's fun isn't it? My I have a turn?
Where in the test reports does it say what the total weight of each boat is. I see the F90 powered one but not the E-TEC 90 report. Where does it say how much the persons weigh?
Is the Alumicraft the same boat or merely the same model of boat? One test was from 2007, the other from 2011. Do you suppose everything is exactly the same over those four years? Do you suppose anything might not be accounted for? How about the gas? in 2007 is was probably straight gasoline. In 2011 it is probably E10.
But wait! What about the propellers and RPM? Could there be any difference there? Oh yes, I see that the E-TEC seems to be a little underpropped at 5425 RPM. The Optimal WOT RANGE for the E-TEC 90 is 5000-5200 RPM. Gee, I wonder what might have happened if the tester had used a 19" Viper instead of the 17" Viper? Let's go visit the Propeller Calculator and find out:
http://continuouswave.com/cgi-bin/propcalc.pl
Hmmm...36.8 MPH at 5425 RPM with a 17" prop (and 2:1 gear ratio) is 11.6 percent slip, a rather normal number for the Viper.
OK, we know increasing 2 inches of pitch should drop the engine speed by 300-400 RPM so let's put that, say 350 RPM, deduction into the Propeller Calculator and see what happens:
5075 RPM with a 19" Viper and 11.6 percent slip and we get? 40.4 MPH.
Oops! So much for your argument.
Tom W Clark posted 09-22-2011 08:58 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
But seriously,
[quote]...it's seems the Yamaha has more HP.[quote]
Yes, I agree with you there. The F90 seems to have 2.2 more HP. Not surprising really, given that it has 23 percent greater displacement.
jharrell posted 09-22-2011 09:00 PM ET (US)     Profile for jharrell
Oh yes E-TEC is very original, The most common letter in the English language dash "TEC", very unique and non-descriptive.
Interesting it's not listed on Wikipedia's disambiguation, instead the first entry is a virus that causes diarrhea: http://en.wikipedia.org/wiki/ETEC :)
Wouldn't "D-TEC" make more sense? I guess that doesn't have the same ring to it.
Hey I though I was helping by giving the E-TEC a fabulously descriptive and more unique moniker, there is nothing pejorative in my intentions.
Tom W Clark posted 09-22-2011 09:02 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
cbone wrote:
[quote]There have been several engines where the higher HP models have been the exact same as the lower HP versions and only the decal was different.[quote]
Really? Exactly which ones?
cbone posted 09-22-2011 09:23 PM ET (US)     Profile for cbone  Send Email to cbone
The list is huge. Evinrude Johnson 28hp, 48hp, 65hp, 88hp, 100hp, 110hp, 155hp. Just about every brand used it. Thats not even getting into the engines that we derated in 1985. Mercury and Yamaha all used this and it can even be seen in modern times.
The funny part is that we all pay higher prices for increase HP on the same block when in reality, what does it really cost to increase the HP. In some cases it is most likely cheaper since the tuner can be much smaller.
jharrell posted 09-22-2011 09:37 PM ET (US)     Profile for jharrell
Unless two people weigh the same as one, which there is a slight possibility, the avg male human weight in this country is currently 190lbs, female 164 lbs. Most boat test I have seen specify 200lbs a person with gear.
The dry weight listed is identical, it is the exact same model, why should we assume different? Do you think they put 200 lbs somewhere after market?
quote:
How about the gas?
10 gallons for the Yamaha, 1/3 tank for the E-TEC which for a 20 gallon tank is 6.66 gals. E10 won't help you here.
RPM change would be dependent on HP if slip remains constant, what your essentially saying is the E-TEC makes more HP at 5075 RPM than 5425 RPM? I guess it's possible, Evinrude doesn't seem to know how to prop their boats for their own enigne tests, they seem to chronically run them up to 5500, maybe you should consult with them.
Hey lets do the same with the Yamaha, since it too is running to close to redline. Guess what it's getting 14.9% slip. go to a 21 inch and lower the rpm 350, and it fetches 40.6 mph, still faster with more weight. If we take your advice and stick with 88.8hp for the E-TEC that still puts the Yamaha at 98 HP! That didn't change a thing, but a decent Argumentum Verbosium.
Don't ignore the 8 degree difference in air temp, or do you think colder air doesn't help an engine?
Still waiting on that answer how a Merc, Suzuki and a E-TEC engines scored the exact same power rating down to the 100th kW, don't leave me hanging on that one too.
wstr75 posted 09-22-2011 09:52 PM ET (US)     Profile for wstr75  Send Email to wstr75
My Classic Montauk powered by an E-TEC 90 with Stiletto prop and jackplate does 44.5 mpg as per GPS and registered the same speed going in the opposite direction on a windless day. Here is my post from last year regarding the measurements:
http://continuouswave.com/ubb/Forum4/HTML/007374.html
Correction: 44.5 mph
wstr75 posted 09-22-2011 09:56 PM ET (US)     Profile for wstr75  Send Email to wstr75
jharrell posted 09-22-2011 10:07 PM ET (US)     Profile for jharrell
-16.03% slip is impressive, I knew Stilleto's where tall didn't know Stilleto's where over 2 1/2 inches taller and that's assuming 0% real slip.
Hey where is Peter to come cry foul of this negative slip when I need him.
jharrell posted 09-22-2011 10:36 PM ET (US)     Profile for jharrell
I wonder why divtruk's Montauk is so much slower with the same boat, engine and prop? His prop seems to have -8% slip, instead of the interesting -16%.
Anyway given wstr75 data, the Montauk shows a 188.9 hull factor on Crouch's if Tohsgib's correct and a lightly loaded Montauk is roughly 1600 lbs and Tom/EPA is right with 88.8HP for the E-TEC.
This would mean Jeff's Montauk with a mint Merc 90 inline 6 would be putting out 99 HP to hit 47mph.
cbone posted 09-22-2011 10:41 PM ET (US)     Profile for cbone  Send Email to cbone
44.5 mph when using a jackplate and a stainless steel prop seem about right for 82hp engine on 17 montauk. ;)
jharrell posted 09-22-2011 11:09 PM ET (US)     Profile for jharrell
cbone, I think we are beating a dead Veradosaurus, and it's been extinct a while.
This does raise an interesting thought though, if Evinrude came out with an E-TEC 90 H.O. would it still be listed as 66.19kW with the EPA?
It seem's all the other HO's are listed with exactly the same power as their normal counterpart, does that mean you are paying more for nothing with an HO?
cbone posted 09-22-2011 11:40 PM ET (US)     Profile for cbone  Send Email to cbone
You are paying for the cool stickers!
Don't question the EPA Kw/HP ratings either. They are done in some magical way that no one here can explain but they are certain they are peak HP even though it does not make any sense.
What is the highest post thread here on CW? I think this one will break 200 easily.
Peter posted 09-23-2011 08:33 AM ET (US)     Profile for Peter  Send Email to Peter
Nick -- I believe have it right. Let me spell it out for you.
1. Whaler says 85/90 HP (powerhead rated) is good for 38 MPH. We'll use 85 HP. Under the simple rule that you need to square the HP to double speed, to reach 42.3 MPH, as reported by WSTR75 you would need 105 HP (powerhead rating).
2. You tell us that powerhead rating is about 10 percent higher than propshaft rating. So a 105 HP (powerhead rating) is equal to about 95 HP propshaft rating.
3. Last time I checked 95 does not equal 82. So something isn't quite right with Larry's assertion.
JHarrell -- Back in 2010 when you started promoting the Suzuki DF90A you stated:
quote:
From what I can gather here and from boat tests a modern 90 should get between 39-45 mph depending on how its proped and which engine. For instance the 3 cyclinder Etec at 1296cc seems to top out at 39-40mph on a 17, where a 4 cyclinder 1502cc 90 Suzuki should get 42-43mph.
See continuouswave.com/ubb/Forum4/HTML/007264.html
In light of WSTR75's report of 42.3 MPH without a jack plate, do you think you need to revise your statement regarding the E-TEC's speed capability? Also, since you are taking the position that the Suzuki DF90A should be 3 MPH faster based on a single comparative test report, maybe you should also revise your statement to say that the Suzuki should get 44 to 45 MPH on a Montauk. That promise ought to get some high speed folks (maybe you included) to take the plunge on a Suzuki DF90A so we can get some actual data to see if it lives up to that expectation.
jharrell posted 09-23-2011 09:18 AM ET (US)     Profile for jharrell
Your right Peter, I have been looking for good speed data and fuel burn numbers of modern engines on a Montauk, and at the time I could not find any above that speed, so yes I revise my view in light of new information, see it's not so hard to do ;). 44.5mph seems attainable by one account, although most seem lower than that, it would be interesting to know why.
I wonder if I will ever get such a concession out of you for anything? Maybe you will revise the "-5% is an error" statement about the Suzuki since wstr75 is getting -16%?
I may have to put my money where my mouth is since no one else has taken the plunge with the new DF90a on a Montauk if I want first hand information on how it compares to an E-TEC. By all accounts the old DF70 was a great engine on the Monatuk with extremely good fuel economy and it weighed more with less displacement and power.
jharrell posted 09-23-2011 10:05 AM ET (US)     Profile for jharrell
Peter there where a coupleof gems in that BWB article I didn't even notice, I should have read the conclusion more carefully:
http://www.bwbmag.com/output.cfm?id=943183
"The most impressive aspect of our 90 shoot-out is the closeness of the results. With the exception of the over-revving Suzuki — and again, this engine was limited by available props — the difference between the slowest and fastest was 2.2 mph."
"Quinlan went on to say that there’s no doubt in his mind that if the Suzuki had a bigger prop to keep it within its recommended wide-open-throttle range, it would have been the fastest engine of the bunch."
Care to revise anything yet?
Tom W Clark posted 09-23-2011 10:21 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
All right, lists are fun too!
- We now have aluminum boats used as solid comparisons for the classic Montauk.
- We have the 170 Montauk confused with the classic Montauk in our comparisons.
- We have arguments about motors other than the E-TEC 90 this thread is about.
- We have blindly ignorant statements made with zero supporting evidence because they are what "People" say.
- We have horsepower data from the EPA discredited as meaningless because it's their fault we have Ethanol in our gasoline.
- We have personal first hand experience and speed data from members here dismissed yet speed data provided by the outboard manufacturers themselves promoting their products are taken as Gospel.
- But what we DO NOT have is any credible evidence the Evinrude E-TEC 90 is significantly less powerful and slower than all the other 90 HP outboards being sold.
cbone posted 09-23-2011 10:33 AM ET (US)     Profile for cbone  Send Email to cbone
The horsepower data from the EPA is discredited as meaningless because it is IMPOSSIBLE for three completely different engines, with three completely different technologies, tested on three different dynos, on three different days, in three different locations to be EXACTLY THE SAME.
It is impossible but everyone skips over that fact.
Peter posted 09-23-2011 10:48 AM ET (US)     Profile for Peter  Send Email to Peter
I never said the Suzuki couldn't be the fastest if it was propped to keep it within the recommended WOT range. I only observe that there is no mention of banging off the rev limiter by the BWB crew. Unlike you, the experienced BWB crew doesn't speculate wildly about speeds like 52 MPH.
I do think you should put your money where your mouth is and buy a Suzuki DF90A and put it on the Montauk instead of relying on published manufacturer reports. I have no reason to believe that a Suzuki DF90A does not produce 90 HP (or 82 HP by Larry's standards).
Again, let's refocus your attention back on the assertion by Larry that the E-TEC is an 82 HP motor instead of diverting attention away to other things Do you still believe Larry given the accounts on CW of being able to achieve 42.3 MPH without a jack plate? You previously asserted that it was only good for 39-40 MPH. Apparently, that is factually incorrect.
jharrell posted 09-23-2011 10:55 AM ET (US)     Profile for jharrell
Nope that was used to compare the E-TEC to a Yamaha.
Still waiting on that answer about the 3 different engines. The Evinrude HO listings pretty much discredit the EPA data, either that or Evinrude is ripping people off with the HO's, which one is it?
Who dismissed anything? I certainly didn't.
How much HP difference do you consider significant? 2HP isn't, how about 3? By your own admission the Yahama has more horsepower, the evidence presented shows it to be a greater difference than the EPA numbers, which have evidence to show they are inaccurate to begin with.
Owtrayj25 posted 09-23-2011 10:57 AM ET (US)     Profile for Owtrayj25  Send Email to Owtrayj25
As I read back through this thread, Larry simply made a comparative statement regarding the E-TEC 90 and its apparent horsepower. Since there was an assertion from someone here that the Yamaha 90 2-stroke was in fact only 82/83 HP, and that the E-TEC 90 performed similarly, that the E-TEC should also be proclaimed as only 82/83 HP, at the Yamaha was dubbed. If we are going to arbitrarily re-set the Yamaha 90 to 83 HP, we should be fair and re-set the E-TEC as well, as it performs similarly.
Tom W Clark posted 09-23-2011 11:05 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Owtrayj25 -- You make a good point, though for the record, what Larry said was:
quote:
...the E-tec 90 at 83HP...
This simply is not true.
The two stroke Yamaha 90 does NOT perform like the E-TEC 90. That is clear to anybody who has operated them both, as I have, on classic Montauks. My brother-in-law had a 1988 Montauk with a two stroke Yamaha 90 for several seasons. There is no comparison.
I can assure you that Larry has never in his life operated a classic Montauk with either an Evinrude E-TEC 90 or a Yamaha 90. Have you? Has anybody else here?
Tom W Clark posted 09-23-2011 11:07 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
And, a hundred or so posts later, did anybody here even bother to read the old document about how the EPA tests procedures are conducted, actually at that time, proposed to be conducted?
jharrell posted 09-23-2011 11:18 AM ET (US)     Profile for jharrell
Yes they only speculated 50+.
You said:
Looks like I had the same conclusion as Quinlan from BWB one that you didn't share. I never brought up a limiter you did.
