| Author | Topic: Lowrance HDS-8 Article Index |
I have written a number of long articles about the Lowrance HDS-8. This article is an index to those other articles about the Lowrance HDS-8. Lowrance HDS GPS Data Display Lowrance HDS Update to v4.0 HDS-8 Installation NMEA-0183 Interface Lowrance HDS7 v. HDS8 Lowrance GPX Export Also there is this good discussion on interfacing of the Lowrance HDS-8 to a GX2100 radio with an AIS receiver. HDS-8 to GX2100 Connections |
Information about the Lowrance HDS-8 is given in the articles about the Lowrance HDS-8 that are linked above in the index listing of articles about the Lowrance HDS-8. |
Information about connecting an HDS-8 to an AIS receiver using a 38,400-BPS MNEA-0183 serial data connection is given in a REFERENCE article about AIS and ship spotting. See: AIS Ship Spotting |
More information on connecting an HDS-5 or HDS-7 to an AIS receiver, particularly an AIS receiver that is part of a Standard-Horizon VHF Marine Band radio, can be found in Connecting AIS Receiver to Lowrance HDS-5 or HDS-7 These devices have only one serial port, unlike the HDS-8 or HDS-10, which can be configured to have two serial ports. |
For information on the latest system software update for the HDS series, see Lowrance HDS Series Software Update v4.1 |
How to import routes to a HDS chart plotter from files stored in the .GPX format: Exchanging Navigation Data Among Different Chart Plotters |
HDS Menu Map http://continuouswave.com/whaler/reference/HDS_Menu.html This reference article documents the menu structure of the Lowrance HDS-8. HDS: Phantom LORAN HDS: Battery Voltage v. Supply Voltage |
New articles about the HDS include: Lowrance HDS: TRAILS
| Mr T |
Jim--this is an excellent reference set, and being an owner of a HDS-8, I thank you for it. The capability of the unit is impressive indeed. [Thank you for the kind words--jimh] |
Since its initial appearance, my on-line hypertext guide to the HDS menu structure has been continually updated. I have been expanding the detail of various menus, exploring more deeply into them, and including more screen captures. The menu information is now quite comprehensive. Again, this on-line hypertext guide is available at: HDS User Interface |
HDS NMEA-2000 Parameter list http://continuouswave.com/ubb/Forum6/HTML/003271.html The above article lists the NMEA-2000 parameter group numbers that the HDS can support in either send or receive. |
Unlike all of the above articles, the article linked below is not written by me, but is from Lowrance. It is a good presentation that explains how the HDS series of multi-function devices can be networked at three levels: NMEA-0183, NMEA-2000, and proprietary Lowrance Ethernet. This presentation is an excellent overview of the three network systems and details what data can be exchanged between devices on the three networks: HDS System Overview |
HDS: Viewing Photo Images http://continuouswave.com/ubb/Forum6/HTML/003297.html The above article describes in detail how to add photo images to the memory of an HDS unit. This can be useful for storing images of harbors or other points of interest. |
This interesting article and thread show the impressive accuracy of the GPS receiver in the HDS-8 while simultaneously showing charts from major electronic chart publishers NOAA, Garmin, Navionics, and Lowrance to have some considerable errors: Electronic Charts for Isle Royale This is the twenty-first article I have written about the Lowrance HDS-8. I hope you have enjoyed them all. |