Tohsgib posted 09-23-2011 11:24 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Peter I never said 90hp was my point. I said 85 which is 76prop rated and hence why it does 38. With a proper setup(like my 70 had) I bet 40-41 could be possible and hence why I have seen 39+ with a 70. I did agree that the 100 is 90 @ the prop as you can see where I posted right under you "Yes it is about 10% on outboards and 7% on I/O's." I hope that clears things up.
Tom...yes I have driven both a 90 Yamaha and E-Tec on smirked montauks. The 90 Yamaha(mine 41.5) was faster than Len's E-Tec. Len's neighbor has a red dot 17 with a 90 Yamaha, I think they should race. Len has a lighter hull but heavier engine so it should wash, both have bottom paint. The hulls are 1 or 2 years apart and no jackplates so should be a good match up.
cbone posted 09-23-2011 11:24 AM ET (US)     Profile for cbone  Send Email to cbone
"And, a hundred or so posts later, did anybody here even bother to read the old document about how the EPA tests procedures are conducted, actually at that time, proposed to be conducted?"
Yes I did. And as stated before by you, the EPA does not dyno the engines that manufacturers do. The manufacturers did not call each other up and agree to test the engines in the same location on the same day with the same dyno. So my question stands but you wont answer it.
How is it possible for three completely different engines, with three completely different technologies, tested on three different dynos, on three different days, in three different locations to be EXACTLY THE SAME with not one hundredth a difference in HP difference.
Anyone that has does scientific tests knows that too many variable come into play and that is impossible.
Tom W Clark posted 09-23-2011 11:25 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
So what do the Kw numbers really mean?
cbone posted 09-23-2011 11:28 AM ET (US)     Profile for cbone  Send Email to cbone
EXACTLY!!!!! You tell me. Your the one stating as fact that they are peak dyno HP without proof. You dont know what they mean. But we are all sure they are NOT peak HP as tested on a dyno.
Tom W Clark posted 09-23-2011 11:31 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Why do you say that? It is illogical.
jharrell posted 09-23-2011 11:37 AM ET (US)     Profile for jharrell
I read it, it was extremely long and I could find no details on how engine power was derived, perhaps you could point me to the relevant section, since you seem to know it.
It mentions a "steady state test cycle" which leads here: http://www.dieselnet.com/standards/cycles/iso8178.php
The most relevant note I could find is: "Rated speed is the speed at which the manufacturer specifies the rated engine power"
Generally it seems up to the manufacturer to specify what "rated power" is and the EPA does not test themselves.
So how about those H.O. EPA numbers?
Tom W Clark posted 09-23-2011 11:40 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
But you have not yet explained how you came to that conclusion.
Tohsgib posted 09-23-2011 11:41 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
I like HO's. So did Eddie Murphy & Hugh Grant.
Tom W Clark posted 09-23-2011 11:41 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
We are not discussing diesel engines, were are discussing outboard motors.
jharrell posted 09-23-2011 11:44 AM ET (US)     Profile for jharrell
Please continue, I would like to be enlightened on the source of these numbers. Just a hint, maybe a section number?
Tom W Clark posted 09-23-2011 11:46 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Nick -- You only got 41.5 MPH out of your Yamaha powered Montauk? You should have installed a jackplate on it!
cbone posted 09-23-2011 11:53 AM ET (US)     Profile for cbone  Send Email to cbone
Tom
Also the HO version come out to be exactly the same as the regular version when it has been proven that the HO's perform better. Also because several engines landed directly on the HP which while not impossible would be very difficult once but over four times leads me to believe that these are not peak HP numbers.
Logic shows that these numbers can not be trusted.
Owtrayj25 posted 09-23-2011 11:56 AM ET (US)     Profile for Owtrayj25  Send Email to Owtrayj25
Tom, if you read a little further, you see where his logic comes from. Larry goes on to say
quote:
Jim - With the Yamaha 2-stroke 90 also running the same top end as the Evinrude E-tec 90 reported here, remember that Tom Clark pointed out to us that Yamaha shows that engine as an actual 82 or 83HP.
He must have got that idea from you.
Tom W Clark posted 09-23-2011 11:59 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
So by that reasoning we can throw out the 83.3 HP (found in the EPA data) rating of the old two stroke Yamaha 90.
You can't have it both ways, relying on the EPA data in one case and dismissing it in another.
It seems a 90 HP outboard is a 90 HP outboard.
jharrell posted 09-23-2011 12:04 PM ET (US)     Profile for jharrell
Yes you can, the data comes from two different manufacturers.
If it's up to the manufacturers to test, data from one could be accurate, while another is not.
It sounds to me as though you believe Evinrudes power ratings are accurate. In that case do you believe the 115 HO is actually the same power as the normal 115, and in fact you would just be paying for stickers?
Tom W Clark posted 09-23-2011 12:10 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
This is hilarious! You can choose to believe one manufacturer's data but then dismiss another's arbitrarily?
Hell, you can argue anything in the world, no matter how ricdiculous, if you employ that non-logic.
Owtrayj25 -- The E-TEC 90 on wstr75's Monatuk goes 44.5 MPH.
Nick said his Montauk went 41.5 MPH with its two stroke Yamaha 90.
How can you describe that as "the same top end"?
Tohsgib posted 09-23-2011 12:33 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
I did not have a jackplate. I saved that for the 70 Suzukirude.
jharrell posted 09-23-2011 12:34 PM ET (US)     Profile for jharrell
No I never said I believed one over another, all I said it is possible for one to be accurate and one to be inaccurate therefore if you conclude one to be accurate that does not mean they are all accurate, which you claimed, this would be a logical fallacy of composition.
There are some real problems with the EPA power numbers which you seem to be avoiding at all cost. You also cannot describe how they even obtained the numbers, only pointing to long texts that never mention a power test procedure.
Owtrayj25 posted 09-23-2011 01:00 PM ET (US)     Profile for Owtrayj25  Send Email to Owtrayj25
Sure, with -16% slip??? Man, that E-TEC is indeed magical. Even defies physics....
Tohsgib posted 09-23-2011 01:22 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
I guess I had slip.
K Albus posted 09-23-2011 02:56 PM ET (US)     Profile for K Albus  Send Email to K Albus
In this report from Popular Mechanics back in 2000, the Evinrude (a Ficht, not an E-Tec) was the slowest of five 115 hp motors tested, and of course, the Mercury OptiMax was the fastest: http://www.popularmechanics.com/outdoors/recreation/boating/1276841 . Go get 'em, Larry!
K Albus posted 09-23-2011 03:29 PM ET (US)     Profile for K Albus  Send Email to K Albus
The EPA numbers cited by Jim are self-reported numbers from the engine manufacturers. The EPA regulations cited by Tom Clark do not provide the specifics for how horsepower is measured and reported. They do provided, however, that horsepower is to be measured in accordance with SAE J1228/ISO 8665, which are incorporated into the regulations by reference. Those two standards, however, are generally not available for free on the internet.
I have located an Adobe Flash viewable copy of SAE J1228 on a Chinese website. See: http://www.docin.com/p-122421125.html .
Section 8 of SAE J1228 makes it clear that actual horsepower may vary by up to 10% from declared horsepower:
quote:
The declared (rated) power at declared (rated) engine speed of any individual marine propulsion engine or propulsion system shall not deviate from its measured value by more than:
a. ±5% for engines or propulsion systems with speed governors of more than 100 kW declared power,
b. ±10% or ±0.45 kW, whichever is greater, for all other engines and propulsion systems.
L H G posted 09-23-2011 03:50 PM ET (US)     Profile for L H G
The Evinrude 90 guys are really taking a beating in this thread. It's happening in veradosaurus thread too.
On a related issue ...[the related topic was not an issue and has been deleted from this discussion. Larry has already succeeded in dragging another E-TEC re-powering discussion into a silly lunchroom food fight about non-related topics, and I see nothing useful in adding one more topic.--jimh]
jimh posted 09-23-2011 05:32 PM ET (US)     Profile for jimh  Send Email to jimh
Kevin--Let me direct your attention to your previous statement. Would it be a fair representation of your statement that, by extension, you then must believe that Larry is better able to measure the horsepower of the E-TEC 90 than the EPA can with their testing procedures?
And, as a follow-up, is it your statement also that skillful deduction of horsepower from anecdotal reports of poorly controlled comparison tests is always more accurate than dynamometer measurement of horsepower? Or is only Larry able to do this?
jimh posted 09-23-2011 05:37 PM ET (US)     Profile for jimh  Send Email to jimh
By the way, I think the Flash-from-China document essentially says the same thing the one I have had posted here for about a decade does. See
http://continuouswave.com/whaler/reference/ICOMIA28-83.html
I carefully transcribed that document from a rasterized source a long time ago. I don't think it contains anything new.
Larry--Please stop your efforts to give the E-TEC a name. It already has a name. However, I would appreciate it if you could learn to spell it more accurately. E-TEC is all capitals and with a hyphen. It is always surprising to me how much trouble people have with spelling E-TEC properly.
jimh posted 09-23-2011 05:43 PM ET (US)     Profile for jimh  Send Email to jimh
When Larry says "the Evinrude guys" I assume he means the several hundred Boston Whaler boat owners who selected an E-TEC for re-powering and have written about it here in these pages. I guess the people who are delivering the "beating" are the three guys who still have not bought a modern engine for their Boston Whaler and are running twenty year old two-cycle outboards. That is some beat down, yes sir. The horror, the horror.
K Albus posted 09-23-2011 06:11 PM ET (US)     Profile for K Albus  Send Email to K Albus
Jim - I don't believe the EPA tests many, if any, engines at all. I believe the EPA relies primarily upon data reported to the EPA by the engine manufacturers. I also believe that the self-reported data from the manufacturers is more likely to be accurate that Larry's anecdotal data, or the anecdotal data from any other source.
That being said, however, the SAE standard by which the engine data are to be reported clearly permits a certain amount of inaccuracy. At ± 10%, there could conceivably be as much as a 20% difference in horsepower between two engines nominally designated as 90 horsepower engines. When a manufacturer self-reports that an engine produces 90 horsepower at 5,500 rpm, what they are really reporting is that the engine produces somewhere between 81 and 99 horsepower at 5,550 rpm. In other words, it is quite possible that the E-TEC 90 produces less than 90 peak horsepower, notwithstanding the fact that BRP reports data to the EPA for that motor based on a horsepower rating of 90.
Regarding the SAE standard, I provided the link to that document because that is the document which is actually incorporated by reference into the Code of Federal Regulations. See: http://ecfr.gpoaccess.gov/cgi/t/text/text-idx?c=ecfr& sid=8041bd2bce530a7b3f5e9d76f5ef937b&rgn=div8&view=text&node=40:20.0.1. 1.5.1.1.6&idno=40
jharrell posted 09-23-2011 06:22 PM ET (US)     Profile for jharrell
Perhaps it was Evinrudes intention that it's be associated with the Enterotoxigenic Escherichia coli virus, after all they both should give you quite a "hole shot".
Peter posted 09-23-2011 06:46 PM ET (US)     Profile for Peter  Send Email to Peter
I forgot that Mercury offered a 440 lb V6 OptiMax 115. That product was quite a success in the marketplace. ;)
Before the Evinrude haters get too excited about an Evinrude coming in last....there is something quite peculiar about the test. Read on.
quote:
We needed a test hull that was perfectly balanced, easy to rig, easy to handle, quick to plane, fast, adaptable to five different engines with shaft lengths of either 20 or 25 in., had lots of room for test gear and, last but not least, looked pretty in our photos!
Everyone we talked to suggested Kenner Boats, County Rd. 63 E., Knoxville, AR 72845; 501-885-3171; www.kennerboats.com. Cousins Bill and Dale Kenner enthusiastically agreed to make a stripped version of their center-console 21 V-150, 21 ft. 7 in. long, with a 91-in. beam and 16 degrees transom. It's hand-laid fiberglass, 100 percent foam-filled and covered by a five-year warranty.
This particular hull has the transom cut down to 23 in. and is equipped with an aircraft aluminum CMC Power Lift rated for 300 hp. This allowed us to test engines with either a 20- or 25-in. shaft.
Huh? If I read that right they actually purposely set out to test some 20 inch models and some 25 inch models of 115 HP outboard motors side by side for a "no-holds-barred comparison test of the top five outboards in which 2-stroke, 4-stroke, Ficht and Optimax technologies slug it out head-to-head" before they picked a test boat. If you were going to do a "no-holds-barred" test, why would you choose different motors with different shaft lengths? Who came up with that goofy test protocol?
The Evinrude they tested happened to be one of the two 25 inch models. The other was the Yamaha. The rest were 20 inch models. If you know anything about Evinrudes, the 25 inch model is equipped with a 25 inch leg and the large V6 gearcase housing stuffed with 2.25:1 gears (rather than the 1.85:1 gears used in the V6) not an intermediate size gearcase like the 20 inch models have with 2:1 gears. If you know anything about Yamahas, they get a 25 inch model out of sticking a 5 inch shaft extender onto the 20 inch intermediate size gearcase. The proper testing protocol would have had all of the motors uniformly having either 20 or 25 inch shaft lengths, but more preferrably 20 inch lengths where all motors use intermediate sized gearcases. If they had done that, then they would have had a "no-holds-barred" test.
PM should stick to doing a no-holds barred test on screw drivers and the like.
P.S. PM editors if your reading -- flat head versus flat head or Philips vs Philips not flat head versus Philips versus Torx. OK. ;)
L H G posted 09-23-2011 07:19 PM ET (US)     Profile for L H G
Actually, I think FICHT, E-TEC, BLACK MAX, OPTIMAX, and VERADO are all stupid names. What in the world does E-TEC actually mean? Absolutely nothing, just a corny made-up word, and so are the others.
Actually, the Japanese have made fools out of the Amercian builder's marketing. They are straight and to the point, with no gimmicks. They simply put decals on their engines saying exactly what they are: (brand name) + FOUR STROKE. Some also add EFI to distinguish from carburetors. At some time they might want to use DFI instead of EFI if it ever happens. That's it.
I'm glad to see Mercury now doing what their Japanese competition does, on engines from 2 to 150-HP. No gimmick names. Just plain old 4-stroke decals like the Japanese do, which seems to work since 80% of the market now belongs to FOUR STROKES.
With Mercury and Evinrude, the only builders left of 2-stokes, the words "TWO STROKE" need not be used, because 2-strokes have had 100 years of being the norm. But all these engines really need is a decal that says Evinrude DFI or Mercury DFI, and get rid of the E-TEC and OPTIMAX garbage. I kind of even like "TWO STROKE DFI".
But in the meantime, for the sake of pure entertainment and readship hits, I think the use of dinosaur names is kind of clever.
If some want to point out that they think the brand new Mercury 150 platform is a Japanese style 4-stroke dinosaur, be my guest. If some want to point out that the now 7-year old Evinrude 90 2-stroke is a less powerful, fuel consuming dinosaur, that's fun too.
So keep discussing which dinosaur has what deficiencies. Great reading.
jimh posted 09-23-2011 08:16 PM ET (US)     Profile for jimh  Send Email to jimh
Re engine product names: the Evinrude FICHT was named after the inventor of the injector, a Herr Ficht from Germany. It is not a a "made-up" name. Evinrude actually also called the engine a "Ram Injection" model. This is a very descriptive name, because it describes the mechanism of the injector. So I cannot agree with Larry that Evinrude just "made up silly names" for their Ficht or Ram-Injection engines.
Regarding OptiMax and VERADO, these are made-up names. OptiMax seems to invoke a notion of a combination of optimum and maximum. VERADO is a completely made up word, but with a Latin-sounding root. Maybe Mercury wanted it to appeal to customers in Florida and Latin America. Sales of the VERADO are highly correlated with the inverse of distance from Miami, and anyone who has been to Miami lately knows that Spanish is spoken there more commonly than English. Es la verdad. When I first heard the model name VERADO I was not particularly positive about it, but since then it has become very familiar to me. VERADO immediately describes a specific segment of the Mercury product line. It is a very good name. I have never referred to the engine as anything but a "VERADO" and that is because Mercury has given the product a very good and very distinct name. I do not agree that VERADO engines should be called "Four Stroke" engines.
Evinrude has already said that E-TEC does NOT have a meaning, it is not an acronym. I think the "TEC" is interpreted by most to mean technical or technological. The 'E" as a prefix is just about universally interpreted to mean electronic. Therefore, although Evinrude says that the E-TEC does not have a meaning, for most it likely evokes a notion of electronic technology. Considering we have E-mail, and E-Commerce, I do not think it is particularly very far out of the mainstream to have E-TEC. The only downside to E-TEC is that no one seems to be able to spell it correctly.
I am not ready to pronounce that all American manufacturers ought to throw in the towel and follow the lead of the Japanese. Neither was George Buckley, an engineer with a Ph. D. degree and plenty of savvy business leadership. Buckley drove Mercury Marine and later Brunswick to a new level, a level where they could invent the VERADO--a new propulsion system instead of a copy-cat Japanese four-stroke.
I want to thank Larry for his compliment on the VERADOSAURUS name. It is much appreciated. The thread on the VERADOSAURS is the best collection of information about the new Mercury engine, and it contains by far the best collection of critical comments and observations about the engine. It is the number-one source of information (or pointers to information) about the new engine on the internet. I think the name was responsible for eliciting some of the participation that has occurred there, both on the pro and con side of the arguments.
thegage posted 09-23-2011 10:48 PM ET (US)     Profile for thegage  Send Email to thegage
Do you understand the modern concept of marketing, branding, and the value of being able to trademark a unique "made-up" name? Apparently not.
John K.
Basshole posted 09-24-2011 02:28 AM ET (US)     Profile for Basshole  Send Email to Basshole
Actually Jim, E-TEC stands for Everyone's Totally Excellent Choice! I think Verado would make a good name for a western movie or something. OptiMax would be a great name for a bodybuilding protein powder or a power bar type deal! I can barely pronounce Ficht, that name just straight up sucks! Can't really bag on the Japanese motor names, they're just too normal. Geez, I must be really bored.
jimh posted 09-24-2011 09:20 AM ET (US)     Profile for jimh  Send Email to jimh
I'd like to get this thread back to its original topic, selecting a propeller for a Boston Whaler boat. But let me summarize the sidebars and intentional distractions that have been added:
--a completely specious value for the true horsepower of the E-TEC 90 was introduced. It apparently was invented out of thin air. An irrational attempt to justify it followed. The basis for the horsepower value was deduction of engine power from boat speeds obtained in poorly controlled and randomly reported tests of dissimilar boats and engines;
--a certified value of true horsepower was introduced. This value was based on the accepted dynamometer test procedures used for all outboard spark ignition engines sold in the USA. An irrational attempt was made to discredit this test data on the basis that none of the participants were completely familiar with or could explain in detail the test procedure and its standards. On the other hand, the EPA, the government agency which regulates the sale of outboard engines by measurement of their exhaust emission, apparently is satisfied with the measurements.
The participants then divided into two groups. One group supports the specious value of horsepower based on the anecdotal reports of boat speed, and the second group supports the measured value obtained from the certified test data using a dynamometer.
In my opinion there are actually no participants who really believe the specious value to be true, and their support for it is simply in fun. They do this to enable a discussion to occur, but, being rational, educated, men of science, in their real minds they know the certified and measured value of horsepower is the true figure. Their insistence on using the made-up figure is simply a position they have assumed for sake of argument. This is the only logical assessment. To conclude they actually believed the nonsensical and invented horsepower figure would imply they were fools. I know many of these people and they are not fools. They are just fooling around with this silly number.
Now, let's get back to the propeller selection and recommendations for this Montauk.
jharrell posted 09-24-2011 09:51 AM ET (US)     Profile for jharrell
How do you explain this discrepancy:
250 H.O. from your own photo of it's power plate "These labels are often the best source of information about engine power output." : 186.4kW
http://continuouswave.com/whaler/reference/ETEC250HO.html
250 H.O. from the "certified test data using a dynamometer" EPA: 183.87kW
In fact according to the EPA the 3.3 standard E-TEC 250 has more torque at 629.42Nm than the larger displacement 3.4 HO 250 at 573.33Nm
If we go by your suggestion that the EPA is a reliable source of information there would be absolutely no reason to buy an H.O. engine, in fact Evinrude might be committing fraud by selling an engine as "High Output" when in fact it's output is identical to it's normal variant.
jimh posted 09-24-2011 10:52 AM ET (US)     Profile for jimh  Send Email to jimh
Readers who suspect that Evinrude has committed a crime (fraud) should contact their local prosecutor or attorney general. Please stop trying to drag this topic into the weeds with nonsense.
Any further articles in this thread which do not contain a recommendation for a propeller for the MONTAUK will be deleted.
Tohsgib posted 09-24-2011 10:52 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Larry...Yamaha STILL makes the HPDI in 150-200hp.
Jim I would "imagine" that the E in E-TEC stands for Evinrude and Technology and that BRP is lying to you. If not it is too coincidental being that all they do is hype the technology from pistons made from moonrock to injectors from alien spaceships. Then again the Yamaha V-MAX was a motorcycle that had a V4 engine that kicked absolute but when it was released in 1985. It was STILL kicking butt in 2007 when it was discontinued...unchanged for 22 years. What it has in common with a V6 outboard beats the hell outta me.
It "would" make sense for Mercury to ditch the OptiCrap moniker and go with something simple like Larry stated. Maybe people would buy them.
L H G posted 09-24-2011 11:56 AM ET (US)     Profile for L H G
Getting back to divtruk, it appears choice of propeller was not his question. He seems to have spent money for a 15" BRP aluminum propeller that gives him a poor 38 MPH top end. He has also spent money for a 15" Stiletto, clearly a better prop than the BRP prop, that gives him 41.5 MPH. Considering that his Evinrude 90 has the same 2.0 gear ratio as my Mercuy 115 in-line 6, and turns the same 5500 RPM, and that my Merc powered Montauk runs a 22" pitch Laser II, the 15" pitch prop on the Evinrude 90 sounds right to me. Considering the HP discussion here, I doubt if his engine could turn a 17" Stilletto, even though it should. Tom Clark repeatedly sells the 15 for E-tec 90's on a Montauk.
It also appears that the 2-1/2" height is optimum. When you keep raising a jackplate, and top end slows down, you are too high.
Tohsgib posted 09-24-2011 12:16 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
That depends on the engine and prop. I kept moving mine up in 1" increments until it was not increasing speed, then I lowered it about 1/2 inch. My cav plate was 4.5" above keel, same on my Revenge, both are Suzukis.
Tom W Clark posted 09-24-2011 12:25 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Well, I suppose we could debate it, but why not just let divtruk try a 13-1/4" x 17" Stiletto Advantage and then report back.
Wouldn't that be the most reliable way to see how a 13-1/4" x 17" Stiletto Advantage would perform on his Evinrude E-TEC 90 powered Montauk?
Of is a Mercury 115 on another Montauk with a completely different propeller a better way to determine how a 13-1/4" x 17" Stiletto Advantage would perform on an Evinrude E-TEC 90 powered Montauk?
It seems to me that if the 13-1/4" x 15" Stiletto Advantage on his Evinrude E-TEC 90 is allowing it to reach 5400 RPM at WOT then increasing the pitch to a 13-1/4" x 17" Stiletto Advantage ought to drop his RPM by 300-400 RPM and put it right smack dab in the middle of the 90 HP Evinrude E-TEC's Optimal Engine Speed range of 5000-5200 RPM.
What would happen to his boat speed remains to be seen.
divtruk posted 09-24-2011 01:09 PM ET (US)     Profile for divtruk  Send Email to divtruk
A little history. This E-TEC is not the original motor on this boat. I had bought a 1974 Montauk that had this 90 E-TEC on it. I was going to fix up the Montauk but but discovered there was more work on the hull than I really wanted to perform. Plus I decided I wanted the fiberglass center console.
I located and purchased a 1988 Montauk that had a 1988 Yamaha 2-stroke on it. I removed the Yamaha and installed it on the 1974 hull. After some minor hull repairs and clean up I sold the 1974 Montauk for pretty much what I paid for it.
At that point I did the complete rebuild of the 1988 hull. The jack plate was added not just for better performance as much as I like how it moves all the control cables and wiring a bit farther back so there is less clutter in the back of the boat. Plus it looks nice. The 90 E-TEC had the aluminum prop on it when I bought it. By the way, the 1974 hull did just over 40 mph with the E-TEC with aluminum prop and no jack plate.
I purchased the Stiletto based on the comments from people on this board. That left me with the aluminum prop as a spare. Always nice to have a spare. Another reason I wanted to keep the E-TEC is that the E-TEC is approved for use on Lake Tahoe. The Yamaha was not. Most of the decisions I made were NOT based on seeing how fast I could make this boat go.
jharrell posted 09-24-2011 01:50 PM ET (US)     Profile for jharrell
I would think if divtruk's wanted to improve top speed he should probably look to how wstr75 was able to accomplish 3 more mph with the same boat,prop, and engine, with a similar jack-plate.
Going to the 17 pitch Stilleto should reduce load carrying and hole shot, but the only report I could find of the 17 performance was from meridian, which seems to be the second fastest know Montauk with an E-TEC 90, fetching 44.4mph at 5300rpm.
http://continuouswave.com/ubb/Forum4/HTML/007297.html
If the 17 where to somehow perform like wstr75 15, it should fetch 50mph! Wouldn't that be something.
With so many hundreds of Montauk and E-TEC owners on this board, maybe one of them will chime in with a higher than 44.5 mph top speed with the 90 and what prop they used.
If divtruk has the money to spend, or someone loans him a 17 Stilleto it would be interesting to know what kind of difference it makes, but it really doesn't seem worth it based on what the 15 is capable of.
Tohsgib posted 09-24-2011 02:00 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
If I had his boat I would tweak the 15 to get me down to 5200. If he carries big loads, keep as-is.
Tom W Clark posted 09-24-2011 02:14 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
I am sure divtruk can decide for himself what he wants to do.
I do offer this observation: this boat will perform very differently in Lake Tahoe at over 6000 feet of elevation than in Lake San Antonio at only 800 feet.
At that altitude, the 90 HP E-TEC will be closer to a 75 HP motor and the 13-1/4" x 15" Stiletto Advantage will serve much better.
This also reminds of something else we failed to discuss in this thread, divtruk is operating his boat in freshwater, not saltwater. There will be a significant increase in boat speed is he ever uses it in denser saltwater.
Tohsgib posted 09-24-2011 02:35 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
I would not say it is significant, maybe 1/2mph or so.
Tom W Clark posted 09-24-2011 02:50 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Oh, it makes a significant difference. My boat is 2 MPH faster in the saltchuck than on the lake.
In digging around I found this old thread. I believe the report is credible because it comes from somebody I know, Casey Sears, here in the PNW and it describes his classic Montauk THAT ACTUALLY GOES 50 MPH!
Larry will be heartened to note the motor is a conventional two stroke Mercury, as he has always claimed Mercury outboards are more powerful and faster than anybody else's. He has often claimed a three cylinder Mercury 90 on a Montauk can make it go 50 MPH.
Unfortunately for Larry and his wild claims, this boat has 115 HP motor on it, not a 90 HP motor on it. This top speed was hit under ideal conditions, saltwater, good chop, light fuel load and just one person aboard. The 50.3 MPh top speed is not the average of a two way test run but simply the highest value displayed in the GPS.
Interestingly, he later reports using the same boat, same motor, same propeller on Lake Washington here in Seattle (freshwater, 20 feet elevation) and has this to say:
quote:
I just had my boat on Lake Washington all weekend and did not see over 46.
That is over 4 MPH difference in boat speed between the saltwater of Puget Sound and the freshwater of Lake Washington.
http://continuouswave.com/ubb/Forum4/HTML/001863.html
jharrell posted 09-24-2011 02:55 PM ET (US)     Profile for jharrell
I am glad you have given your blessing to divtruk, otherwise he may have taken your advice as gospel and not an opinion.
I wonder which lake wstr75 runs his boat in, I know Aquone Lake, NC is over 3000ft elevation.
Imagine what wstr75's boat would do in salt water, do you think it could hit -20% slip?
There must surely be an E-TEC 90 on a Montauk that can break 45mph if run in salt at sea-level given Tom's insight?
jimh posted 09-24-2011 03:27 PM ET (US)     Profile for jimh  Send Email to jimh
Tom--Thanks for pointing out another example of how the top speed a boat can reach can be highly variable with environment and atmospheric conditions. I noted the exact same variation, 4-MPH, and provided an earlier example. Yours is even better since it came with a Mercury motor attached. Imagine that!
Tom W Clark posted 09-24-2011 04:02 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Let's just take Casey's report at face value and assume his Montauk went 50.3 MPH with a 115 HP motor.
Would somebody be so kind as to run those numbers through Crouch's Speed Calculator and then tell us what the predicted speed would have been, ceteris paribus, if the motor were only a 90 HP motor?
jharrell posted 09-24-2011 06:09 PM ET (US)     Profile for jharrell
44.5 mph, see I don't leave you hanging, it would be nice to return the favor.
Now given ceteris paribus and PSW did not have a jack-plate with the motor mounted only 1 1/3" up:
http://continuouswave.com/ubb/Forum4/HTML/001695.html
We should deduce a E-TEC 90 will not need a setback nor be mounted any higher to attain 44.5mph if it is a 90 HP motor ceteris paribus.
Also PSW lost 4mph by simply going from fresh to salt water! Given ceteris paribus wstr75's Montauk should reach 48.5 mph in salt water!
Surely there are many Montauk's run in salt water with an E-TEC 90, we should have many reports of over 45+mph with this boat/engine combination, hopefully someone will speak up to confirm.
divtruk posted 09-24-2011 07:18 PM ET (US)     Profile for divtruk  Send Email to divtruk
I will give you a top speed next time I have the boat out on Monterey Bay.
Tohsgib posted 09-24-2011 08:43 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
"Surely there are many Montauk's run in salt water with an E-TEC 90, we should have many reports of over 45+mph with this boat/engine combination, hopefully someone will speak up to confirm."
No offense but I doubt that will happen.
WT posted 09-24-2011 10:36 PM ET (US)     Profile for WT  Send Email to WT
"I will give you a top speed next time I have the boat out on Monterey Bay."
I'm not sure I'd want to hit even a 1 foot swell at 45 mph on a Montauk.
But I think a perfect spot for a saltwater speed check might be in Bodega Bay Harbor. There is a 1 mile straight away perfectly suited for a speed run if the wind isn't too bad.
http://img.photobucket.com/albums/v665/warrent/Misc/BodegaBayHarbor.gif
Hitting a swell in Monterey Bay at 44 -45 mph?
http://smg.photobucket.com/albums/v665/warrent/ 170%20Montauk%20speed%20runs/?action=view¤t=2010-05-15083752.mp4
http://smg.photobucket.com/albums/v665/warrent/ 170%20Montauk%20speed%20runs/?action=view¤t=2010-05-15083046.mp4
I'm hoping to see my top speeds increase by 2 mph the next chance I get in Bodega Bay Harbor. I never knew about the saltwater effect on the hull.
Good luck and have fun.
Warren
divtruk posted 09-25-2011 01:56 AM ET (US)     Profile for divtruk  Send Email to divtruk
If the swell is from the NW, the area right off the Santa Cruz boardwalk is usually pretty calm. I have even seen it glassy over there. With a SW swell the area off Del Monte Beach in Monterey gets pretty flat. Its all a matter of what conditions and where you are.
WT posted 09-25-2011 02:47 AM ET (US)     Profile for WT  Send Email to WT
I'd sure hate for my prop to suddenly come out of the water when it's spinning at 6,000 rpm and trimmed up to the nth degree. I suppose the rev limiter would prevent our pistons from flying out from under the cowling.
My 170 Montauk's hull weighs 1400 pounds and your classic Montauk's hull weights just 900 pounds. It wouldn't take much to get you airborne.
Good luck and keep us posted.
Warren
WT posted 09-25-2011 03:57 AM ET (US)     Profile for WT  Send Email to WT
I'm not sure if this was mentioned before but divtruk's test runs at Lake San Antonio are about 900 feet above sea level. Perhaps the higher elevation had adverse effects on WOT speeds?
Warren
jimh posted 09-25-2011 08:42 AM ET (US)     Profile for jimh  Send Email to jimh
Boat is speed is assumed to always be proportional to horsepower to the 0.5 exponent. If a boat goes 50.3 with 115-HP, then with 90-HP it would go
(90/115)^0.5 x 50.3 = 44.5-MPH
prj posted 09-25-2011 10:41 AM ET (US)     Profile for prj  Send Email to prj
wstr 75's WOT speed with his E-TEC XX HP is a clear outlier. It is the lone example of traditional 90 HP / Montauk performance achieved with the E-TEC.
Can anyone vouch for this fellow's identity? Has anyone seen wstr 75 and jimh in the same room?
Tom W Clark posted 09-25-2011 01:45 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Thanks for doing the math Jim. Yes, 44.5 MPH is what I come up with when I calculate what the top speed of Casey's boat would have been, ceteris paribus, if his Montauk had a 90 HP motor on instead of a 115 HP motor on it.
Likewise, during the weekend spent on Lake Washington when Casey's Montauk could not go faster than 46 MPH with its 115 HP motor, it would have, ceteris paribus, only have gone 40.7 MPH if it had had only a 90 HP motor.
This range, 40.7 MPH to 44.5 MPH sounds familiar. It does in fact, correspond nicely with the reported top speeds of classic Montauk equipped with Evinrude E-TEC 90 HP motors on them.
This should not come as any surprise because it also corresponds closely to all reported top speeds of classic Montauk with 90 HP motors on them, regardless of brand.
The question was posed: Where are the Evinrude E-TEC 90 powered classic Montauks that go faster than 45 MPH? I ask: Where are the Montauks with 90 HP outboard of any brand that go faster than 45 MPH?
This is a long thread so it may be worth repeating what I wrote long ago:
"... a 90 HP outboard on a classic Montauk is good for a top speed in the low 40s."
Please, somebody shown me, with some credible evidence, how that general statement is wrong. I have yet to see any in this thread.
Tom W Clark posted 09-25-2011 01:52 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Warren,
At 900 feet of elevation there would be, ceteris paribus, a 2.7 percent loss of horsepower because the air grows thinner with altitude and holds less oxygen.
Here is one of many online calculators that help compute the loss of horsepower with altitude:
http://www.wallaceracing.com/braking-hp.php
wstr75 posted 09-25-2011 04:29 PM ET (US)     Profile for wstr75  Send Email to wstr75
You guys have got me doubting who I am, what I do and so forth. I will attempt to re-do my speed run again one day this fall. The boat has the GPS system module integrated with the Evinrude motor controls and also a separate Lowrance HDS-5 GPS. Here is the info regarding the lake and elevation: http://en.wikipedia.org/wiki/Badin_Lake
Maybe, just maybe my 90 E-TEC is slightly stronger than the average E-TEC. There is something called a bell curve, i.e. normal distribution and bell curves have tails.
http://en.wikipedia.org/wiki/Normal_distribution
Scroll down in the above link to the bell curve diagram and at the two sigma point there is 2.2% of the population from there to the end on the right side tail. Perhaps my lovely 90 E-TEC is one of those 2.2% motors and has an extra three or four hp. Perhaps my newly restored and polished hull last year was also in the top 2.2% bracket for "surface drag factor". Then again, maybe there was an ideal itty bitty bit of ideal chop (again the beyond two sigma zone, i.e. 2.2% of surface conditions) for putting energy saving/speed enhancing air under the hull.
Then again, maybe my GPS is somehow off and is lying to me. I truly don't know. As a guy who designs and sells mechanical stuff dealing with water flows, in reading everyone's technical arguments, my instinct is to doubt my speed number. My only counter argument is the two sigma outlier possibility. I welcome your comments pro and con.
Bill in NC
wstr75 posted 09-25-2011 04:32 PM ET (US)     Profile for wstr75  Send Email to wstr75
This will make it easier:
jharrell posted 09-25-2011 04:54 PM ET (US)     Profile for jharrell
How did you determine wstr75 was credible while Jeff was not?
Tom W Clark posted 09-25-2011 05:04 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
I don't.
Again, somebody show me, with some credible evidence, how a classic Montauk with 90 HP on it should NOT be expected to achieve a top speed between 40 and 45 MPH.
jharrell posted 09-25-2011 05:25 PM ET (US)     Profile for jharrell
Well Jeff achieved 47mph, which is outside the range of 40-45mph, so unless you do not think Jeff is credible, there is your evidence.
Tom W Clark posted 09-25-2011 05:48 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
A single data point is not very meaningful, don't you think?
jharrell posted 09-25-2011 06:48 PM ET (US)     Profile for jharrell
How many data points show 45mph? There so far is a single data point at 44.5mph yet you seem to give it credence, why not Jeff's?
Tom W Clark posted 09-25-2011 07:08 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Actually, I give equal credence to both Jeff and wstr75's reports, which is to say, they are suspect.
I am also sure they both are being perfectly honest in what they report. Just as I certainly do not think anybody else here is lying though it may be that some participants here are mistaken.
However, wstr75's boat is not the only report of a Montauk with an Evinrude E-TEC 90 HP outboard going 44.5 MPH. Meridian's does too. We have seen no reports in this thread of any 90 HP powered Montauks going 45 MPH, Jeff's notwithstanding.
This thread started with divtruk being generous to share with us his own data points as precisely as he could. I thank him for that. It is through reports like these that we all learn more about the performance potential of these classic Boston Whalers.
Then there was, very early on, a certain participant who came in here and crapped all over drivtruk's thread by interjecting his usual BS. We've been trying to clean up the mess ever since.
jimh posted 09-25-2011 08:18 PM ET (US)     Profile for jimh  Send Email to jimh
Tom--Your observation is very acute.
jharrell posted 09-25-2011 08:23 PM ET (US)     Profile for jharrell
Ah so it takes two reports. What about Clark Roberts: "I ran a 20" pitch Quicksilver High Five (five blades/stainless) on a 1978 seventeen Newport with 1995/96 Merc 90 for several years. It would run (lightly loaded) at 46mph anytime and would hit right at 50mph on a cool day with a little chop on the water."
http://continuouswave.com/ubb/Forum4/HTML/002718.html
Is that good enough?
Tom W Clark posted 09-25-2011 08:33 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
I think Clark's report, for obvious reasons, remains suspect.
Clark Roberts is a longtime Continuous-Wave participant, a good guy who knows how to hotrod a Whaler. I invite Clark Roberts to join this discussion and tell us about that 1978 Newport and how he measured his boat speed.
Owtrayj25 posted 09-25-2011 08:43 PM ET (US)     Profile for Owtrayj25  Send Email to Owtrayj25
Maybe Clark had the aide of Mother Nature (wind, tide???) like Casey Sears acknowledged in his report of 50.3 MPH, yet that data point was immediately accepted into the discussion as fact in order to deduce other speed estimates. HHHmmm....
jharrell posted 09-25-2011 08:48 PM ET (US)     Profile for jharrell
I detect a pattern, if the report does not agree with your premise it is suspect. That is normally called cherry picking.
Why was meridian's report given any more credence than Jeff's, Clark's or wstr75's?
prj posted 09-25-2011 09:11 PM ET (US)     Profile for prj  Send Email to prj
The suggestion that this continuing discussion has anything to do with divtruk's fabulous Montauk and repower is a distraction. It was recommended that the actual meat be separated probably 100 replies ago. That way the content of the article would be more reliably connected to the title of the article.
Furthermore, Bill's response earlier this afternoon, after the Lions finished dismantling the Vikings, is perfectly reasonable and well expressed. I'm only slightly more certain that this "Bill" fella, with his engineering background, precise and circumspect use of the english language and completed profile isn't our esteemed moderator. Would you have spelled it Thermaco or ThermaCo, Bill?
wstr75 posted 09-25-2011 10:43 PM ET (US)     Profile for wstr75  Send Email to wstr75
You can call our company name anyway you like as long as you call us. I enjoy the postings of this community and have learned much about Boston Whalers, propellers, engines, trailers, safety practices and a myriad of other neat stuff like West Coast (Pacific) wave dynamics from all of you.
Functional products that are simple and elegant are often the hardest to design. In my humble opinion, the Classic Whaler designs are simple and elegant yet are quite tough with surprisingly good performance with minimal power. My thanks to the moderators and the many contributors on this forum.
Bill in NC
Tom W Clark posted 09-26-2011 09:52 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Owtrayj25-- Casey acknowledged his top speed test run was under ideal conditions and NOT an average of a two way test run. That was precisely my point; along with saltwater, there are several environmental factors that can help a boat go (or appear) faster one day than the next.
The same may have been true of Clark's boat, but his claimed 50 MPH was achieved with only a 90 HP motor not a 115 HP motor. Furthermore, with a 20" HighFive that 90 would have to be turning about 6500 RPM. That is why that data point is suspect. But again, I invite Clark to join us and talk about that boat.
Tom W Clark posted 09-26-2011 10:10 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
jharrell -- The pattern is the same for both you and I. Outlier data points raise eyebrows.
Meridian's boat used a 13-1/4" x 17" Stiletto Advantage not a 13-1/4" x 15" Stiletto Advantage. 44.5 MPH at 5400 RPM is believable with the 17 inch pitch, less so with the 15 inch, as you have already noted.
And, of course, Jeff and Clark's reports are true outliers, wstr75's is not.
Owtrayj25 posted 09-26-2011 10:35 AM ET (US)     Profile for Owtrayj25  Send Email to Owtrayj25
Tom, my point was that this data, obviously flawed, was used to back into a potential for speed of the E-TEC; perhaps you were just demonstrating the absurdity of it all, and I was just too thick to get your point.
But what really frustrated many here is the reliance on EPA data presented as the basis for authenticating horsepower of various engines. This data has on many occasion proven to be unreliable, and in many cases, impossible to achieve (e.g. 3 engines of differing brand, with differing technologies ALL cited as having precisely the same power output). It was then discovered that the EPA does not test the engines at all, yet relies on the manufacturers to present the data, and provides testing procedures which allow for a 10% deviation in cowl HP. That to me does not seem to be an accurate way to determine a precise power output of an outboard engine.
These types of citations of the EPA data is what started this whole absurd exchange on power output of competing engines. I believe the EPA data was collected and presented as a means to attach emission levels to different marine engines, not authenticate a particular engines precise horsepower. With all of the inconsistent information presented in the EPA data, some here want to continually point to this document as a means to authenticate horsepower, as if a government agency is incapable of collecting and publishing misleading information. C'mon, this is the same government sending billions of dollars to dead social security recipients, and $14T in debt. Sheesh.
jharrell posted 09-26-2011 10:41 AM ET (US)     Profile for jharrell
Clark notes 5700rpm here: http://continuouswave.com/ubb/Forum4/HTML/003487.html
That model Merc was a 2.33:1 ratio correct? If so that shows -7.92% slip with a 20p prop at 50mph. This is half the slip wstr75 reports, and slightly less than divtruk reports at -8.21%. Even meridian is shows -4.31% slip at 5300rpm with his 17p.
Perhaps the high five prop has similar under rated pitch just as the stiletto obviously does.
wstr75 posted 09-26-2011 11:59 AM ET (US)     Profile for wstr75  Send Email to wstr75
I went out this morning to read the pitch/diameter information on my Stiletto prop and could not find any numbers or any kind of stamped information on the prop blades, outer hub or inner hub. The Stiletto name tag label is still glued tightly to the hub. Would the ID and size info be underneath the label? I welcome suggestions as to where to find the ID and size info on the propeller. I searched the Internet for Stiletto's manufacturing/customer service site and was unable to get to someone who could instruct me on how to determine the prop's lineage.
This prop was installed at the dealer where the boat was repowered (and rehabilitated). I instructed the dealer to install a 15" Stiletto prop as per Tom Clark (and others) comments on this forum. Dealers being dealers have lots of stuff going on in the springtime and I'm now trying to conclusively determine what size/dimension prop is on the motor.
Bill in NC
Tom W Clark posted 09-26-2011 12:03 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Checking my file of propeller tests I have personally conducted I found a test sheet for a pair of 19" High Fives. 5900 RPM at 46 MPH through a 2:1 gear ratio is 13.3 percent slip, which is a little higher than most props but tremendously so.
Tom W Clark posted 09-26-2011 12:06 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Bill, the part number is on the aft end of the hub casting. You may have to remove the prop nut and spacer washer to see it.
If the prop is a 13-1/4" x 15" Stiletto Advantage I, the part number will be (in part) 1315. If it is a 13-1/4" x 17" Stiletto Advantage I, the part number will be 1317.
Tom W Clark posted 09-26-2011 12:12 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Owtrayj25 -- I understand what you are saying about Casey's top speed report. However, unless you believe he was actually underreporting his to speed, my argument is only strengthened if you consider that the top speed may be overstated.
And no, this thread is not about the EPA power ratings, it is about the conjecture that the E-TEC 90 is not a (roughly) 90 HP outboard. I have shown that this cannot be the case and arguments against this position have fallen flat.
wstr75 posted 09-26-2011 12:54 PM ET (US)     Profile for wstr75  Send Email to wstr75
Thank you Mr. Clark. I raised the motor, looked down into the hub nut area and, viola!, discovered my 15" prop was a 17" prop! The numbers were 21317 and 01317.
Here are my thoughts:
1. My E-TEC 90 is putting out pretty good horsepower numbers.
2. My prop slippage factor with the 17" wheel is within the expected range.
3. My recollection of that afternoon's speed run was the rpm indicator jumped around a bit. I-Command is all electronic and as such is supposed to to be uber accurate, but oftentimes it seems to "round up" or "round down" the rpm number. Like when the motor is idling, it jumps up and down 50 rpm when it is obvious the motor rpm holding a steady beat. It does the same thing at wide open throttle with rpm numbers jumping around all while the motor's tone is sounding constant. I will get out on the water sometime this fall to re-do the speed run and will give special attention to the rpm.
That's my $0.02 and personal research on this subject. I welcome any and all comments.
Bill in NC
prj posted 09-26-2011 12:56 PM ET (US)     Profile for prj  Send Email to prj
I'm not certain thats what this article is about at all, Tom. I think the argument is that the E-TEC 90 is the weakest, or among the weakest engines labeled "90 HP". This exact assertion was put forth as Option A in the tenth post of this lengthy article.
While some have asserted that the engine may more accurately be called the E-TEC 83 HP, that was done partially in jest and consistent with jimh's relabeling of his favorite whipping boy brand.
We can all find anecdotal reports with outlier results. But we also can all see that the compelling majority of performance reports tell us WOT speeds from the E-TEC are lower than most other engines.
Tom W Clark posted 09-26-2011 12:58 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Given the fact that Bill's propeller is, in fact, a 13-1/4" x 17" Stiletto Advantage, I now retract my suggestion that Bill's report is an outlier data point.
Tom W Clark posted 09-26-2011 01:00 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Patrick -- Let me repharse what I have repeated several times in this thread:
If the Evinrude E-TEC 90 is weaker than all other 90 HP motors made, where is the credible evidence that supports this?
Tom W Clark posted 09-26-2011 01:05 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
quote:
...we also can all see that the compelling majority of performance reports tell us WOT speeds from the E-TEC are lower than most other engines.
No, that is simply not true and again invite anybody to provide credible evidence of this not being so.
L H G posted 09-26-2011 06:43 PM ET (US)     Profile for L H G
[Off-topic. Please recall we are discussing the E-TEC 90 on a Montauk. Please start a new discussion to begin to predict the outcome of hypothetical boat and motor comparisons. Thanks--jimh]
L H G posted 09-27-2011 02:29 PM ET (US)     Profile for L H G
I guess we have established that there is ton of credible evidence that the majority of E-tec 90 powered Montauks on CW run about 38-41 MPH top end, with a non-representative one or two maybe reaching 43MPH. That's about it, and that means they are generally a slow 90, or a normal 83.
I see a lot of Montauks out on the water in the various places where I boat, but I have only seen one with an Evinrude 90 E-tec on it. The others are all running other engines, many with OMC V-4's and various Mercs. I guess almost all of the E-tec 90 powered Montauks on are on this site, but nowhere else. What do we have, maybe 30 E-tec 90 powered Montauks actually participating here? Didn't Boston Whaler sell 100,000 17 hulls?
jimh posted 09-27-2011 04:12 PM ET (US)     Profile for jimh  Send Email to jimh
Larry--You should spend a few moments learning to spell E-TEC. If you put one-ten-thousandths as much effort into learning to spell E-TEC as you did into making up stuff about it, your comments would have more validity.
L H G posted 09-27-2011 04:39 PM ET (US)     Profile for L H G
Jim, I will concentrate on that if I ever should mention the name again. But other than you, Tom and Peter, people know none of this is made up. I have just indicated what I have read here. Now, I suppose it's possible that folks like Jeff, Clark Roberts, and many, many others, are the ones that "made stuff up"? The engine, whatever it's horsepower atually is, speaks for itself. And for many, a top speed of 41 MPH is fine for a Montauk, and more than some need. Most people with Montauks powered by the 83HP Yamaha 90 are also happy with the same 41 MPH.
macfam posted 09-27-2011 08:04 PM ET (US)     Profile for macfam  Send Email to macfam
Come to Falmouth, Cape Cod, with 14 harbors. The original home of Boston Whaler (During the years before the move to Edgewater FL., Cape Cod was always the top selling dealer(s) for Boston Whalers)
There are very many Montauks with 90 E-TECs in every harbor. I see them every week. They look great, and seem to run great.
Several boaters have beached nearby, and we talk "Whalers".
From the discussions I've had with a few, they seem "over the top" pleased with the E-TEC's. Perhaps it's the way they start, or the no smoke....but if it's anything like my 30 E-TEC, it's because the have all the attributes of great 2-strokes.....with the "pleasures" of great 4-strokes.....except the maintenance.
The 90 E-TEC has been very well received......and from what I see...even with 4-5 teenagers loaded in.....sure tow skiers and tubes like crazy.
Local dealer (Edward's Boat Yard) says they are the "perfect match".
I wish I could say I've driven one...........
L H G posted 09-27-2011 09:42 PM ET (US)     Profile for L H G
Edwards Boatyard is a Seaswirl, Parker and Evinrude dealer, so from his perspective an Evinrude would be a perfect match for any boat, even a Montauk. But I would concede an Evinrude 90 is a good match for a Montauk as are about 10 other engines of various year, HP and brand.
I'll even bet the local Whaler Dealer, Nauset Marine, would diagree with him and say Mercurys are THE perfect match for a Whaler!
Tom W Clark posted 09-28-2011 12:44 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Credible evidence?
Anybody?
Bueller?
prj posted 09-28-2011 10:34 AM ET (US)     Profile for prj  Send Email to prj
I've spent some time searching and find that I'm either using the wrong search terms or Montauk owners do a poor job of accurately and legibly reporting performance.
At the risk of letting you cherry-pick data to fit your claim, please provide credible links showing the E-TEC achieving the 43-45 MPH expected top speed that I keep reading a 90 HP yields on a Classic Montauk.
Tom W Clark posted 09-28-2011 11:24 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
quote:
...the 43-45 MPH expected top speed that I keep reading a 90 HP yields on a Classic Montauk.
Now Patrick, you are beginning to get closer to the truth. I've used the search feature too and keep seeing themes repeated. Perhaps the most prominent theme is that a Mercury 90 can make a Montauk go 50 MPH, or close to it, and as a corollary, a Mercury 90 HP outboard is faster than any other brand of 90 HP outboard.
It has become clear the basis of this theme comes from one enthusiastic and long time Continuous-Wave participant who latched on to the Clark Roberts reports cited earlier in this thread. From the time those reports emerged six or seven or eight years ago, this participant has repeated at every opportunity, that a 90 HP Mercury should be good for 50 MPH, or close to it, on a classic 16'-7" Whaler.
Over and over, in thread after thread, a single data point has now become legendary and has grown to become part of the performance culture around here. Your Montauk only goes between 40 and 45 MPH? Well, you should have a Mercury 90 on it. Clark Roberts reports the three cylinder Mercury 90 is good for 48 MPH!
I'll say it again: A classic Montauk with a 90 HP E-TEC, or any other brand and model of outboard motor is good for a top speed in the low 40s, with the ultimate top speed dependent on any number of environmental and load conditions. Until somebody undertakes a comprehensive review of all performance reports of Classic Montauks and enters said data into a spreadsheet for critical analysis, there will always be the opportunity for accusations of "cherry picking".
And for anybody who believes a Montauk (or a Newport) can go 50 MPH (or even 48) with a three cylinder Mercury 90 turning a 20" HighFive propeller, I have a bridge I'd like to sell you.
L H G posted 09-28-2011 06:53 PM ET (US)     Profile for L H G
Nobody is talking about Montauks going 50 MPH with a 90. You generally need a 115 to do that, and EVERYBODY knows that. We are just reporting that E-TEC 90 owners here are consistently reporting 41 MPH with a Stilleto 15" performance prop sold by Tom, and less than that with aluminum props.
So the real question, is 41 slow for a 90? I think it is.
Boston Whaler sold a lot of classic white Montauks before the newer 170 came out, with Merc 90 2 and 4-stroke engines. To help answer Tom's question, can anybody dig up those archived BW performance reports? I want to say I remember 44 MPH.
Here's a performance calculation some of you engine guys can make for me. I am curious how much HP I am using in my own Montauk to go 42 MPH. It has a 115 HP engine, 2.0 gearing just like the E-TEC, and when running a Mercury 21" pitch Black Max aluminum prop, easily loafs along at 42 MPH turning 4500 RPM. How much HP is being used to reach that speed? I haven't had the right conditions to test top end speed with this prop, but it will turn the engine up to 5500 easily. A 22" Laser II should end up being the permanent prop for this rig at a scary fast 52 MPH. Just a guess.
Tom W Clark posted 09-28-2011 08:37 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Larry - That's not very nice of you to suggest Clark Roberts is a liar. He's been around longer as you have and has owned more Whalers and more outboard motors than you have.
We are talking about the classic Montauk here. The Montauk 170 is a completely different boat. When we find a Montauk 170 repowered with an E-TEC 90, it might be fun to compare them.
Also, when, and if, you ever get your Montauk to achieve WOT, please do let us know how fast it goes and at what RPM it does so with whatever propeller you choose to use. It will be fun to see how it does.
In the mean time, let us continue to discuss the 41, 42, 43 and 44.5 MPH Montauk/E-TEC 90s that have become so popular.
cbone posted 09-28-2011 11:19 PM ET (US)     Profile for cbone  Send Email to cbone
I am not sure that we are comparing apples to apples though.
These E-Tec numbers seem to be done with modern stainless steel props and jackplates. These boats have been dialed in and run very well.
I wonder what a v4 crossflow 90hp OMC with a jackplate and stainless steel prop can run with proper set up. Dont they run 42-43 with aluminum props while mounted on the transom?
I feel that 41-44mph is the average top speed but I feel like that is comparing against other engines on the transom swinging an aluminum wheel.
Is that true?
These numbers mean nothing without the setup information. As we have seen in the orginal post, 1/2 inch higher is good for over 1 mph.
cbone posted 10-04-2011 05:39 PM ET (US)     Profile for cbone  Send Email to cbone
Barnacle is claim 50mph+ with a 90hp on 17 whaler. I wonder if that is with a jackplate.
prj posted 10-04-2011 06:00 PM ET (US)     Profile for prj  Send Email to prj
Feh. Unsubstantiated outlier, like a 45 MPH E-TEC.
Russ 13 posted 10-05-2011 02:58 AM ET (US)     Profile for Russ 13  Send Email to Russ 13
Back in 2001 I owned a 17 Montauk with the three cylinder 90 HP Mercury. It ran 47-48 with a 19P vented stiletto.
A great combo. Wish I still had it.
Also the 90 Yamaha @ 260lbs is a great match for the 15'.
So I would speculate from the above info. that the two stroke 90 Mercury three cylinder engines were more powerfull than the new E-Tech. 90.
Russ 13 posted 10-05-2011 03:33 AM ET (US)     Profile for Russ 13  Send Email to Russ 13
The above speed was from GPS, engine mounted third hole up with one person onboard, light fuel & gear load, light chop, in saltwater.
As much up trim as possible, before prop blowout.
All sad that the new Mercury's are soooo heavy.
With the four strokes & their related weight, I
guess Tohatsu & Evenrude are the only current contenders.
jimh posted 10-05-2011 08:08 AM ET (US)     Profile for jimh  Send Email to jimh
What is this E-tech engine that people keep talking about in this discussion?
jharrell posted 10-05-2011 10:53 AM ET (US)     Profile for jharrell
The standard abbreviation for technology is "tech" so it is no wonder the average person would remember the engine name as E-TECH rather than E-TEC, just a easy to make mistake since "tec" is not an abbreviation for anything common or remotely related to outboards. If you had only heard the name "E-TEC" spoken aloud it would be natural to assume "tech".
http://en.wikipedia.org/wiki/Tech
The data points keep stacking up for Mercury motors exceeding 44.5 mph on a classic 17 hull, how many must be reported before the possibility is accepted by the E-TEC adherents?
cbone posted 10-05-2011 11:31 AM ET (US)     Profile for cbone  Send Email to cbone
It seems like we are comparing the E-Tec running jackplates and modern stainless steel props against everyone else mounted on the transom with aluminum props.
jimh posted 10-05-2011 12:56 PM ET (US)     Profile for jimh  Send Email to jimh
My impression from reading owner comments about classic Boston Whaler MONTAUK 17 hulls re-powered with the E-TEC 90-HP--and that's exactly what you get, 90-HP--is the owners are all quite satisfied and happy.
There seems to be a relentless and ineluctable force--actually a cadre of Mercury fans--that want to insist that owners of the MONTAUK 17 and E-TEC 90-HP combination are missing something. My impression of what those E-TEC 90 owners are missing is as follows:
--they are missing the smoke in the exhaust of their engine
--they are missing the rough starting and poor idle characteristics in their engines
--they are missing having to change spark plugs, water pump impellers, and gear case lubricant every year in their engines
--they are missing the noise, vibration, and harshness in their engines
--they are missing the bad fuel economy in their engines
--they are missing the prohibitively high exhaust gas emissions in their engines,
and, if you believe a few anecdotal reports of not particularly well controlled boat speed comparisons,
--they may be missing one or two miles per hour in top speed.
It is also my impression that the owners of the E-TEC 90 engines are NOT missing any of the following:
--fantastic engine torque and acceleration
--engine size, weight, and proportions that are appropriate for the MONTAUK 17
--ability to utilize modern electronic instrumentation networking like NMEA-2000
--spending more time on the water.
I suppose we can keep this thread going on longer, maybe to 300-articles, and we can keep finding some Boston Whaler boat with some motor in some conditions with some measurement of speed which shows that a 90-HP can run faster than 44-MPH.
L H G posted 10-05-2011 02:03 PM ET (US)     Profile for L H G
Come on, Jim, what a bunch of pro-E-TEC exaggerated baloney.
In spite of Tom Clark's accusation, I am happy to see that Russ has collaborated the results that our highly esteemed contributor Clark Roberts has also indicated. So now it appears we have a situation where the Merc 90 2-stroke is possibly over 90 HP, and the E-TEC 90 is definitely less, with about 44 MPH being a good average for a TRUE 90, such as an old OMC V-4 in either 90 degree or 60 degree configuration, or any of the current 4-strokes. Merc L6 "towers" are too powerful for this discussion!
Russ 13 posted 10-05-2011 10:12 PM ET (US)     Profile for Russ 13  Send Email to Russ 13
I know my addition to this thread is a "tad" late.
The prop I used was a Stainless Stiletto 19P.
The boat ran a solid 47 MPH,
whenever I wanted to air it out.
As for the "smoke", TCW-3 oils stopped most of that.
Changing your gear lube every season is a good idea.
The water pump impeller, IF you don't run aground in sand
they should last several seasons (Five is a good #)
I'll give you the spark plug reason, I did have to change
them yearly, sometimes Biannually.
As to the idle, an injected engine should idle better than
a carberated one.
As to being a FAN of the E.P.A.......that is just unbelievable from an educated individual. *
* I think Jim was using this as propaganda.
E-TEC on.....Or is it E-Tech, how bout Evenrude....
from Canada...aye.
P/S I like Yamaha's. Very Reliable & well made.
Mr C posted 10-06-2011 12:11 AM ET (US)     Profile for Mr C  Send Email to Mr C
Uncle already.
Mr C posted 10-06-2011 12:12 AM ET (US)     Profile for Mr C  Send Email to Mr C
Uncle already.
jimh posted 10-06-2011 09:13 AM ET (US)     Profile for jimh  Send Email to jimh
L H G says:
Larry--You are right. I did exaggerate a bit. When I said
"fantastic engine torque and acceleration"
I probably should have said "really good engine torque and acceleration." Using the adjective "fanatastic" implies that the engine torque and acceleration were something out of a fantasy. They're not. They're just really good.
Now everything else I said is not an exaggeration, but, rather, the simple truth. Those reasons are why the people who actually own Boston Whaler MONTAUK 17 boats with E-TEC 90-HP motors are so happy. If they did not get all of those advantages with their new motor, they would not be so happy. I don't think there is any E-TEC 90-HP owner who is ready to give up all of those advantages in order to take a chance that he could get one or two miles-per-hour greater speed at maximum throttle. There is a simple reason for that.
The number of times and places where you can run a 17-foot MONTAUK at more than 44-MPH is a rather small number and represents only a small fraction of the time spent running the boat and engine. This is another advantage of the E-TEC 90-HP: it will give you a very accurate history of the throttle setting and engine speed. What owners of an E-TEC find out from their engine history is just how very little time they spend with the engine running at maximum throttle. It is typically less than one-percent of the time.
The silly argument that keeps being put forth here is that in order to perhaps get one or two miles-per-hour greater speed during less than one-percent of the operating time of the engine, E-TEC owners ought to give up all the other clear advantages of their modern, low-emission outboard engine. It is no wonder that they don't want to make that sort of a trade-off.
How much difference will 1-MPH hour make? Let's say we are on a 25-mile run with our 17-foot MONTAUKS. If one boat goes 44-MPH and the other goes 45-MPH, what advantage accrues to the faster boat? Over a 25-mile run that means the faster boat gets to the destination 45-seconds sooner. Do you think that anyone is going to give up all the advantages of the E-TEC so that the one day of the year they run at wide open throttle for 25-miles they can save 45-seconds? Now that is fantastic!
prj posted 10-06-2011 10:14 AM ET (US)     Profile for prj  Send Email to prj
The latest tack is to now minimize the importance of WOT speed, clearly a tacit acknowledgment that the E-TEC 90 HP does not match WOT speeds for most 90 HP outboards. I also think that the WOT speed of the E-TEC is not within 1 MPH, trends seem to put it consistently at 3-4 MPH slower than typical 90s, almost 10% slower that is. If one would care to consider outliers, which I don't, that spread would increase to more like 6-8 MPH.
Again, the ETEC proponents find themselves in clear agreement with the very foundation of the assertions put forth in the 7th post of this article!
I tend to agree with most of jimh's assertions regarding the benefits of the E-TEC 90 on a Montauk and also doubt that there is a better repower option available at this time.
That said, this article wouldn't have tallied 265 posts if benefits were the basis for it. The issue that brings us to post 266 is the fact that the E-TEC 90 performs almost identically to the 83 HP Yamaha 90 2 stroke. Thus the playful monicker was generated. I'd think that all of those 100 or more fellows that repowered, and are reaping the benefits detailed just above, would be man (or woman) enough to accept and acknowledge this fact rather than tossing about red herrings and prolonging the mockery of their chosen engines which consistently yield significantly slower WOT speeds.
Russ 13 posted 10-06-2011 12:20 PM ET (US)     Profile for Russ 13  Send Email to Russ 13
Red herrings...something fishy about that!!
I think the solution, would be for both Yamaha & Evenrude
to up the output of their respective 90HP. Models.....
OOOOPPPSS forgot about that silly EPA group & their overregulation. Smells like fish again.
IF the E-Tec., is as reliable & Durable as the two stroke Yamaha, then it is truely a GREAT engine....
Even if they both are a little slow.
Tohsgib posted 10-06-2011 02:46 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Wow...8 days in the Caribbean and nothing has changed.
jimh posted 10-06-2011 03:28 PM ET (US)     Profile for jimh  Send Email to jimh
I see we are back to the nonsense about 83-HP, a number Larry made up and pulled from the air. It is amazing how much effort has been put out to rationalize Larry's invented horsepower.
Personally, I thought my explanation of the difference between 44-MPH and 45-MPH was brilliant. It should have silenced all but the irrational participants. I think that it actually may have done just that.
L H G posted 10-06-2011 06:36 PM ET (US)     Profile for L H G
You guys should stop blaming me for a PROBLEM Evinrude created for themselves, over rating an engine for sales and marketing purposes. And guess what? Yamaha is just getting even with them for attacking their 4-strokes on video! I guess that was OK.
We have numberous reports that the 7 year old design of the 3-star Evinrude 90 performs almost exactly the same as the 26 year old design of the NO-star Yamaha 90.
Thanks to some good research work by Tom Clark, we have learned that the Yamaha 90 is putting out only 83HP at the prop. Is Yamaha's HP number for their 2-stroke 90 "nonesense", "made up". "pulled from the air" and "invented"? You decide. After all, it's not my number. But Yamaha has a pretty good reputation around here in spite of the Evinrude attack ads.
Tom W Clark posted 10-06-2011 07:57 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Larry -- Do you think just repeating your nonsense over and over will somehow make it true?
I've no made any accusations just asked several questions that have still gone unanswered.
How can you take a source of information at face value in the case of one motor (the discontinued two stroke Yamaha 90 at 83.3 HP per EPA data) and then turn around and mock the source of the information in the case of another motor (the Evinrude E-TEC 90 at 89.9 HP)?
Tom W Clark posted 10-06-2011 08:02 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Russ -- Thank you for contributing your personal experience with your Montauk and its Mercury 90 HP outboard. What year was your Montauk and motor?
You said it would go 47-48 MPH but then later you said it would go 47 MPH per GPS in saltwater. Which is it? It certainly sound as if you had it dialed in very nicely with the Stiletto Advantage propeller and the elevated mounting height. You are a wise man.
I am curious, what RPM was your motor turning at WOT? Do you still have your performance notes from your two way test runs?
Tom W Clark posted 10-06-2011 08:04 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Given how many three cylinder Mercury 90 were made over the years and how many of them wound up on classic Montauks, where are all the members here on Continuous-Wave that own this combination and why have they not chime din with their 47 MPH speed reports?
Tom W Clark posted 10-06-2011 08:06 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Oh, and speaking of fast old Mercury outboards, can somebody explain to us why the Mercury 100 HP motor on my friend's 1988 Montauk can only go 40 MPH in saltwater with a 12-3/4" x 21" Aluminum Quicksilver propeller? It seems that with an extra 10 HP it ought to be good for 48 MPH, no?
Keeper posted 10-06-2011 08:08 PM ET (US)     Profile for Keeper  Send Email to Keeper
Mercury motors are tired and over rated.
Unless from their race division . . . and even those are getting weak.
Spare me the built in US Jargon too. Feeble.
Peace
Keeper
Tom W Clark posted 10-06-2011 08:12 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
For me the take away of this thread is that if you want to go faster, you need more horsepower. If 44 MPH is not fast enough for you then you ought to buy a 115 HP motor.
I think that is fine and many guys do just this or even more ridiculous overpowering. I know of one guy who even put a six cylinder 150 Mercury 150 on his Nauset. He was very proud of that.
For that vast majority of Montauk owners, it seem that 44 MPH is more than enough. Some guys even have smaller motors that do not go as fast. Many classic Montauks are powered by 70, 60 even 50 HP outboards and they make their owners happy. I am certainly not going to criticize them for their motor buying decision. What is the point of that?
L H G posted 10-06-2011 09:18 PM ET (US)     Profile for L H G
I agree any true 90 should push a Montauk 44 on average. Tom, as a prop seller, can an E-TEC 90 using the 15" (effective 17) Stiletto prop go 44 on the Montauk at 5500 RPM? I can't make that calculate. Or would it need a 17" (effective 19) Stiletto, which you don't seem to be selling for this setup?
Nobody has been saying a Montauk has to go a certain speed, as you say even a 40 works on the boat.
But repeatedly over the years, we see "How can I make my Evinrude 90 E-Tec go faster than 38 with the alum prop. Which means these people are disappointed in that speed for 90 HP. Your 15" Stiletto prop seems to get most of them up to 40-41.5 @ 3 holes up. That speed calculates.
Incidentally, that 4 cylinder Mercury split cowl 100 you mentioned was over-rated also, but the 2 + 2 platform's a good performer in the 115 and 125 HP versions. Don't ask me why. Mercury took the 100 off the market because the 3 cylinder 90's were faster when the cubes were increased around 1995 and bucket cowlings introduced for this line. The split cowl 90's were not good runners and did not have the power of the predecessor L6 90's.
Russ 13 posted 10-06-2011 09:48 PM ET (US)     Profile for Russ 13  Send Email to Russ 13
The 17' Montauk & 90 Mercury engine were both a 2000 model.
The boat would run a solid 47MPH, with an occasional 48...
Smooth waxed bottom, a great combination.
Very fast for a non stepped or padded hull.
I agree that top end speed is only one aspect of ownership.
I would also agree the reliability & durability are more
important.
"It ain't no fun, when your engine won't run."
No matter what brand it is.
And the largest thread posting record is...........???
Tom W Clark posted 10-07-2011 12:12 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Russ -- That is very impressive. I wish I could have gotten that out of my three cylinder 1994 Mercury 90 on my 1988 Montauk. It was only good for 42 MPH at 5300 RPM with the 20" Lightspeed (Laser II).
Tom W Clark posted 10-07-2011 12:23 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Larry -- Well, there you go again, making a wild claim with absolutely nothing to back it up.
When I search Continuous-Wave for "How can I make my Evinrude 90 E-Tec go faster than 38 with the alum prop." I get only a 13 results and none of them are about a Montauk except this thread.
Among those results is Len Simpson describing how his Evinrude E-TEC 90 is good for 52.2 MPH on his Sport 15 [ With? guess what, a Stiletto Advantage ] and how pleased he is with it.
http://continuouswave.com/ubb/Forum4/HTML/006056.html
And then there is Clark Roberts with his first impressions of the Evinrude E-TEC 90 where he writes:
"Yesterday I piloted a friend's 17 Outrage with his new 90 E-TEC...Starting the new engine was instant with just a key turn and idle was smooth and very, very quiet (as quiet as my 115 Merc four-stroke) and acceleration was fierce. Owner said that it was quicker out of the hole than the 115 V4 Evinrude it replaced. Top speed, with just me aboard (190-lbs.), at 5500-RPM trimmed out was 35-MPH (per GPS). I haven't figured out the theoretical top speed yet because I don't know the weight of that hull. Bottom line: I'm very impressed with the engine's fit and finish, size, quietness (quieter at top speed also than my four-stroke), and low end power."
http://continuouswave.com/ubb/Forum4/HTML/003196.html
But I see absolutely nobody asking: "How can I make my Evinrude 90 E-Tec go faster than 38 with the alum prop."
Tohsgib posted 10-07-2011 09:05 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Russ...GPS? I doubt any 90 will fetch 48 on a montauk....not even a T.O.P. My modified 70 on a 15 would barely do 48. My 115 OMC would barley break 46.
wstr75 posted 10-09-2011 09:55 PM ET (US)     Profile for wstr75  Send Email to wstr75
I trailered over to Badin Lake this afternoon and re-ran the performance test. Air temperature was 72 degrees and the lake water temperature was 73 - 74 degrees. Beautiful fall day with a breeze coming from the east. The speed trials were run north to south and south to north.
2700 rpm - 21.1 mph
3050 rpm - 24.5 mph
3300 rpm - 26.8 mph
4700 rpm - 39.6 mph
5450 rpm - 44.62 mph (was bobbling from 44.3 to 44.62 mph)
90 hp Evinrude E-TEC 2009 model year
1987 Montauk
17" Stiletto prop
Adjustable aluminum set-back plate
3/4 tank of fuel (24 gallon Moeller tank)
205 pound human being (gained a few pounds since last year)
Two batteries located in the console
Driver was crouched down behind the console
The above numbers were shown on both the I-Command gauge GPS and the Lowrance HDS-5 GPS (two separate GPS units), i.e. the two GPS units were in agreement.
Bill in NC
Russ 13 posted 10-09-2011 10:39 PM ET (US)     Profile for Russ 13  Send Email to Russ 13
Well there you go 44 MPH with two batterys, 3/4 fuel load
205 # driver and a 15P prop.
And the NAY sayers don't believe that I ran 47 MPH.
With 19P prop, turning @ 5700 RPM, one small battery, 6 gallons of fuel, and a 175# driver............
The pitch difference alone would add several MPH,
not to mention the boat being roughly 175 pounds lighter.
wstr75 posted 10-09-2011 10:47 PM ET (US)     Profile for wstr75  Send Email to wstr75
Russ, my prop was checked and found to be a 17".
Tom W Clark posted 10-11-2011 11:56 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Bill -- Thank you for your detailed and contemporary performance reports. Given that you most recently ran your boat on a warm day in freshwater at 500 feet of elevation, I am impressed with the performance of your Evinrude E-TEC 90.
I guess it just goes to show how important the correct propeller and motor mounting height is to getting the most out if your boat.
Tom W Clark posted 10-11-2011 12:24 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Russ -- I am impressed with the performance of your boat too.
47 MPH at 5700 RPM though 2.33:1 gears with a 13-1/4" x 19" Stiletto Advantage is negative 7 percent calculated propeller slip, very impressive indeed.
prj posted 10-11-2011 01:35 PM ET (US)     Profile for prj  Send Email to prj
Bill, are your numbers above averaged from the two directional runs? That 44+ MPH WOT speed is indeed the seemingly magic number for a 90 HP outboard on a Classic Montauk.
Tohsgib posted 10-11-2011 02:39 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
Very impressive considering I ran a 2.42:1 with a Suzuki 18" prop(like Stiletto) and at 5700 only fetched about 39.
Owtrayj25 posted 10-11-2011 04:28 PM ET (US)     Profile for Owtrayj25  Send Email to Owtrayj25
Very impressive indeed....-2% slip and all.
wstr75 posted 10-11-2011 04:29 PM ET (US)     Profile for wstr75  Send Email to wstr75
PRJ,
I 44.62 mph was the max consistent speed seen in both directions. I did see a 44.8 mph at one time but threw out that data point since it was only seen once. Readings between 44.3 to 44.62 were commonplace during the max speed run. You've got to understand the boat was jumping around as I was repeatedly scanning the gauges while also keeping an eye on boat traffic and wakes, an overall heavy mental processing load for my 59 year-old bi-focaled eyes and brain.
I think my boat/motor set-up has been taken as far it can go. 5450 rpm is likely all that is going to come out of my E-TEC. The prop is somehow still grabbing sufficient water but it's top section has got to be out or almost out of the water judging by the spray pattern. In a future trip I'd like to have someone drive the boat while I look down at the prop. I'm pretty much through with running at max speed and will keep the speed under 40 mph to ensure sufficient water is getting picked-up by the water pump. Another benefit for keeping it under 40 mph is it allows enjoyment of the boating and scenery aspects because to get the extra 4+ mph requires a sensitive touch on the trim and a higher level of concentration. It is a "Who needs the static, it hurts the head kind of boating lifestyle kind of thing, i.e. less engineering/tinkering and more laid-back recreational cruising stuff.
Bill in NC
prj posted 10-11-2011 04:37 PM ET (US)     Profile for prj  Send Email to prj
Thanks Bill, I appreciate your effort in pulling together the data and presenting it legible and convincingly.
When doing performance runs with my boat, I've used a grease pencil on the console gelcoat to scribble down barely decipherable numbers at predetermined and noted RPMs. While still a challenge, its reasonable for one person.
As you note, those WOT speeds are done rarely, for bragging rights and to publish for posterity and reference here. Its certainly not to be considered typical or relaxing boating, regardless of age.
Patrick
wstr75 posted 10-11-2011 04:43 PM ET (US)     Profile for wstr75  Send Email to wstr75
I guess you guys are inferring something is amiss for the rpm numbers and propeller pitch to jive with the max speed readings, i.e. negative slip calculations. Hey, I am as curious as you are about this matter. Do you think Stiletto has incorrectly labeled the propeller pitch? Perhaps it is a 17.5" pitch or larger? Could it be a GPS error thing? Could the rpm gauge be off by 100 rpm? Thoughts? Maybe I was running at 38 mph and some kind of time-space continuum thing exists at Badin Lake to increase speeds by 15%? Buehler, Buehler, Buehler? .... ?
Seriously, I buy the negative slip arguments you are making. What do you think is reason for the 44.3 to 44.62 mph readings?
Inquiring minds want to know.
Bill in NC
Tom W Clark posted 10-11-2011 07:48 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Calculated propeller slip (slip) is not well understood. It is simply the percentage difference between the theoretical distance a propeller will travel forward based on its pitch vs. the actual distance it travels forward. But less slip is not necessarily better than more slip. Every model of propeller will have a typical range of slip in a typical installation. Slip will vary with one particular model of propeller as the rigging on an application varies or as the propeller itself varies from its original design shape.
In the case of the Stiletto Advantage, especially the small tube version (4.25), the slip will, for whatever reason, be negative. How can this be? I honestly do not know. The most obvious reason would be that the manufacturer simply underrates the nominal pitch and there may be some truth there. The Yamaha Performance Series three blade stainless steel propeller is (as far as I can tell) exactly the same propeller, same casting as the Stiletto Advantage and Turbo 1 (all are made by Precision Propeller Industries Inc.) and is made in even numbered pitches, yet the Stiletto and Turbo are made in odd numbered pitches, so a 15" Stiletto will be the same as a 16" Yamaha.
The only trouble with this theory is that in the one case I know of a Stiletto propeller actually being taken into a Prop Scan propeller shop to have its pitch measured at three points on the blades, near the root, middle and near the tip, conformed the pitch was essentially as stated. Go figure.
I do not really care about whether the pitch is over or under stated on any given model of propeller, what I do care about is that any given propeller perform within the range of slip I have come to expect from it.
The Stiletto Advantage 4.25 in a classic Whaler usually runs with between 2 percent and -2 percent slip. The large tube Advantage 4.75 typically runs with between 1 percent and 5 percent slip. When the slip calculations exceed these values, my eyebrow goes up.
Different models of propellers have different typical ranges of slip. For example, the small tube the blade Mercury Vengeance usually has very low slip between -2 and 4 percent yet the four blade Mercury Trophy Plus will usually yield rather high slip values in the 2 to 6 percent range which is exactly the opposite of what the "general rule" about going from a three blade to a four blade suggests.
When talking about slip, you must consider the model of propeller being used. A Stiletto Advantage on a Montauk yielding -2 percent slip sounds perfectly normal to me. Negative 7 percent slip makes me suspicious.
wstr75 posted 10-11-2011 09:24 PM ET (US)     Profile for wstr75  Send Email to wstr75
Tom,
Thank you for this information and the interesting information regarding seemingly alike Yamaha and Stiletto propellers having different performance characteristics. It sounds like subtle differences in propeller configuration often yield not so subtle differences in performance.
Thanks for the explanation regarding normal slip variance ranges for Stiletto propellers.
Bill in NC
pcrussell50 posted 10-13-2011 01:31 AM ET (US)     Profile for pcrussell50  Send Email to pcrussell50
Smooth and waxed running surface? At close to 50mph, it might not matter much if you handicap yourself with a shiny waxed bottom, but at bass boat speeds, a shiny waxed pad appears NOT to be the way to go:
http://www.bassboatcentral.com/don'twax.htm
A lot of racers swear by a 400 grit finish
YMMV
-Peter
L H G posted 10-13-2011 04:53 PM ET (US)     Profile for L H G
Cupping on a prop, which all props have today, adds 1" to 2" of effective pitch. That is where the discrepancies may be coming from. A cupped 15" Stiletto will act like a 17" pitch? Mercury says that # of blades matters too. A four blade of the same pitch will run like 1 extra inch of pitch, maybe 2.
My Whaler normally needs 23" pitch props, but the 21" Mercury Revolution-4's I am using definitely top out like 23's. I could not turn up 23" Rev-4's.
If the 15" Stiletto is the fast prop of choice for a jacked up E-tec 90 on a Montauk, how fast can the boat go at 5500 RPM and 2.0 gearing. 41-42 at the most?
Russ 13 posted 10-13-2011 10:51 PM ET (US)     Profile for Russ 13  Send Email to Russ 13
Wax on, wax off.
For boat speeds under 50 MPH, no perceivable difference.
Depth sounders, live well pickups, dol-fins...
All add aditional drag, the above mentioned Whaler did not have any of those, But did have some cupping added to the Stilletto.
So maybe the slip was closer to -4, I don't know.
I do know that it ran good & fast, I should have kept it.
Tom W Clark posted 10-14-2011 09:29 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Uh, no Larry, if all propellers are cupped (which, with few exceptions, they are) then how can a cupped Stiletto act like a 17" pitch unless the 17" pitch propeller is not cupped? We know 17" pitch outboard propellers are all cupped so how do you explain a 15" pitch Stiletto acting like a cupped 17" pitch propeller?
Uh, no, that is not necessarily correct. I just finished cautioning against these general rules of thumb. If this were true, how do you explain the three blade Mercury Vengeance having a greater effective pitch than the four blade Mercury Trophy Plus?
Or the three blade Mercury MIRAGEplus having a greater effective pitch than the four blade Mercury VenSura (Offshore)?
General rules of thumb break down pretty quickly. This is why it is so important to consider the particular model of propeller being considered; they are all unique, not just generic pieces of hardware.
Tohsgib posted 10-14-2011 01:43 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
I do believe the faster you go the more the slip. A boat doing 70 is not going to have -2 slip, more like 12%.
L H G posted 10-14-2011 07:03 PM ET (US)     Profile for L H G
Tom - My information comes from published Mercury propeller information I have. If you think it's wrong, take it up with them, not me. You seem to think you know more about props than Mercury does.
I don't use Stilettos, so I don't know anything about them. But from what I've read here, it seems like their pitch designations don't conform to industry standards, which could be deceptive and costly to a buyer not up on their "unique" designations.
Peter posted 10-14-2011 07:33 PM ET (US)     Profile for Peter  Send Email to Peter
Larry, where is the "industry standard" for propeller pitch designation published? Who controls it -- ICOMIA?
Tom W Clark posted 10-15-2011 11:47 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Larry -- My propeller information comes from a lot of personal experience with propellers I have owned and a lot of detailed propeller testing I have conducted myself on my boats and boats belonging to others, as well as a tremendous amount of anecdotal propeller information from the people who actually use propellers and who are kind and generous enough to contribute their detailed information about their propellers, like jimh, divtruk and wstr75. I do not merely regurgitate manufacturer's marketing.
I do not believe you have ever contributed a detailed propeller report yet you continue to offer advice about propeller selection based on nothing more than what you have read from Mercury marketing, interpreting it (often incorrectly) as you see fit.
There is no "industry standards" for propeller pitch designation.
I mention all of this not because I think you will change your unfortunate habits but because of the hundreds or thousands of people reading this now, or in the future, who I want to take away some useful, applicable and accurate information about propeller selection for their Boston Whaler.
Tom W Clark posted 10-15-2011 11:59 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Nick -- Slip it is not nearly that simple. Any given model of propeller on a given boat will generally have more slip as the boat speed passes minimum planing speed and less slip as the boat goes faster and faster and slip may, or may not, increase as WOT is approached.
Slip from boats that go very fast, 70 MPH say, do not necessarily have greater propeller slip than the average Boston Whaler, it depends on a great number of things.
For example, a propeller operating in a surfacing application where the water and air are mixed will slip more. This situation is more common on high performance boats than the average Boston Whaler.
jimh posted 10-16-2011 09:43 AM ET (US)     Profile for jimh  Send Email to jimh
Tom--From my propeller testing experience, I have observed one phenomenon enough that I think I can translate it into a Rule of Thumb. Although you have just mentioned that there is a good chance that any simplistic rule about propellers will not hold up very long, I think this observation has a good chance of surviving the test of time:
General Rule of Propeller Testing
If you only test Mercury brand propellers on your boat, the propeller found to work the best in your testing will be a Mercury propeller.
Tom W Clark posted 10-21-2011 10:31 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Jim -- Another equally true, and perhaps corollary, rule-of-thumb is that one will never know how well their boat can perform if they do not consider propellers other than what they currently have.
grander posted 10-22-2011 07:53 PM ET (US)     Profile for grander  Send Email to grander
[Changed TOPIC--Contact the moderator for this topic--jimh]
barnacle posted 10-26-2011 01:34 AM ET (US)     Profile for barnacle  Send Email to barnacle
Someone asked if a faceplate was on my 1999 17 90 mercury. No . Any 90honda prop tests
barnacle posted 10-26-2011 01:43 AM ET (US)     Profile for barnacle  Send Email to barnacle
Jackplate not faceplate. Just a no name Steele 17 over reved6000
Tom W Clark posted 10-28-2011 11:03 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Just another data point. I recently received some photos and performance data from Paul Mucciolo for his recently restored 1998 17' Alert (stripped down Montauk) and its Mercury 90 two stroke and a high performance 13-1/4" x 20" Mercury Laser II propeller.
On my advice, Paul and his brother raised the motor on the transom to its fourth set of bolt holes. They are very pleased with its new top speed: 44 MPH.
Tom W Clark posted 10-28-2011 11:16 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Honda 90 prop tests? I know Andy Roberts owns a classic Montauk with a BF90 on it. Checking my filed correspondence I see he has tried a couple propellers and reported to me last year that it did 40 MPH with the 13-1/4" x 17" three blade aluminum @ 6000 RPM and 42-43 MPH @5800 RPM with a 13-1/4" x 19" Stiletto Advantage 4.25.
Obviously, the 13-1/4" x 17" Stiletto is the better choice and what I believe he has on the motor now, though I have not hear from him what the top speed is with that prop.
His motor is mounted all the way down on the transom and should be raised three bolt holes. That would probably bring his top speed up to 44 or 44.5 MPH.
Tom W Clark posted 10-31-2011 12:14 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Here is one more data point:
I have previously mentioned in this thread my friend who recently bought a 1987 Montauk with a Mercury 100 motor (mounted one hole up) and found in would only go 39.9 MPH in saltwater with a 12-3/4" x 21" Aluminum Quicksilver propeller at a little over 4700 RPM.
On my advice, the motor has been raised to the fourth bolt hole ("three holes up") and a 13-1/4" x 9" Stiletto Advantage I installed. This weekend he reported he was now able to achieve 42.9 MPH at 5100 RPM.
That is a 3 MPH gain with a simple propeller swap and motor height adjustment.
While this still falls short of the Magical, Mythical Mercury/Montauk 48-50 MPH top speed that legend holds as possible, it does comport with my previous statement that a 90 HP outboard (and since Larry claims the Mercury 100 is weak, we'll just call it 90 HP) on a classic Montauk is good for a top speed in the low 40s.
jimh posted 11-01-2011 09:14 AM ET (US)     Profile for jimh  Send Email to jimh
After over 300 articles, have we seen any real evidence that most 90-HP motors drive a MONTAUK to 50-MPH? It looks to me like most 90-HP motors drive a MONTAUK to the low- to mid-40-MPH range of speeds.
Has the mythical beast of L H G's imagination been slain?
Tohsgib posted 11-01-2011 10:06 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
GPS does not lie...we want pics and don't cheat by using your bud's boat.
Owtrayj25 posted 11-01-2011 10:40 AM ET (US)     Profile for Owtrayj25  Send Email to Owtrayj25
Got a chuckle out of that...in other words, a GPS can be made to lie;-)
Tom W Clark posted 11-01-2011 12:09 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
For all the contributions to this thread, one point has yet to be made: The Evinrude E-TEC 90 did not exist ten yeas ago.
There is no opportunity for older folks to reminisce about how fast their Evinrude E-TEC 90 powered Montauk went ten, or fifteen or twenty years ago. And there does seem to be a rough correlation between claims of high top speed and number of years elapsed since that event occurred.
While it is true that GPS, under certain circumstances, is fallible, human memory is much more so.
jharrell posted 11-01-2011 12:40 PM ET (US)     Profile for jharrell
So yesterday I hit 44mph in my old inline Merc with a pitted quicksilver 19p and roughed up LU paint over-revved to 5100rpm. I would venture the cooler air probably contributed to the 1mph increase, it actually got down in the 70's ;).
So I should really clean up my LU and get a Stiletto just to see how fast the old inline will go and do some myth busting before I get a new engine, now the only questions is whether to go 19p or 21p on the stiletto.
Tom W Clark posted 11-01-2011 12:45 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Excellent data point. Yes, clean up the lower unit and install a 13-1/4" x 19" Stiletto Advantage.
What year is your Montauk?
How high on the transom is the motor mounted?
Tohsgib posted 11-01-2011 01:14 PM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
5100 is not over revving on an inline. I think 90 was 5250, 115 was 5500, and 140 was 5750.
jharrell posted 11-01-2011 02:03 PM ET (US)     Profile for jharrell
The 21 is tempting though, should perform more like a 23" correct?
1986.
I was tweaking the jackplate up and trimming out it ended up with the vent plate about 4-5" above the keel as shown in the following photo's, you can also see how rough the LU is:
https://picasaweb.google.com/lh/photo/ uB-HtRBN8pVfH54MM96uKpNyNflSr_BDos3tKmqm-pg?feat=directlink
https://picasaweb.google.com/107007622155886602752/ WhalerProject?authkey=Gv1sRgCOHiqYL_38ejFw#5670102896295177970
My original manual disagree's ;):
https://picasaweb.google.com/107007622155886602752/ WhalerProject?authkey=Gv1sRgCOHiqYL_38ejFw#5670102882345068930
Tom W Clark posted 11-01-2011 02:13 PM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
The 21" Stiletto might be tempting but I don't think it would even allow your motor to reach 4500 RPM.
The motor height looks great. All you need is a little sandpaper and a $5 can of Phantom Black spray paint:
http://www.amazon.com/Mercury-Phantom-Black-Paint/dp/B001447J5U
jharrell posted 11-01-2011 02:24 PM ET (US)     Profile for jharrell
Yeah my next project was going to be to sand and paint the LU before I put on a new prop, just to see if that makes any difference by itself.
Although I might just sand and leave it bare, at least for a few outings, isn't that what the racers do ;).
L H G posted 11-01-2011 08:05 PM ET (US)     Profile for L H G
I'm impressed that the old, throwback, outdated, carbureted, beat up, 2-stroke Merc 90 outruns the high tech direct fuel injected, ultra modern, brand new E-tec 90 by 2 MPH, and even with that old dog Mercury QSS prop vs a high tech Stiletto!
Redline on the L6 Merc 90s is 5000, (115's are 5500 & 140's are 5800), so I would use a Mercury 20" Laser II (you can get a Quicksilver version for less called Lightspeed). That should keep the revs down and bring the speed up to 46 MPH. Not bad.
If a true 90 gives a Montauk 44, then the E-tec at 41-42 is less HP, and maybe this old L6 is more HP (if the engine can achieve 46).
What year is that Mercury tower? The gearcase design indicates 1979 or newer.
barnacle posted 11-01-2011 08:50 PM ET (US)     Profile for barnacle  Send Email to barnacle
Thank you for the bfHonda 90 advice. My 2 stroke 1999 is gone and I got an excellent trade because the Honda dealer did a lake test on my trade. I know l am an old guy, but l will not even brag what a 21 cupped mercury prop would crank at 5500. This a standard 1999 17 and the 90 mercury at 303 pounds. I do not think an etec could come close to that old screamer smoker.
Tom W Clark posted 11-02-2011 09:43 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Paul Mucciolo's 1998 17' Alert has a 1998 Mercury 90 two stroke on it that weighs 303 pounds and has a high performance 13-1/4" x 20" Mercury Laser II propeller. As he reported just a week ago, the boat does 44 MPH with the motor mounted high on the transom.
The 1998 Alert and the 1999 Standard are the exact same configuration and vary by only 100 pounds of hull weight due to the Alert's heavier layup. Unless Larry tells us there was a profound change in the design of the Mercury 90 between 1998 and 1999, I am going to give you the benefit of the doubt and assume your boat went 44.5 MPH because it weighed a little less.
In other words, the three cylinder two stroke Mercury 90 would seem to be as powerful as the Evinrude E-TEC 90.
Tom W Clark posted 11-02-2011 09:46 AM ET (US)     Profile for Tom W Clark  Send Email to Tom W Clark
Larry -- 44 MPH (speed of Justin's Mercury L6) is half a mile per hour slower than 44.5 MPH (speed of wstr75's and Meridian's E-TEC 90s), not two miles per hour faster.
jimh posted 11-02-2011 10:40 AM ET (US)     Profile for jimh  Send Email to jimh
Tom--Thanks again for making a critical observation and pulling some facts out of this morass of conjecture, reminiscence, and imagination.
The E-TEC faster than the Mercury--well, Howdy Doody, what do ya know about that?
It seems to me that the E-TEC retains all of the good qualities of the old two-cycle engines, and gets rid of all of their bad qualities. It is a good example of a modern, well-designed, well-engineered product that has supplanted the older products of its kind.
It's akin to watching Hi-Def television on a LED display; you don't want to go back to a round black-and-white CRT picture, do you?
prj posted 11-02-2011 01:53 PM ET (US)     Profile for prj  Send Email to prj
So, there we have it, two reports of optimized E-TEC 90s reaching the expected WOT speed of typical and traditional 90 HP outboards: 44 MPH. Well, maybe its just one report, as I scanned through this massively long article for a Meridian and was unable to find theirs.
I wonder what the top two optimized WOT speeds are for some of the other 90 HP outboards on the market? I certainly wish someone would execute and document them as rigorously as wstr75 Bill where the same speed to the hundredth was achieved in both directions ; )
wstr75 posted 11-02-2011 08:22 PM ET (US)     Profile for wstr75  Send Email to wstr75
Hey, I strive for accuracy! My next GPS will undoubtedly have an accuracy to thousandths of MPH!
jimh posted 11-02-2011 09:35 PM ET (US)     Profile for jimh  Send Email to jimh
A GPS receiver typically cannot measure speed. It deduces speed from the time needed to travel between position fixes. The position fixes contain errors. The general GPS receiver speed data is accurate to about 0.5-MPH. For more on the accuracy of GPS receivers when computing speed, see an excellent discussion on this topic in SMALL BOAT ELECTRICAL at
Accuracy of GPS Receiver Speed Measurements
http://continuouswave.com/ubb/Forum6/HTML/002179.html
Also, it is not unusual to see a GPS receiver provide speed data with quite a bit of variation even when the boat speed is quite constant. Operators who pick the highest speed shown out of perhaps 100 readings as the one to use for boat speed are probably introducing even more error.
Tohsgib posted 11-03-2011 08:26 AM ET (US)     Profile for Tohsgib  Send Email to Tohsgib
It can not be that bad if most competition ski boats use GPS cruise control to maintain an exact speed during runs.
jharrell posted 11-03-2011 09:52 PM ET (US)     Profile for jharrell
LHG, the tower was purchased new with the boat in 1986 , it has the brown stickers.
Here are a couple more photos of it:
http://lh5.googleusercontent.com/-meYSdwS-1LU/TrBAfOWgh1I/AAAAAAAAAGA/ 7uHiJ0WjIps/s1024/IMAGE_1DF02C12-319B-4FD6-B77E-2CEAAE15630F.JPG
http://lh5.googleusercontent.com/-9hl5l76mn-4/Tdg3-4llxHI/AAAAAAAAACY/ uFilayLMCQ0/s1024/IMG_0198.JPG
jimh posted 11-04-2011 12:56 PM ET (US)     Profile for jimh  Send Email to jimh
This thread has lasted longer than Kim Kardashian's marriage. Is there any aspect of the 1988 MONTAUK with E-TEC 90-HP engine performance that we need to further resolve?
Or can we wrap this up after 330 articles?
thegage posted 11-04-2011 01:30 PM ET (US)     Profile for thegage  Send Email to thegage
Please, put us out of our misery!
John K.
jimh posted 11-04-2011 09:49 PM ET (US)     Profile for jimh  Send Email to jimh
I'll take the final word: after L H G invented 83-HP as a figure pulled out the air, there was never any substantive proof or even flimsy evidence offered to support it, and, as far as I can tell, Larry just made that up to rile up the readers.
When the dust settled the 90-HP E-TEC was measured at 88.9-HP, or within about one-percent of the rated power, which is probably less than the margin of error of the measuring equipment.
It has been a fun ride, and I fully expect we will get to do it all again soon in a few weeks when another classic MONTAUK owner re-powers with a 90-HP E-TEC .
Until then, good night.
